View Full Version : Rodeo | Passport | MU
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24 25
  1. acceleration/idle issue.Help
  2. 97' 3.2 with 4L30E/auto. Slow/Harsh downshifts when coming to a stop
  3. EGR Harness VOM readings
  4. burned oil smell
  5. 4wd question
  6. 2000 Rodeo Hesitation on Acceleration
  7. Guages gone nuts - Please Help!
  8. Rodeo Passport Fuel Gauge Problem Fix-Sending Unit
  9. problem with door hinges
  10. Spark plugs
  11. 94 won't idle
  12. Problem with Idle 99 Rodeo
  13. code 0128 on isuzu rodeo 2001
  14. What Air Filter
  15. Hot Rodeo! - Help!
  16. 2000 Rodeo Tranny Filter Change
  17. Rodeo LS Heavy Duty Shocks
  18. 1996 Rodeo Transmission fluid/filter change.
  19. Simple Stereo Upgrade?
  20. Want to change/flush tranny fluid, but have heard of horror stories in doing so!!Help
  21. I want to give my car a tune-up (Spark Plugs, Spark Plug Wires) Hard to do??!?
  22. Advice Please; I did the EGR clean(let me know if I did right) + O2 Sensor.CEL!!!!
  23. 1991 Rodeo Sounds Like A Spaceship In Mid Flight
  24. Replacing O2 Sensors, difficulty? Price$?
  25. Intake Manifold Gaskets Covered?
  26. 96 3.2L 107K P1406 code
  27. flashing CEL
  28. How many odd-ball 4x2'ers do we have
  29. major repair help - sunvisor clip
  30. '95 passport headlights
  31. 1999 Rodeo 3.2 code 301
  32. belt squeal help
  33. Auto Gear shift not releasing from park
  34. Fuel sensor for isuzu rodeo
  35. Valve clearance adjustment?
  36. 96 rodeo starting problem
  37. 95 1/2 Rodeo will not start after extended driving
  38. 2001 rodeo slips in 1st then catches
  39. Rodeo leaky sunroof
  40. 1997 Passport reverse gauges
  41. 96 rodeo
  42. power/shifting problems..... after hours on road
  43. Help - Lower radiator hose will NOT
  44. FPR leaking
  45. tightening body mounts
  46. Automatic tranny ?? - at what maximum
  47. Codes 171 And 174
  48. Serpentine belt tensioner removal...
  49. Rodeo Hard Shell Spare Cover
  50. bad smell...
  51. 95.5 Rodeo transmission problem
  52. wanted: misc. parts
  53. CEL won't come on
  54. Major RANT!! Arghgh!! - within the last
  55. 1999 Honda Passport starting problems
  56. Starter replacement: Do I need
  57. Where is the Power Window Relay on a Honda Passport
  58. Squeal Sound...
  59. MAF sensor - can y'all tell me where
  60. 99 Isuzu Cam Position Sensor
  61. Trim on windshield coming off
  62. '96 Isuzu Rodeo - Suspension problem?
  63. Rodeo Roof Spoiler
  64. What does the inside of your intake runners look like after 80K
  65. Camrys in place of Rodeos?!?!
  66. Update:correction on the weight of tires..
  67. Write up on swaping a +98 motor and dash to a 89-94 Amigo:
  68. 96 Rodeo lights dimming
  69. Rodeo Fuel Gauge Issues-Sending Unit
  70. Torque converter lockup
  71. 99 Rodeo Fuel Gauge Problem
  72. Starting Problem with my '98 Passport
  73. TOTAL Windshield Wiper Failure
  74. Codes P1340, P0300B, P0131
  75. new shocks or calmini lift?
  76. CEL on and Check Trans light blinking after low oil
  77. Engine Failure due to oil pump?
  78. Rodeo fixed??
  79. Brakes acting funny..
  80. Shocks for 97' Rodeo
  81. CEL 97' Rodeo
  82. Got p0158 code
  83. BUCKING Rodeo
  84. 2000 Passport slipping out of 4 hi while driving
  85. 93 rodeo tranny problem
  86. You guys are right again! EGR intake port was UGLY!
  87. 99 Passport. Code P0405?. Can this affect transmission?
  88. Heater control valve?
  89. 2K Rodeo-Ign Key Won't Come Out ?
  90. tilt steering stuck
  91. Connecting Spot Lights
  92. Why won't my back window lock?
  93. 2000 Rodeo ABS & Engine Trouble Codes
  94. dissapearing coolant. Help please
  95. 97 3.2 Rodeo front and rear speakers
  96. Installing new shocks
  97. suggestions for adding HP
  98. Which way should I lean? Help me
  99. largest tire size for 16" aluminum wheels
  100. rear brakes
  101. ???Better Tranny and Tow Rating????
  102. really wanna lower my isuzu HELP
  103. Changing spark plugs
  104. I know I'm going to regret this,
  105. Burning smell....
  106. Update to the clunking
  107. Replacing starter. Trouble loosening exhaust bolts. Passport 99'
  108. 1996 Rodeo Driver's Side Mirror question
  109. 2000 Rodeo Headlight / Corner light
  110. Charging Problem- 98 Rodeo 3.2
  111. Engine tick
  112. 2000 passport code p1340
  113. Engine Gone?!; Clueless as to what I should do, please read!
  114. Curious: What kind of antifreeze
  115. Timing Belt
  116. AutoSave or PremierXTend Product
  117. Trys to stall when warn start
  118. Is it really worth it?
  119. where is isuzu cars/ trucks made
  120. CV joints/boots
  121. She's back on the road - belt jumped a
  122. 4wd problem with 1996 Rodeo
  123. Isuzu tech. phone number?
  124. Slightly used EGR valve for sale
  125. Tailgate Issue
  126. Gen 2 rear window reg in '97?
  127. faqs
  128. I keep blowing fuses
  129. Fuel gauge problem easy and cheap fix
  130. 94 rodeo check engine light
  131. Where Is The Cigarette Lighter Fuse Box 99 Rodeo??
  132. Another exhaust question...
  133. 95 Isuzu Rodeo Brake Lights HELP
  134. FS: 1997 Rodeo 3.2L 153k superb
  135. '98 Rodeo 3.2V6 Tranny Issues
  136. compressor replacement
  137. 94 model: Driver's door is stuck locked!!
