View Full Version : Rodeo | Passport | MU
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25
  1. FAQ Maintenance
  2. Changing 99 Passport serpentine belt (visable).
  3. Cracked Cylinder Head 99 Rodeo
  4. Replaced Timing Belt
  5. Replaced Timing Belt
  6. Keyless entry question
  7. 97 Rodeo Starter removal?
  8. '95 rodeo shifts without key in ingnition.
  9. 100 Amp main fuse blowing 98 rodeo V6
  10. Electrical Problems
  11. Puchasing manual hubs
  12. Hissing from passenger side
  13. A few questions abou my 95
  14. 9 1/2 or 10 1/4 clutch?
  15. coolant disposal
  16. Replace Engine?
  17. Replacing rotors on 01 Rodeo
  18. need new shocks
  19. leak soaking my rear flooring
  20. Transmision shifting hard??
  21. Brake Question Help Please!
  22. CEL code P0440
  23. Alternator change on a 95
  24. 95 Rodeo tranny, no 4th/ just overreevs?
  25. P0131 &P0137 O2 Sensors
  26. Good thing we ain't driving our Rodeo's in Scotland
  27. cracked radiator
  28. 1998 Rodeo
  29. '97 Rodeo for sale.....
  30. Transmission
  31. popping noise
  32. 04 Rodeo brake problem
  33. 04 Rodeo Battery connector corroding
  34. 2001 rodeo isuzu for sale 5k
  35. Someone Please help!
  36. Alarm System
  37. Intake manifold gasket
  38. Clutch Leaking Fluid Where do I look?
  39. Cat Question
  40. Spare Tire, How do I remove?
  41. Rodeo/Passport history?
  42. 2000 Passport Auto Transmission problems
  43. what to do...
  44. Hitch Install - weekend project gone awry
  45. Ramdm mtpl cylinder misfire, HELP!!!!!
  46. Maintenance Questions
  47. How to tighten rear glass???
  48. New to Passport, have some questions
  49. battery question
  50. Tranny Trouble (again!)
  51. 1996 isuzu CPU Problem?
  52. need help with 93 Rodeo Izusu Regulators for Windows V6 3.2
  53. 1999 rodeo 2.2 code p-1627
  54. Help! My cat ate a golfball!
  55. 94 isuzu rodeo crankshaft pulley removakl /install /torques...????
  56. Need running trouble shooting help with my 99 Rodeo
  57. Isuzu Rodeo Glow Gauges Dim / Broken ?
  58. Help - am I being taken for a ride?
  59. Where do I get an oil pump?
  60. Help Finding Intake Air Temperature Sensor
  61. Replaced Starter and Look What Happened!!
  62. Intake manifold torque settings.
  63. Cam Position Sensor error code
  64. 1998 Rodeo Fuel Pump Help
  65. 2001 Rodeo 3.2 "Bucking" on acceleration
  66. Black clutch fluid, hard to shift
  67. LOOKING TO BUY: Rodeo Soft-Top
  68. Speedometer question
  69. Rodeo driving lights replacement
  70. 98 Rodeo will not idle??
  71. 01' Rodeo transmission question
  72. CEL code P0342
  73. 99 Rodeo Coolant Coming Out Under #6 Coil Pack
  74. questions on 2000 rodeo
  75. 2000 Rodeo Bizzare Electrical Short?
  76. FWIW - Napa Gold 1334 oil filter's
  77. Got code 0157
  78. 1997 Passport alarm issues...HELP!!!!!
  79. I give up! CEL P0401 is BACK
  80. Selling my baby: 2002 Rodeo Sport V6/AT/2WD Softie.
  81. HELP (Please) 2000 isuzu rodeo, transmission
  82. Rims 4 Sale
  83. How often tranny replaced or rebuilt?
  84. Valve tick!!!
  85. How to relieve overcharged A/C
  86. Can a Rodeo be flat towed behind an RV?
  87. Goodbye Rodeo
  88. A/c question on a 95 passport.
  89. 2002 Rodeo Sport...roof removal?
  90. Help with 4wd and my new Tranny for 98 Rodeo
  91. surging rpm
  92. A couple questions.
  93. 97 rodeo 2.6L code p1406
  94. Please Help!
  95. Where are the EGR and Idle Air Controller Valves located?
  96. Rodeo 2001 3.2 Starts rough when cold and ofter dies
  97. Timimg belt Problems
  98. Replacing the rear main oil seal on 96 Isuzu Rodeo 3.2L
  99. jack storage?
  100. 95.5 Rodeo 3.2L cranks but wont start
  101. 2000 rodeo radio wires
  102. tranmission help
  103. ac compressor
  104. Fuel Pump gauge Flashing
  105. 92 3.1 rodeo no spark interm.
  106. Few tranny issues
  107. 99 Izusu - Fair Prices for Atlanta Repair?
  108. Rodeo SAS on 44's
  109. Replacing the belt idler pulley...I think
  110. 1995.5 windshield washer help
  111. 95.5 Passport Maintenance/Repair costs
  112. Type of Coolant?
  113. CV Driveaxle replacement
  114. High Idle on Rodeo 3.2L...tried various things
  115. lights on dash
  116. Door won't open from inside
  117. '01 Rodeo Hard Starts
  118. Transmission overfilled??
  119. Help With wiring..or something else?
  120. Help!! My Car Is Dying!
  121. 94 Rodeo 3.2 Headlights stopped working
  122. Central Locking System
  123. 98 Isuzu Rodeo Ticking/Rattling problem solved finally
  124. Timing belt--Where to buy, what do I need?
  125. transmission 2001 rodeo
  126. My Passport is running ritch..? Or is it something else? Ramblin where are ya..
  127. 2000 Isuzu Rodeo Spring Cleaning....Lots of stuff forsale...
