View Full Version : Rodeo | Passport | MU
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22 23 24 25
  1. Need engine for 94 Passport
  2. Rear Defogger Problem
  3. Falls Dead When Put In Park
  4. 99 rodeo 4wd question
  5. Where can I get Red Crown Grease?
  6. my oil is dark, red or brown?
  7. my oil is dark, red or brown?
  8. I need all the help i can get
  9. 99 Rodeo Engine parts for sale
  10. i need help !
  11. EGR port as an indication of high oil cunsumption??
  12. Kenwood CD receiver KDC 6011
  13. White Smoke....Help
  14. blower motor
  15. Check engine light
  16. 1999 Passport Power Steering Pump Removal
  17. alternator
  18. wiring Q?
  19. 2.2 rodeo taking a while to start
  20. Hard up/dn shift, PRND lights display wrong gear...
  21. Anyone familiar with BG44k fuel cleaner?
  22. Speedometer Noise
  23. 3.2L V6 IS an interference engine
  24. Slight pinging noise
  25. 3.2 timing belt???
  26. Auxillary plug wiring.
  27. Transmission Problems
  28. 96 Passport dash light problems
  29. Where to get Lifters?!
  30. Heater problems
  31. 2.6 coolant drain plug
  32. Cigarette lighter fuse
  33. Loose belt ??
  34. Looking for Passport Parts!!
  35. Towed my new ride home with my ZU
  36. 3.2L DOHC isuzu V6 motor valve clearance
  37. Can't get reverse gear.
  38. 1994 Honda Passport
  39. are these signs of a tranny replacement?
  40. Adding fluid to 99 Isuzu Rodeo automatic transmission
  41. Front Wiper Fuse Blows
  42. Service Manual Recomendation???
  43. Windshield Wiper Motor
  44. 1986 toyota pick-up died
  45. 99 Rodeo Tailgate Lock Cylinder
  46. long to do list
  47. Lower oil pan removal.
  48. Fuel Sending Unit
  49. Engine Knocking, Please help...
  50. rear view mirror
  51. 1992 sputtering rodeo, bad idle
  52. Low Oil Pressure
  53. How to check relays
  54. Timing questions
  55. '92 Rodeo Automatic hubs
  56. 2001 Rodeo Accessories for sale
  57. Iac
  58. intake gasket may be leaking
  59. Coolant capacity '99 3.2L Auto
  60. Back Window Lock/Release button issue
  61. Rodeo Belt Problems....Help!
  62. 99 Rodeo Automatic Gear Selecter Lock won't release
  63. Blower switch or motor not working HELP!!!
  64. 99 rodeo engine parts for sale
  65. Help with fuel pressure reading
  66. Replacing wheel studs
  67. Check Engine Light
  68. boa remote start
  69. 1992 Rodeo NO FUEL *Confused*
  70. Timing Belt replacement interval
  71. sputtering Isuzu
  72. rear door won't open-auto lock works fine
  73. severe gas smell
  74. Honda Passport Problems
  75. Another tranny Q
  76. hood bump stops
  77. Bucking Isuzu Rodeo
  78. car shaking at 55 mph on up, not the wheels or tires...
  79. How to clean 1992 Rodeo EGR?
  80. SOLSTER'S '99 maintenance service
  81. What is this duct for?
  82. Where?
  83. installing front brake pads, 00 Isuzu Rodeo
  84. difficulty removing power steering belt on 95 Rodeo
  85. Event Data Recorders (EDRs) or Crash Data Recorders (CDRs)
  86. race gas
  87. 95 1/2 Rodeo Check Trans Light
  88. O2 Sensor Heater Circuit Malfunction!!!
  89. Fram suredrain
  90. Tire air pressure recommendation
  91. Interior electrical
  92. Aftermarket Remote start/keyless entry
  93. Trailer Light Wiring??
  94. 1999 Isuzu rodeo-Just purchased
  95. Rear Defroster and wiper issues.
  96. Brush guard for an '02
  97. Pictures of lifted Rodeos?
  98. Catalytic converters testing?
  99. Just Purchased
  100. Power/Winter
  101. HELP!!Replacing vavle cover gaskets
  102. Emission Problems?
  103. Lube Chasis Help/Instructions
  104. overheating rodeo
  105. Second gen muffler
  106. Fuel Smell
  107. Error Code P1441
  108. Rodeo Lift kits?
  109. Factory Fog Lights
  110. Max tire size
  111. Need Oil And Oil Filter Recommendation
  112. 95 4X4 Rodeo Oil Pan Gasket
  113. 94 passport coolant leak
  114. 1995 Rear Hatch won't lock
  115. O2 sensor location
  116. Remove Intake to get valve covers off?
  117. Radiator Fan Clutch
  118. Considering purchase....
  119. Brake light issues - update
  120. Slow accelerating, lack of power
  121. AC Clutch vs Compressor
  122. 2001 Rodeo Brake Light issues
  123. 2000 Passport has intermittent hard start
  124. 94 rodeo transmission type
  125. Motor Oil For High Mileage Vehicles
  126. 2001 Rodeo parts on Ebay:
