View Full Version : Rodeo/Passport
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 23
  1. 1999 Isuzu rodeo oil pressue light
  2. Electrical problem help!
  3. 4x4 Indicator Light
  4. Rotella - 1st Impression @ 400 miles
  5. Fuel Sending Unit Fixed
  6. New tricks for an old rodeo
  7. Idle problems
  8. a/c and cooling fans
  9. Amigo-2K - found Rotella
  10. Key stuck in ignition switch
  11. 01 Rodeo That I Just Bought
  12. couple problems with 92 rodeo
  13. How much for a 98 rodeo, 2.2L
  14. 01 Rodeo Issues
  15. bad oil pressure sensor? help!
  16. O2 sensor question (02 passport)
  17. How many miles have you gone without a timing belt replacement?
  18. Cel
  19. Recalls on my 1998 isuzu rodeo.
  20. super/turbo charger
  21. 96 Rodeo starts sometimes, died at a stoplight
  22. ABS Light on
  23. 93 Auto Transmission question
  24. Engines for 97 Passport 3.2liter
  25. rear collision-alignment/tranny problems
  26. is my isuzu really a isuzu
  27. 18 MPG HWY & 200 MPT (tank) City
  28. Free after rebate Chevron Techron Conc:
  29. 98 rodeo not starting :(
  30. Engine Swaps For A 91 Rodeo?
  31. "Tickers" - if you knew then, what ....
  32. Rodeo Tranny problems
  33. Piston Slap?? Can anyone describe
  34. '93 Rodeo 4x4 front axle rebuild?
  35. cabin air filter?
  36. Rear rotors
  37. door lens cover
  38. Diagnosis complete = sticky/stuck lifter
  39. Isuzu assesories
  40. electrical problems to 2001 Rodeo?
  41. limp
  42. Flip Kit Questions
  43. Opinion: 5w-30 High Mileage oil?
  44. Multiple problems with my Isuzu Rode 1993(V6) ....please help
  45. upshift and cruise control problem
  46. Can i use a spark plug ...
  47. Should I Buy a Used 2003 Rodeo???
  48. Brake noise
  49. Water to clean carbon
  50. transmission stuck in Limp Mode (safe mode)
  51. broken fuel gauge??? please help me!!!
  52. Very poor acceleration
  53. cold start-up issues
  54. 96 Rodeo Noise
  55. drive by wire
  56. IS anyone having problems with oil burning in 2000 rodeo?
  57. TickingNoise tensioner or lifter
  58. rear axle limited slip????
  59. Spark Plug Tube - Oil Accumulation
  60. Check Enging Light
  61. 96 rodeo-no horn, no right turn signal
  62. Idle dropping really low
  63. Wanted - 3.2 Engine for 99 Rodeo
  64. Rodeo Overheating
  65. 120K maintinence
  66. spare tire cover ?
  67. Why is my Rodeo Holding back?
  68. Valet Keys?
  69. My Lift Gate Lock Doesn't lock...
  70. OBD Code P0304
  71. What am I hearing? Tensioner??
  72. Looking to jack up my Rodeo 4-6"! Any ideas at low cost?
  73. 97 Passport power loss
  74. Burning Oil like there's no tomorrow
  75. grinding sound
  76. Very high Idle 99 Passport
  77. Is it possible to fix the Window Switch???
  78. Poll: What oil filter are U running?
  79. Oil Pressure drops to Zero at idle
  80. OEM oil filter - who's it made by?
  81. Opinions: Puralator Premium oil filter?
  82. Passport oil pressure
  83. Battery & ABS Lights flashing-egines dies at times
  84. Suspension Lift 98 Rodeo
  85. Trailer Wiring Harness
  86. a/c on 92 rodeo
  87. factory door remotes
  88. What is the stock battery? '00 Rodeo
  89. More power
  90. 2000 Honda Passport Low Fuel Light - Idle Rough
  91. 2001 Rodeo Problem
  92. Shift interlock solenoid
  93. Oil Pressure Reads Low when truck is warm?
  94. thump during wheel spin
  95. second muffler and benefits
  96. 1995 Isuzu Rodeo Hesitation
  97. Tranny fluid with oil? How much?
  98. Swap a 3.2L V6 for a diesel?
  99. 97 3.2L auto transmission troubles
  100. 01rodeo-clock light out
  101. engine swap
  102. 95 Rodeo Steering Wheel Shimmy
  103. ticking noise... not timing belt
  104. red light on dash
  105. checking timing belt / campaign stickers
  106. tick tick tick
  107. Check engine light comes on when fuel gets low
  108. 94 Delta 88 /Electrical Problem Found
  109. 2000 Rodeo ( ISC ) Suspension module / HELP
  110. Rodeo 3.2L SOHC valve train noise
  111. pulling ac blower 97 passport
  112. Automatic Transmission Problem
  113. taillight/dashlight problems
  114. 97 3.2L Alternator/Electrical issues
  115. FOR SALE: 1998 Isuzu Rodeo - HOUSTON TX
  116. first oil analysis after 12K with synthetic
  117. New Exhaust
  118. 01 Rodeo Sport ABS problem
  119. 99 rodeo won't start, have power !
  120. 1994 passport manual transmission removal
  121. Any ideas why??
  122. how to check tranny fluid in a 97 3.2L auto?
