View Full Version : Rodeo | Passport | MU
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25
  1. lsd passport/rodeo
  2. Rodeo 97 Dash Bevel
  3. Off acceleration stumbling
  4. 2000 Rodeo not start after running out of gas.
  5. serpentine belt tensioner
  6. Inacurate fuel guage
  7. Transmission Fluid Change - 93 Rodeo V6 - where is plug?
  8. CD Changer Jam - 2001 Passport
  9. 96 3.2l rodeo electrical probl
  10. 1997rodeo Rocker Arm Noise
  11. Passport won't start consistently
  12. noise
  13. sharp exhaust buzz with throttle blip
  14. Range sensor
  15. 95 Rodeo fuel light erratic (gauge is fine)
  16. 1997 Isuzu Rodeo Keyless Entry/Alarm
  17. Help! 96 Rodeo 3.2 stalls after running for a bit
  18. Rodeo02 - "Lower block skirt" is
  19. Any have info on an aftermarket receiver hitch?
  20. Truth or not? POLL: Regarding oil level
  21. 98 Rodeo 2.2L Cylinder 3 Misfire
  22. Brake Rotor Thickness??
  23. Help find part? Number and picture included
  24. SoCal 95 Rodeo parting out!!! Motor, ext.....
  25. looking for headlight assembly
  26. Reddish/yellow particules in oil?
  27. ABS Plate Disintegrated
  28. Intermittent Rear ABS light
  29. Adding Tranny fluid to oil?
  30. One long strange trip...
  31. muffler sucking
  32. 2wd to 4wd?
  33. 4WD HI jumping out of gear
  34. Cigarette lighter on '96 rodeo
  35. Please help
  36. no rear wiper
  37. '96 rodeo alternator woes
  38. Electrical problems in 2000 Rodeo
  39. 4WD not engaging
  40. coolant temp sensor
  41. Fan for AC/heat
  42. Rear differentials? Which one . . .
  43. 97 Passport Cranshaft Pulley
  44. 1994 Rodeo - Host of Problems
  45. 1994 rodeo trans--no drain plug
  46. 97 rodeo problems
  47. 2000 Rodeo diagnostic jumper terminal location
  48. 1999 Isuzu Rodeo Crank For Sale
  49. Strange Brake Light Behavior
  50. Help alarm 98 Rodeo
  51. 2000 Rodeo Jerky Transmission (cont.)
  52. Mud flaps or NO - want opinions
  53. ARB Bumper for 97 Rodeo's ??
  54. Water Pump
  55. 99 Izuzu Rodeo locking lug nuts
  56. 97 rodeo heater/ac fan BUZZ/NOISE
  57. Monroe shocks now on sale
  58. Rear End Seal Replacement
  59. high idle
  60. strike plate/arm not clicking together
  61. Rodeo Runs Rough
  62. Rear right bumper part?
  63. Dreaded CEL - what next
  64. need more power
  65. Ran out of gas. Won't start after refuelling
  66. knocking or bearing noise
  67. 96 Passport Change to Mobil 1
  68. 96 Passport converting to Mobil 1
  69. Strangest instrument light question ever...
  70. Floor Mats for '95 Rodeo
  71. PCV Price Difference
  72. 96 rodeo coolant leak
  73. 200 Rodeo Jerky Transmission
  74. 1995 Rodeo Mileage
  75. Need Help! Possible starter? You tell me.
  76. Rodeo '98 Maint Tranny and Front Diff.
  77. Fuel pump relay clicking
  78. Volts are GOOD, ABS issue ??
  79. Power Steering Problem--WARNING!
  80. Pop-ups..... unacceptable
  81. Isuzu rodeo 2000...Error code 1340
  82. running too rich
  83. Brake light, Oil light, Battery light - A/C does not work
  84. missing under hard accel at 5K?
  85. 4WD Clicking Noise
  86. cumsumer reports
  87. Surging During Acceleration
  88. No Wiper FLuid??
  89. No Wiper Fluid
  90. Changing the Fuel Filter on a 95' Rodeo
  91. 99 rodeo rear wheels shuttering
  92. Jerky transmission and a huge oil puddle in garage ('00 LSE)
  93. 96 Rodeo periodicly dies...etc
  94. shocks
  95. Electrical issues with a 93
  96. Transmission Fuid Change. HOW to ?
  97. 01 Rodeo V6- What MPG should I Expect??
  98. Body Lift or Suspension lift?
  99. Isuzu Tech's/anyone, need thoughts
  100. More oil leaking
  101. Intermittent Air Conditioner Problems
  102. Bizarre electrical problems '99 Rodeo
  103. 1998 honda passport coil problem
  104. torsion bar lift
  105. A/C Quit
  106. 1996 or 1997 light and radio problems
  107. 97 rodeo problems
  108. Need 03 Input
  109. Help needed for '99 console R & R
  110. 01 Rodeo New Shocks - Great Improvement
  111. Dash Lights
  112. Lowering a 2wd Rodeo
  113. looking for exploded view of engine
  114. Need help with Windows and Lighter
  115. water leak
  116. Timing marks won't line up....
  117. Engine suddenly cuts out... Then restarts
  118. need used transmission
  119. CEL On and Off???
  120. Safe to Drive?
  121. Need thoughts, low occ. voltage
  122. 95 Rodeo/Passport possible blown rings?
