View Full Version : Rodeo/Passport
- electric windows
- Honda Passport/Isuzu Rodeo 3.2V6
- Roof Rack and headliner
- steering problem
- HELP! i have a ticking noise that won't stop 96' Rodeo
- "power drive" button on 94 ls
- 98 Rodeo Startup Problem
- Alternator? Belt?
- 99 isuzu rodeo starting prob
- Headgasket oil leak??
- Rodeo transfer/differential case fluid
- Electrical short 1993 3.2L
- alternator whine, belt squeal
- Rodeo still leaking coolant
- 97 rodeo 4wd problem
- 97 Rodeo Steering Jerking
- Clutch gone, sell it or scrap it?
- Power button 01 Rodeo?
- Idle speed high! Help!
- where is the defogger relay?
- Anyone else having serpentine belt pulley issues in 98+ Rodeos?
- 99 transmission upgrade
- Red thing under the hood next to the firewall?
- questions about using 2wd low....
- Truck making odd sound (94-Rodeo)
- Counterfeit Rodeo?!?!
- 95.5 3.2 4wd knock/timing? issues
- blinking U/S light
- '94 passport wont start
- 96 egr valve
- Engine fan making unbelievable noise
- 97 Rodeo w/ 15" wheel offset
- Major '00 LS 4WD problem
- oxygen sensor question?
- egr valve cleaning
- 1993 rodeo vent glass..
- Sending unit confusion- 2000
- Air-Bag Light stay on.
- 98 Rodeo/Passport abs light
- Front axle mounting bracket
- 99 rodeo 2wd auto only reverse unless i put it into winter mode
- 1998 Isuzu Rodeo Tranny Problem
- 20" wheels and tire size
- Junkyard lift?
- rear window wiper
- Having hard time with reverse.
- Starter Motor
- Radio Wiring Harness
- Power Steering High Pressure Hose
- a prank that has a great outcome
- CEL keeping me from getting my inspection
- thermostat check after the water pump
- water pump
- Thinking about water pump and t-belt change?
- separating 'U' joint from front axle assembly
- SERP belt issue
- 94 rodeo wheel rubbing rotor
- window regulator
- crank pulley bolt size?
- Locktronics issue... I think
- Pre-98 owners, highly recommend
- Transmission Cooler Lines
- EGR Valve - ok to use carb cleaner on it
- CEL light on 99 rodeo
- Cleaning EGR - do I need to change
- Overheated and "wouldn't go"
- Testing fuel pressure
- Is there no front diffy in 2WD?
- Knocking
- 2002 passport vibration problem
- Where to buy parts??
- Splash Guard Removal
- Alloy wheels to fit a '96 Rodeo
- 99 Dash bulbs
- noob Rodeo owner
- Reverse
- 94 rodeo 4wd
- I am back
- Why can't I get these bolts started???
- 99 rodeo 2wd auto only reverse 6cyl
- More timing belt questions
- 94 Rodeo Tranny Swap
- 4 wheel mode pulling to the right.
- 4 tires changed, 4wd runs rough
- 99 Rodeo LS - Faulty Transmission Mode Switch??
- Dash Kits
- Rodeo 97 Oscillating noise: front center to right side
- Oil smell and a brake question
- 98 Rodeo has no dash lights
- diff. fluid change question
- Alternator problems?
- Problems with Gas Pedal on 95 Honda Passport
- 1993 Rodeo speedometer gone crazy
- body mount?
- how to check service engine light...
- Gas gauge
- Rodeo Enging Revving
- Help with nut size!
- Cause more problems cleaning EGR ?
- Transmission and Intermittent Check Engine Light
- placement options...where to put the stuff??
- 99 Rodeo Reset ABS light?
- WATCH closely -
- Isuzu Rodeo Manual
- Cant get PCV valve out of 01
- High-pitched squeal from power lock system
- Flashing CEL, New Cat. Conv., EGR, Denso Iridium Plugs
- 97 rodeo vibration
- Removing crankshaft pulley on '96 Rodeo 3.2
- Wheres EGR valve on 01 rodeo?
- 2004 windshield wipers
- Rodeo02 - Lesson learned, help w/ P0401
- 2005 Xterra - what's your impression?
- Removing front grill on 01 rodeo?
- Help! Where's the oil drain plug?
- Are all 4 O2 sensors the same?
- HELP with 1996 roof rack installation
- Here it is!! Pics, too!
- O2 sensors? Which Brand?
- 93 rodeo starter
- Doors make popping noise
- 1996 Rodeo Engine Problem
- Battery Post question
- Replaced plugs but still runs slugish
- Hard start after fuel filter replacement?
