View Full Version : Rodeo/Passport
- 95 1/2 Rodeo will not start after extended driving
- 2001 rodeo slips in 1st then catches
- Rodeo leaky sunroof
- 1997 Passport reverse gauges
- 96 rodeo
- power/shifting problems..... after hours on road
- Help - Lower radiator hose will NOT
- FPR leaking
- tightening body mounts
- Automatic tranny ?? - at what maximum
- Codes 171 And 174
- Serpentine belt tensioner removal...
- Rodeo Hard Shell Spare Cover
- bad smell...
- 95.5 Rodeo transmission problem
- wanted: misc. parts
- CEL won't come on
- Major RANT!! Arghgh!! - within the last
- 1999 Honda Passport starting problems
- Starter replacement: Do I need
- Where is the Power Window Relay on a Honda Passport
- Squeal Sound...
- MAF sensor - can y'all tell me where
- 99 Isuzu Cam Position Sensor
- Trim on windshield coming off
- '96 Isuzu Rodeo - Suspension problem?
- Rodeo Roof Spoiler
- What does the inside of your intake runners look like after 80K
- Camrys in place of Rodeos?!?!
- Update:correction on the weight of tires..
- Write up on swaping a +98 motor and dash to a 89-94 Amigo:
- 96 Rodeo lights dimming
- Rodeo Fuel Gauge Issues-Sending Unit
- Torque converter lockup
- 99 Rodeo Fuel Gauge Problem
- Starting Problem with my '98 Passport
- TOTAL Windshield Wiper Failure
- Codes P1340, P0300B, P0131
- new shocks or calmini lift?
- CEL on and Check Trans light blinking after low oil
- Engine Failure due to oil pump?
- Rodeo fixed??
- Brakes acting funny..
- Shocks for 97' Rodeo
- CEL 97' Rodeo
- Got p0158 code
- BUCKING Rodeo
- 2000 Passport slipping out of 4 hi while driving
- 93 rodeo tranny problem
- You guys are right again! EGR intake port was UGLY!
- 99 Passport. Code P0405?. Can this affect transmission?
- Heater control valve?
- 2K Rodeo-Ign Key Won't Come Out ?
- tilt steering stuck
- Connecting Spot Lights
- Why won't my back window lock?
- 2000 Rodeo ABS & Engine Trouble Codes
- dissapearing coolant. Help please
- 97 3.2 Rodeo front and rear speakers
- Installing new shocks
- suggestions for adding HP
- Which way should I lean? Help me
- largest tire size for 16" aluminum wheels
- rear brakes
- ???Better Tranny and Tow Rating????
- really wanna lower my isuzu HELP
- Changing spark plugs
- I know I'm going to regret this,
- Burning smell....
- Update to the clunking
- Replacing starter. Trouble loosening exhaust bolts. Passport 99'
- 1996 Rodeo Driver's Side Mirror question
- 2000 Rodeo Headlight / Corner light
- Charging Problem- 98 Rodeo 3.2
- Engine tick
- 2000 passport code p1340
- Engine Gone?!; Clueless as to what I should do, please read!
- Curious: What kind of antifreeze
- Timing Belt
- AutoSave or PremierXTend Product
- Trys to stall when warn start
- Is it really worth it?
- where is isuzu cars/ trucks made
- CV joints/boots
- She's back on the road - belt jumped a
- 4wd problem with 1996 Rodeo
- Isuzu tech. phone number?
- Slightly used EGR valve for sale
- Tailgate Issue
- Gen 2 rear window reg in '97?
- faqs
- I keep blowing fuses
- Fuel gauge problem easy and cheap fix
- 94 rodeo check engine light
- Where Is The Cigarette Lighter Fuse Box 99 Rodeo??
- Another exhaust question...
- 95 Isuzu Rodeo Brake Lights HELP
- FS: 1997 Rodeo 3.2L 153k superb
- '98 Rodeo 3.2V6 Tranny Issues
- compressor replacement
- 94 model: Driver's door is stuck locked!!
- Update on the "DID it overheat" thread....
- Engine Swap Question
- RPM Pause on deceleration
- Pulling a crankshaft pulley
- overhead stuff...
- Torque converter slow to lockup?
