View Full Version : Rodeo | Passport | MU
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25
  1. stupid clutch
  2. Big Cypress Preserve, FL
  3. Where is the iac valve for 97 Rodeo?
  4. Few issues with '94 Rodeo 3.2. Probably unrelated.
  5. 93 rodeo stalling and no turn signals
  6. Is alternator needed for starting?
  7. Front turn signal lamp "socket"
  8. P1125 TPS signal intermittant
  9. Replaced shocks - a few questions
  10. Gizmo: How do you like the Daytons?
  11. rear wheel bearings
  12. 1998 Isuzu Rodeo Exhausht
  13. '98 Rodeo low fuel pressure
  14. Finally got tranny rebuilt
  15. what could have happened?
  16. 1997 Turns but doesn't start
  17. 98-02 Rodeo-Ever had the Timing Belt break?
  18. Where is coolant drain plug?
  19. torque converter cover missing bolt
  20. Several warning lights (transmission dificulty)
  21. Steering Boot
  22. P0300
  23. 1993 Rodeo Transmission Check Light Fashing
  24. 1994 Passport engine miss
  25. Heater-inlet Hose
  26. 98 Rodeo - Lug Nut key/locks
  27. '99 LSE Won't Start
  28. 94 passport heater core
  29. combo of dash warning lights.....diagnosis?
  30. Please Identify this part
  31. Cross reference. Bracket needed
  32. Tire/Rim question
  33. Idle air control valve
  34. A/C expansion valve location on 99 rodeo v6
  35. 1998 Rodeo Isuzu Window and Cruise won't work
  36. engine swap
  37. 2000 Rodeo Door Popping
  38. Strange Transmission issues- 99 rodeo
  39. Small Gas Tank Issue
  40. Window washer question
  41. Where do you folks get parts?
  42. 94 rodeo engine problems
  43. 95 rodeo 3.2L 4WD 5 speed gas mileage?
  44. 1993 V63.2 4WD wheel bearing
  45. Fan Clutch - how many of you have had
  46. Timing belt, plugs & hoses
  47. 96 Rodeo Gas Pedal Sticking Pictures!
  48. Yankee Hill / Loch Lomond trails run pics
  49. 2001 Rodeo brake light problem
  50. Repairs Cost: Front Brakes, T-Belt, water pump etc
  51. Air Conditioning Myth !?!?!?
  52. '99 Passport trans filter change
  53. Found an engine for a '97
  54. Extended warranty
  55. 1998 Isuzu Rodeo 4X4 problem
  56. 01' Rodeo p300 code/Randm mtpl cylndr msfire, HELP!!!!
  57. Low Mileage 96 Rodeo on Ebay:
  58. What Is Better?
  59. off-topic help
  60. 94 Rodeo ATF coolant lines
  61. 94 Rodeo is gutless til "Check Engine" light comes on
  62. rodeo shocks..
  63. Cross country road trip chcklist; have I
  64. 1998 Isuzu Rodeo AC not engaging
  65. Surferfletch - can you advise me
  66. Rodeo Gas Pedal Sticking and Brake Fluid Light on HELP!!
  67. Rodeo problem.
  68. '95 Rodeo... no Instrument Lights
  69. Starter?
  70. Rodeo Alt OEM New on Ebay:
  71. dirty egr stealership$$
  72. proud of my battery
  73. 2000 Isuzu Rodeo - Electrical
  74. thermostat
  75. Heavy duty radiator replacement?? ......
  76. '98 Rodeo A/C Compressor Won't Engage
  77. 1998 Isuzu Rodeo Rear Axle
  78. Back to smaller tires - anyone interested ...
  79. 97 Passport- Not getting enough charge
  80. Alternator Again!!?!?
  81. Problems never end
  82. '94 Rodeo overheating issues
  83. Parts/ classifieds
  84. 95 Passport engine troubles
  85. Bosch, PIAA, Rain-X, Michelin, : Which is the best wiper-blade?
  86. 1998 Rodeo miss-fire
  87. Best place to buy Brake Rotors and Pads???
  88. Oil weights
  89. Tranny techs, come inside (99 Rodeo V6)
  90. Need auto transmission for a 1996 Rodeo
  91. Look what I found.....
  92. +98 hard top
  93. trailer attachement 7 pins for Rodeo 2001 3.2l
  94. 1996 Rodeo 3.2, 4x4, 125k - throttle surge
  95. Crazy Dash Lights...
  96. Cel???
  97. Fan Clutch? Slipping Belt? SUPER LOUD screeching at cold startup!!!
  98. Diffy Cover Questions
  99. Curious: what's your gas bill up to??
  100. Rear bearing? Or just brakes?
  101. Tensioner Question
  102. Saints John / Deer Creek Trail this weekend - mostly scenery
  103. CTS questions
  104. power window in/op
  105. Idle Problem Solved - IACV Cleaned (99 Passport)
  106. 1998 Isuzu Rodeo rear brakes
  107. 1998 Isuzu Rodeo timing belt replacement?
  108. Interior Lighting/ parking lights
  109. 1995 Rodeo 3.2l MAF?
  110. RwABS and Brake Dashboard Lights
  111. Ok, since my Rodeo is the oil tester dummy
  112. Check engine light on 2000 Rodeo
  113. 1998 Isuzu Rodeo
  114. 1998 Isuzu Rodeo AC not working
  115. Fuseable Link
  116. Easy Cruise Control?
  117. 99' rodeo cylinder head bolts
  118. Need center caps?
  119. Range mode sensor
  120. 1995 Isuzu rodeo no spark
  121. where is fuel filter located?
