View Full Version : Rodeo/Passport
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23
  1. no rear wiper
  2. '96 rodeo alternator woes
  3. Electrical problems in 2000 Rodeo
  4. 4WD not engaging
  5. coolant temp sensor
  6. Fan for AC/heat
  7. Rear differentials? Which one . . .
  8. 97 Passport Cranshaft Pulley
  9. 1994 Rodeo - Host of Problems
  10. 1994 rodeo trans--no drain plug
  11. 97 rodeo problems
  12. 2000 Rodeo diagnostic jumper terminal location
  13. 1999 Isuzu Rodeo Crank For Sale
  14. Strange Brake Light Behavior
  15. Help alarm 98 Rodeo
  16. 2000 Rodeo Jerky Transmission (cont.)
  17. Mud flaps or NO - want opinions
  18. ARB Bumper for 97 Rodeo's ??
  19. Water Pump
  20. 99 Izuzu Rodeo locking lug nuts
  21. 97 rodeo heater/ac fan BUZZ/NOISE
  22. Monroe shocks now on sale
  23. Rear End Seal Replacement
  24. high idle
  25. strike plate/arm not clicking together
  26. Rodeo Runs Rough
  27. Rear right bumper part?
  28. Dreaded CEL - what next
  29. need more power
  30. Ran out of gas. Won't start after refuelling
  31. knocking or bearing noise
  32. 96 Passport Change to Mobil 1
  33. 96 Passport converting to Mobil 1
  34. Strangest instrument light question ever...
  35. Floor Mats for '95 Rodeo
  36. PCV Price Difference
  37. 96 rodeo coolant leak
  38. 200 Rodeo Jerky Transmission
  39. 1995 Rodeo Mileage
  40. Need Help! Possible starter? You tell me.
  41. Rodeo '98 Maint Tranny and Front Diff.
  42. Fuel pump relay clicking
  43. Volts are GOOD, ABS issue ??
  44. Power Steering Problem--WARNING!
  45. Pop-ups..... unacceptable
  46. Isuzu rodeo 2000...Error code 1340
  47. running too rich
  48. Brake light, Oil light, Battery light - A/C does not work
  49. missing under hard accel at 5K?
  50. 4WD Clicking Noise
  51. cumsumer reports
  52. Surging During Acceleration
  53. No Wiper FLuid??
  54. No Wiper Fluid
  55. Changing the Fuel Filter on a 95' Rodeo
  56. 99 rodeo rear wheels shuttering
  57. Jerky transmission and a huge oil puddle in garage ('00 LSE)
  58. 96 Rodeo periodicly dies...etc
  59. shocks
  60. Electrical issues with a 93
  61. Transmission Fuid Change. HOW to ?
  62. 01 Rodeo V6- What MPG should I Expect??
  63. Body Lift or Suspension lift?
  64. Isuzu Tech's/anyone, need thoughts
  65. More oil leaking
  66. Intermittent Air Conditioner Problems
  67. Bizarre electrical problems '99 Rodeo
  68. 1998 honda passport coil problem
  69. torsion bar lift
  70. A/C Quit
  71. 1996 or 1997 light and radio problems
  72. 97 rodeo problems
  73. Need 03 Input
  74. Help needed for '99 console R & R
  75. 01 Rodeo New Shocks - Great Improvement
  76. Dash Lights
  77. Lowering a 2wd Rodeo
  78. looking for exploded view of engine
  79. Need help with Windows and Lighter
  80. water leak
  81. Timing marks won't line up....
  82. Engine suddenly cuts out... Then restarts
  83. need used transmission
  84. CEL On and Off???
  85. Safe to Drive?
  86. Need thoughts, low occ. voltage
  87. 95 Rodeo/Passport possible blown rings?
  88. 97 Rodeo V6 - Oil pressure drops to zero
  89. Camshaft Position Sensor?
  90. 1999 Rodeo LSE Problem
  91. Locating Electronic Flasher?
  92. fuel pump going?
  93. speed up problem on start
  94. Splitfire plugs?
  95. 95 LS weird clutch problem
  96. Intake Manifold Gasket
  97. remote programming
  98. Cover gasket??? need help please!
  99. What car has the rodeo 3.2 in it?
  100. How to get 250 hp out of 3.2 rodeo
  101. Rodeo Clubs In Atlanta ??
  102. Did 95 rodeo have factory Alarm???
  103. 3.2 hydraulic valve train noise
  104. Fuel Pressure on 3.2L
  105. Rodeo 97. Hesitating Windows!!!
  106. Windows just screwed up
  107. 96 rodeo electrical problems
  108. New inexpensive wheels?
  109. Question about ABS light, brake light and lifters?
  110. How do you change dash kights on 95 rodeo
  111. My First Rodeo -- Used
  112. fuel pump
  113. Slip Yoke
  114. Service Bulletins
  115. Shocks, tires and spark plugs
  116. ?Clanking Sound?
  117. 1999 Rodeo Valet Switch
  118. Have to replace cj shafts, any preferences?
  119. How to remove windshield wiper arms?
  120. 94 V6 smog test near fail
  121. New 95' Rodeo Owner
  122. HELP!! Blinking Check Engine Light
  123. 95.5 Rodeo 3.2 4WD Starter problem
  124. 1996 Rodeo Auto Trans - Synthetic Fluid?
