View Full Version : Rodeo | Passport | MU
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 [25]
  1. 5 speed manual transmission problems
  2. Hard to find parts....
  3. 95 Rodeo won't start
  4. Rear Axle Mystery Failure HELP!
  5. A different kind of fuel gauge problem?
  6. 95 Rodeo Missing/cricket Noise??
  7. F!!K Timing Chain Broke AGAIN
  8. Fuel Filter Replacement on 2000 Rodeo V6
  9. nice chrome wheels for sale
  10. 1992 Rodeo
  11. another 3.2L bites the dust..
  12. Anyone with tranny / 4L30E troubles...
  13. Electric Window problem 95 Rodeo
  14. Changing the ATF & Timing belt
  15. 2000 Rodeo 4x4 Front Wheel Bearing repack...
  16. obd code p0141
  17. 2000 CEL light flashes don't know whats going on!
  18. 2000 CEL flashing?!? car is hesitation and won't change gears
  19. grill
  20. sad day eh.
  21. 92 Rodeo hydraulic clutch problem
  22. Engine Failure on 99 Rodeo 3.2L
  23. Delayed Starting
  24. Hissing and NO power!
  25. Trailer Light Adapter
  26. Lifter Problem?
  27. Where to start with a check engine light
  28. 2000 rodeo w/ CEL and check trans light flashing
  29. Dead Rodeo
  30. Rodeo idle problem (2000)
  31. Is there a check engine Light diagnostic tool?
  32. Help with 15 - 16 inch Rims...anyone?
  33. 99 rodeo sunroof stuck open
  34. 2002 isuzu rodeo harness
  35. 1992 Rodeo IAT sensor location?
  36. Rear Speaker Replacement 1999 Passport
  37. Taking door apart ('00)
  38. Help!!! Stuck Key
  39. Help!!! Stuck Key
  40. 99 Rodeo -- OBD code P1627
  41. 95 3.2L missing on downward rpms
  42. Digital clock has gone nuts
  43. Rebuilding the 1998 Isuzu Rodeo 4L30E Transmission
  44. Abs
  45. Euro-tails
  46. fuel level readout is wrong???
  47. One of the wipers not working
  48. Vaccum canister stuff
  49. 2 questions for Rodeo owners
  50. 1998 rodeo whistles,idle surges
  51. 93 rodeo wont start
  52. gaskets
  53. Rodeo burns oil.
  54. This Form Is Dead!!!!
  55. 94 Automatic Transmission trouble
  56. fuel sending unit
  57. 98 Rodeo modification ideas.
  58. 99 Rodeo, Changing trans fluid myself
  59. ignition timing
  60. 2000 Rodeo Check Engine Light
  61. Service in connecticut
  62. oil light came on
  63. brake pad life
  64. Speakers
  65. 00 Rodeo, Tranny noise
  66. brake light
  67. 1991 Rodeo
  68. 1996 Isuzu Rodeo 3.2L EGR Valve Location
  69. Missing in Gear only???
  70. clicking noise
  71. rodeo 1995.5 temp. sensor location
  72. die
  73. Engine oil flush
  74. loud hiss/whine when at first, then goes away when warm
  75. Need To Sell Brand New 1996 Isuzu Rodeo Part
  76. rodeo defect
  77. 1994 Isuzu Rodeo running rich
  78. 94 Rodeo 4x4 not engaging
  79. Trailer Lighting Hookup for 2001 Isuzu Rodeo
  80. 4 cyl gas mileage
  81. Problem with my 4wheeldrive
  82. hi flow exhaust for 97 rodeo
  83. will a bosch reman alt work?
  84. 1995 Rodeo - overheating - where is electric fan switch??
  85. mass airflow screen removel
  86. No lights on left half of instrument cluster
  87. 2000 Rodeo check engine light/no gas guage
  88. 97 rodeo problem(s)
  89. Removing radio in 2000 Rodeo
  90. my keys are stuck!!!Please help!
  91. Model year changes
  92. carrier bearing(center bearing) 95 rodeo
  93. 2000 Rodeo transmission filter?
  94. Thermostat 2.2L 98 Rodeo
  95. lack of fuel?
  96. Tailgate locking
  97. CV axle removal: Can't seperate upper ball joint.
  98. 92 rodeo alternator broke off the top and lower bracket HELP!
  99. Need How-to on changing the thermostat
  100. New Rodeo..Bad Heater Custom Wiring Job
  101. gunning it
  102. Just bought a Rodeo...
  103. 93 Rodeo 4L30E A/T Code 33
  104. Changing the Axle Oil?
  105. Horn troubles
  106. 18" Isuzu Rodeo Chrome Wheels FOR SALE!
