View Full Version : Rodeo/Passport
- fuel in with oil
- 2000 Rodeo Help? Left Me Walking
- 95 rodeo will not start
- wheel???
- hot 92 rodeo will not start
- Crankshaft seal replacement 97 Rodeo 3.2
- spark plug wires
- Slipping problem after clutch replacement
- Rattling Sound
- Boots
- power steering
- 1999 Rodeo 3.2 Crossover exhaust section
- Fan Clutch on 98 Rodeo
- EGR Valve - Clean or Replace?
- 2000 Rodeo Stalls When stopping
- Replacing Front Drive axle
- passenger side window off line
- engine revs up between changing gears
- 4 wheel drive
- gas hog!!!!!!!!!!!!!!!!!
- drain and refill coolant
- 97 Passport bogs out under acceleration
- 2000 Honda Passport - which oil
- Battery Alt Issue?
- Access to TSB's?
- Scratching/grinding Sound on acceleration
- Wiper Relay Number
- start up runs real rich, lots of fumes!
- V6 Rodeo Revs high on start.
- 99 Jimmy steering wheel radio controls
- 96 Rodeo no pwr to blower motor or switch
- Pain in the butt starter
- Trans No Go 95 4x4
- Price for replacement of Intake manifold gaskets
- 95 Rodeo Fuel Gauge
- Brakes locking up?
- 95 isuzu rodeo heater control light burned out
- Tire size
- Double Platinum or Iridium Sparkplugs?
- 98 Rodeo Resonating sound
- Passport needs service, isuzu or honda dealer?
- does o2 sensor brand matter??
- gas tank leek 92
- Inductive timing pickup...
- Water going into the crankcase
- bank 1 or 2??
- Help PO171 and PO172 Codes
- Fuel Trim Too Lean/cel
- 1997 Rodeo V6...is it a 3.2?
- Price on Timing Belt
- 94 3.2 rodeo getting to much fuel
- Alarm pin switch on the hood? +98?
- Code 0463 (fuel level sensor)
- anyone have thier old body lift instructions?????
- CD-Changer Mounting '96 Passport
- 96 rodeo cooling problems
- Egr Valve
- Need to vent!!
- Looking for a few ideas
- muffler question
- bad gas milage
- Rodeo Tranny Help
- 30,000 mile service prices
- Isuzu Survey:
- Am I having Transmission Problems???
- Sunroof!
- Rodeo stalls when idle and shut off engine
- Gas consumption
- belts
- Help with trouble codes please???
- Has anyone swap the engine??
- 94 rodeo wont start
- Wheel Size, esp. backspacing
- 97 Passport Pinging
- Adjusting loose steering on a 92 rodeo
- 99 Rodeo ABS Module Wiring/Connector
- timing question
- 99 Rodeo Shifting Hard
- tranny code
- 98 rodeo needs help. will not start.
- Rodeo Stutters Then "Check Trans" and "Cruise Control" Lights Come On...
- cel p1153 p1171 HELP!!!!!!
- 94 amigo wont start
- tranny error code 32
- 93 izusu rodeo wont start
- 92 rodeo 3 inch body lift....31s or 32s????
- Question
- cruise control fuse location??
- '94 Rodeo 3.2 not an interferance eng.
- Electical question
- Air Bag Light
- 97 Passport Just wont start
- oil in with spark plug
- 01 pasport fuel sender bad
- bad tranny
- trouble starting 98 Rodeo
- e-brake light
- 4L30E auto tranny filter
- Cold air at a stop
- Sudden Acceleration
- Tried everything ENGINE TICKS LOUDER
- fuel leak around vacuum canister
- Tranny Id
- 1996 Passport dipstick ?
- 92 rodeo how to remove front fender????
- Moab Isuzu event
- daytime running lights won't shut off
- 1999 Rodeo/Passport Fender**Please Help
- 4WD on 96 Passport does not engage
- rear abs and brake light on
- Attention Canadian shoppers
- 93 Rodeo UTE (australia, holden rodeo) lack of power
- P0300??????
- 1999 Isuzu Rodeo V6 Erratic Idle/Stalling/Hard Starting
- 95 passport timing belt removal
- 92 rodeo GAS LEAK......need HELP
- PCV location
- 2000 Honda Passport Valve Clatter
- 1993 Rodeo oxygen sensor light
- speedometer needle gone crazy
- engine cylinder out
- Gas Mileage
- 99 Rodeo 2WD V6 Check Trans light flashing
- 97 4 cyc. 5 speed rodeo
- car stereo
- Where to buy online parts for 99 rodeo?
- Ngk ?
- 97 Rodeo-Lift kit, or beef kit!!
