View Full Version : Rodeo/Passport
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23
  1. changing Timing belt
  2. Please Help Anti-freeze Leak!
  3. 2000 rodeo 4x4 rear axle.
  4. Where is the Starter? 98 Rodeo
  5. 2002 Isuzu Rodeo Tailgate Problems
  6. Clutch questions!!
  7. how hard is it? really....
  8. how hard is it? really....
  9. 4WD Noise + Ignition Problem
  10. broken emergency brake
  11. Nightmare screeching sound
  12. lifting 1994 rodeo
  13. Seatbelt ideas for center console? Have
  14. Cleaning EGR on 95 3.2L V6
  15. Anyone Replace Tailpipe - have brand suggestions?
  16. synthetics, synthetics, everywhere
  17. radiator (auxillary) fan
  18. radiator (auxillary) fan
  19. radiator (auxillary) fan
  20. went trough a pond
  21. Egr Valve - How Does Isuzu Mech. Fix? * Check Engine Light *
  22. water pump
  23. 1997 rodeo w/ check engine light
  24. Start Attempt Kills Power
  25. to you all with fuel gauge issues
  26. Brakes
  27. what fuse takes care of......
  28. center (carrier) bearing
  29. ABS brake light
  30. a/c comressor so hot
  31. Rims off a 2002 trooper
  32. rear differential size
  33. Rodeo Fuel Injector Air Leak
  34. front and rear differential
  35. Front differential fluid changeout?
  36. Brakes grabbing/slipping or shuddering
  37. Oh great, now what have I done to this Rodeo?
  38. blue print rodeo/passport picture-- any?
  39. front mounted trailer hitch
  40. Air bag sensors
  41. ABS Help
  42. Intermittent Wipers not working
  43. Front wheel make noise
  44. Rear end advice
  45. egr code plus another ?
  46. MU/Rodeo auto trans ratio's
  47. Curious - where's the torque band
  48. 3" body lift on 96 honda passport auto
  49. 95 3.2 rough during acceleration and no power
  50. window wiper fluid lever
  51. 3.2 engine seized
  52. WOW! Cool, emergency brake REALLY
  53. Can't open rear door
  54. brake light on and battery light on and no heat
  55. Fuel pressure specs for 2000 Rodeo 3.2L
  56. 1993 4wd LS 3.1L 5spd transmission stuck in gear H_E_L_P !
  57. 00' Rodeo engine knock under load
  58. Ran out of Gas!!!
  59. 1998 rodeo 5spd 4x4 not working
  60. intake manifold gasket
  61. off road lighting
  62. Transmission down shifts by its self
  63. Rear Disc Brakes
  64. Part of PVC grommet broke and fell in!!
  65. RE: Rattle (exhaust??)........
  66. so, i'm a girl....
  67. What is the best/worst MPG you have recorded in your Isuzu
  68. EGR code, could it mean bad IMG
  69. front axle replacement
  70. white smoke...loss of power
  71. alternator wiring
  72. Suggestions for a problem??
  73. Torque spec for spark plugs?
  74. 97 V6 Passport Belt Changes
  75. fuel filter question
  76. P0401/EGR CEL code is back??
  77. 2002 ABS Light, where do I start?
  78. 2002 ABS Light, where do I start?
  79. Ticking only when cold
  80. exhaust very hot
  81. Emergency break problems.
  82. 96 rodeo headlamp replacement
  83. Rattle(exhaust???) under Passport during acceleration....
  84. Po107
  85. 94 isuzu rodeo ignition
  86. mercury egr valve
  87. 4wd gets stuck
  88. EGR Valve Replacement 1999 Rodeo Isuzu
  89. Rodeo' hybrid twin?
  90. 2000 Rodeo shimmy in steering wheel @ 45-75 mph
  91. What is this connector?
  92. Rodeo 4wd Indicator Light
  93. dream project
  94. rear glass hatch won't stay up in winter - Rodeo 97
  95. 95 Isuzu Rodeo Won't Start
  96. CEL once in a while
  97. 5spd to auto swap?
  98. overhead console
  99. Isuzu in the news:
  100. Fuel Problems/Studdering/Hesitation
  101. what is the diff between 00 an 99 rodeo interior
  102. Install Instructions for Rodeo Glow Gauges
  103. Problem up front
  104. Speaker Problem???
  105. I spin out like crazy on ice in my 92
  106. I spin out like crazy on ice in my 92
  107. code 1627&463 PLEASE HELP
  108. 00' Rodeo Creaks, rattles and clunks in COLD weather
  109. rodeo wont start after new alternator,starter,batt
  110. Heat range of spark plug
  111. 1995 Passport window rattle
  112. Cruise control fuse on 95 passport
  113. Annoying squeak under the hood
  114. 99' amigo coolant disappears?????
  115. Canister puge valve number
  116. 99 Rodeo wont start.
  117. Slipping clutch?
  118. must sell my 02' Rodeo Sport
  119. Car Trouble, Need Help???
  120. Oil from K&N Air filter
  121. 98 suspension Qs
  122. adding guages
  123. No cup holders, no arm rest
  124. Isuzu engines and transmission
  125. Knocking, ticking not the time belt or tensior
  126. Mobil 1 Stopped the Ticking (For Now...)
  127. Rodeo won't start
  128. power steering return line?
