View Full Version : Rodeo | Passport | MU
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21 22 23 24 25
  1. Super 95.5 Rodeo . .
  2. Bad Fuel Sending Unit -> Check Engine??
  3. Fan Clutch Removal
  4. drive belt
  5. 2000 Rodeo blades stopped working
  6. API SM/GF4 oil versus SL/GF3 oil? . . .
  7. Passport heater fan not working
  8. A/C Fan doesnt tun on....
  9. Open Thermostat
  10. Heating
  11. Key Stuck! HELP
  12. Brake Lights
  13. 2002 Rodeo hesitates/jerks into gear
  14. Installing transmission fluid
  15. Installing transmission fluid
  16. What IS the tensioner pulley?
  17. 96 rodeo check engine light
  18. Bushing for Popping doors
  19. Brake Warning Indicator
  20. rodeo keyless remote
  21. 94 passport slow going into reverse?
  22. Speakers for a 93
  23. What year to buy
  24. squaling belts!!!!!!!!!!!
  25. 2nd Gen Skid Plates
  26. heavy duty alternator
  27. passport suspension
  28. Bolt size for OEM bumper
  29. How many miles do you have your Isuzu?
  30. egr valve
  31. water coming from exhaust
  32. Air conditioner problems
  33. Mountain driving w/auto Opinions?
  34. Isuzu Rodeo 1993, 3.2, leaking antifreeze out the back of the engine
  35. Running out of IDEAS
  36. HELP me STOP! NO Rear Brakes !!!
  37. Dont Know What To Do!!!!
  38. Over revving and surging
  39. Isuzu Rodeo 99 "U/S" LIGHT
  40. Adding Alpine CD Changer to 1996 Passport
  41. fuel in with oil
  42. 2000 Rodeo Help? Left Me Walking
  43. 95 rodeo will not start
  44. wheel???
  45. hot 92 rodeo will not start
  46. Crankshaft seal replacement 97 Rodeo 3.2
  47. spark plug wires
  48. Slipping problem after clutch replacement
  49. Rattling Sound
  50. Boots
  51. power steering
  52. 1999 Rodeo 3.2 Crossover exhaust section
  53. Fan Clutch on 98 Rodeo
  54. EGR Valve - Clean or Replace?
  55. 2000 Rodeo Stalls When stopping
  56. Replacing Front Drive axle
  57. passenger side window off line
  58. engine revs up between changing gears
  59. 4 wheel drive
  60. gas hog!!!!!!!!!!!!!!!!!
  61. drain and refill coolant
  62. 97 Passport bogs out under acceleration
  63. 2000 Honda Passport - which oil
  64. Battery Alt Issue?
  65. Access to TSB's?
  66. Scratching/grinding Sound on acceleration
  67. Wiper Relay Number
  68. start up runs real rich, lots of fumes!
  69. V6 Rodeo Revs high on start.
  70. 99 Jimmy steering wheel radio controls
  71. 96 Rodeo no pwr to blower motor or switch
  72. Pain in the butt starter
  73. Trans No Go 95 4x4
  74. Price for replacement of Intake manifold gaskets
  75. 95 Rodeo Fuel Gauge
  76. Brakes locking up?
  77. 95 isuzu rodeo heater control light burned out
  78. Tire size
  79. Double Platinum or Iridium Sparkplugs?
  80. 98 Rodeo Resonating sound
  81. Passport needs service, isuzu or honda dealer?
  82. does o2 sensor brand matter??
  83. gas tank leek 92
  84. Inductive timing pickup...
  85. Water going into the crankcase
  86. bank 1 or 2??
  87. Help PO171 and PO172 Codes
  88. Fuel Trim Too Lean/cel
  89. 1997 Rodeo V6...is it a 3.2?
  90. Price on Timing Belt
  91. 94 3.2 rodeo getting to much fuel
  92. Alarm pin switch on the hood? +98?
  93. Code 0463 (fuel level sensor)
  94. anyone have thier old body lift instructions?????
  95. CD-Changer Mounting '96 Passport
  96. 96 rodeo cooling problems
  97. Egr Valve
  98. Need to vent!!
  99. Looking for a few ideas
  100. muffler question
  101. bad gas milage
  102. Rodeo Tranny Help
  103. 30,000 mile service prices
  104. Isuzu Survey:
  105. Am I having Transmission Problems???
  106. Sunroof!
  107. Rodeo stalls when idle and shut off engine
  108. Gas consumption
  109. belts
  110. Help with trouble codes please???
  111. Has anyone swap the engine??
  112. 94 rodeo wont start
  113. Wheel Size, esp. backspacing
  114. 97 Passport Pinging
  115. Adjusting loose steering on a 92 rodeo
  116. 99 Rodeo ABS Module Wiring/Connector
  117. timing question
  118. 99 Rodeo Shifting Hard
  119. tranny code
  120. 98 rodeo needs help. will not start.
  121. Rodeo Stutters Then "Check Trans" and "Cruise Control" Lights Come On...
  122. cel p1153 p1171 HELP!!!!!!
  123. 94 amigo wont start
  124. tranny error code 32
  125. 93 izusu rodeo wont start
  126. 92 rodeo 3 inch body lift....31s or 32s????
