View Full Version : Rodeo | Passport | MU
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23] 24 25
  1. Removing front brake rotors
  2. Shaking & Slipping in front when braking?
  3. bogged down till warmed up
  4. 99 Rodeo Cooling System
  5. 94 V6 Overheating when pulling boat
  6. 2001 Rodeo Troubles
  7. grill....
  8. PCM "upgrade" --> Reprogramming the computer
  9. 1994 rodeo stopped, gears locked?
  10. Engine seems bogged down...
  11. 95, very squealy starts
  12. Crank Pulley Bolt
  13. Clutch Mystery
  14. Rodeo will not start
  15. Blwer Motor
  16. 6 CD Changer
  17. Electrical Mayhem II
  18. power driverside window repair
  19. 2000 auto tranny problems
  20. 99 rodeo rear speakers
  21. 99 Rodeo wiper delay faulty
  22. Cruise control- 1995.5 Rodeo
  23. 1995 rodeo electrical(?) problem
  24. Need New Engine Please
  25. 92 Rodeo (transmission Control Module) 4 sale
  26. Opinions on this Please !!
  27. Electric Cooling fans on always w/AC
  28. 94 Isuzu rodeo 2.6L timing issues
  29. Altezza (Clear lights) for 2000 Rodeo
  30. 20's for sale!!
  31. 98 Rodeo ABS issue
  32. 1996 overheating
  33. 99 rodeo hard starting
  34. Lugs/nuts, need input on right one's....
  35. the diff. between reg. b20a5 & JDMb20a5
  36. Checking the Tranny fluid level
  37. Need input on trans service(or lack of)
  38. 1999 Rodeo LS V6 Fuel Filter
  39. owner's manual is missing pages 9-7 and 9-8
  40. 1994 Rodeo Plug Wires
  41. Help - Removing Cv !!!!!!
  42. Which year has had the least problems??
  43. 94 Rodeo check trans light flashing..
  44. Brake Light Replacement on 99 Isuzu Rodeo
  45. cv joint purchasing
  46. Warrany- Need help quick!!
  47. New Rodeo owner!! Need help please!!!
  48. Heater output cut off
  49. Check engine light - always on!!!
  50. Fuel Sending Unit - '99 Isuzu
  51. 98 Rodeo won't start
  52. Help with '99 Front Rotors 4WD
  53. Electrical Mayhem!
  54. 1999 Rodeo T-Connector Hookup
  55. driver power window
  56. I need advice!!!
  57. Anybody Here Got Any Car-audio installed
  58. 98 Rodeo front vibration
  59. Should I Get Rid Of Mine?
  60. Rodeo Newbie
  61. Turn Signals / Flasher Troubles
  62. Vavle bent?
  63. Make a 4x4 a 4x2
  64. 2000 Rodeo 3.2 Lifters wont pump
  65. Changing rotor on '91 Rodeo 4w drive
  66. Compression?
  67. 96' 3.2L No Oil Pressure Indication
  68. Stupid engine is pinging
  69. Hey, 2000Frontera, need help with wiper delay relay ID
  70. Check Engine Light came on Went to Autozone and...
  71. After Market AC
  72. 98 A/C Problems
  73. Tranny quirk
  74. 1999 Rodeo V6, Won't start???
  75. Filler Plug On Differential Won't Come Off
  76. 95 Rodeo with leaking CV boot
  77. Thermostat numbers
  78. 97 izuzu rodeo no start no run
  79. Bad acceleration after Rodeo is warm.
  80. low oil pressure?
  81. 96 needs replace instrument panel light. Any help?
  82. Tire brand opinions needed.
  83. Need Denso
  84. Looking for cage, 2000 Rodeo
  85. Running w/5 lugs instead of 6?...
  86. start problems after refueling.
  87. Loose Connection Somewhere
  88. Clutch Problems w/ 92 rodeo
  89. Engine rebuild?
  90. Filed compliant w/NHTSA
  91. Help with 99' Rodeo
  92. Problems starting in the morning.
  93. Error codesflash on Air Bag light
  94. 1997 rodeo coolant leak
  95. Question 3.1L Chev engine and ????? transmission
  96. Three items to reduce oil consumption. Is this a fair deal?
  97. 97 Rodeo engine dies.....
  98. My Alarm Goes Off For No Apparent Reason
  99. Slippery film/radiator update
  100. 92' turn signal wont work
  101. 2002 din wiring harness trouble
  102. Help! Keyless Entry
  103. White Slippery Film in radiator? Any .....
  104. 97 rodeo rear wheel alignment?
  105. 93 isuzu pickup bucking, stalling, rough idle,
  106. Big uh-oh....or maybe slightly smaller uh-oh?
  107. Bought 99 Rodeo LS from Auction Fuel Gauge problem
  108. 2000 Rodeo manual door locks
  109. 2000 Rodeo Warning Light S/U
  110. 95 3.2 4x4 auto rear antilock light?
  111. Door Schematics?
  112. Smoking, bad acceleration, how to pull codes
  113. HELP! changing the front rotors on a 2000 rodeo
  114. 2000 Rodeo S end of Lease/AC problem
  115. Replace CV Boots, CV Joints or whole Axle?
  116. Replacing clutch fan with electric??
  117. Lower ball joint removal? Help!
  118. steering box grease
  119. Rear Brake Rotors for 2000 (how to replace)
  120. Machining Question+ a few (hundred) others
  121. won't hold water
  122. '01 Rodeo shock swap... special tools?
