View Full Version : Rodeo/Passport
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23]
  1. Help!!! Stuck Key
  2. Help!!! Stuck Key
  3. 99 Rodeo -- OBD code P1627
  4. 95 3.2L missing on downward rpms
  5. Digital clock has gone nuts
  6. Rebuilding the 1998 Isuzu Rodeo 4L30E Transmission
  7. Abs
  8. Euro-tails
  9. fuel level readout is wrong???
  10. One of the wipers not working
  11. Vaccum canister stuff
  12. 2 questions for Rodeo owners
  13. 1998 rodeo whistles,idle surges
  14. 93 rodeo wont start
  15. gaskets
  16. Rodeo burns oil.
  17. This Form Is Dead!!!!
  18. 94 Automatic Transmission trouble
  19. fuel sending unit
  20. 98 Rodeo modification ideas.
  21. 99 Rodeo, Changing trans fluid myself
  22. ignition timing
  23. 2000 Rodeo Check Engine Light
  24. Service in connecticut
  25. oil light came on
  26. brake pad life
  27. Speakers
  28. 00 Rodeo, Tranny noise
  29. brake light
  30. 1991 Rodeo
  31. 1996 Isuzu Rodeo 3.2L EGR Valve Location
  32. Missing in Gear only???
  33. clicking noise
  34. rodeo 1995.5 temp. sensor location
  35. die
  36. Engine oil flush
  37. loud hiss/whine when at first, then goes away when warm
  38. Need To Sell Brand New 1996 Isuzu Rodeo Part
  39. rodeo defect
  40. 1994 Isuzu Rodeo running rich
  41. 94 Rodeo 4x4 not engaging
  42. Trailer Lighting Hookup for 2001 Isuzu Rodeo
  43. 4 cyl gas mileage
  44. Problem with my 4wheeldrive
  45. hi flow exhaust for 97 rodeo
  46. will a bosch reman alt work?
  47. 1995 Rodeo - overheating - where is electric fan switch??
  48. mass airflow screen removel
  49. No lights on left half of instrument cluster
  50. 2000 Rodeo check engine light/no gas guage
  51. 97 rodeo problem(s)
  52. Removing radio in 2000 Rodeo
  53. my keys are stuck!!!Please help!
  54. Model year changes
  55. carrier bearing(center bearing) 95 rodeo
  56. 2000 Rodeo transmission filter?
  57. Thermostat 2.2L 98 Rodeo
  58. lack of fuel?
  59. Tailgate locking
  60. CV axle removal: Can't seperate upper ball joint.
  61. 92 rodeo alternator broke off the top and lower bracket HELP!
  62. Need How-to on changing the thermostat
  63. New Rodeo..Bad Heater Custom Wiring Job
  64. gunning it
  65. Just bought a Rodeo...
  66. 93 Rodeo 4L30E A/T Code 33
  67. Changing the Axle Oil?
  68. Horn troubles
  69. 18" Isuzu Rodeo Chrome Wheels FOR SALE!
  70. light blinking please help
  71. Wheels Paint are Flaking
  72. gauges not working
  73. New To The Board
  74. Alarm Wiper ABS Control Unit location?
  75. Rodeo 99 - changing plugs
  76. Looking for aftermarket
  77. HELP - Rodeo Cranking but Not Starting when warm
  78. isuzu rodeo hard to start
  79. Shaking or rough engine at highway speeds
  80. replace power mirror
  81. Battery Light and Brake light come on and A/C fan doesn't work
  82. low fuel indicator not working
  83. Sounds like marbles in motor when I accelerate
  84. Is it good car???
  85. Trying to get rid of my car/parts...
  86. Air-conditioner problems
  87. horrid MPG
  88. Should I buy it???
  89. KILLER Chrome Wheels for sale for Rodeo!!!!!
  90. squeaky tailgate
  91. water pump problems
  92. Brake Pedal Locks Up
  93. Isuzu Rodeo TICKING NOISE !
  94. Looking for HP&T help
  95. 1998 Rodeo Crankshaft position sensor
  96. '98 Passport Oil Guzzler
  97. 3.2L low oil pressure
  98. Noisy 91 5-Speed Transmission
  99. Heating issue
  100. 2002 passport won't start
  101. revving out of control
  102. 98 2.2 Starting Prob
  103. Can a new radiator cap cause a vehicle not to start?
  104. revs up all by its self
  105. Just Found this section
  106. Keyless Remote
  107. Pulling off the 2.2L infavor of the V6
  108. 1992 Rodeo starting problem
  109. 1999 Isuzu Rodeo Starting Problems
  110. starter replacement
  111. 18" Detata Wheels with tires FOR SALE!