- Rear Glass Studs 98+
- ABS Technical Question 98+
- Replacing fuel filter
- removing fuel rail
- P0430 ('99 Rodeo V6) Strong gas smell
- jobs in progress - please look for entertainment, ?s
- 1996 Rodeo 3.2 loud knock at low rpm
- Steering Clunk
- Changing Rear windshield wiper
- Installing brakes question
- 94 passport ac/alt.electrical
- 01 Rodeo brake question/problem
- Is my Rodeo an early or late '97?
- 97 Isuzu Rodeo won't start, just clicks
- new coolant leak - help ID source please!
- After Market PCV valves
- Can someone please check their voltmeter?
- Can someone check their Voltmeter .....
- Pre-98 owners: What size of tire...
- accelerator pause?
- FS: Bridgestone Revo's 1yr/9k
- warranty ifo needed?
- Charging Problems
- 1999 rodeo automatic transmission
- 92 3.1 cranks ALOT before starting....
- Years, engine, mileage
- Honda Pasport missing in 2 cylinders
- Shock Replacement
- Difficulty of 01 rodeo plug replacement
- 99 rodeo wont start
- 94 LS stock wheels
- Missing Surging please help....
- Will 15x7 or 15x7.5 wheels off a 94
- '98 Rodeo trans holds 1st and 2nd gear when cold
- creaking noise
- CEL Code P0442
- Front Brake Pads Wont Fit!!!
- Pre 1998 valvetrain, 1998+ #1 rod bearing..
- EGR Cleaning
- new to me 2000 rodeo ls
- 4wd max speed
- Radio harness plug needed
- Need help getting rid of annoying squeeking
- rear brakes
- dead battery
- jack handle and tire tool
- 99 4x4 abs and other problems
- Refurb
- '96 3.2L V-6 Rodeo - Overheating Fixed!!!
- window controls-96 rodeo 3.2 v6
- fuel dash light-96 rodeo 3.2 v6
- NEW EGR cleaning article:
- How do i get a door for 98 izuzu rodeo
- towing for 1996 rodeo
- CV joint problems or steering?
- getting ready to change clutch in 92 rodeo...
- 2002 Amigo Parts for sale
- Very low idle when comming to stop
- 96 rodeo-high idle problems
- 1994 Rodeo LS 4wd hub/rotor separation
- 1996 idling issues
- 95 Rodeo Upper Timing Cover Removel
- 96 3.2L Knock Sensor
- 2000 Rodeo Speed Sensor/Speedometer
- rear brakes
- Procedure to remove cargo area interior panels?
- Need input on service/maintenance??
- Poll: What color is yours?
- 1998 Rodeo Shifting Issues
- What is good compression pressure? And more??
- Isuzu Rodeo 99 Tail Lights problems
- FS: 2000 Rodeo LS (Texas)
- Help!!! Check Engine Light Blinking
- Rodeo rearview mirror with dimming
- scan guage
- Coolant leak help!!!!
- 93 V6, 3.2L engine, cast iron or alum. heads
- 4L30E help
- Can Rodeo brake pedal distance be changed?
- It just got serious....
- Please help me, Engine Swap 3.2l
- Quirky Electircal issues
- ('98 Rodeo-Battery & Brake Light on > 2400 RPM
- Good Price?
- Help Losing Power!? Alternator issues maybe?
- Sea Foam Question
- 93 A/c problems
- 93 A/c problems
- very slow acceleration
- Dash Lights???
- Recommend a spot for a subwoofer please.
- MAD! ARghg! Dealer smashed truck
- best plugs for 92 3.1....
- rear wiper
- Smallest bumps cause clanking
- wiper fluid leak
- G-80 code = Limited slip ?? Tire
- No upshift light in 1/2 gear
- What is your idle speed? '99-up
- Idle Problem Solved (98 Passport)
- Need input on a few quirks
- i want a sunroof
- Engine timing off
- Anyone buy their Rodeo w/100K clocked?
- crap...left window down
- Windshield wiper leaking
- '01 Rodeo OEM AM/FM cassette deck question
- 2004 Rodeo - Anyone know anything
- 99 Isuzu download.
- 92 Rodeo-Electronic Spark Control, Runs Waaay Rich
- A/C Problem Unknown - Please Read Symptoms
- EBAY: 95 woodgrain kit:
- The infamous Check Engine Light strikes again
- P.O.S. O2 Sensors
- cat conv=tranny problems?
- Front End Shake After A Brake Job
- 1996 Alternator alternatives?
- top end tick; oil pressure bottoms out
- few questions about 92 isuzu rodeo...
- recovering starter mounting bolt dowels
- Engine Blues, for Technically Inclined
- Timing Belt on Rodeo
- lx vs. ex....difference?
- cigarette lighter socket
- Reverse Lights
