View Full Version : Rodeo/Passport
- 1999 Rodeo LS V6 Fuel Filter
- owner's manual is missing pages 9-7 and 9-8
- 1994 Rodeo Plug Wires
- Help - Removing Cv !!!!!!
- Which year has had the least problems??
- 94 Rodeo check trans light flashing..
- Brake Light Replacement on 99 Isuzu Rodeo
- cv joint purchasing
- Warrany- Need help quick!!
- New Rodeo owner!! Need help please!!!
- Heater output cut off
- Check engine light - always on!!!
- Fuel Sending Unit - '99 Isuzu
- 98 Rodeo won't start
- Help with '99 Front Rotors 4WD
- Electrical Mayhem!
- 1999 Rodeo T-Connector Hookup
- driver power window
- I need advice!!!
- Anybody Here Got Any Car-audio installed
- 98 Rodeo front vibration
- Should I Get Rid Of Mine?
- Rodeo Newbie
- Turn Signals / Flasher Troubles
- Vavle bent?
- Make a 4x4 a 4x2
- 2000 Rodeo 3.2 Lifters wont pump
- Changing rotor on '91 Rodeo 4w drive
- Compression?
- 96' 3.2L No Oil Pressure Indication
- Stupid engine is pinging
- Hey, 2000Frontera, need help with wiper delay relay ID
- Check Engine Light came on Went to Autozone and...
- After Market AC
- 98 A/C Problems
- Tranny quirk
- 1999 Rodeo V6, Won't start???
- Filler Plug On Differential Won't Come Off
- 95 Rodeo with leaking CV boot
- Thermostat numbers
- 97 izuzu rodeo no start no run
- Bad acceleration after Rodeo is warm.
- low oil pressure?
- 96 needs replace instrument panel light. Any help?
- Tire brand opinions needed.
- Need Denso
- Looking for cage, 2000 Rodeo
- Running w/5 lugs instead of 6?...
- start problems after refueling.
- Loose Connection Somewhere
- Clutch Problems w/ 92 rodeo
- Engine rebuild?
- Filed compliant w/NHTSA
- Help with 99' Rodeo
- Problems starting in the morning.
- Error codesflash on Air Bag light
- 1997 rodeo coolant leak
- Question 3.1L Chev engine and ????? transmission
- Three items to reduce oil consumption. Is this a fair deal?
- 97 Rodeo engine dies.....
- My Alarm Goes Off For No Apparent Reason
- Slippery film/radiator update
- 92' turn signal wont work
- 2002 din wiring harness trouble
- Help! Keyless Entry
- White Slippery Film in radiator? Any .....
- 97 rodeo rear wheel alignment?
- 93 isuzu pickup bucking, stalling, rough idle,
- Big uh-oh....or maybe slightly smaller uh-oh?
- Bought 99 Rodeo LS from Auction Fuel Gauge problem
- 2000 Rodeo manual door locks
- 2000 Rodeo Warning Light S/U
- 95 3.2 4x4 auto rear antilock light?
- Door Schematics?
- Smoking, bad acceleration, how to pull codes
- HELP! changing the front rotors on a 2000 rodeo
- 2000 Rodeo S end of Lease/AC problem
- Replace CV Boots, CV Joints or whole Axle?
- Replacing clutch fan with electric??
- Lower ball joint removal? Help!
- steering box grease
- Rear Brake Rotors for 2000 (how to replace)
- Machining Question+ a few (hundred) others
- won't hold water
- '01 Rodeo shock swap... special tools?
- +98 Rodeo Fuel Gauge Fix write up:
- 2002 Rodeo Head Blown / Tranny Overheat!
- rodeo wont start
- 30k Service quoted at $920??
- 95 Isuzu Rodeo Stereo Installation
- Questions about Rodeos
- 98 Rodeo Keyless Entry
- OBD II code P0440
- 98' Rodeo 4WD engaging at will...
- 98 Rodeo Transmission Problem
- Coolant in plug chamber
- Another good Isuzu site
- Isuzu error codes
- CV joint noise?? 99 Rodeo
- After warm horribly rough with misfire
- Noisy lifters not caused by faulty lifters
- Stereo and Clock don't work, Checked fuse its ok, what gives?
- Intake Manifold Gasket Repair
- air turns on when passenger door is closed
- Crankshaft Pulley
- Help with 96 Rodeo ....no spark
- 94 automatic idles like a vw bus and bucks too
- 2000 Rodeo keeps stalling
- clicking noise coming from shift lever
- still having turn signal probs please help
- 98 Rodeo fuel gauge wrong and uses more gas
- Timing Belt
- Camshaft Position Sensor (LOCATION PLEASE)
- Octane requirement
- 93 no spark?
- shock replacement.
- shifter issues
- WindNoise, AC and Air Leak
- Rearend shakes at take off with a load on.
- 60,000 Mile Service
- air conditioner issue?
