View Full Version : Rodeo/Passport
- P1275
- Rear tire traction/spinning
- bagged isuzu pickup?
- Ebay: +98 Coils:
- Looking for Front Bumper Options
- Rodeo 3.2L DOHC
- Battery/Alternator??
- Found an EXCELLENT engine cleaner ...
- gear shift sticks
- stripped spark plug
- noise from middle of truck
- New Engine? Well used I guess
- caliper bolts
- finicky cold starts
- getting serious about valve cover and timing
- tail light question
- **1996** Rodeo Keyless Entry
- Computer upgrade: Jet Performance Products
- Rodeo Remote Control Programming
- Headlight/tail light issue
- What's your gas mileage on Rodeo 4WD 3.2?
- aftermarket exhaust?
- Spare tire under cargo area instead of behind the vehicle
- Gas Questions
- Weird radiator leak
- Temperature Gauge roller-coaster
- SELLING my Rodeo ad on autotrader.com
- Exhaust leak
- 99 Rodeo, need new engine
- alternator ideas?
- new stereo install...
- 94 rodeo with ticking
- Accumulator cover replacement
- how to replace accumulator cover on rodeo auto?
- '02 Rodeo 2WD V6 o2 sensor and leaky trans
- engine dress up kits?
- Manual tranny? Clue me in on
- rear hatch lock release
- horn doesn't work and lights get bright and dim
- wide tires?
- 97' Rodeo confused computer?
- Shot A/C Compressor: 99 Rodeo
- A/C compressor
- 2000 Rodeo 3.2 power problems
- BIG BIG problem with my Rodeo
- new cleaning method for EGR's
- A/C Magnetic Clutch Pulley Assembly Repair
- exhaust options
- Non-OEM horn for Rodeo?
- Sound
- Wiper arm mounting
- Engine
- PCV Location
- ABS Sensor Testing
- airy tick sound
- 2000 Rodeo 4WD Tranny problem
- 1995 Rodeo 3.2L knock
- 2000 Rodeo 4x4 - slipping out of gear
- 99 Rodeo 5 speed manual: Problems shifting
- brake lights out when lights are on, but work fine when lights are off?
- rough running rodeo
- ABS Sensor Removal
- error code how to?
- idleing problems
- anyone have p/n for rancho shocks???
- 1997 Rodeo 4 Cyc Ticking
- interchangeabilty
- 2000 rodeo rotor replacement
- 1997 rodeo Alternator
- what type of engine?
- Plug change
- Passport with erratic problems
- 2001 Rodeo, Good Choice
- 99 Rodeo having problems shifting gears
- reverse light hook up
- 99 Rodeo Giving Me the Blues
- Electrical problems with 2001 Rodeo
- What exactly is a flip kit????
- Great at 750 RPM idle, lacks power with gas
- 97 Rodeo 4cycl temperature gauge
- Hesitation and poping at start up
- Help Selling My Rodeo
- 1999 and 2000 rodeo grill question
- Battery change caused ABS light
- Electrical problems. Does this sound like a short to you?
- dealership problems again help!!
- 1992 Rodeo TBI problems
- 1996 Passport Parking brake woes
- Gas fumes 2000 3.2
- Needed 1999 Isuzu Rodeo Manual Please
- Tranny contoller codes...
- Rodeo models that do not connect to a computer for diagnosis
- timing head scratcher
- Need help finding a lift kit for 94 passport???
- sending unit ?
- anyone ever tried....?
- Fault codes P1391 & P1406
- A/C blowing fuse
- Removing Cooling Fan Assembly
- Goes sideways in highway bumps, Help!
- Programming Rodeo PCM
- 92 Rodeo OIL PAN LEAKING....need help!!!
- Stuck in winter mode
- Fuel Pump 94 Rodeo
- 99 V6 engine shot
- Rad fan ?
- 91' Rodeo 3.1L-New ECM or Not/or relay ???
- 98 Isuzu Rodeo Needs Rebuilt Motor????
- 91 3.1 alternator problems
- 6-Disk CD changer will not eject
- Lowering the 95 Rodeo
- Can somebody tell me how to remove the rear wiper blade?
- programing keyless remote
- No speedo
- Dome light operation
- Thinking about a 1996 Rodeo
- serpentine belt
- Alarm Question
- Help finding wires for engine codes
- Confused about 1996 Rodeo Keyless Entry
- Do 97's need the EGR cleaned?
- 1996 Isuzu Rodeo Problem-Help?!
- No turn signals and no power windows
- 99 Rodeo wont start
- 99 Isuzu rodeo trouble starting
- 2000 Honda Passport Flywheel Woes!