  112. Pictures Of Wheels On Truck
  113. altenator belt wont stay tight
  114. Transmission Probs
  115. speedometer failing
  116. 18" Detata Profiler Wheels on Pirelli Tires FOR SALE !
  117. water pum woes on a 92 rodeo
  118. My Wifes Rodeo
  119. loose heat shield
  120. 02 Rodeo 4WD with 20s?
  121. Fuel Pump problem 1995.5 Rodeo
  122. Custom mesh grill
  123. rodeo fuel gauge problems
  124. firewall access
  125. rear anti-lock brake light
  126. rear leaf springs for a 92
  127. 4 X 4 sytem
  128. my rodeo is falling apart...HELP!!!
  129. intake
  130. will rims from a 1998 Rodeo fit on a older 1997 rodeo?
  131. Seized Engine
  132. Battery dies after new stereo installed 97 Rodeo
  133. 2004 isuzu lineup!
  134. 97 Rodeo Hood Rattling
  135. 97 Rodeo Rear Door Lock failure
  136. loud knocking noises
  137. Looking for toolbox lid and storage box lid for Isuzu Rodeo Sport/Amigo
  138. Creaking noise at low speeds?
  139. Odd LOUD tap noise goes away after 3,000
  140. Taillight bulb replacement
  141. 2000 rodeo windshield wiper problem
  142. Spark plugs
  143. '99 Rodeo - Poor Gas Mileage, Knocking
  144. 1999 Rodeo Ls Trans. Shift Probl.
  145. engine dies when put in drive.
  146. Radio/CD
  147. Transmission question - 99 Rodeo
  148. v8 swap
  149. engine surging/running hot
  150. 91 Rodeo Starter problem
  151. Grill Guard
  152. CV Boot
  153. Hello
  154. Speakers
  155. Engine turns off
  156. Rodeo not starting when HOT
  157. tire size question
  158. 94 Rodeo, oil pressure
  159. Tailgate won't open
  160. 1999 Rodeo ABS pump running repair $100.00
  161. blinker trouble
  162. Serpantine Belt Replacement
  163. accessories
  164. any suggestions?
  165. Rear wiper motor doesn't work
  166. clunking-when starting or stopping
  167. ABS light on
  168. starter parts??
  169. Starting Problems
  170. 2002 Rodeo
  171. 2002 wire harness?
  172. Looking for a Sportier look and growl
  173. How To Fold-Down Rear Seats--'99 Rodeo
  174. Not Starting
  175. Clicking noise in passenger side
  176. thinking of buying an isuzu
  177. Bad Emmisions Smell Please Help
  178. 2001 Passport Hatch Squeaking
  179. 1992 Rodeo tailgate
  180. 45K service on my 2000 Rodeo
  181. bucking 1992 Isuzu Rodeo HELP!!
  182. passport motor
  183. 2000 Rodeo code P0401
  184. Need help very badly
  185. Rodeo gas cap problems
  186. Help
  187. Lots of Websites
  188. Help
  189. Help!!
  190. Isuzu meet
  191. Isuzu Hubs
  192. auto trans fluid filler port
  193. My 94 rodeo has jumped time
  194. A couple of Isuzu accessories for sale:
  195. testing...do not look
  196. Good websites???????????
  197. Passport SUCKS!!!
  198. Older
  199. Least Expensive Options: Grill Guards
  200. Tire Size question...
  201. Isuzu Rodeo 2000
  202. Damn Chevy's
  203. Clear corner lenses for a '98 Rodeo
  204. Passport Engine Code?
  205. Just bought a 2000 Rodeo :)
  206. installing the head unit
  207. check out these pics of my ride
  208. Check out these pics of my ride
  209. anyone know where I can get clearcorners fo my passport?
  210. hey
