View Full Version : Rodeo/Passport
- I see quite a few posts on where to buy factory parts, here you go
- Timing belt
- Apology to 2eyefishclaw
- bye guys (read this)
- Speakers
- 92rear wiper n0t working
- acceleration/sputtering issue 95 Rodeo
- back from shop...high idle rpm
- fuel sender and ecm reset?
- ABS recall ? reimbursement ?
- Possible bad alternator??
- I'm thinking about buying a Rodeo what do you think?
- Blower motor
- 1995 Rodeo Very Cold Weather Start Issues...
- 2nd gen. Rodeo fuel sending unit / fuel pump
- Need Advice! Just bought '95 Rodeo w/110k miles
- flowmaster check engine
- 99 Rodeo 3.2 stalling
- 97 Rodeo P0300 random misfire
- Need Help Asap Electrical
- 98 passport losing oil
- rear wiper motor wont quit
- Clutch and Transmission Replacement
- need help finding
- need help finding
- 95.5 Rodeo 4X4 Rear Suspension (leaf springs)
- Importance of PCV valve replacement?
- Clunking noise when turning
- Would you swap belt driven fan for electric fan?
- Old Rodeos
- Replace 3.2L V6 Engine
- Clutch woes! please help!
- 99 pass port fuel pump problem
- Help. Must change Starter on 93 Rodeo
- How do you check the tranmission fluid?
- Electrical problem solved; you won't believe the cause
- Welding an exhaust flange - tailpipe!
- passport starter replacment
- help with CEL
- 1995.5 4X4 Problems!
- 1994 rodeo cooling fan
- Isuzu Rodeo Coolant
- Charging light on, brake light on, fuel light on - No A/C fan
- P255/65R16 tires on 2000 Rodeo - Tire pressure?
- All sensors in front of intake names?
- 95 rear door hatch won't open..
- Rodeo or BMW- you make the call!
- Ranchos
- High-pitched loud whining noise when tranny selector is set to D.
- BGK 44 fuel cleaner? Anyone use
- P0440 = EVAP System Malfunction
- manual on ebay
- CEL on and Check Trans light blinking.
- Buy a nice 98 4x4 !!!
- [Exhaust] Bent pipe.
- 2000 Rodeo Transmission Noise
- I need some tech advise on belts on 94 Rodeo
- Heater not hot
- 94 Rodeo Trans light blinking
- reverse glow gauges
- 4WD Indicator Light
- 99 Rodeo Wiper Interval Module
- 95 Rodeo Child Safety Locks Problem
- HELP!!! '94 Shifting Problems
- Isuzu Rodeo (97)
- Rear window wiper
- "Check Engine" light during shifting
- Head Gasket or Valve CoverGasket?
- 2003 Washer Fluid Change
- 94 Passport with Problems
- Noise coming from Somwhere???
- took Rodeo into shop>>help!!!
- gm t5 transmission on the1991-1992 3.1 liter rodeo ?
- Possible coolant leak
- 2001 Isuzu Rodeo Sport spark plug location
- lubing the slip joint on 2 piece drive shaft????
- O2 sensor light reset??
- Shifting problems
- 93 rodeo electrical
- Need help with rear wiper
- 92 rodeo codes 34 and 45
- Aftermarket light bar with off road lights
- Warn manual hubs
- 2001 Rodeo Security System
- Clicking noise, sounds like relay behind frontdash passesnger side
- weight of oil
- CV half shaft problem?
- electrical? 98 Rodeo wont start - coincidentally after fender replace
- airhorn install/fuse problem
- red light
- Equiped with cruise, but will not engage
- 92 rodeo how to remove oil sender unit
- Relaced Tranny now have another problem
- How do you drain the block?
- Wiper Fluid Stopped Working
- Low voltage at idle
- headlight adjustment
- high oil pressure then drops down when idle
- engine fuze
- is it hard to replace the valve cover gaskets on a 92 rodeo 3.1 liter with the carb
- Looking for a 1988-1995 Isuzu 4x4 pickup.
- 98 Rodeo Engine trouble again
- 98 rodeo Heater Core help
- Reduce power light
- Passenger side keyhole
- 1st gen Rodeo rear speakers!
- Is it a water pump failure?
- Help!!just Bought 99 Rodeo;car Shakes When I Accelerate
- Low Oil Pressure issues
- 1992 rodeo,2wd.. can a transmission be rebuilt?