  129. Bizarre Alarm Problem on '99 Rodeo
  130. CEL codes P0401 and P0463
  131. it's a 4x4, but what kind?
  132. where did you learn?
  133. CEL came on
  134. In-line transmission filter
  135. 92 rodeo rear end clunk...
  136. CEL & Check trans light are on
  137. Sloshing Fluid - 02 Isuzu Rodeo LS 4wd
  138. P1404
  139. 96 Isuzu wont start right away
  140. Transmission filter question
  141. T5 Manual Tranny swap
  142. 01 rodeo remote question
  143. winter button
  144. Honda Fuel Gauge Malfunctioning?
  145. ABS Box Hangs UP?
  146. transmission cooler
  147. what years will interchange with my 95.5?
  148. WinALDL
  149. Replacing dash lights help needed
  150. No 4WD on rodeo.
  151. Bucking like a bronco
  152. Installing a new wiper linkage
  153. 2000 rodeo
  154. 95 Rodeo - Low heat, hi idle
  155. starter ???
  156. problem with heating in 1995 Isuzu Rodeo
  157. timing belt tensioner bearing and Idler replacement
  158. 2000 Rodeo Auto Trans service question
  159. Installing Rear Axle.
  160. 97 passport 4x4 issues
  161. Rear Winshield Wiper
  162. 95 Rodeo read Anti-Lock solution (ABS)
  163. Crankshaft Pulley Removal 1994 Rodeo 3.2 liter
  164. '01 Rodeo V6 gas guage acting funny
  165. light bar
  166. Governor setting?
  167. ion sensor code P1312
  168. One thing leads to another.....
  169. 01' rodeo tps (throttle position sensor)
  170. Front Hub nut tool
  171. '98 Rodeo starting/bucking problems.
  172. Left Turn Signal
  173. Banging when turning in 4wd
  174. Difference between 1995.5 and 1996?
  175. 97' w/80,000, for $4000, is this a good deal?
  176. Belt Tensioner
  177. Wiper Linkage shot
  178. 92 Rodeo
  179. How long should IMG last?
  180. Energy Suspension Sway Bar Bushing
  181. 96 rodeo hetaer quits on right turns...really!
  182. Timing belt question??
  183. Caps on Roof
  184. Manual door locks fell out?
  185. 99 Amigo turns but does not start
  186. Repairing power windows
  187. 96 Runs but won't idel
  188. need help Engine Stalling Problem
  189. No Clutch pedal tension
  190. Stabilizer Bar to Control Arm Linkage
  191. solenoid valve
  192. noise from 99 Rodeo
  193. 97 rodeo spindle bearing
  194. Ignition switch will not return and release key
  195. O2 sensor
  196. mystery!
  197. Power Steering Problem
  198. help 96 3.2 rodeo crankshaft pulley bolt will not come off!
  199. the $570 repair
  200. wont go in reverse sometimes
  201. Isuzu FAQ Maintenance
  202. Cel...yay
  203. Well, I got my auto-lock hubs working properly again.
  204. confirm my thoughts?
  205. Factory 12 Disc CD changer
  206. installing lug nuts
  207. Whining/Wheezing sound on acceleration + driver side winshield wiper fluid
  208. 97 Rodeo: Runs rough
  209. P0405? Cel
  210. 100,000 mile service ideas
  211. gotta love the stock 6 disc cd player...
  212. Transfer Shifter dis-engages @ 45 mph
  213. anti seize vs threadlocker
  214. Instant CEL problems
  215. Engine Seized Up Over The Weekend
  216. Dealer says my 97 Rodeo has transmission slipping (a little)
  217. Hard start '92 v6 3.1L
  218. auto transmission not shifting
  219. Repair Center
  220. Correct Oil weight
  221. 99 isuzu rodeo fuel pump noise
  222. 2002 4 Cyl Rodeo runs hot
  223. 95 Rodeo first tune up
  224. 99 rodeo v6 build up
  225. 92 3.1L rodeo issues
  226. wiper relay replacement info posted
  227. What can i all do to my 91 Rodeo
  228. 2.6 engine swap with 5 speed tranny
  229. Rear window falls
  230. it IS still leaking
  231. 1995.5 Rodeo leaf spring bushings
  232. tailgate panel on an Isuzu Rodeo 2000
  233. Valve timing
  234. Should i buy a `98 Passport 4WD????
  235. '99 Rodeo fan stopped working
  236. Check engine light... trouble code
  237. Someone had some auto-lock hubs.....
  238. Building HP in an NA H22
  239. Brake Light Issues
  240. Engine surges then dies
  241. rear flanged axle.
  242. need help with missfire or jerking with rodeo
  243. ABS light
  244. isuzu manual inside:
  245. 95.5 rodeo which engine?
  246. Front shock bolt.
  247. Mpg
  248. How do you tighten the rear lift glass
  249. Strange behavior at idle
  250. oxygen sensors