- Stepping on seagulls???? [brakes]
- wont start
- 98 Isuzu rodeo...fuel gauge not reading properly
- Check trans light blinking, alternator gauge
- Spark plug opinions
- Changing spark plugs
- Changing front rotors on 97 Rodeo
- brakes help
- Anti-theft Alarm Sounds w/o Known Cause
- Tires: What size options are there?
- help !! passport is running rich - power loss
- Tires: P-rated or LT-rated?
- Overheating... '94 Rodeo 3.2
- decreased gas milage
- Still got the groove!
- Replacing starter in 2000 Rodeo
- 1999 Rodeo LS 4X4 CEL and ODB Code P0303
- stupid question
- A Few 2004 Rodeo 3.5L Questions??!!
- Typical Temp range on 3.2L??
- Doors and windows
- Service Shop for my Rodeo
- Acceleration problems
- Sounds like a train.....
- Intermittent wiper problem
- OBD_II Scan code P1340?? What is it?
- Rodeo FAQs on this board?
- ABS light and gas gauge issues on my 98 Rodeo
- Has an oil addiction
- 95 Rodeo Won't Start
- Missing In Gear? Not at idle? Ive tried everything.
- Help me change my headlight bulbs
- Help! 2000 Rodeo leaking trans fluid!!!
- 4x4 club
- 95 V6 4X4 check tranny light
- Radiator hoses
- Tapping Noise
- EGR Port pictures, 2nd gen:
- Bumping sound from the rear
- paint for a rodeo 1995.5
- 2000 Rodeo Codes
- 95 v6 3.2 Clutch problem?
- top end of motor tapping-94 rodeo
- Shock installation problems
- thanks guys
- Doing It Again!!??
- Trouble starting
- gas gauge reading incorrectly
- Strange Brakes Light Behavior
- problems with rear end of 99 rodeo
- problem with the dash board light
- Checking the ignition switch
- CEL flashing on and off on my 2000 rodeo...
- Removing engine cover
- Thnk U, & I should introduce myself. . .
- 2000 Rodeo possesed
- Rodeo2 - the 100K for t/belt, does that ....
- check enging lite on again
- Code for '96 3.2/5-speed
- where's the fuel level sending unit
- Tranny Oil Service Life Monitor
- Knocking noise when turning left
- Rear window glass rattling
- '98 Humming noise from rear end
- Timing belt change/Interference ??
- Automatic tranny shifting problems
- Window regulator removal and installation
- 1991 isuzu rodeo
- trans disengaging(new 4th gear servo)
- 2001 Rodeo pulls to the right.
- Location of ABS Sensors on 99 Rodeo 4WD
- 97 (almost) overheating
- slip yoke
- "Steam" cleaning your engine
- 2000 CEL problem...how many others are having this?
- Need a drivers side door
- Air Conditioner Compressor 99 Rodeo
- '95 3.2 compressor clutch removal
- A lot of issues
- Urgent PLease Help!
- shutting down
- Spark Plugs $$$
- 1997 Rodeo Lugs and Lug nut Breakage
- trans
- Easiest way to get 2"lift on 95 Rodeo
- 1996 Rodeo Check Engine Light
- 2000 Rodeo 2.2L Spark Plug Change
- Do I want to buy a Rodeo?
- '91 Rodeo floods out when starting...help
- 94 Rodeo Right Blinker Only Wants To Buzz Please Help
- Rear Speakers 5" ???
- replacement shocks?
- Calmini Shocks F&R for sale - Rodeo
- CHECK ENGINE light on 2000 Rodeo
- Trouble starting Rodeo after driving for a bit.
- Changing shocks
- Valve cover gaskets
- Anybody heard of the Inhibitor Mode Switch?
- Fuel Sending Unit again
- Looking for parts
- Fuel Econ
- 1992 Isuzu Rodeo For Sale
- Rodeo Running Like a VW! AAAAHHHH!
- Engine whine 2000 Rodeo?
- broken rear glass/defroster AGAIN
- suspension question
- it's not the hood hinges
- new guy here needs direction
- Starting Problem - not consistent
- US/CND Warranty Issue
- no juice to fuel pump
- 94 rodeo 4x4 tranny ?'s
- white face gagues replacment?
- 4l30-e
- Brush guard recalled
- Deafening scream when started
- new spark plugs
- high idle
- 1/4 times
- 98 99 00 01 Isuzu Amigo Rodeo Altezza Tail Light
- This board is wonderful
- What is the smaller pan under the tranny on a 2001 Rodeo?
- 99 rodeo OBD II PO171 problem
- Need clip that hold headlight bulb secure - 95.5 rodeo
- p1627 pcm a/d conversion malfunction
- How to check transmission fluid 99 Isuzu Rodeo??
- 2000 Rodeo has no power
- squeeky
- 95 rodeo...ticking sound and low oil pressure