  123. Setting Valve Timing
  124. 2000 Rodeo deterent alarm
  125. '97 Rodeo Questions
  126. 1993 Rodeo 3.2L ist it close interference?
  127. Can I put a radio from a 2000 rodeo into a 1999?
  128. fixing head gaskets - replacing engine (huh?!)
  129. 2000 Honda Passport Spark PLugs?
  130. CEL Code 402 EGR Flow Excessive ??
  131. transmission model # ???
  132. Hydraulic clutch wowes
  133. ebay: hidden subwoofer
  134. A/C Cold sometimes.....
  135. Transmission Issues
  136. Battery Tray
  137. Rear Axle
  138. changing water pump
  139. What range is the Power band?
  140. rodeo won't turn over
  141. fluid transfer pump?
  142. rodeo price
  143. Questions???????
  144. Rattle from passenger side dash
  145. 2001 Rodeo LS Brake Question
  146. 2002 Rodeo Sport leaking Tranny Fluid?
  147. 2001 blower motor
  148. isuzu rodeo wiper intermittent problem - delay module
  149. tranny issue...need help!!!
  150. Cam Shaft Sensor
  151. switch 3.2l to 4.3l gm
  152. Junk Yard Parts
  153. A/C Fan
  154. 97 Rodeo trailer wiring problems
  155. Multitude of issues (possibly engine, tranny, other?)
  156. Rear transmission seal
  157. Transmission Wooes.
  158. max tire size for 95 rodeo
  159. Brake Rotors???
  160. 2002 Rodeo Sport new shocks KYB
  161. cylinder numbers
  162. Automatic Transmission Flush- Safe for High Mileage?
  163. tow package
  164. Can't find the oil dip stick?
  165. 2000 Honda Passport Intermittent Wiper Problem
  166. Spare tire cover -I found one cheap
  167. Cargo ACC Outlet
  168. A/C intermittently not kicking in
  169. CEL solid and flashing
  170. 2001 Rodeo stalls when cold....Help!!!
  171. 2001 Rodeo V6 wants to stall when starting cold
  172. 01 Rodeo Deadly slow...
  173. FYI - Akebono ceramic brakes
  174. 4L30E loves a fresh drink!
  175. How much to replace cv joints
  176. '97 power steering fluid
  177. time and cost estimate for lash adjusters
  178. bad alternator
  179. Stick shift Question
  180. Keyless Remote for '01 Rodeo
  181. Another happy Isuzu Owner
  182. Spare Tire Rack Adjustment
  183. EGR How hard to move should pintle be?
  184. Intermittant loss of power problem
  185. 2002 Rodeo trany leak
  186. sport rear seat removal/question
  187. 99 Rodeo rough idle - IMG already replaced
  188. Altezza Lights for 2000 Rodeo
  189. Rodeo won't start
  190. Hard Starting
  191. Excessive cranking...then fumes when started..
  192. 94 EX 4x4, tranny code 61 ??
  193. Hard shifting 96
  194. tapping noise
  195. STP gas treatment
  196. the error 'Codes'
  197. Major Transmission Problems!
  198. no turn signals/4 ways
  199. 1999 rodeo engine stalling while stopping
  200. 1993 Rodeo LS 2wd FOR SALE
  201. I.M. Gasket Upper or Lower?
  202. always in limp mode... any suggestions?
  203. Shity spark plugs cause O2 sensor code??
  204. the '99 gave a loud bang
  205. Ooops- door panel removal
  206. What kind of tires are you running?
  207. shipped Replacement mirror- didnt fit
  208. 2002 Keyless Remote FCC ID#
  209. Excessive Cranking, Engine Failure
  210. Early Rodeo Electric Windows
  211. Problem Bleeding Clutch System in 95 Isuzu Rodeo
  212. Rearend Noises
  213. Exaust Manifold Removal.....
  214. Just what we need ... another Passport bulletin
  215. keyless entry remote number
  216. Car Dying While I Am Driving It Help Asap!!!
  217. Ping-a-ling
  218. Painting "Chrome" Bumper End Caps?
  219. Problems after alternator install
  220. Oxygen sensor and EGR vlave
  221. engine support brackets
  222. Fuel Sending Unit, 1999 Rodeo, 4 Cyl, 2.2
  223. Flashing 4wd indicator light
  224. 1999 Spare Tire Cover?
  225. tranny problems
  226. Warranty Question
  227. Air mass meter/air flow meter/dishonest mechanic
  228. Confused about my 98 rodeo
  229. Security system
  230. Towing Long Distance?
  231. Website for Rodeo Parts
  232. Vacuum Hose Diagram????
  233. The Dealer is fishy
  234. Rodeo works without keys
  235. rattling in rear of 92 rodeo
  236. 95 Rodeo - condenser fan question
  237. Tranny fluid replace
  238. starter brand
  239. Head gasket replacement
  240. Rodeo under the knife:
  241. suggested preventive work on rodeo 2001 v6 3.2
  242. Skid Plates
  243. Motor pinging
  244. 98 Rodeo blown fuse
  245. 2000 Muffler on '99 Rodeo?
  246. Lifting a 2nd gen Rodeo
  247. what now? with transmission
  248. Squeaking noise
  249. Rear end bottoms out
  250. oxygen sensor code PO135 & misfire in #5
