View Full Version : Rodeo/Passport
- 95' no cold start
- 1993 Rodeo Overheating
- 4X4 Light Blinking
- 94 passport no 3rd gear shift in 4 wheel drive?
- 1995 Isuzu Rodeo, Trans Problem
- 99 rodeo 4wd, replaced starter still no luck.
- exhaust question
- Electronic Throttle Control
- 2002 rodeo-tail light fuse shorts out
- P0172
- Hard Starting Blues?
- Hood latch problem
- 99 Rodeo 3.2 hunts, stalls Code P0101-0102
- 1998 Rodeo Started Problems
- abs brake light indicator - failure?
- axle issue
- 01 passport need door handle
- 98 Passport - 4WD Not Disengaging Consistently
- Fuel Pump Seal issue
- rodeo engine suddenly turns-off while driving?
- Rear Wiper Will Not Stop!
- Interior Temperatur Control Cable
- Drivetrain Light on
- '95 Rodeo 3.2L Tune-Up Questions
- New Owner maintenance questions
- side view mirror on rodeo
- P0116 ECT Circuit Range/Performance CEL Help
- Flipping upper ball joints on a lifted Passport
- 2000 Troubles starting
- 2000 Troubles starting. . .but it always starts eventually.
- Oil Pump replacement
- Rear End Shake/vibration
- Opinions on dipstick heaters please
- Replacing leaf spring bushings and engine ticking...
- 1997 Transmission slip in 1st gear
- 98 Rodeo Catyl. exhaust flange to header
- 1996 Rodeo interferance engine ?? yes or no
- Blinking 4x4 light
- EGR P0401 That will not go away
- Please Help 4cyl Rodeo.
- EVAP Canister Vent Solenoid
- Removing Transmission Pan Bolt 99 Passport
- '00 3.2L 6VD1 Valve Adjustment
- 94 Passport 3.2L starting problem
- Coolant Crossover o-rings?
- 99 Isuzu 3.2 - upgrading to larger oil filter?
- '99 Rodeo - won't start after accident
- I almost sold my Rodeo
- Shocks to replace ISC ones.....
- 04 rodeo workshop manual
- crankshaft position sensor on 99 isuzu rodeo
- gas gauge not working? same for 94 rodeo?
- 2000 Passport Rear Wiper not working
- New brakes and Front Bearings $1000????
- Wipers come on with turn signal
- new timing belt wearing very fast.
- Worn timing belt
- Free Cupholder for '90-'96 Rodeo!
- New Isuzu owner.....
- another oil guzzler
- My smoking 01 rodeo..
- Key won't release from ignition
- 98 Rodeo 3.2 4x4 code p405 help!!
- Really stupid problem.
- Harmonic balancer
- 97 Rodeo accelerator cable
- 97 Passport Timing Belt Replacement
- What are you buying your Zu for Xmas?
- 95 Rodeo Repair Manual
- 2001 Rodeo 6cyl - Timing Belt or chain??
- Anyone DIY remote start?
- 2004 3.5 Rodeo Will Not Start
- 04 Rodeo 4wd Problem
- still having problems with my 3.2
- 96 Rodeo 3.2 no power and sputtering until TPS is > 60%
- 98 Rodeo 3.2 4x4
- Red Dust? All Over Pulleys
- really LOST need help!!
- Fog light install
- 1999 Rodeo Manual transmission removal
- Name that ride
- Brands of Timing Belts, Water Pumps, Hoses
- 2000 Isuzu Rodeo Engine "stumbles"
- How do I post pictures?
- Winter mode question
- Which Aftermarket Air Intake for '95 Rodeo?
- 4x4 problem
- 94 Rodeo auto hub 4wd won't engage
- 98 rodeo coolant leaking
- Code 0101
- Cooling Fan constanly running
- my rodeo's
- what are the rust prone areas on a 2000 rodeo?
- 2001 isuzu rodeo 6cyl stalls but will start right up
- tranny slippage
- trailer wiring?
- All I want for Christmas is a flashing Check Engine Light....
- cooling problem
- Changes to my 99 Honda Passport..
- 99 isuzu rodeo
- Leaking pink stuff...
- Need dash button "blank"
- clunk noise in rear on turns
- CV Boots & warranty
- tranny problem need help
- 2004 rodeo idle air control location
- 2000 Isuzu Rodeo factory alarm
- Engine rev at start up
- Blowing fuse for reverse/signal lights....
- EGR 401 code and old CAT
- No power windows or locks from driver side
- '98 Rodeo overheating\pressure problem | any ideas?
- '94 Isuzu Rodeo TPS - What's it look like inside?
- Atf
- Antifreeze
- Headlights and Cornor Lamps.
- curious to know...
- Loose steering 97 rodeo - cause?
- Pretty much every O2 sensor code just came up NEED HELP!!!