- 96 Rodeo PCM (electrical) issues?
- differential oil recommendation
- FAQ's are back up:
- Transmission range mode sensor question
- loud tapping after timing belt replacement
- Quick tranny questions
- Vents ALWAYS blow air ?
- Lost economy/fuel pump
- Water pump replacement-
- Cleaning out the Blower Motor...
- windsheild wipers
- Very high idle
- KS Sensor Circuit Input Low
- how to remove tail light assembies (sp)
- 97 Honda Passport Error Code Po327?
- Wanted: Junkyarder
- 1993 rodeo for sale
- Passport vs Rodeo
- tailgate won't open
- 1996 to 1994 V6 motor swap issues
- Temperature hand elavated and truck smoking some...
- Fan Inside Radiator....?
- 1996 V6 Rodeo P0401 Check Engine Light
- overheating ,timing belt tension ?
- 2002 Rodeo - Need A/C HELP
- Which Plugs for a 99 Rodeo
- 95 Rodeo Tranny Woes UPDATE
- Monroe Sensa-Trac at SALE Sears
- How to lube slip yoke
- 95 Rodeo Tranny woes??? Maybe
- roof rack
- I'v been cleaning my EGR wrong
- Fog Lights won't turn off
- 97 w/ a loud tailgate
- 3.2 vs. 3.2--much difference?
- taking a trip--what services?
- Wheel stud broken
- Towing car 1100 miles
- Rodeo IAT and ECT out of range [P0401]
- Australia oil recommendation . . .
- Aftermarket options?
- 2004 Isuzu Rodeo making a racquet!
- changing spark plugs
- How do you remove the door panels?
- Rear Axle leaking! 98 rodeo 4x4
- 94 Rodeo Auto Trans
- 95.5 Rodeo 4x4 lower ball joints
- 1996 Rodeo 4X4 Light, Fuel Sending Unit, and performance..
- 91 rodeo 3.1L injectors not working?
- interfearance engine or non?
- Isuzu manual
- Vibration around 45mph
- Lost Fuel efficiency
- wire up a light bar
- sun roof trouble
- Problem after serp belt change
- FOR SALE: 1996 Isuzu Rodeo LS
- aftermarket keyless entry
- Rodeoo clutch?
- Thermostat housings.
- 96-97 owners - I need your assistance
- Passport won't start
- 95 pick-up ECM fuse problem
- Evaporator core 2001 isuzu rodeo
- Solster's 1999 Rodeo Offroad Project
- speaker selection
- No dash lights.
- factory radio wire colors?
- Is This Possible?!?!?!?!?!?!?!??
- rodeo 2000 6vd1cam sensor code after cam belt change
- rodeo 2000 cam sensor stay on after cam belt change
- Which compressor G or D?
- off road light bars
- Lifter problems
- looking to spruce up the passport
- dash switches
- Chrome?
- Window regulators
- 98 Rodeo Clear Corners
- Is $500 too much for replacing speed sensor?
- 97 rodeo dash lights come on when shifting
- Pics of Offroad Modded Rigs Wanted!
- Update: Dipstick REMOVED!
- A/C Buzzing
- Excessive Cranking
- AC probs. on 95 Passport
- Hot A/C
- power window only goes down
- timing belt installation
- Power Window Problems
- IAC Location 2000 Rodeo V6
- HELP! - Dipstick broke off inside tube. . .
- sick, sputtering, and staggering rodeo
- firehawk tires
- Radiator Fan Clutch
- Poll: What oil are you running?
- Tokico Trekmasters vs. Monroe Sensatracts
- 1992 Rodeo for SALE 4x4.......
- right turn signal problems
- Taking over 2000 Rodeo 2wd, V6 - maintenance question
- 96 paasport intake manifold ?
- Will a 16x8" wheel fit in the wheel
- A little more bang out of my rodeo?
- power window problems
- 91 4x4 p/u problems... :(
- high mileage oil
- Ebay air intake
- AirVent question
- 99 A/T Woes
- Battery Volts?
- Power issue with 95 Passport 3.2L
- More 01 Rodeo problems
- Walkman car kit = audio tachometer
- A/c Filters??????
- Oil results with Rotella after 900 miles
- 95 rodeo knocking sound on top of engine
- jumpy oil pressure gauge and over heating
- easy 3" lift
- Sea Foam and Auto-RX
- Advice on buyin '93 Rodeo
- 97 3.2L Valve train rattle
- Roaring at 2,000 RPM...
- Noisy air conditioner
