View Full Version : Rodeo | Passport | MU
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 23 24 25
  1. Engine Seized Up Over The Weekend
  2. Dealer says my 97 Rodeo has transmission slipping (a little)
  3. Hard start '92 v6 3.1L
  4. auto transmission not shifting
  5. Repair Center
  6. Correct Oil weight
  7. 99 isuzu rodeo fuel pump noise
  8. 2002 4 Cyl Rodeo runs hot
  9. 95 Rodeo first tune up
  10. 99 rodeo v6 build up
  11. 92 3.1L rodeo issues
  12. wiper relay replacement info posted
  13. What can i all do to my 91 Rodeo
  14. 2.6 engine swap with 5 speed tranny
  15. Rear window falls
  16. it IS still leaking
  17. 1995.5 Rodeo leaf spring bushings
  18. tailgate panel on an Isuzu Rodeo 2000
  19. Valve timing
  20. Should i buy a `98 Passport 4WD????
  21. '99 Rodeo fan stopped working
  22. Check engine light... trouble code
  23. Someone had some auto-lock hubs.....
  24. Building HP in an NA H22
  25. Brake Light Issues
  26. Engine surges then dies
  27. rear flanged axle.
  28. need help with missfire or jerking with rodeo
  29. ABS light
  30. isuzu manual inside:
  31. 95.5 rodeo which engine?
  32. Front shock bolt.
  33. Mpg
  34. How do you tighten the rear lift glass
  35. Strange behavior at idle
  36. oxygen sensors
  37. electric windows
  38. Honda Passport/Isuzu Rodeo 3.2V6
  39. Roof Rack and headliner
  40. steering problem
  41. HELP! i have a ticking noise that won't stop 96' Rodeo
  42. "power drive" button on 94 ls
  43. 98 Rodeo Startup Problem
  44. Alternator? Belt?
  45. 99 isuzu rodeo starting prob
  46. Headgasket oil leak??
  47. Rodeo transfer/differential case fluid
  48. Electrical short 1993 3.2L
  49. alternator whine, belt squeal
  50. Rodeo still leaking coolant
  51. 97 rodeo 4wd problem
  52. 97 Rodeo Steering Jerking
  53. Clutch gone, sell it or scrap it?
  54. Power button 01 Rodeo?
  55. Idle speed high! Help!
  56. where is the defogger relay?
  57. Anyone else having serpentine belt pulley issues in 98+ Rodeos?
  58. 99 transmission upgrade
  59. Red thing under the hood next to the firewall?
  60. questions about using 2wd low....
  61. Truck making odd sound (94-Rodeo)
  62. Counterfeit Rodeo?!?!
  63. 95.5 3.2 4wd knock/timing? issues
  64. blinking U/S light
  65. '94 passport wont start
  66. 96 egr valve
  67. Engine fan making unbelievable noise
  68. 97 Rodeo w/ 15" wheel offset
  69. Major '00 LS 4WD problem
  70. oxygen sensor question?
  71. egr valve cleaning
  72. 1993 rodeo vent glass..
  73. Sending unit confusion- 2000
  74. Air-Bag Light stay on.
  75. 98 Rodeo/Passport abs light
  76. Front axle mounting bracket
  77. 99 rodeo 2wd auto only reverse unless i put it into winter mode
  78. 1998 Isuzu Rodeo Tranny Problem
  79. 20" wheels and tire size
  80. Junkyard lift?
  81. rear window wiper
  82. Having hard time with reverse.
  83. Starter Motor
  84. Radio Wiring Harness
  85. Power Steering High Pressure Hose
  86. a prank that has a great outcome
  87. CEL keeping me from getting my inspection
  88. thermostat check after the water pump
  89. water pump
  90. Thinking about water pump and t-belt change?
  91. separating 'U' joint from front axle assembly
  92. SERP belt issue
  93. 94 rodeo wheel rubbing rotor
  94. window regulator
  95. crank pulley bolt size?
  96. Locktronics issue... I think
  97. Pre-98 owners, highly recommend
  98. Transmission Cooler Lines
  99. EGR Valve - ok to use carb cleaner on it
  100. CEL light on 99 rodeo
  101. Cleaning EGR - do I need to change
  102. Overheated and "wouldn't go"
  103. Testing fuel pressure
  104. Is there no front diffy in 2WD?
  105. Knocking
  106. 2002 passport vibration problem
  107. Where to buy parts??
  108. Splash Guard Removal
  109. Alloy wheels to fit a '96 Rodeo
  110. 99 Dash bulbs
  111. noob Rodeo owner
  112. Reverse
  113. 94 rodeo 4wd
  114. I am back
  115. Why can't I get these bolts started???
  116. 99 rodeo 2wd auto only reverse 6cyl
  117. More timing belt questions
  118. 94 Rodeo Tranny Swap
  119. 4 wheel mode pulling to the right.
  120. 4 tires changed, 4wd runs rough
  121. 99 Rodeo LS - Faulty Transmission Mode Switch??
  122. Dash Kits
  123. Rodeo 97 Oscillating noise: front center to right side
  124. Oil smell and a brake question
  125. 98 Rodeo has no dash lights
  126. diff. fluid change question
  127. Alternator problems?
  128. Problems with Gas Pedal on 95 Honda Passport
  129. 1993 Rodeo speedometer gone crazy
  130. body mount?