  123. 97 Rodeo V6 - Oil pressure drops to zero
  124. Camshaft Position Sensor?
  125. 1999 Rodeo LSE Problem
  126. Locating Electronic Flasher?
  127. fuel pump going?
  128. speed up problem on start
  129. Splitfire plugs?
  130. 95 LS weird clutch problem
  131. Intake Manifold Gasket
  132. remote programming
  133. Cover gasket??? need help please!
  134. What car has the rodeo 3.2 in it?
  135. How to get 250 hp out of 3.2 rodeo
  136. Rodeo Clubs In Atlanta ??
  137. Did 95 rodeo have factory Alarm???
  138. 3.2 hydraulic valve train noise
  139. Fuel Pressure on 3.2L
  140. Rodeo 97. Hesitating Windows!!!
  141. Windows just screwed up
  142. 96 rodeo electrical problems
  143. New inexpensive wheels?
  144. Question about ABS light, brake light and lifters?
  145. How do you change dash kights on 95 rodeo
  146. My First Rodeo -- Used
  147. fuel pump
  148. Slip Yoke
  149. Service Bulletins
  150. Shocks, tires and spark plugs
  151. ?Clanking Sound?
  152. 1999 Rodeo Valet Switch
  153. Have to replace cj shafts, any preferences?
  154. How to remove windshield wiper arms?
  155. 94 V6 smog test near fail
  156. New 95' Rodeo Owner
  157. HELP!! Blinking Check Engine Light
  158. 95.5 Rodeo 3.2 4WD Starter problem
  159. 1996 Rodeo Auto Trans - Synthetic Fluid?
  160. im looking at buying a rodeo. pros/cons
  161. 2004 Rodeo - no keyless entry ?
  162. Oil Pressure Gauge "0" -- HELP!
  163. 97 rodeo 3.2 Running Rich!!! HELP!!!
  164. which engine is better? 3.2 SOHC or DOHC?
  165. Signal Light Dim
  166. Fuel Filter, PCV, and Resetting Computer
  167. Paint Problem
  168. Engine Stuttering
  169. 99 Rodeo 3.2
  170. CEL = Need tranmission replacment!
  171. Replacing Fuel filter for '93 V6
  172. 93 Rodeo shifter button only engages when engine is off
  173. 95 Steering Play
  174. A/C clutch locked up
  175. spark plug gap
  176. EGR Problems
  177. 96 bucking rodeo!
  178. 1992 rodeo blows fuses
  179. OBD2 (0174) Exhaust MYSTERY
  180. Warranty question for 2000 Rodeo
  181. Turn Signal/ Hazard mayhem
  182. CEL and P codes....
  183. Changing wheel studs
  184. Rough Idle & Check Engine Light
  185. engine woes
  186. the dreaded CEL...what to do????
  187. My Windows Won't Roll Down In Back Of My 1995 Rodeo
  188. Just dropped my 00 off for new shocks.
  189. Introduction, with some questions!
  190. Rodeo - a good vehicle?
  191. Turn signal/Brake light puzzle
  192. coolant drain plugs on block
  193. Right Anti-lock brakes
  194. Sunroof wind noise
  195. at wits end - Need Help!
  196. Transmission flush query....
  197. window regulator
  198. help how do you set the clock on a 1995 rodeo
  199. 1996 Rodeo - Instrument panel lights
  200. Engine replacement
  201. Quick T-Belt Tension Question
  202. Altezza lights causing brake lights to stay on
  203. 94 isuzu timing belt install
  204. Muffler / Tail Pipe Separation - Rodeo '99
  205. a./c clutch for 93 Rodeo
  206. 2001 ATF cooler
  207. 2000 intelligent suspension control
  208. this woman is going nuts with these noisy lifters
  209. could very low oil cause lifter noise
  210. 2000 Rodeo CEL and Rough Idle
  211. Tire wear on the outside of both front tires
  212. 98 honda passport air condition is hot
  213. Isuzu random missfire plus os2 sensor bank one sensor one switched to lean
  214. pulley bolt type of threads
  215. 95 rodeo trans problem
  216. Anyone with trans temp guage on Rodeo?
  217. 2000 Dash squeak - HELP!-
  218. 2000 Rodeo new shock impressions
  219. 1998 Isuzu Rodeo Engine Problems
  220. Smaller Gas Tank 1999 Rodeo
  221. power locks
  222. 1996 Isuzu Rodeo 3.2L V6 4x4--New Owner
  223. Idles rough but not what you might think
  224. rodeo
  225. High Idle
  226. Rear rotors shot at 50K miles - did we get ripped off?
  227. 99 rodeo manual transmission
  228. abs light on
  229. Urgent Tranny Issue
  230. 95 Hard Gas Pedal Problem
  231. Locked up Auto Tranny stick
  232. AC Condeser VS a rock
  233. 96 rodeo charging, brake, 4wd issues
  234. window switch replacement
  235. serpentine belt broke
  236. Black smoke and no power
  237. Trouble starting, idling high
  238. rodeo elect problem
  239. 96 Rodeo electrical prob
  240. '99 Rodeo hard shifting tranny
  241. Towing equipment
  242. rodeo 4 cylinder engine
  243. Rodeo Oxygen Sensor
  244. 95 wipers dont work intermittently
  245. vacation
  246. Cruise Control and Headlights
  247. Headlights need adjusted??
  248. Isuzu Rodeo Transmission Fix
  249. Removing front brake rotors
  250. Shaking & Slipping in front when braking?