  138. Update on the "DID it overheat" thread....
  139. Engine Swap Question
  140. RPM Pause on deceleration
  141. Pulling a crankshaft pulley
  142. overhead stuff...
  143. Torque converter slow to lockup?
  144. DID it overheat or not??
  145. Crazy electrical issue.
  146. Another odd-ball for the record book
  147. 98 rodeo w/ engine knock
  148. 95 Rodeo Anti-Lock Brake light stays on...
  149. Tire Rubbing
  150. 2002 Isuzu Rodeo Factory Subwoofer And Amplifier
  151. 1991 Rodeo fast idle
  152. Persistant Clunking
  153. failed emissions test
  154. ac fan switch problems
  155. Timing belt R&R - Killer, or just a pita?
  156. 2000 Rodeo just purchased..Need parts
  157. 2004 rodeo 3.5L
  158. New Alt and battery but wont hold a charge
  159. Tail light removal for 01 Rodeo?
  160. Belt tensioner
  161. Looking for new parts online (Tail light, fog kit) best place?
  162. Speed sensor experiment w/clutch
  163. HIDs in 99 Rodeo
  164. 1999 Rodeo V6 MT - Exhaust leak - common areas?
  165. Ok, all O2's are now replaced, but
  166. 2000 Rodeo for Sale
  167. IMPORTANT!! Ingition Timing Trouble
  168. Rodeo 2001 v6 - change plugs?
  169. New radio and speaker ques....
  170. Brake light and alarm problems
  171. Help
  172. 98 Rodeo Horn
  173. 98 rodeo (please help)
  174. Wow! Didn't know spark plugs
  175. Possible purchase of a 91 Rodeo 2WD Auto Trans...You thoughts?
  176. shocking...
  177. fog light question
  178. 97 rodeo 4wd
  179. High Pitched Engine Sound upon Acceleration
  180. My CEL light IS caused by a
  181. G80 Locking Differential Question
  182. '97 Honda Passport with 3.2 liter engine stalls...
  183. 91 Rodeo Transmission
  184. '94 Rodeo... Replacing fron hubs?
  185. Few Quick Questions (4wd)
  186. Just for fun - a Zu ancestor?
  187. UOA - here it is! Finally did one...
  188. mufflers
  189. user bars..for your pleasure
  190. Battery Light On & Engine Revs: '95 Rodeo
  191. Isuzu Rodeo Honda Passport Fuel Sensor Sending Unit - Gas Gauge Not Working
  192. Auto Transmission major problem '99 LS
  193. EGR problems
  194. Transmission question
  195. For Sale, 98 Rodeo 4cyl, needs engine work
  196. FS - 265/75 R16 Yokohama Geolander AT II
  197. ABS question
  198. Inadvertently fixed hard start problem
  199. Rust coming from A/C compressor (01 Rodeo V6)
  200. Odd twist on CEL and Speedometer / Speedo gear - 95 Rodeo/5 speed
  201. Maintenance
  202. Terrible grinding noise of doom
  203. Trans dipstick for 2003?
  204. Engine Code 0155 won't go away
  205. 1996 Rodeo 4wd Vacuum Switches
  206. muffler issues
  207. 250k on OEM timing belt:
  208. Location of lug nut wrench
  209. Need assistance - unrelated to Rodeo
  210. Temporary Hitch question
  211. Air Bag light on 95 3.2
  212. 95 Rodeo 3.2 Coil pack
  213. 92 rodeo - hard start and idle
  214. 2001 Rodeo V6 tail light & cruise problem
  215. What do the gauges mean??
  216. Need exhaust crossover (Y) pipe for 99 Rodeo
  217. Can I fit a 15x8 Rim on a 2000 Rodeo??? Please Help...
  218. 99 Honda Passport: Check Engine Light?
  219. What auto tranny was in the '91-92's??
  220. 2004 Rodeo 4x4 Conversion
  221. 97 Rodeo Transmission Trouble
  222. 2000 Rodeo..Trans light and Cruise set light / Engine Shutdown
  223. thermostat and overheating
  224. 95 3.2 please help!!!
  225. 3.2 Engine Codes?
  226. Symptoms of radiator blouuuckage?
  227. Waterproof Altenator???
  228. changing a side view mirror
  229. whining noise
  230. deep creek sea foam and PCV
  231. Which brand of oil and weight to use
  232. Hard starting when HOT problem again 92 rodeo
  233. brake pad replacement
  234. electronic problem??
  235. New Isuzu/Colorado truck which -
  236. jdm engine
  237. Tailgate removal
  238. replacing the starter on 97 rodeo 3.2L v6 manual? hard?
  239. 1st Post! glad to have finally found you guys...
  240. Some newbie help please
  241. Squeaking sound on cold days.
  242. '94 Rodeo A/T probs. Computer?
  243. changing spark plugs
  244. getting bigger tires
  245. hard to shift into gear
  246. Rodeo needs a weight-loss plan
  247. Isuzu Rodeo 95 Window Regulator Cable Rewiring Question
  248. new guy with a used 98 rodeo Ls 4x4
  249. Please help me rich fuel mixture.
  250. 1999 rodeo transmission probs