- horn buzzer Defeat procedure? 1999 Rodeo
- Look it's magic...oil loss but no source
- egr valve and egr backflow transducer
- Changing the FSU
- Check engine light and Emissions
- My 94 Passport wont start after sitting for 3.5 months
- engine codes?
- Offroading
- Need transmission help 2000 Rodeo AT 4WD
- program for keyless remote for 2004 Rodeo
- Check Transmission and Cruise set light come on.
- 2001 Rotors
- Transmission slipping
- Wtf!!??
- code 0175?
- I know it's the alternator but...
- Starting Problem
- Misc. Problems
- Shifter button sticking.
- how big i can go?
- Cruise control question
- Shifter cable pics?
- Qestion on 4x4
- Head Gasket Replacement
- Insane leaking
- Bad Fuel Smell
- 92 rodeo hesitation
- pressing brake stops LEFT turn signal
- 1999 Isuzu Rodeo with some troubles - RPM flux/idle stalling/wont start
- O2 Sensor Part Number
- Sold my Rodeo
- Sold my Rodeo
- Challenging squeal
- disable abs on rodeo 2004
- Anyone Replace Muffler on 96
- im leaking
- Hood Release broke...HELP!
- I'm baacckkk.....had some
- ('00 Rodeo) Negative or Positive Ground/Siren & PA install
- 1995 vs 1995.5 Passport
- 1993 isuzu rodeo 2.6L
- 1995 Isuzu Rodeo wont start
- 99 Rodeo won'tstart no spark
- 97 rodeo misfire..... any suggestions?
- Scan tool suggestions
- Isuzu tf low power
- Nightmare body work at California shop
- No brake lights or cruse control & can't get out of park after the engine has starte
- Flex Pipe / Exhaust
- Starter
- How do you use HEAT only on windshield defrost setting
- 2x4 '01 Rodeo Sport owners, I'm preparing for Kansas winter
- Surge and stall problem.
- 88 isuzu amigo o2 light on spits and sputters.
- 94 Rodeo Engine wiring help
- 2001 Rodeo EGR Valve Location?
- disconnect torque converter clutch connector from transmission
- 2000 rodeo clutch
- Rodeo glove compartment lock stuck
- Failed Emission Test. What should be my next step?
- Transmission rodeo 2004
- 01 Rodeo ABS codes
- 1993 Isuzu Rodeo 3.2L 4x4 -Honda Passport question
- 2002 4 cyl Rodeo low power and overheats
- Cranking the torsion bars = bad tire wear?
- help
- Timing belt/Hesitation question....
- Window motor - how tough to change?
- 1993 Rodeo... Need torque specs...
- 245/75/16 vs. 245/70/16?
- automatic hard shift sometimes
- P1220 code
- 93 rodeo PLZ HELP!!!
- Transfercase/4x4 Issue
- Key Broke off IN ignition...'97 Rodeo
- Can I put drive flanges on a 94?
- Calmini 2" lift
- 1998 Rodeo ABS Light
- 93 rodeo wont start, heres the symtoms. help please
- 93 rodeo ecm help. wont start
- I Need Help!
- Misfire, smoke, loud ticking, hard to start
- Automatic Transmission Fluid Leak
- isuzu Rode hood latch
- Isuzu Rodeo, Fuel Sending UNIT problems
- '01 2WD Hub to Rotor Bolts Torque Specs?
- 98 Rodeo starting problem
- obd p0452
- looking to buy rodeo. what to look out for
- anti theft alarm
- 95 Rodeo bucking and stalling
- Isuzu Rodeo - Reduced Power
- 2002 2.2L 4cyl transmission
- Installing Cam Sensor 2002 Rodeo 4 Cylinder
- Transmission compatibility - 2002-2000 Rodeo
- where is trans ?
- How much is my engine worth? 2000 Rodeo, 73k, 4 cyl, 2.2L
- Front Wiper Motor - return - or for sale
- ecm location??
- 2000 Passoprt - replaced FSU, now excessive cranking..
- Ignition key buzzer
- Wiring kits
- rear viper
- Timing Belt parts - Autozone good enough?
- O-Ring Replacement Under Intake Manifold.
- Won't start when hot - runs great otherwise
- Help for New users on abbrev
- Factory Alarm / Keyless Entry Info Needed
- Power Lock Relay
- Fuel Pump Problems
- gear indicater on the dash of my 2000 rodeo won't move
- Illumination problems.
- 1998 Passport.. Coil Problem..
- Horn=Off Airbag light=On
- Code P1406 on 97 Passport/Rodeo
- IMG replace this weekend.torque consensus?
- 2000 rodeo timing? help!
- Power steering only works at higher rpms
- P1391 G Sensor Performance
- Please Help! clutch problem
- 1994 Isuzu Rodeo - Alternator replacement
- Clicking coming from center console shift area?
- UAS (universal anchorage system) in a 01+ Rodeo
- Code P0154 Persistent '96 Rodeo