  123. +98 Rodeo Fuel Gauge Fix write up:
  124. 2002 Rodeo Head Blown / Tranny Overheat!
  125. rodeo wont start
  126. 30k Service quoted at $920??
  127. 95 Isuzu Rodeo Stereo Installation
  128. Questions about Rodeos
  129. 98 Rodeo Keyless Entry
  130. OBD II code P0440
  131. 98' Rodeo 4WD engaging at will...
  132. 98 Rodeo Transmission Problem
  133. Coolant in plug chamber
  134. Another good Isuzu site
  135. Isuzu error codes
  136. CV joint noise?? 99 Rodeo
  137. After warm horribly rough with misfire
  138. Noisy lifters not caused by faulty lifters
  139. Stereo and Clock don't work, Checked fuse its ok, what gives?
  140. Intake Manifold Gasket Repair
  141. air turns on when passenger door is closed
  142. Crankshaft Pulley
  143. Help with 96 Rodeo ....no spark
  144. 94 automatic idles like a vw bus and bucks too
  145. 2000 Rodeo keeps stalling
  146. clicking noise coming from shift lever
  147. still having turn signal probs please help
  148. 98 Rodeo fuel gauge wrong and uses more gas
  149. Timing Belt
  150. Camshaft Position Sensor (LOCATION PLEASE)
  151. Octane requirement
  152. 93 no spark?
  153. shock replacement.
  154. shifter issues
  155. WindNoise, AC and Air Leak
  156. Rearend shakes at take off with a load on.
  157. 60,000 Mile Service
  158. air conditioner issue?
  159. Stepping on seagulls???? [brakes]
  160. wont start
  161. 98 Isuzu rodeo...fuel gauge not reading properly
  162. Check trans light blinking, alternator gauge
  163. Spark plug opinions
  164. Changing spark plugs
  165. Changing front rotors on 97 Rodeo
  166. brakes help
  167. Anti-theft Alarm Sounds w/o Known Cause
  168. Tires: What size options are there?
  169. help !! passport is running rich - power loss
  170. Tires: P-rated or LT-rated?
  171. Overheating... '94 Rodeo 3.2
  172. decreased gas milage
  173. Still got the groove!
  174. Replacing starter in 2000 Rodeo
  175. 1999 Rodeo LS 4X4 CEL and ODB Code P0303
  176. stupid question
  177. A Few 2004 Rodeo 3.5L Questions??!!
  178. Typical Temp range on 3.2L??
  179. Doors and windows
  180. Service Shop for my Rodeo
  181. Acceleration problems
  182. Sounds like a train.....
  183. Intermittent wiper problem
  184. OBD_II Scan code P1340?? What is it?
  185. Rodeo FAQs on this board?
  186. ABS light and gas gauge issues on my 98 Rodeo
  187. Has an oil addiction
  188. 95 Rodeo Won't Start
  189. Missing In Gear? Not at idle? Ive tried everything.
  190. Help me change my headlight bulbs
  191. Help! 2000 Rodeo leaking trans fluid!!!
  192. 4x4 club
  193. 95 V6 4X4 check tranny light
  194. Radiator hoses
  195. Tapping Noise
  196. EGR Port pictures, 2nd gen:
  197. Bumping sound from the rear
  198. paint for a rodeo 1995.5
  199. 2000 Rodeo Codes
  200. 95 v6 3.2 Clutch problem?
  201. top end of motor tapping-94 rodeo
  202. Shock installation problems
  203. thanks guys
  204. Doing It Again!!??
  205. Trouble starting
  206. gas gauge reading incorrectly
  207. Strange Brakes Light Behavior
  208. problems with rear end of 99 rodeo
  209. problem with the dash board light
  210. Checking the ignition switch
  211. CEL flashing on and off on my 2000 rodeo...
  212. Removing engine cover
  213. Thnk U, & I should introduce myself. . .
  214. 2000 Rodeo possesed
  215. Rodeo2 - the 100K for t/belt, does that ....
  216. check enging lite on again
  217. Code for '96 3.2/5-speed
  218. where's the fuel level sending unit
  219. Tranny Oil Service Life Monitor
  220. Knocking noise when turning left
  221. Rear window glass rattling
  222. '98 Humming noise from rear end
  223. Timing belt change/Interference ??
  224. Automatic tranny shifting problems
  225. Window regulator removal and installation
  226. 1991 isuzu rodeo
  227. trans disengaging(new 4th gear servo)
  228. 2001 Rodeo pulls to the right.
  229. Location of ABS Sensors on 99 Rodeo 4WD
  230. 97 (almost) overheating
  231. slip yoke
  232. "Steam" cleaning your engine
  233. 2000 CEL problem...how many others are having this?
  234. Need a drivers side door
  235. Air Conditioner Compressor 99 Rodeo
  236. '95 3.2 compressor clutch removal
  237. A lot of issues
  238. Urgent PLease Help!
  239. shutting down
  240. Spark Plugs $$$
  241. 1997 Rodeo Lugs and Lug nut Breakage
  242. trans
  243. Easiest way to get 2"lift on 95 Rodeo
  244. 1996 Rodeo Check Engine Light
  245. 2000 Rodeo 2.2L Spark Plug Change
  246. Do I want to buy a Rodeo?
  247. '91 Rodeo floods out when starting...help
  248. 94 Rodeo Right Blinker Only Wants To Buzz Please Help
  249. Rear Speakers 5" ???
  250. replacement shocks?
