View Full Version : Rodeo | Passport | MU
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25
  1. 94 Rodeo TOO MUCH FUEL (rodeo02 and others!)
  2. warranty..yes? no? maybe...
  3. P1391 and P1392 CEL
  4. Water Pump/Timing Belt?
  5. Stalling...CEL
  6. 95 Rodeo 3.2 Realigning timing marks
  7. Super Charged Axiom video:
  8. PCV question
  9. Abs!!!!!!!!!!!!!!!!!!!!
  10. wiper linkage: help
  11. Brand New 2004?
  12. Front turn signal on 95 Rodeo
  13. Where are timing marks on 95 rodeo 3.2l??
  14. Probably gonna lose the Rodeo......
  15. Cargo Panel
  16. Alternator does not charge
  17. rear caliper overhaul kit
  18. a rose, is a rose, is a rose...
  19. i want a new alternator
  20. loss of engine power uphill
  21. oh come on!...CEL again..
  22. Rodeo 99 LS 4x4 for sale
  23. For Sale 1994 Isuzu Rodeo
  24. 01 Rodeo Front Wheels Buckle under tight turns
  25. 95 rodeo 3.2l help
  26. 2001 Rodeo starting problems - linked to Alarm?
  27. Fixing Rust
  28. will it fit??
  29. Leaky transmission
  30. 94 4x4 rear axle
  31. Opinions on a 00 Rodeo grill modification
  32. Spark Plug Oil
  33. egr
  34. sticky rear caliper pin causing squeal?
  35. For you oil fanatics....
  36. Almost lost the Rodeo last night....
  37. changing Timing belt
  38. Please Help Anti-freeze Leak!
  39. 2000 rodeo 4x4 rear axle.
  40. Where is the Starter? 98 Rodeo
  41. 2002 Isuzu Rodeo Tailgate Problems
  42. Clutch questions!!
  43. how hard is it? really....
  44. how hard is it? really....
  45. 4WD Noise + Ignition Problem
  46. broken emergency brake
  47. Nightmare screeching sound
  48. lifting 1994 rodeo
  49. Seatbelt ideas for center console? Have
  50. Cleaning EGR on 95 3.2L V6
  51. Anyone Replace Tailpipe - have brand suggestions?
  52. synthetics, synthetics, everywhere
  53. radiator (auxillary) fan
  54. radiator (auxillary) fan
  55. radiator (auxillary) fan
  56. went trough a pond
  57. Egr Valve - How Does Isuzu Mech. Fix? * Check Engine Light *
  58. water pump
  59. 1997 rodeo w/ check engine light
  60. Start Attempt Kills Power
  61. to you all with fuel gauge issues
  62. Brakes
  63. what fuse takes care of......
  64. center (carrier) bearing
  65. ABS brake light
  66. a/c comressor so hot
  67. Rims off a 2002 trooper
  68. rear differential size
  69. Rodeo Fuel Injector Air Leak
  70. front and rear differential
  71. Front differential fluid changeout?
  72. Brakes grabbing/slipping or shuddering
  73. Oh great, now what have I done to this Rodeo?
  74. blue print rodeo/passport picture-- any?
  75. front mounted trailer hitch
  76. Air bag sensors
  77. ABS Help
  78. Intermittent Wipers not working
  79. Front wheel make noise
  80. Rear end advice
  81. egr code plus another ?
  82. MU/Rodeo auto trans ratio's
  83. Curious - where's the torque band
  84. 3" body lift on 96 honda passport auto
  85. 95 3.2 rough during acceleration and no power
  86. window wiper fluid lever
  87. 3.2 engine seized
  88. WOW! Cool, emergency brake REALLY
  89. Can't open rear door
  90. brake light on and battery light on and no heat
  91. Fuel pressure specs for 2000 Rodeo 3.2L
  92. 1993 4wd LS 3.1L 5spd transmission stuck in gear H_E_L_P !
  93. 00' Rodeo engine knock under load
  94. Ran out of Gas!!!
  95. 1998 rodeo 5spd 4x4 not working
  96. intake manifold gasket
  97. off road lighting
  98. Transmission down shifts by its self
  99. Rear Disc Brakes
  100. Part of PVC grommet broke and fell in!!
  101. RE: Rattle (exhaust??)........
  102. so, i'm a girl....
  103. What is the best/worst MPG you have recorded in your Isuzu
  104. EGR code, could it mean bad IMG
  105. front axle replacement
  106. white smoke...loss of power
  107. alternator wiring
  108. Suggestions for a problem??
  109. Torque spec for spark plugs?
  110. 97 V6 Passport Belt Changes
  111. fuel filter question
  112. P0401/EGR CEL code is back??
  113. 2002 ABS Light, where do I start?
  114. 2002 ABS Light, where do I start?