  127. Question
  128. cruise control fuse location??
  129. '94 Rodeo 3.2 not an interferance eng.
  130. Electical question
  131. Air Bag Light
  132. 97 Passport Just wont start
  133. oil in with spark plug
  134. 01 pasport fuel sender bad
  135. bad tranny
  136. trouble starting 98 Rodeo
  137. e-brake light
  138. 4L30E auto tranny filter
  139. Cold air at a stop
  140. Sudden Acceleration
  141. Tried everything ENGINE TICKS LOUDER
  142. fuel leak around vacuum canister
  143. Tranny Id
  144. 1996 Passport dipstick ?
  145. 92 rodeo how to remove front fender????
  146. Moab Isuzu event
  147. daytime running lights won't shut off
  148. 1999 Rodeo/Passport Fender**Please Help
  149. 4WD on 96 Passport does not engage
  150. rear abs and brake light on
  151. Attention Canadian shoppers
  152. 93 Rodeo UTE (australia, holden rodeo) lack of power
  153. P0300??????
  154. 1999 Isuzu Rodeo V6 Erratic Idle/Stalling/Hard Starting
  155. 95 passport timing belt removal
  156. 92 rodeo GAS LEAK......need HELP
  157. PCV location
  158. 2000 Honda Passport Valve Clatter
  159. 1993 Rodeo oxygen sensor light
  160. speedometer needle gone crazy
  161. engine cylinder out
  162. Gas Mileage
  163. 99 Rodeo 2WD V6 Check Trans light flashing
  164. 97 4 cyc. 5 speed rodeo
  165. car stereo
  166. Where to buy online parts for 99 rodeo?
  167. Ngk ?
  168. 97 Rodeo-Lift kit, or beef kit!!
  169. 94 rodeo
  170. 93' Rodeo Electrical???
  171. 92 Rodeo Heating Up
  172. 92 rodeo stuck, when 2wd car makes it out fine
  173. "94 Rodeo Valve - interference?
  174. 2002 Rodeo Sport Oxygen sensor bank locations?
  175. 91 Rodeo anti-lock brake/emergency light stuck on
  176. removing injector wires for IMG replacement
  177. Ok all, here's a 4x4 q.
  178. 96 Clutch to floor
  179. 2000 Passport EX want power seats
  180. 1997 Rodeo-Idle flucuation
  181. 1996 Acura LSX
  182. 2000 Rodeo Spark plug wires HOW!
  183. Trailer lights for 99 Passport
  184. 2002 Rodeo Sport leans to right
  185. Rear brake problem
  186. Fluctuating idle 99 Passport
  187. 93 Rodeo running rough
  188. 91 Rodeo Wont Start
  189. smoke @ startup
  190. And Also
  191. Tranny Clunk
  192. Tranny Problems on '93 Rodeo
  193. Shake at 50 MPH
  194. overheating, oil in plug tubes
  195. 97 rodeo check trans & check engine lights
  196. acting weird
  197. Muffler
  198. 99 Rodeo Brakes Grabbing
  199. 2001 rodeo 4-Wheel Drive Problems
  200. Common FAQ questions
  201. Running Boards/Nerf Bars/Step Bars
  202. floor jack?
  203. 97 5 speed 4 cycl.
  204. 97 4 cycl. rodeo
  205. 96 rodeo starter
  206. Has anyone installed a remote start on an 04 Rodeo?
  207. power ports are dead
  208. In Appreciation of our Foru, and it's policies
  209. Stuck key
  210. Fuel filter in 1993 4WD
  211. 1998 Drive Belt Idler Replaced
  212. Tiny Light
  213. 1999 Rodeo Rough Idle ?
  214. 2001 3.2L Engine pictures
  215. What Size Allen Bolts on 3.2L V6 Valve Covers?
  216. 1997 Rodeo-Transmission
  217. 96 3.2 Rodeo (Passport) fluid leak
  218. St. Charles Isuzu Live!
  219. Lug Nuts (aftermarket ones)
  220. location of 92 rodeo EGR valve
  221. Disable factory keyless entry
  222. 50k maintanance
  223. Hooking up iPod to stop indash cd changer (6disk) - 2000 rodeo
  224. looking for mirrors for 98 rodeo sport
  225. keyless entry reprograming
  226. cel
  227. Dash lights
  228. FAQ's for +98 Isuzu's:
  229. Welcome to the Forum: Read This FIRST!!
  230. Aftermarket Gauges
  231. Partial dash lights off
  232. Persistant fuel delivery problem on 99 Passport
  233. Code Reader
  234. speedometer
  235. Cheap Factory Isuzu Rodeo Air and Fuel Filter...NOW!
  236. How to change the Rear diffy Fluid? New Info!
  237. rear door speakers
  238. possibly buying 93 rodeo...what to look for???
  239. voltage reg or alternator
  240. kick panels
  241. Possible Tranny Slippage?
  242. 92 Rodeo will 31's fit????
  243. transmission problem??
  244. 91 rodeo v6 doa
  245. dash light
  246. timing belt install now wont start
  247. check engine light on isuzu rodeo 96, pls. help!
  248. Clicking Sound
  249. 1994 3.2l wont start/ stay running
  250. Loud knocking noise
