View Full Version : Rodeo | Passport | MU
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
  1. Alarm turn on by itself
  2. Where to buy parts?
  3. K&N Air Filter 1998 Honda Passport
  4. Transmission Click Sound
  5. 1998 Honda Passport Transmission Cooler
  6. Bumping/thumping noise underneath the dashboard
  7. 2002 Rodeo noise behind the glove box
  8. Never had a problem...now it's making a weird noise :(
  9. creeking sound
  10. New-used 97 Rodeo
  11. Spark plugs...?
  12. Freaking sound from the rodeo
  13. Made in Japan or USA?
  14. Honda Passport '94 V-6 3.2L
  15. 1998 Passport part out
  16. 1999 passport shocks
  17. passport issues
  18. New and have a rodeo problem
  19. 4 wheel drive doesn't stay engaged 97 Rodeo
  20. Frame swap on Rodeo
  21. FS: 98 Rodeo parts
  22. VIN to Tell Difference Between 95 and 95.5?
  23. All Kinds of issues
  24. The mysterious disappearing coolant saga...
  25. transmission loud between 1st and 2nd
  26. 1996 Honda Passport EGR question
  27. Need another key, 97 Rodeo
  28. 4x4 Front End Not Pulling
  29. Timing belt replacement
  30. 2001 Isuzu questions
  31. Rodeo 92 3.1L MAP Sensor
  32. 200 Rodeo trans again
  33. Rodeo photos
  34. 98 Rodeo bumper fix
  35. Thank you for a great forum
  36. Steamy exhaust?
  37. 98 Passport - Rear wiper acting weird
  38. I'm BACK!!! With a 97 Rodeo and ?s
  39. Isuzu Rodeo and Axiom Recall Letter
  40. Water pump
  41. parting out 2001 rodeo.
  42. Change or just drain and fill on Rodeo
  43. What is this? Help appreciated!
  44. Shift lock doesn't unlock despite foot on brake pedal
  45. rodeo 2004 aisin ATF pan plug size
  46. iat sensor 95 isuzu 3.2 v6 4x4
  47. 95 Isuzu Rodeo No Powersteering At Idle
  48. Replacement Windshield Washer Reservoir for 95 Rodeo
  49. Weird Starting Problem
  50. wanted-rodeo wiring harness/fusebox
  51. 99 passport check engine light
  52. rodeo blues
  53. Oil Substance in wheel well
  54. check transmission again
  55. 2001 Isuzu Rodeo Car Alarm Program Code
  56. 2001 Isuzu Rodeo Car Alarm Program Code
  57. Hood Stuck Closed
  58. Just picked up my first Rodeo, No Reverse?
  59. 95.5 Isuzu Rodeo running rich
  60. FLUIDS and stuff
  61. it sputters and dies
  62. Brake Pad Set Replacement
  63. The cursed P0401 EGR Flow Insufficient
  64. Replacing heater core - '95 Rodeo
  65. 95 rodeo vibration
  66. 98 Passport 3.2 speedo quit and tach flutters
  67. Leaking antifreeze!!!
  68. IM FRUSTRATED!!!!!! 1999 Rodeo 3.2l
  69. 2000 Pass Intermittent Stutter
  70. Atf change
  71. 2000 honda passport/isuzu rodeo v6 auto
  72. What is this!?!?!?!? '99 Rodeo
  73. 2001 Isuzu Rodeo p0463
  74. Rodeo ODB code 446
  75. 97 Rodeo Blower Not working
  76. 01 Rodeo Overheating - Opinions?
  77. 01 Rodeo Thermostat Install - Which Way?
  78. pics of 99 isuzu rodeo engiine bay
  79. 1995.5 Rodeo oil pressure and electrical problems
  80. Shift Indicator Problems on Automatic Honda Passport
  81. 2000 rodeo trans question.