  122. 99 rodeo fuel pump noise
  123. No power in cab
  124. isuzufaq.com
  125. Passport objections?
  126. Fuel gauge floats...
  127. 1991 Rodeo Performance Exhaust???
  128. code P300- randum multiple cylender mis-fire
  129. Steering Wheel Cover Removal
  130. Front Driveshaft Stuck!!
  131. 97 Isuzu Rodeo no fuel no fire
  132. Overheating! water missing, but where?
  133. If you could design your own Isuzu?
  134. Curious - if you could do it over again,....
  135. Has Anyone Changed A Clutch?
  136. Rear Main Seal
  137. Oil Burning Problems? 2001 Rodeo
  138. P0430 code represent which sensor?
  139. Hawaii Rodeo Owners? Having trouble climbing hills (97 Rodeo 3.2)
  140. clunking in front suspension
  141. 2 problems with 01 Rodeo P0430 code & water leak
  142. 99 Passport hesitating to shift into reverse
  143. Torque specs on alloy wheels??
  144. egr valve replacement
  145. FYI - future reference for wheel/rim info....
  146. Pre 98 bumper swap
  147. FAQ Problems
  148. 98 Rodeo Alarm Problems
  149. 96 Rodeo - Problems are piling, what is the cause?
  150. Temporary FAQ'S page until they get the real one up and running again.
  151. Wheels - don't have much choice but to
  152. When will the FAQ'S page work again???
  153. Replacing engine on 2000 Isuzu
  154. CD Player shorted a fuse in link?
  155. Exsessivly high idle 2000-2500 rpms
  156. rattling noise under the hood
  157. Speedometer gear source???
  158. source for '97 chrome bumper end cap
  159. 01 rodeo wont go into gear
  160. auto tranny question
  161. moon roof
  162. OEM rear brake pad set.
  163. to all off roaders... true story..
  164. help 99' rodeo won't start
  165. my rodeo has low power at low end
  166. colorado trail run this weekend
  167. When replacing rotors?
  168. 1995 Rodeo, OBD 2 connector whereabouts
  169. Coolant Problem.
  170. Help with frozen track bar and shock nuts!
  171. Well got some great news...& sad news...
  172. pcv valve doesn't fit 3.2L v6 93 Rodeo
  173. 01 rodeo trans range sensor?
  174. 1993 Rodeo Oxygen Sensor light at 180,000 miles
  175. threw a rod
  176. Passport Timing Belt
  177. Need help withfor my 1996 Izusu Rodeo!
  178. 2001 Rodeo ABS Light
  179. Is 2007 the final year for Isuzu???
  180. Cheap fix for tailgate net in rodeo
  181. Trail run to Bill Moore Lake - lots of pics
  182. 4WD Light will Not come on.
  183. ABS and brake lights on?
  184. 02 Rodeo cooling fan
  185. 99 rodeo shift knob button will not push in
  186. another exteneded drive and...
  187. Going Crazy over this!
  188. 97 rodeo rear glass won't open!
  189. Idler Arm
  190. engine for a 95 Trooper - $500
  191. Stuck Spark Plugs
  192. Freon?
  193. Anybody know about KYB GR2 Shocks?
  194. 1995 Passport V6 Crank No Start
  195. RrABS and BRAKE light illuminated tonight
  196. Code P0430 on my 01 Rodeo?
  197. Tranny fluid question
  198. 01 Rodeo steady cel went off
  199. Overheating - Bypass Hose Coolant Leaking
  200. Multi-Port Injector Question and a few others
  201. Alarm problems with 99 Isuzu Rodeo
  202. 2001 Rodeo Check Engine Light Stays On
  203. 99 Rodeo ECM gets very hot....
  204. Rancho or Sensa-Trac?
  205. Will They Pay ?
  206. Please help!!! power loss
  207. Gotta check this out... what an embarrasement for mercedes
  208. Rodeo 4 wheel drive
  209. New alternator chewed through belt < 1 month
  210. GREAT - Now the tranny fill plug ...
  211. Timing Belt Parts and Bad Auto Parts Staff
  212. CEL problems
  213. Yet another question about cleaning the EGR valve
  214. here's a question that will stump you
  215. Hatch glass
  216. Tranny problems
  217. Standing oil in common chamber / intake plenum!
  218. Power steering problems...
  219. Engaging 4WD - HOW TO on-the-fly-shift for my Honda Passport 1996, Please help
  220. Speedometer on 92' Rodeo
  221. Transmission
  222. Is the tranny relearning??........
  223. rodeo turbo
  224. Clutch Replacement
  225. clean engine compartment
  226. Test drove an '02 Trooper; can't say
  227. 2002 Rodeo V6 oil filter wrench
  228. Spark plug question:
  229. '95 Rodeo 2WD LSD
  230. To Rodeo or not to Rodeo - that's my question
  231. 2 quick questions
  232. Size of ATF coolant hoses?.........
  233. Getting ready for timing belt and water pump swap.. need some advice please...
  234. Rodeo Alarm Buzzer
  235. Sorry a few more auto ??
  236. GM THM 200-4R does our 4L30-E have
  237. Keyless locking and alarm setting problem
  238. cable routing on 94 roedo power windows
  239. Camshaft Position Sensor & Valve Cover Gasket
  240. High mileage ATF for high mileage auto??
  241. Knock in steering
  242. Suspension Questions
  243. 93 Rodeo stalls when its put into gear.. Help
  244. In over my head
  245. My 95.5 Rodeo is totalled
  246. 93 Rodeo Clutch Problem
  247. Random harness in center console
  248. Rodeo02 - need your help in regards
  249. Thermostat only opens after engine is off -- Why????
  250. Replace Mirror
