View Full Version : Rodeo/Passport
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23
  1. 98 Rodeo blown fuse
  2. 2000 Muffler on '99 Rodeo?
  3. Lifting a 2nd gen Rodeo
  4. what now? with transmission
  5. Squeaking noise
  6. Rear end bottoms out
  7. oxygen sensor code PO135 & misfire in #5
  8. fixed super loud knock 96 rodeo 3.2 v6 6vd1
  9. Synthetic Oil 125K on 3.2 Should I switch
  10. 2001 Rodeo Electrical Problems
  11. 93-97 Rear Bumper To Fit On A 91 Rodeo?
  12. Recently installed lift/ 2nd generation Rodeo
  13. starter replacment/passport/rodeo
  14. Rodeo 97 Burning Rubber Smell
  15. 3.1----3.2 Difference
  16. Isuzu engine wiring for sale
  17. 91 rodeo engine swap.
  18. Another knocking Question
  19. Egr Valve
  20. Another Mirror Question
  21. Outside Mirror- that special tool
  22. tow hooks
  23. head gasket leak
  24. rear end noise GONE!!
  25. 95.5 rodeo Rotten egg smell
  26. Check Engine 440
  27. clutch/transmission problem
  28. Help- outside Right mirror
  29. Window Regulator parts
  30. 93 Rodeo runs good cold stalls when warm..
  31. 1991 Isuzu Rodeo Check Engine Light
  32. Noisy lifters. Can you adjust ?
  33. 1996 Rodeo Won't Start
  34. opinions requested
  35. Fundamentals of Oxygen Sensor Life
  36. 98 rodeo rear end jerk-growl
  37. 95 rodeo 3.2 v6
  38. OEM alarm keyless entry information needed.
  39. O2 Sensor and CEL
  40. PCV valve location
  41. St Charles Isuzu
  42. where to get a good rebuilt transmission
  43. transmission woes! please help!
  44. 1993 Rodeo 4WD
  45. How do I remove & replace tranny accumulator cover?
  46. How to Remove ReplaceTranny Accumulator cover
  47. should blower fan work with key on???
  48. Isuzu Story ......
  49. transmission leaking, 99 3.2lt
  50. right side engine knock...suggestions
  51. isuzu to chevy
  52. Keyless Entry Questions
  53. 95 Rodeo Timing Belt
  54. Need Help...please!!!
  55. Need advise about the starter (98 Rodeo)
  56. Engine knock noise
  57. Passport hard starting running rough
  58. Electric fan not working.
  59. Coincidental battery death?
  60. New range sensor clean up write up +98:
  61. high revs during start
  62. Heater / AC Control Lighting
  63. 93 Rodeo pegs voltmeter, check trans light and tranny slips...
  64. Thieves!!!!!!!!!!!!!!
  65. 3.1L head bolts
  66. 2000 Rodeo A/C
  67. 98 Passport engine alternatives...
  68. Automati Trans Leak: Easy Fix
  69. fixing the fuel sending unit
  70. Isuzu Rodeo 2000 air compressor
  71. Towing 12ft Uhaul with a Passport
  72. Rod Bearings
  73. leanel Injectors
  74. More power window woes 1997 Rodeo
  75. Interesting EGR tube cleaning idea
  76. cold air intake for isuzu rodeo 2001
  77. Winter Mode
  78. "Hissing" sound under dash
  79. question about factory cd player
  80. Question about tailgate on 99 Rodeo
  81. 00' Rodeo Underneath tire carrier
  82. Rear tire carrier
  83. alternator, battery, or other problem?
  84. IMPORTANT...Isuzu FAQ Maintenance!!!
  85. hard starting rodeo
  86. Three Flywheels later
  87. Special on parts at St. Charles
  88. ABS Setup on 02' 2wd
  89. How to disable anti-theft alarm
  90. '00 Rodeo Air Conditioner not working
  91. Anti-sway bar and shocks
  92. Help identifying switches
  93. 98 Isuzu Coil Ground Location?
  94. 92 Rodeo AT issues
  95. Fuel pressure problems?
  96. Need an ASH TRAY, where to buy?
  97. I'm Losing It
  98. CLR Radiator
  99. CHECK THIS OUT shop manuals 99-02
  100. Replace Oil Pump
  101. OEM Brake part #'s? Are there different
  102. air conditioner problems 1994
  103. OEM Brakes - Metallic or ceramic??
  104. To Buy "with ticking" or not to buy
  105. Replaced Head Gasket,,,now won't start
  106. 1995.5 rodeo won't start?
  107. 94 passport ac clutch removal
  108. removing spare tire from underneath
  109. Timing belt replacement quection
  110. Where does this wire go!??! (98 Rodeo 2.2)
  111. 99 rodeo engine squeeling from the rear
  112. help with serp. belt installation on a 2k rodeo
  113. couple of 91 rodeo problems.
  114. lagging
  115. 1999 Rodeo Trailer Hitch???
  116. Now won't start
  117. 01 Rodeo ABS Light On
  118. 2001 faulty relay
  119. 1997 rodeo faq
  120. Temperature questions
  121. Shock recommendations?
  122. Slip Yolk
  123. 2000 rodeo rim size?