  82. Recall issued for Rodeo frames!
  83. possible oil presure problem
  84. PO420, P0171 Need Help Please
  85. 2000 Rodeo Spark Plugs
  86. 99 Rodeo wiring harness
  87. 3.2l rodeo chatters!!!
  88. "CatFuzz"" DO you still have??
  89. Engine Fan, related...
  90. 97 rodeo "no dash lights"
  91. egr
  92. Coil Overs to replace stock coils and shocks 99 4WD Rodeo
  93. any idea?
  94. rear windshield wiper
  95. Isuzu Rodeo 2000 Engine wanted
  96. Rear differential Seal Leak?
  97. rodeo 2004 3.2L transmission fluid
  98. rodeo 2004 front rotors
  99. P1153 on 98 V6 Isuzu Rodeo manual speed
  100. Achilles Tires
  101. 2000 Isuzu Rodeo Parts Needed!
  102. Moonroof Drainage holes clogged?
  103. 2000 trnsmission leak
  104. transmission fluid
  105. Tailgate Lock Actuator
  106. 93 Rodeo power steering V-BELT tensioner assy
  107. Disappearing CEL
  108. 10yrs or 120k ... 10yrs for me ...
  109. 2001 Rodeo speeds up while driving
  110. 1996 rodeo 4 speed auto tran problem
  111. Looking to Buy 2000 Passport
  112. 2002 Rodeo - Clicking - Won't Turn Over - All Lights On
  113. Detailed help needed with IMG replacement on '99 Rodeo 3.2L
  114. Replacing thermostat On 1999
  115. '94 rodeo 3.2L no spark
  116. 98 Rodeo center cap spring washers ???
  117. 2001 Passport A/C Low Side Pressure Question.
  118. EGR clean the large hole that supplies exhaust flow
  119. Heres is a really weird problem.....Can anyone help??....please!!
  120. Need a keyless
  121. A Couple of issues with my 2001 Passport
  122. GPS Map Update
  123. cylinder is filling with water
  124. 2001 Passport
  125. 2000-2001 rodeo swap
  126. Just got a rodeo
  127. Whirring sound in Drivetrain... somewhere.. I think.
  128. Loose Skid Plate...
  129. Range mode sensor?????
  130. 99 rodeo camshaft position sensor where is it
  131. Isuzu Rodeo will not shut off
  132. Isuzu Rodeo Runs HOt
  133. 200k!
  134. My 2000 rodeo is slipping?
  135. 2001 Rodeo A/C clicking
  136. Isuzu gauge problem
  137. '93 Rodeo - Intermittently working during summer in 90+ temps
  138. It just clicks-98 rodeo
  139. 99 rodeo fuel pressure
  140. Adding New ATF fluid - Leaky Servo Cup
  141. isuzu rodeo clutch slave cylinder
  142. 00 trans question
  143. What fluid goes in the transfer case?? Feel stupid for asking, lol!!
  144. 01 Rodeo Misbehaving
  145. Car engine racing while on idle
  146. Connecting rods
  147. Where online do I buy a range mode sensor?
  148. Water Boiling "IN" Radiator (not out)
  149. 96 rodeo engine swap with a 99 rodeo
  150. 2000 Rodeo - no pwr windows, rear wiper, ac/heat, turn signals, ...
  151. Crankshaft broken?!?!
  152. 2000 Passport lighter/ACC socket no power
  153. Lights dim when braking
  154. 1997 rodeo ac problem
  155. My First 100k ...
  156. 95.5 Rodeo Head Bolt Removal
  157. only 14 MPG on my 98 rodeo v6
  158. 98 Passport White smoke from exhaust and Power loss
  159. Rodeos and Passport Frame Rust made the local news...
  160. 97 Rodeo A/C not working
  161. ABS light & controller 2001 Sport
  162. 1998 rear view mirror removal
  163. key won't come out
  164. 97 rodeo new fuel pump still no pressure
  165. Evap Canister Purge Solenoid/Vent Solenoid
  166. 1995 Rodeo Transmission Problem
  167. Battery and brake light came on
  168. 2000 Passport 4WD - ABS Sensor Location
  169. what do these codes mean?!??!!?!