  127. Cam Position Sensor
  128. can't get the locking lug nuts off
  129. HELP! 1991 Isuzu Rodeo Overheating Problem
  130. Lifter tick is back after being gone for awhile...
  131. My Sunday Project
  132. 2000 spark plug help
  133. For sale 1996 Heads
  134. Need ar filter recommondation!
  135. Brakes
  136. Rear Window Defroster/Stereo Ideas
  137. 96 3.2l rodeo-alt swap
  138. For Sale:K&N Replacement air filter
  139. Broken Timing Belt on 98 2.2L Rodeo
  140. remote keypad lost
  141. ABS always on in 91 Rodeo..
  142. 2001 Spark Plug Extensions Leaking
  143. '94 Half Shaft Removal
  144. Passenger Window Stuck Open - How do I get it up?
  145. Alternator problems?
  146. What crakhead enginer came up with this (tranny)
  147. heater/ac blower motor/relay tip
  148. 2001 Rodeo problems
  149. 96 Rodeo Hard to start..Help please...
  150. "clicking" noise when starting up rodeo
  151. Spare Tire Mount Problem
  152. 2000 rodeo bodylifts???
  153. 1995 Rodeo hesitation
  154. 1993 Rodeo wont go into 4WD
  155. O2 and random misfire problem NEED HELP!!
  156. Hissing noise from under dashboard
  157. 96 Passport want ingage or shift into any gear
  158. Finally did some maintenance!
  159. '98 Rodeo completely shut down - electrical?
  160. Anyone WTB a 99 Rodeo w/ a siezed engine?
  161. Hard shift transmission fix
  162. overheating rodea, front fan wont come on
  163. rubber trim
  164. 99 Rodeo Automatic with slipage between gears
  165. 3.1 timing issues
  166. 2000 Rodeo V6 Timing Belt
  167. rear brake light problem
  168. rodeo smells like gas
  169. factory intake on 95.5 3.2
  170. Motor Oil
  171. Clearing the Codes
  172. Wheels for 97 Rodeo
  173. Brake Pad Life?
  174. 2.2L Coil Pack Connections
  175. Fix for Broken Wheel Studs
  176. Accelerator Problem on a 98
  177. help with 98 rodeo
  178. Need Feedback
  179. 98' Rodeo #3 Cyl Misfire
  180. 2000 Rodeo Rear Wiper problem
  181. extended warning beep
  182. 97 Rodeo broken, despair immense
  183. 95 security alarm system program remote
  184. Electrical? problem??
  185. new Timing Belt for the 2.2 Liter DOHC
  186. Remanufactured Alternators
  187. Will my christmas tree car ever be normal?
  188. 1994 Rodeo Headlight Wiring/Switch Issue??????
  189. Who to believe
  190. 2000 rodeo electrical? problems
  191. 4WD not working
  192. Coolant Temperature on 97 Rodeo
  193. Speedometer stopped
  194. New Guy Here
  195. gas light comes on at a half of tank
  196. Different oil viscosity for winter?
  197. What type of Motor Oil for 1994 Isuzu Rodeo
  198. VSV Valve & EGR Transducer
  199. 4WD Clicking
  200. Isuzu rodeo 2003
  201. Need some quick help please..
  202. sunroof issues
  203. Will Trooper wheels fit on my Rodeo?
  204. Brand New 2004 Rodeo Help Please.....
  205. maf upgrade
  206. To replace master window switch unit
  207. wheel cleaning
  208. coolant leak
  209. How to replace wiper motor?
  210. 3.2 L Starting issues ....help!
  211. 1998 Rodeo Keeps Overheating
  212. Some Concerns
  213. Wobble
  214. 2000 Isuzu Rodeo 3.2
  215. Rodeo problem...
  216. Replacement Parts Source?
  217. Horn, Alarm horn relay linked?
  218. Lost Key
  219. Need an engine for a 99
  220. wheel width?
  221. Turn signal issue
  222. blinking check transmission
  223. Dana 44 Rear end
  224. Oil pan gasket??
  225. Stock wheel specs?
  226. engine module with different barcode
  227. 95 isuzu Rodeo Engine Sputters
  228. 98rodeo still stalling after alot of repairs- NUTS!
  229. Engine check back on
  230. Whistling in transmission??
  231. improve handling
  232. Should I replace my Timing Belt?
  233. Year compatibility
  234. Transmission flush query.... on +98
  235. Oxigen Sensors
  236. Passenger side CV/axle concerns 95.0
  237. Looking to buy Passport engine
  238. Locating the Power Window Relay
  239. Whining Sound 98 Rodeo
  240. Signal light and power window fuse keep blowing up! Need help!
  241. 97 Rodeo Electrical Problems
  242. Rodeo 97 Repair Manual
  243. 95 4x2 Rodeo need help please!
  244. 3.2L Ping
  245. 2000 Passport - Oil Usage
  246. Wacky smell
  247. carrier bearing
  248. help with 97 rodeo vacuum lines
  249. 1998 Rodeo Thermostat Location & Replacement
  250. What parts are interchangeable with the 95 Rodeo