  125. im looking at buying a rodeo. pros/cons
  126. 2004 Rodeo - no keyless entry ?
  127. Oil Pressure Gauge "0" -- HELP!
  128. 97 rodeo 3.2 Running Rich!!! HELP!!!
  129. which engine is better? 3.2 SOHC or DOHC?
  130. Signal Light Dim
  131. Fuel Filter, PCV, and Resetting Computer
  132. Paint Problem
  133. Engine Stuttering
  134. 99 Rodeo 3.2
  135. CEL = Need tranmission replacment!
  136. Replacing Fuel filter for '93 V6
  137. 93 Rodeo shifter button only engages when engine is off
  138. 95 Steering Play
  139. A/C clutch locked up
  140. spark plug gap
  141. EGR Problems
  142. 96 bucking rodeo!
  143. 1992 rodeo blows fuses
  144. OBD2 (0174) Exhaust MYSTERY
  145. Warranty question for 2000 Rodeo
  146. Turn Signal/ Hazard mayhem
  147. CEL and P codes....
  148. Changing wheel studs
  149. Rough Idle & Check Engine Light
  150. engine woes
  151. the dreaded CEL...what to do????
  152. My Windows Won't Roll Down In Back Of My 1995 Rodeo
  153. Just dropped my 00 off for new shocks.
  154. Introduction, with some questions!
  155. Rodeo - a good vehicle?
  156. Turn signal/Brake light puzzle
  157. coolant drain plugs on block
  158. Right Anti-lock brakes
  159. Sunroof wind noise
  160. at wits end - Need Help!
  161. Transmission flush query....
  162. window regulator
  163. help how do you set the clock on a 1995 rodeo
  164. 1996 Rodeo - Instrument panel lights
  165. Engine replacement
  166. Quick T-Belt Tension Question
  167. Altezza lights causing brake lights to stay on
  168. 94 isuzu timing belt install
  169. Muffler / Tail Pipe Separation - Rodeo '99
  170. a./c clutch for 93 Rodeo
  171. 2001 ATF cooler
  172. 2000 intelligent suspension control
  173. this woman is going nuts with these noisy lifters
  174. could very low oil cause lifter noise
  175. 2000 Rodeo CEL and Rough Idle
  176. Tire wear on the outside of both front tires
  177. 98 honda passport air condition is hot
  178. Isuzu random missfire plus os2 sensor bank one sensor one switched to lean
  179. pulley bolt type of threads
  180. 95 rodeo trans problem
  181. Anyone with trans temp guage on Rodeo?
  182. 2000 Dash squeak - HELP!-
  183. 2000 Rodeo new shock impressions
  184. 1998 Isuzu Rodeo Engine Problems
  185. Smaller Gas Tank 1999 Rodeo
  186. power locks
  187. 1996 Isuzu Rodeo 3.2L V6 4x4--New Owner
  188. Idles rough but not what you might think
  189. rodeo
  190. High Idle
  191. Rear rotors shot at 50K miles - did we get ripped off?
  192. 99 rodeo manual transmission
  193. abs light on
  194. Urgent Tranny Issue
  195. 95 Hard Gas Pedal Problem
  196. Locked up Auto Tranny stick
  197. AC Condeser VS a rock
  198. 96 rodeo charging, brake, 4wd issues
  199. window switch replacement
  200. serpentine belt broke
  201. Black smoke and no power
  202. Trouble starting, idling high
  203. rodeo elect problem
  204. 96 Rodeo electrical prob
  205. '99 Rodeo hard shifting tranny
  206. Towing equipment
  207. rodeo 4 cylinder engine
  208. Rodeo Oxygen Sensor
  209. 95 wipers dont work intermittently
  210. vacation
  211. Cruise Control and Headlights
  212. Headlights need adjusted??
  213. Isuzu Rodeo Transmission Fix
  214. Removing front brake rotors
  215. Shaking & Slipping in front when braking?
  216. bogged down till warmed up
  217. 99 Rodeo Cooling System
  218. 94 V6 Overheating when pulling boat
  219. 2001 Rodeo Troubles
  220. grill....
  221. PCM "upgrade" --> Reprogramming the computer
  222. 1994 rodeo stopped, gears locked?
  223. Engine seems bogged down...
  224. 95, very squealy starts
  225. Crank Pulley Bolt
  226. Clutch Mystery
  227. Rodeo will not start
  228. Blwer Motor
  229. 6 CD Changer
  230. Electrical Mayhem II
  231. power driverside window repair
  232. 2000 auto tranny problems
  233. 99 rodeo rear speakers
  234. 99 Rodeo wiper delay faulty
  235. Cruise control- 1995.5 Rodeo
  236. 1995 rodeo electrical(?) problem
  237. Need New Engine Please
  238. 92 Rodeo (transmission Control Module) 4 sale
  239. Opinions on this Please !!
  240. Electric Cooling fans on always w/AC
  241. 94 Isuzu rodeo 2.6L timing issues
  242. Altezza (Clear lights) for 2000 Rodeo
  243. 20's for sale!!
  244. 98 Rodeo ABS issue
  245. 1996 overheating
  246. 99 rodeo hard starting
  247. Lugs/nuts, need input on right one's....
  248. the diff. between reg. b20a5 & JDMb20a5
  249. Checking the Tranny fluid level
  250. Need input on trans service(or lack of)
