Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Isuzu
> Rodeo/Passport |
View Full Version :
Rodeo/Passport
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
3.2L DOHC isuzu V6 motor valve clearance
Can't get reverse gear.
1994 Honda Passport
are these signs of a tranny replacement?
Adding fluid to 99 Isuzu Rodeo automatic transmission
Front Wiper Fuse Blows
Service Manual Recomendation???
Windshield Wiper Motor
1986 toyota pick-up died
99 Rodeo Tailgate Lock Cylinder
long to do list
Lower oil pan removal.
Fuel Sending Unit
Engine Knocking, Please help...
rear view mirror
1992 sputtering rodeo, bad idle
Low Oil Pressure
How to check relays
Timing questions
'92 Rodeo Automatic hubs
2001 Rodeo Accessories for sale
Iac
intake gasket may be leaking
Coolant capacity '99 3.2L Auto
Back Window Lock/Release button issue
Rodeo Belt Problems....Help!
99 Rodeo Automatic Gear Selecter Lock won't release
Blower switch or motor not working HELP!!!
99 rodeo engine parts for sale
Help with fuel pressure reading
Replacing wheel studs
Check Engine Light
boa remote start
1992 Rodeo NO FUEL *Confused*
Timing Belt replacement interval
sputtering Isuzu
rear door won't open-auto lock works fine
severe gas smell
Honda Passport Problems
Another tranny Q
hood bump stops
Bucking Isuzu Rodeo
car shaking at 55 mph on up, not the wheels or tires...
How to clean 1992 Rodeo EGR?
SOLSTER'S '99 maintenance service
What is this duct for?
Where?
installing front brake pads, 00 Isuzu Rodeo
difficulty removing power steering belt on 95 Rodeo
Event Data Recorders (EDRs) or Crash Data Recorders (CDRs)
race gas
95 1/2 Rodeo Check Trans Light
O2 Sensor Heater Circuit Malfunction!!!
Fram suredrain
Tire air pressure recommendation
Interior electrical
Aftermarket Remote start/keyless entry
Trailer Light Wiring??
1999 Isuzu rodeo-Just purchased
Rear Defroster and wiper issues.
Brush guard for an '02
Pictures of lifted Rodeos?
Catalytic converters testing?
Just Purchased
Power/Winter
HELP!!Replacing vavle cover gaskets
Emission Problems?
Lube Chasis Help/Instructions
overheating rodeo
Second gen muffler
Fuel Smell
Error Code P1441
Rodeo Lift kits?
Factory Fog Lights
Max tire size
Need Oil And Oil Filter Recommendation
95 4X4 Rodeo Oil Pan Gasket
94 passport coolant leak
1995 Rear Hatch won't lock
O2 sensor location
Remove Intake to get valve covers off?
Radiator Fan Clutch
Considering purchase....
Brake light issues - update
Slow accelerating, lack of power
AC Clutch vs Compressor
2001 Rodeo Brake Light issues
2000 Passport has intermittent hard start
94 rodeo transmission type
Motor Oil For High Mileage Vehicles
2001 Rodeo parts on Ebay:
Cam Position Sensor
can't get the locking lug nuts off
HELP! 1991 Isuzu Rodeo Overheating Problem
Lifter tick is back after being gone for awhile...
My Sunday Project
2000 spark plug help
For sale 1996 Heads
Need ar filter recommondation!
Brakes
Rear Window Defroster/Stereo Ideas
96 3.2l rodeo-alt swap
For Sale:K&N Replacement air filter
Broken Timing Belt on 98 2.2L Rodeo
remote keypad lost
ABS always on in 91 Rodeo..
2001 Spark Plug Extensions Leaking
'94 Half Shaft Removal
Passenger Window Stuck Open - How do I get it up?
Alternator problems?
What crakhead enginer came up with this (tranny)
heater/ac blower motor/relay tip
2001 Rodeo problems
96 Rodeo Hard to start..Help please...
"clicking" noise when starting up rodeo
Spare Tire Mount Problem
2000 rodeo bodylifts???
1995 Rodeo hesitation
1993 Rodeo wont go into 4WD
O2 and random misfire problem NEED HELP!!
Hissing noise from under dashboard
96 Passport want ingage or shift into any gear
Finally did some maintenance!