  128. 96 Passport Low Idle
  129. 99 Passport Brake Pedal/Dash Lights
  130. cel flashing only when accellerating?
  131. EXACTLY which tranny fluid goes into
  132. Seal replacement on auto tranny
  133. tail light help!
  134. Replacing rotors and pads on 00 Rodeo... DIY job?
  135. Spare Tire Carrier
  136. Methods to Lower a 99 rodeo
  137. Driver's side window
  138. Pulling Engine and Transmission?
  139. 1998 Rodeo Calipers
  140. 1998 Rodeo Fuel Pump
  141. Help With A 96 Rodeo That Wont Charge
  142. Easy way to figure out the bad ABS sensor
  143. Turn the key and nothing
  144. Where to get wiper relay for intermittent prob?
  145. a few offroad pics of a couple isuzu's
  146. 1994 Isuzu Rodeo Oil Filter... whereisit?!?!?
  147. oil leak on 1997 isuzu rodeo
  148. Whining sound after replacing starter??
  149. Question about shocks
  150. whirring under the timing belt covers
  151. 2002 Rodeo for sale
  152. Think maybe after 10+ tries to start
  153. Exterior Maintainence
  154. pepboys...
  155. help I need to fix my truck
  156. Compressor clutch replacement instructions
  157. Scrapping noise coming from the passenger side
  158. How do you clean the MAF (mass airflow sensor)
  159. 95 Rear Doors Locked
  160. Bad fuel pump or bad gas
  161. Please Help!?!
  162. 2000 Rodeo rebirth
  163. Engine is ticking and CEL is on code 1406
  164. P1404
  165. 2001 tube steps...
  166. Doing some work this weekend
  167. No Clutch!!!
  168. My next truck?
  169. Rodeo to Rodeo Sport seat swap??
  170. rear bearing replacement
  171. 1999 Isuzu Rodeo eating batteries
  172. 94 rodeo.... engine ticking noise @144,000miles
  173. Installing ARB Bumper on 2nd Gen Rodeo Today...Please Help!
  174. must be something minor....
  175. Momentary electric loss while appling breaks
  176. Rodeo Passport Fuel Sending Sensor Unit-Bad Gas Gauge
  177. Replacing a bad A/C Blower?
  178. replacing clutch in 95 rodeo 4x4/advice
  179. 2002 rims on a 99?
  180. Cracked Head and Head Gaskets
  181. 98 Rodeo LS V6 Automatic with Brakes Grinding
  182. Rodeo hard starting only when warm. Need some info...please.
  183. Change timing belt?
  184. where are the tailer light hook up??
  185. Throttle body - wow, nasty, cleaning as I
  186. Valve adjustment on 2001 V-6?
  187. obd2 scan tool, which one?
  188. intermittent rattle/grinding noise
  189. Auto Hubs will not lock on 2001
  190. changing auto tranny fluid, good idea or not?
  191. HighlandLake - can you repost your EGR
  192. Is it possible just to replace the A/C compressor clutch?
  193. coils on ebay:
  194. Piston ring replacement
  195. Help identify this hose ....
  196. How can I stop 3.2L valve cover gaskets from leaking?
  197. AC Condenser fan question?
  198. O ring and Piston rings
  199. Maf?? O2???? Egr??? 94 Rodeo
  200. Bad O rings
  201. Coolant hoses - There are 12 coolant
  202. Brake Pedal Moaning
  203. Bye Bye GM....Almost
  204. CEL turned off by iteslf
  205. OIL PRESSURE 94 Isuzu
  206. I need help with my 1999 Passport!
  207. Spare Tire Carrier
  208. A/C buzzing sporadically...Any ideas?
  209. 2001 Rodeo Sport-misc. questions
  210. 2000 rodeo leaking oil into plugs 1 and 3
  211. 3.2 rodeo compression
  212. Fog light question
  213. Trying to pinpoint noise
  214. Heater/Radiator hoses - do NOT be fooled
  215. to all rodeo experts out there...my 2001 rodeo is killing me
  216. just got 2000 LS 4X4...speaker question
  217. Brake and Battery Ligh Flashing
  218. Got my smitty's mounted
  219. My front rotors are warped again.
  220. MAF sensor - can I clean with LEAVING
  221. 12.75v draw on battery-can not find problem
  222. This site is awesome
  223. Did I order wrong plugs?
  224. Timing belt question
  225. Rotors - anyone else still running original
  226. cant figure out overheating problems
  227. Snow chain question
  228. 1995 Passport rear hatch rattle *ANNOYING*
  229. 4WD problem - getting desperate
  230. 1997 isuzu rodeo trannny hose leak
  231. 2000 Rodeo
  232. high voltage - 2000 rodeo 2.2L
  233. new battery question
  234. white exhaust smoke
  235. Almost new EGR valve on Ebay
  236. Replacing the t-belt
  237. high idle
  238. Brake Expert Needed! Vacuum Booster squeaks when I press/release the brake pedal...
  239. Air Conditioning Squeel
  240. PVC valve removal
  241. Rodeo Sport V-6 Engine Blows
  242. Intake?
  243. Please Help me make sense of these codes. P1404 , and P0405 - EGR Related
  244. 2001 Rodeo Opinions
  245. white smoke??!! 98/99 auto 2WD
  246. 99 Rodeo LS in shop with timing belt, question
  247. what shocks is best for rodeo?
  248. First time Tranny Flush at 48k?
  249. Environmental fan doesn't work at position #4
  250. 14.7