  124. auto transmission glitch
  125. 99 Honda Passport 3.2 V6 code # P0440
  126. IAT Sensor
  127. 1992 Isuzu Rodeo FOR SALE...4x4,5sp
  128. 93 Rodeo won't start
  129. 350 in a 95 rodeo
  130. 96 Rodeo Intake Manifold Gasket
  131. 97 Rodeo for sale
  132. transmission problem?
  133. 96 Rodeo hard idle
  134. 94 LS shocks/suspension
  135. '96 Rodeo Drivers Brake Light
  136. Help needed
  137. Rodeo for sale, maybe.
  138. Better shifting after a t-tech transmission flush
  139. 1999 rodeo v6 wont start no idle
  140. Rotor--Recommendation
  141. ARB bumper on Ebay:
  142. antenna
  143. sound system
  144. Bought 95.5 Rodeo, Some Questions
  145. 93 Rodeo 3.2 Won't start
  146. 1998 passport alarm
  147. stinky gas/egg smell, check engine light on...
  148. Loud ticking noise
  149. Hitch/Bikerack Questions
  150. More pep from a Standard 4-cyl?
  151. 93 Rodeo Engine Tap
  152. noise 92 Rodeo
  153. Light bulb on floor gear shift?
  154. 1993 rodeo 3.2 engine
  155. New user
  156. Weird heater thing.
  157. Accel. Problem
  158. Tranny
  159. 1991 Isuzu Rodeo Winter/Power mode
  160. hydraulic tensioner-where to get parts? no Isuzu dealer in my area how much is part a
  161. ABS kicking in on dry pavement?
  162. Cruise control
  163. catalytic converter
  164. checking transmission fluid
  165. timming belt changed -- drove a little (didn't run good) quit on me and won't start
  166. Rims
  167. Labor rates calculation
  168. Radiator Flush
  169. abs and brake light
  170. The Next Amigo?
  171. steering column
  172. 97 Rodeo blowing ECM fuse!!!
  173. DIY Tranny Flush
  174. how to tighten the rear view mirror on a 92 rodeo???
  175. Head Gasket Job
  176. Cleaning aluminum parts...
  177. intake and MPG
  178. tranny??
  179. 2000 Passport Rodeo trailer hitch question
  180. disc changer falling apart
  181. e-brake & battery light
  182. no heat
  183. rodeo 2001 fog light next step
  184. FYI: Installed Yakima rack w/Loadwarrior
  185. engine check, rough idle, hard start, dies
  186. How to get to AT fluid fill plug?
  187. 91-97 Owners w/THULE luggage rack
  188. dash lights
  189. performance chip?
  190. Yakahama roof rack. Anyone install
  191. Manual vs auto locking hubs
  192. Why the need for Fuel Injector Cleaners?
  193. "01 Rodeo Codes - What to do?
  194. how much to change timing belt
  195. 1995 Rodeo 4x4 Manual Trans
  196. Ebay: 96-97 Factory rebuild Alt:
  197. Need to replace lower ball joints, and tie rods??
  198. was keyless entry standard on 95.5 Passport?
  199. High Water temp, Cold Air From Heater
  200. New 95.5 Honda Passport owner needs advice on some things
  201. performance chip
  202. Bumper extension
  203. 4wd 2001 Rodeo
  204. abs/brake lights in dash (not just another usual post)
  205. little black box
  206. Muffler Questions
  207. rearerend problem
  208. Transmission - Rodeo or Passport???
  209. 93 transmission
  210. installation of fog light on rodeo 01
  211. 3.1L Overhaul
  212. Water in 98 rodeo bell housing
  213. question on 4wd isuzu rodeo 2001
  214. timing belt aligment
  215. store - storage - storing?
  216. 93 rodeo
  217. rear drum brakes
  218. Super 95.5 Rodeo . .
  219. Bad Fuel Sending Unit -> Check Engine??
  220. Fan Clutch Removal
  221. drive belt
  222. 2000 Rodeo blades stopped working
  223. API SM/GF4 oil versus SL/GF3 oil? . . .
  224. Passport heater fan not working
  225. A/C Fan doesnt tun on....
  226. Open Thermostat
  227. Heating
  228. Key Stuck! HELP
  229. Brake Lights
  230. 2002 Rodeo hesitates/jerks into gear
  231. Installing transmission fluid
  232. Installing transmission fluid
  233. What IS the tensioner pulley?
  234. 96 rodeo check engine light
  235. Bushing for Popping doors
  236. Brake Warning Indicator
  237. rodeo keyless remote
  238. 94 passport slow going into reverse?
  239. Speakers for a 93
  240. What year to buy
  241. squaling belts!!!!!!!!!!!
  242. 2nd Gen Skid Plates
  243. heavy duty alternator
  244. passport suspension
  245. Bolt size for OEM bumper
  246. How many miles do you have your Isuzu?
  247. egr valve
  248. water coming from exhaust
  249. Air conditioner problems
  250. Mountain driving w/auto Opinions?