  115. Ticking only when cold
  116. exhaust very hot
  117. Emergency break problems.
  118. 96 rodeo headlamp replacement
  119. Rattle(exhaust???) under Passport during acceleration....
  120. Po107
  121. 94 isuzu rodeo ignition
  122. mercury egr valve
  123. 4wd gets stuck
  124. EGR Valve Replacement 1999 Rodeo Isuzu
  125. Rodeo' hybrid twin?
  126. 2000 Rodeo shimmy in steering wheel @ 45-75 mph
  127. What is this connector?
  128. Rodeo 4wd Indicator Light
  129. dream project
  130. rear glass hatch won't stay up in winter - Rodeo 97
  131. 95 Isuzu Rodeo Won't Start
  132. CEL once in a while
  133. 5spd to auto swap?
  134. overhead console
  135. Isuzu in the news:
  136. Fuel Problems/Studdering/Hesitation
  137. what is the diff between 00 an 99 rodeo interior
  138. Install Instructions for Rodeo Glow Gauges
  139. Problem up front
  140. Speaker Problem???
  141. I spin out like crazy on ice in my 92
  142. I spin out like crazy on ice in my 92
  143. code 1627&463 PLEASE HELP
  144. 00' Rodeo Creaks, rattles and clunks in COLD weather
  145. rodeo wont start after new alternator,starter,batt
  146. Heat range of spark plug
  147. 1995 Passport window rattle
  148. Cruise control fuse on 95 passport
  149. Annoying squeak under the hood
  150. 99' amigo coolant disappears?????
  151. Canister puge valve number
  152. 99 Rodeo wont start.
  153. Slipping clutch?
  154. must sell my 02' Rodeo Sport
  155. Car Trouble, Need Help???
  156. Oil from K&N Air filter
  157. 98 suspension Qs
  158. adding guages
  159. No cup holders, no arm rest
  160. Isuzu engines and transmission
  161. Knocking, ticking not the time belt or tensior
  162. Mobil 1 Stopped the Ticking (For Now...)
  163. Rodeo won't start
  164. power steering return line?
  165. Bizarre Alarm Problem on '99 Rodeo
  166. CEL codes P0401 and P0463
  167. it's a 4x4, but what kind?
  168. where did you learn?
  169. CEL came on
  170. In-line transmission filter
  171. 92 rodeo rear end clunk...
  172. CEL & Check trans light are on
  173. Sloshing Fluid - 02 Isuzu Rodeo LS 4wd
  174. P1404
  175. 96 Isuzu wont start right away
  176. Transmission filter question
  177. T5 Manual Tranny swap
  178. 01 rodeo remote question
  179. winter button
  180. Honda Fuel Gauge Malfunctioning?
  181. ABS Box Hangs UP?
  182. transmission cooler
  183. what years will interchange with my 95.5?
  184. WinALDL
  185. Replacing dash lights help needed
  186. No 4WD on rodeo.
  187. Bucking like a bronco
  188. Installing a new wiper linkage
  189. 2000 rodeo
  190. 95 Rodeo - Low heat, hi idle
  191. starter ???
  192. problem with heating in 1995 Isuzu Rodeo
  193. timing belt tensioner bearing and Idler replacement
  194. 2000 Rodeo Auto Trans service question
  195. Installing Rear Axle.
  196. 97 passport 4x4 issues
  197. Rear Winshield Wiper
  198. 95 Rodeo read Anti-Lock solution (ABS)
  199. Crankshaft Pulley Removal 1994 Rodeo 3.2 liter
  200. '01 Rodeo V6 gas guage acting funny
  201. light bar
  202. Governor setting?
  203. ion sensor code P1312
  204. One thing leads to another.....
  205. 01' rodeo tps (throttle position sensor)
  206. Front Hub nut tool
  207. '98 Rodeo starting/bucking problems.
  208. Left Turn Signal
  209. Banging when turning in 4wd
  210. Difference between 1995.5 and 1996?
  211. 97' w/80,000, for $4000, is this a good deal?
  212. Belt Tensioner
  213. Wiper Linkage shot
  214. 92 Rodeo
  215. How long should IMG last?
  216. Energy Suspension Sway Bar Bushing
  217. 96 rodeo hetaer quits on right turns...really!
  218. Timing belt question??
  219. Caps on Roof
  220. Manual door locks fell out?
  221. 99 Amigo turns but does not start
  222. Repairing power windows
  223. 96 Runs but won't idel
  224. need help Engine Stalling Problem
  225. No Clutch pedal tension
  226. Stabilizer Bar to Control Arm Linkage
  227. solenoid valve
  228. noise from 99 Rodeo
  229. 97 rodeo spindle bearing
  230. Ignition switch will not return and release key
  231. O2 sensor
  232. mystery!
  233. Power Steering Problem
  234. help 96 3.2 rodeo crankshaft pulley bolt will not come off!
  235. the $570 repair
  236. wont go in reverse sometimes
  237. Isuzu FAQ Maintenance
  238. Cel...yay
  239. Well, I got my auto-lock hubs working properly again.
  240. confirm my thoughts?
  241. Factory 12 Disc CD changer
  242. installing lug nuts
  243. Whining/Wheezing sound on acceleration + driver side winshield wiper fluid
  244. 97 Rodeo: Runs rough
  245. P0405? Cel
  246. 100,000 mile service ideas
  247. gotta love the stock 6 disc cd player...
  248. Transfer Shifter dis-engages @ 45 mph
  249. anti seize vs threadlocker
  250. Instant CEL problems