- 93 rodeo stalling problem
- tail light and dash light trouble
- Isuzu Rodeo 94 engine problems
- CV Boot
- Wiper Motor \ Arm Disengaged
- T-Belt tensioner Where to buy
- Engine won't crank
- Both brake lights out
- Sylvania Silverstar Headlights
- '99 Rodeo standard front heights before torsion bar adjustment
- Starter Problems
- 1994 Passport Check trans light--help
- Popping noise when operating door
- Moonroof inoperable
- Fuel Sending Unit Part Number
- trooper wheels
- what does code P1406 for Rodeo 97 mean ?
- Backpresure on 98 Rodeo
- optima batteries
- wiper fluid problems
- CV Boot Replacement - '95 Rodeo
- 1992 radio wire color codes (odd colors)
- Torsion bar adjustment
- 97 rodeo fuel pump probs?? help!
- Timing Belt Cover / Tension pulley mount
- Aftermarket Alternators - You guys were right!
- changing fluids DUMB Questions
- 1994 electrical problem I think??????
- Rodeo Puzzle: No Start, only a click on ingnition
- 93 Isuzu Rodeo tailgate needed
- help...94 won't start when cold out.
- Rodeo jerks at highway speeds
- 2000 Rodeo Sport with P0128
- Rodeo Speakers & Audio
- U/S Light
- Whistling Sound
- fuel pump help
- broken fuel pump help
- 92 rodeo help
- virbation at highway speed
- Heater Core
- Sloshing sound
- SL Timing Belt
- Coolant Flow
- rodeo transmission noise
- Red transmission oil, Manual 5spd MUA ?
- Transfer Case threads stripped '05
- Engine help
- coolant temp.sensor location. 94 V6
- Stuck in 4WD
- looking for a crankshaft, 99 Rodeo
- electrical issues
- Gas gauge not working, go here for the fix!!!
- 97 Rodeo won't idle when hot
- check engine light
- Help
- Differential changing
- engine warms at idle...cools at speed.
- 98 Rodeo DLC location?
- recomend any sites?
- Need advice on valve cover/head gaskets-96 Rodeo
- Spare Oem Computer/ecm/ecu Brain???
- '95 Isuzu Rodeo Hood Problems
- 4WD won't engage, 99 Rodeo LS
- 2003 Isuzu Rodeo engine miss
- Brakes on Rodeo, 97
- What is the gear ratio
- Dash Light
- alternator
- CEL, Rough Running, Help!
- Help needed with a specific CEL code...
- Dummy lights stay on too long - 95 Rodeo
- sticking throttle cable
- CEL light and Fuel Gauge.
- 94 rodeo black smoke and shuddering problem
- Fan clutch adjustment.
- Thank you Amigo2
- Up Shift Light
- potential tranny problems?
- 2000 Rodeo Isuzu 4WD Front end
- Ticking or pinging??
- Place your vote:
- P1340 please...Kids vacation at risk
- intermitten wipers?
- Error code P0171/system too lean????
- Whining/whistling from under the hood: belt, pulley or timing tensioner
- 1998 Front Bumper.
- Muffler for '99
- 98 Izusu Instrument Lights are Out, HELP!
- Power windows stopped working
- Help My 01 Rodeo Is Falling Apart
- '99 Rodeo instrument lights
- 95 rodeo
- Help with whine noise
- Timing Belt Replacement...
- 96 Rodeo 3.2L V6 - Engine Picture
- Need a pair of grey cloth +98 headrests
- ABS Light
- can't remove the wire connector from headlight
- Oxygen Sensors
- Rear hatch Lock
- no power to fuel pump!! -'92 Rodeo 3.1L
- 98 rodeo thermostat
- Grease Zerts
- EGR cleaning supplement
- Need engine for 94 Passport
- Rear Defogger Problem
- Falls Dead When Put In Park
- 99 rodeo 4wd question
- Where can I get Red Crown Grease?
- my oil is dark, red or brown?
- I need all the help i can get
- 99 Rodeo Engine parts for sale
- i need help !
- EGR port as an indication of high oil cunsumption??
- Kenwood CD receiver KDC 6011
- White Smoke....Help
- blower motor
- Check engine light
- 1999 Passport Power Steering Pump Removal
- alternator
- wiring Q?
- 2.2 rodeo taking a while to start
- Hard up/dn shift, PRND lights display wrong gear...
- Anyone familiar with BG44k fuel cleaner?
- Speedometer Noise
- 3.2L V6 IS an interference engine
- Slight pinging noise
- 3.2 timing belt???
- Auxillary plug wiring.
- Transmission Problems
- 96 Passport dash light problems
- Where to get Lifters?!
- Heater problems
- 2.6 coolant drain plug
- Cigarette lighter fuse
- Loose belt ??
- Looking for Passport Parts!!
- Towed my new ride home with my ZU