'98 Rodeo completely shut down - electrical?
Anyone WTB a 99 Rodeo w/ a siezed engine?
Hard shift transmission fix
overheating rodea, front fan wont come on
rubber trim
99 Rodeo Automatic with slipage between gears
3.1 timing issues
2000 Rodeo V6 Timing Belt
rear brake light problem
rodeo smells like gas
factory intake on 95.5 3.2
Motor Oil
Clearing the Codes
Wheels for 97 Rodeo
Brake Pad Life?
2.2L Coil Pack Connections
Fix for Broken Wheel Studs
Accelerator Problem on a 98
help with 98 rodeo
Need Feedback
98' Rodeo #3 Cyl Misfire
2000 Rodeo Rear Wiper problem
extended warning beep
97 Rodeo broken, despair immense
95 security alarm system program remote
Electrical? problem??
new Timing Belt for the 2.2 Liter DOHC
Remanufactured Alternators
Will my christmas tree car ever be normal?
1994 Rodeo Headlight Wiring/Switch Issue??????
Who to believe
2000 rodeo electrical? problems
4WD not working
Coolant Temperature on 97 Rodeo
Speedometer stopped
New Guy Here
gas light comes on at a half of tank
Different oil viscosity for winter?
What type of Motor Oil for 1994 Isuzu Rodeo
VSV Valve & EGR Transducer
4WD Clicking
Isuzu rodeo 2003
Need some quick help please..
sunroof issues
Will Trooper wheels fit on my Rodeo?
Brand New 2004 Rodeo Help Please.....
maf upgrade
To replace master window switch unit
wheel cleaning
coolant leak
How to replace wiper motor?
3.2 L Starting issues ....help!
1998 Rodeo Keeps Overheating
Some Concerns
Wobble
2000 Isuzu Rodeo 3.2
Rodeo problem...
Replacement Parts Source?
Horn, Alarm horn relay linked?
Lost Key
Need an engine for a 99
wheel width?
Turn signal issue
blinking check transmission
Dana 44 Rear end
Oil pan gasket??
Stock wheel specs?
engine module with different barcode
95 isuzu Rodeo Engine Sputters
98rodeo still stalling after alot of repairs- NUTS!
Engine check back on
Whistling in transmission??
improve handling
Should I replace my Timing Belt?
Year compatibility
Transmission flush query.... on +98
Oxigen Sensors
Passenger side CV/axle concerns 95.0
Looking to buy Passport engine
Locating the Power Window Relay
Whining Sound 98 Rodeo
Signal light and power window fuse keep blowing up! Need help!
97 Rodeo Electrical Problems
Rodeo 97 Repair Manual
95 4x2 Rodeo need help please!
3.2L Ping
2000 Passport - Oil Usage
Wacky smell
carrier bearing
help with 97 rodeo vacuum lines
1998 Rodeo Thermostat Location & Replacement
What parts are interchangeable with the 95 Rodeo
lsd passport/rodeo
Rodeo 97 Dash Bevel
Off acceleration stumbling
2000 Rodeo not start after running out of gas.
serpentine belt tensioner
Inacurate fuel guage
Transmission Fluid Change - 93 Rodeo V6 - where is plug?
CD Changer Jam - 2001 Passport
96 3.2l rodeo electrical probl
1997rodeo Rocker Arm Noise
Passport won't start consistently
noise
sharp exhaust buzz with throttle blip
Range sensor
95 Rodeo fuel light erratic (gauge is fine)
1997 Isuzu Rodeo Keyless Entry/Alarm
Help! 96 Rodeo 3.2 stalls after running for a bit
Rodeo02 - "Lower block skirt" is
Any have info on an aftermarket receiver hitch?
Truth or not? POLL: Regarding oil level
98 Rodeo 2.2L Cylinder 3 Misfire
Brake Rotor Thickness??
Help find part? Number and picture included
SoCal 95 Rodeo parting out!!! Motor, ext.....
looking for headlight assembly
Reddish/yellow particules in oil?
ABS Plate Disintegrated
Intermittent Rear ABS light
Adding Tranny fluid to oil?
One long strange trip...
muffler sucking
2wd to 4wd?
4WD HI jumping out of gear
Cigarette lighter on '96 rodeo
Please help
Web
AF