- 94 rodeo
- 93' Rodeo Electrical???
- 92 Rodeo Heating Up
- 92 rodeo stuck, when 2wd car makes it out fine
- i'm looking to buy a 95 redeo but it has a few problems
- "94 Rodeo Valve - interference?
- 2002 Rodeo Sport Oxygen sensor bank locations?
- 91 Rodeo anti-lock brake/emergency light stuck on
- removing injector wires for IMG replacement
- Ok all, here's a 4x4 q.
- 96 Clutch to floor
- 2000 Passport EX want power seats
- 1997 Rodeo-Idle flucuation
- 1996 Acura LSX
- 2000 Rodeo Spark plug wires HOW!
- Trailer lights for 99 Passport
- 2002 Rodeo Sport leans to right
- Rear brake problem
- Fluctuating idle 99 Passport
- 93 Rodeo running rough
- 91 Rodeo Wont Start
- smoke @ startup
- And Also
- Tranny Clunk
- Tranny Problems on '93 Rodeo
- Shake at 50 MPH
- overheating, oil in plug tubes
- 97 rodeo check trans & check engine lights
- acting weird
- Muffler
- 99 Rodeo Brakes Grabbing
- 2001 rodeo 4-Wheel Drive Problems
- Common FAQ questions
- Running Boards/Nerf Bars/Step Bars
- floor jack?
- 97 5 speed 4 cycl.
- 97 4 cycl. rodeo
- 96 rodeo starter
- Has anyone installed a remote start on an 04 Rodeo?
- power ports are dead
- In Appreciation of our Foru, and it's policies
- Stuck key
- Fuel filter in 1993 4WD
- 1998 Drive Belt Idler Replaced
- Tiny Light
- 1999 Rodeo Rough Idle ?
- 2001 3.2L Engine pictures
- What Size Allen Bolts on 3.2L V6 Valve Covers?
- 1997 Rodeo-Transmission
- 96 3.2 Rodeo (Passport) fluid leak
- St. Charles Isuzu Live!
- Lug Nuts (aftermarket ones)
- location of 92 rodeo EGR valve
- Disable factory keyless entry
- 50k maintanance
- Hooking up iPod to stop indash cd changer (6disk) - 2000 rodeo
- looking for mirrors for 98 rodeo sport
- keyless entry reprograming
- cel
- Dash lights
- FAQ's for +98 Isuzu's:
- Welcome to the Forum: Read This FIRST!!
- Aftermarket Gauges
- Partial dash lights off
- Persistant fuel delivery problem on 99 Passport
- Code Reader
- speedometer
- Cheap Factory Isuzu Rodeo Air and Fuel Filter...NOW!
- How to change the Rear diffy Fluid? New Info!
- rear door speakers
- possibly buying 93 rodeo...what to look for???
- voltage reg or alternator
- kick panels
- Possible Tranny Slippage?
- 92 Rodeo will 31's fit????
- transmission problem??
- 91 rodeo v6 doa
- dash light
- timing belt install now wont start
- check engine light on isuzu rodeo 96, pls. help!
- Clicking Sound
- 1994 3.2l wont start/ stay running
- Loud knocking noise
- Wheels
- Clunking noise from the rear (but has new shocks!)
- do i have a interfarence engine {95.5 3.2 passport}
- loud knocking in the center
- 97 rodeo 4 wheel drive wont engage! help!
- Check engine light problems
- Air conditioner "cycling"
- tips 4 removing a 3.2 V6 DOHC on a 95.5
- 95.5 3.2 V6 DOHC removel
- Some obscure issues here.
- I think my timing belt went...I have a question
- Code P1153
- 93 rodeo...should i buy????
- How much oil
- 2000 Isuzu Rodeo doesn't start
- Brakes/Intake/ABS/Wheel Sensor/Turn Signal/Fuel Sending Unit
- engine light
- clock
- Intelligent Suspension
- Alternator Repair
- Help Removing crankshaft bolt on 3.2L
- OBD 2 Code PO 420
- Exhaust Flex Pipe
- Surging fast Idle when hot...
- Drive belt tensoner
- Alternator issue or not?
- boots
- Diff Lock or LSD on '99 2wd LS???
- Seeking Nominations for an Isuzu Moderator
- 98 Passport Won't Start
- 2000 LSE w/ ISC shocks
- Log of my first 60k of maintenance
- Need help filling transmission fluid
- In need of serious help with 96 Rodeo
- 1992 rodeo will not start--electrical?
- 1994 Rodeo turn signal problem
- 1994 Rodeo Keyless Entry - Can't buy aftermarket remote without FCCID #
- 95 Passport Wouldn't Start