  107. light blinking please help
  108. Wheels Paint are Flaking
  109. gauges not working
  110. New To The Board
  111. Alarm Wiper ABS Control Unit location?
  112. Rodeo 99 - changing plugs
  113. Looking for aftermarket
  114. HELP - Rodeo Cranking but Not Starting when warm
  115. isuzu rodeo hard to start
  116. Shaking or rough engine at highway speeds
  117. replace power mirror
  118. Battery Light and Brake light come on and A/C fan doesn't work
  119. low fuel indicator not working
  120. Sounds like marbles in motor when I accelerate
  121. Is it good car???
  122. Trying to get rid of my car/parts...
  123. Air-conditioner problems
  124. horrid MPG
  125. Should I buy it???
  126. KILLER Chrome Wheels for sale for Rodeo!!!!!
  127. squeaky tailgate
  128. water pump problems
  129. Brake Pedal Locks Up
  130. Isuzu Rodeo TICKING NOISE !
  131. Looking for HP&T help
  132. 1998 Rodeo Crankshaft position sensor
  133. '98 Passport Oil Guzzler
  134. 3.2L low oil pressure
  135. Noisy 91 5-Speed Transmission
  136. Heating issue
  137. 2002 passport won't start
  138. revving out of control
  139. 98 2.2 Starting Prob
  140. Can a new radiator cap cause a vehicle not to start?
  141. revs up all by its self
  142. Just Found this section
  143. Keyless Remote
  144. Pulling off the 2.2L infavor of the V6
  145. 1992 Rodeo starting problem
  146. 1999 Isuzu Rodeo Starting Problems
  147. starter replacement
  148. 18" Detata Wheels with tires FOR SALE!
  149. Pictures Of Wheels On Truck
  150. altenator belt wont stay tight
  151. Transmission Probs
  152. speedometer failing
  153. 18" Detata Profiler Wheels on Pirelli Tires FOR SALE !
  154. water pum woes on a 92 rodeo
  155. My Wifes Rodeo
  156. loose heat shield
  157. 02 Rodeo 4WD with 20s?
  158. Fuel Pump problem 1995.5 Rodeo
  159. Custom mesh grill
  160. rodeo fuel gauge problems
  161. firewall access
  162. rear anti-lock brake light
  163. rear leaf springs for a 92
  164. 4 X 4 sytem
  165. my rodeo is falling apart...HELP!!!
  166. intake
  167. will rims from a 1998 Rodeo fit on a older 1997 rodeo?
  168. Seized Engine
  169. Battery dies after new stereo installed 97 Rodeo
  170. 2004 isuzu lineup!
  171. 97 Rodeo Hood Rattling
  172. 97 Rodeo Rear Door Lock failure
  173. loud knocking noises
  174. Looking for toolbox lid and storage box lid for Isuzu Rodeo Sport/Amigo
  175. Creaking noise at low speeds?
  176. Odd LOUD tap noise goes away after 3,000
  177. Taillight bulb replacement
  178. 2000 rodeo windshield wiper problem
  179. Spark plugs
  180. '99 Rodeo - Poor Gas Mileage, Knocking
  181. 1999 Rodeo Ls Trans. Shift Probl.
  182. engine dies when put in drive.
  183. Radio/CD
  184. Transmission question - 99 Rodeo
  185. v8 swap
  186. engine surging/running hot
  187. 91 Rodeo Starter problem
  188. Grill Guard
  189. CV Boot
  190. Hello
  191. Speakers
  192. Engine turns off
  193. Rodeo not starting when HOT
  194. tire size question
  195. 94 Rodeo, oil pressure
  196. Tailgate won't open
  197. 1999 Rodeo ABS pump running repair $100.00
  198. blinker trouble
  199. Serpantine Belt Replacement
  200. accessories
  201. any suggestions?
  202. Rear wiper motor doesn't work
  203. clunking-when starting or stopping
  204. ABS light on
  205. starter parts??
  206. Starting Problems
  207. 2002 Rodeo
  208. 2002 wire harness?
  209. Looking for a Sportier look and growl
  210. How To Fold-Down Rear Seats--'99 Rodeo
  211. Not Starting
  212. Clicking noise in passenger side
  213. thinking of buying an isuzu
  214. Bad Emmisions Smell Please Help
  215. 2001 Passport Hatch Squeaking
  216. 1992 Rodeo tailgate
  217. 45K service on my 2000 Rodeo
  218. bucking 1992 Isuzu Rodeo HELP!!
  219. passport motor
  220. 2000 Rodeo code P0401
  221. Need help very badly
  222. Rodeo gas cap problems
  223. Help
  224. Lots of Websites
  225. Help
  226. Help!!
  227. Isuzu meet
  228. Isuzu Hubs
  229. auto trans fluid filler port
  230. My 94 rodeo has jumped time
  231. A couple of Isuzu accessories for sale:
  232. testing...do not look
  233. Good websites???????????
  234. Passport SUCKS!!!
  235. Older
  236. Least Expensive Options: Grill Guards
  237. Tire Size question...
  238. Isuzu Rodeo 2000
  239. Damn Chevy's
  240. Clear corner lenses for a '98 Rodeo
  241. Passport Engine Code?
  242. Just bought a 2000 Rodeo :)
  243. installing the head unit
  244. check out these pics of my ride
  245. Check out these pics of my ride
  246. anyone know where I can get clearcorners fo my passport?
  247. hey