  131. how to check service engine light...
  132. Gas gauge
  133. Rodeo Enging Revving
  134. Help with nut size!
  135. Cause more problems cleaning EGR ?
  136. Transmission and Intermittent Check Engine Light
  137. placement options...where to put the stuff??
  138. 99 Rodeo Reset ABS light?
  139. WATCH closely -
  140. Isuzu Rodeo Manual
  141. Cant get PCV valve out of 01
  142. High-pitched squeal from power lock system
  143. Flashing CEL, New Cat. Conv., EGR, Denso Iridium Plugs
  144. 97 rodeo vibration
  145. Removing crankshaft pulley on '96 Rodeo 3.2
  146. Wheres EGR valve on 01 rodeo?
  147. 2004 windshield wipers
  148. Rodeo02 - Lesson learned, help w/ P0401
  149. 2005 Xterra - what's your impression?
  150. Removing front grill on 01 rodeo?
  151. Help! Where's the oil drain plug?
  152. Are all 4 O2 sensors the same?
  153. HELP with 1996 roof rack installation
  154. Here it is!! Pics, too!
  155. O2 sensors? Which Brand?
  156. 93 rodeo starter
  157. Doors make popping noise
  158. 1996 Rodeo Engine Problem
  159. Battery Post question
  160. Replaced plugs but still runs slugish
  161. Hard start after fuel filter replacement?
  162. Rear Glass Studs 98+
  163. ABS Technical Question 98+
  164. Replacing fuel filter
  165. removing fuel rail
  166. P0430 ('99 Rodeo V6) Strong gas smell
  167. jobs in progress - please look for entertainment, ?s
  168. 1996 Rodeo 3.2 loud knock at low rpm
  169. Steering Clunk
  170. Changing Rear windshield wiper
  171. Installing brakes question
  172. 94 passport ac/alt.electrical
  173. 01 Rodeo brake question/problem
  174. Is my Rodeo an early or late '97?
  175. 97 Isuzu Rodeo won't start, just clicks
  176. new coolant leak - help ID source please!
  177. After Market PCV valves
  178. Can someone please check their voltmeter?
  179. Can someone check their Voltmeter .....
  180. Pre-98 owners: What size of tire...
  181. accelerator pause?
  182. FS: Bridgestone Revo's 1yr/9k
  183. warranty ifo needed?
  184. Charging Problems
  185. 1999 rodeo automatic transmission
  186. 92 3.1 cranks ALOT before starting....
  187. Years, engine, mileage
  188. Honda Pasport missing in 2 cylinders
  189. Shock Replacement
  190. Difficulty of 01 rodeo plug replacement
  191. 99 rodeo wont start
  192. 94 LS stock wheels
  193. Missing Surging please help....
  194. Will 15x7 or 15x7.5 wheels off a 94
  195. '98 Rodeo trans holds 1st and 2nd gear when cold
  196. creaking noise
  197. CEL Code P0442
  198. Front Brake Pads Wont Fit!!!
  199. Pre 1998 valvetrain, 1998+ #1 rod bearing..
  200. EGR Cleaning
  201. new to me 2000 rodeo ls
  202. 4wd max speed
  203. Radio harness plug needed
  204. Need help getting rid of annoying squeeking
  205. rear brakes
  206. dead battery
  207. jack handle and tire tool
  208. 99 4x4 abs and other problems
  209. Refurb
  210. '96 3.2L V-6 Rodeo - Overheating Fixed!!!
  211. window controls-96 rodeo 3.2 v6
  212. fuel dash light-96 rodeo 3.2 v6
  213. NEW EGR cleaning article:
  214. How do i get a door for 98 izuzu rodeo
  215. towing for 1996 rodeo
  216. CV joint problems or steering?
  217. getting ready to change clutch in 92 rodeo...
  218. 2002 Amigo Parts for sale
  219. Very low idle when comming to stop
  220. 96 rodeo-high idle problems
  221. 1994 Rodeo LS 4wd hub/rotor separation
  222. 1996 idling issues
  223. 95 Rodeo Upper Timing Cover Removel
  224. 96 3.2L Knock Sensor
  225. 2000 Rodeo Speed Sensor/Speedometer
  226. rear brakes
  227. Procedure to remove cargo area interior panels?
  228. Need input on service/maintenance??
  229. Poll: What color is yours?
  230. 1998 Rodeo Shifting Issues
  231. What is good compression pressure? And more??
  232. Isuzu Rodeo 99 Tail Lights problems
  233. FS: 2000 Rodeo LS (Texas)
  234. Help!!! Check Engine Light Blinking
  235. Rodeo rearview mirror with dimming
  236. scan guage
  237. Coolant leak help!!!!
  238. 93 V6, 3.2L engine, cast iron or alum. heads
  239. 4L30E help
  240. Can Rodeo brake pedal distance be changed?
  241. It just got serious....
  242. Please help me, Engine Swap 3.2l
  243. Quirky Electircal issues
  244. ('98 Rodeo-Battery & Brake Light on > 2400 RPM
  245. Good Price?
  246. Help Losing Power!? Alternator issues maybe?
  247. Sea Foam Question
  248. 93 A/c problems
  249. 93 A/c problems
  250. very slow acceleration