  170. 98 rodeo- timing WAY advanced by PCM
  171. Where is expansion valve?
  172. 2000 Rodeo A/C problem
  173. Where is the EVAP Canister Located?
  174. A/C compressor/drier swap out
  175. 2001 New EGR, engine light still on????
  176. Intermittent wiper conversion
  177. 95 izuzu rodeo 2.7 fills with water
  178. 2000 Rodeo Electrical
  179. 1999 Rodeo Horn stuck - SRS module, how dangerous?
  180. '98 rodeowiper problem
  181. 95 Rodeo lug nuts
  182. Worn Rings?
  183. Just changed my IMG
  184. Flash ECU, will the car start without?
  185. O2 passport grinds going into high gear
  186. Sticking Horn
  187. rodeo crankshaft bolt
  188. '94 Rodeo Rear End Clunk
  189. 2001 rodeo pcm or ecm needs to be programmed
  190. 1999 Rodeo, surging idle
  191. Rodeo Window Trim
  192. '01 Rodeo, surging weird on hard acceleration
  193. Upper Ball Joint Hell!
  194. Limping on right side
  195. 1993 V63.2 weird electrical issue
  196. 1999 Passport P0304 won't go away
  197. Range Mode Sensor?
  198. '02 Rodeo Headache
  199. Another ticky engine question + CEL
  200. rear wiper self starts on key-on and key-off
  201. Speedometer Quit/Stalls while driving?
  202. Wiper motor and/or linkage replacement
  203. 4ZD1 Oil Leak?
  204. 98 & 00 LS - Question about lights?
  205. Rodeo PO174 Code
  206. RESOLVED! 98 99 00 01 02 Rodeo Blower Motor problem
  207. Engine Fire
  208. Timing problem, need help.
  209. Timing and Belt alignment problem
  210. rodeo abs;fuel pump and more
  211. 98 Rodeo Overheating & Leaking Coolant
  212. Starting problem-ready to pull my hair out
  213. Starting problem-ready to pull my hair out
  214. best way to run an amplifier power wire?
  215. Need some experience
  216. 01 Isuzu Rodeo CEL flash on acceleration
  217. Will 98 Rodeo engine work in 00 Passport???
  218. 2002 replacement radiator fan shroud doesn't fit
  219. Help with 2000 isuzu rodeo.
  220. 2000 6 cyl rodeo surging idle
  221. Ball joints on '94 Rodeo
  222. Steering Wheel doesn't lock...
  223. Power locks won't lock with button or Keyless?
  224. 1995 Isuzu Rodeo WON'T START!!
  225. Front Brakes
  226. 2001 Rodeo 4wd problems
  227. 2000 isuzu rodeo idles then quickly stalls
  228. Photo of back of 3.2l engine?
  229. Rodeo sudden shut off
  230. Part out 94 Passport, Michigan
  231. Help Identify this part
  232. smelly exhaust
  233. Fuel system problems / questions
  234. ion sensing
  235. I saw something I thought was pretty smart.
  236. 99 Rodeo Battery Terminals and/or Wires
  237. 97 Rodeo, died in Hwy, won't start
  238. manual trans.
  239. Atlanta Area Mechanics
  240. 94 rodeo hyd.clutch issues
  241. P0304 misfire problem
  242. check trans flashing
  243. 1994 rodeo
  244. what do i need to replace for a 100,000 mile tune up on a 2001 rodeo v-6
  245. Engine turn with no spark on apark plug
  246. axle help
  247. Stiff steering 98 Passport
  248. Removing front drive axle
  249. Muti Codes due to CEL
  250. Location of Knock Sensor 98 3.2L Passport