- DID it overheat or not??
- Crazy electrical issue.
- Another odd-ball for the record book
- 98 rodeo w/ engine knock
- 95 Rodeo Anti-Lock Brake light stays on...
- Tire Rubbing
- 2002 Isuzu Rodeo Factory Subwoofer And Amplifier
- 1991 Rodeo fast idle
- Persistant Clunking
- failed emissions test
- ac fan switch problems
- Timing belt R&R - Killer, or just a pita?
- 2000 Rodeo just purchased..Need parts
- 2004 rodeo 3.5L
- New Alt and battery but wont hold a charge
- Tail light removal for 01 Rodeo?
- Belt tensioner
- Looking for new parts online (Tail light, fog kit) best place?
- Speed sensor experiment w/clutch
- HIDs in 99 Rodeo
- 1999 Rodeo V6 MT - Exhaust leak - common areas?
- Ok, all O2's are now replaced, but
- 2000 Rodeo for Sale
- IMPORTANT!! Ingition Timing Trouble
- Rodeo 2001 v6 - change plugs?
- New radio and speaker ques....
- Brake light and alarm problems
- Help
- 98 Rodeo Horn
- 98 rodeo (please help)
- Wow! Didn't know spark plugs
- Possible purchase of a 91 Rodeo 2WD Auto Trans...You thoughts?
- shocking...
- fog light question
- 97 rodeo 4wd
- High Pitched Engine Sound upon Acceleration
- My CEL light IS caused by a
- G80 Locking Differential Question
- '97 Honda Passport with 3.2 liter engine stalls...
- 91 Rodeo Transmission
- '94 Rodeo... Replacing fron hubs?
- Few Quick Questions (4wd)
- Just for fun - a Zu ancestor?
- UOA - here it is! Finally did one...
- mufflers
- user bars..for your pleasure
- Battery Light On & Engine Revs: '95 Rodeo
- Isuzu Rodeo Honda Passport Fuel Sensor Sending Unit - Gas Gauge Not Working
- Auto Transmission major problem '99 LS
- EGR problems
- Transmission question
- For Sale, 98 Rodeo 4cyl, needs engine work
- FS - 265/75 R16 Yokohama Geolander AT II
- ABS question
- Inadvertently fixed hard start problem
- Rust coming from A/C compressor (01 Rodeo V6)
- Odd twist on CEL and Speedometer / Speedo gear - 95 Rodeo/5 speed
- Maintenance
- Terrible grinding noise of doom
- Trans dipstick for 2003?
- Engine Code 0155 won't go away
- 1996 Rodeo 4wd Vacuum Switches
- muffler issues
- 250k on OEM timing belt:
- Location of lug nut wrench
- Need assistance - unrelated to Rodeo
- Temporary Hitch question
- Air Bag light on 95 3.2
- 95 Rodeo 3.2 Coil pack
- 92 rodeo - hard start and idle
- 2001 Rodeo V6 tail light & cruise problem
- What do the gauges mean??
- Need exhaust crossover (Y) pipe for 99 Rodeo
- Can I fit a 15x8 Rim on a 2000 Rodeo??? Please Help...
- 99 Honda Passport: Check Engine Light?
- What auto tranny was in the '91-92's??
- 2004 Rodeo 4x4 Conversion
- 97 Rodeo Transmission Trouble
- 2000 Rodeo..Trans light and Cruise set light / Engine Shutdown
- thermostat and overheating
- 95 3.2 please help!!!
- 3.2 Engine Codes?
- Symptoms of radiator blouuuckage?
- Waterproof Altenator???
- changing a side view mirror
- whining noise
- deep creek sea foam and PCV
- Which brand of oil and weight to use
- Hard starting when HOT problem again 92 rodeo
- brake pad replacement
- electronic problem??
- New Isuzu/Colorado truck which -
- jdm engine
- Tailgate removal
- replacing the starter on 97 rodeo 3.2L v6 manual? hard?
- 1st Post! glad to have finally found you guys...
- Some newbie help please
- Squeaking sound on cold days.
- '94 Rodeo A/T probs. Computer?
- changing spark plugs
- getting bigger tires
- hard to shift into gear
- Rodeo needs a weight-loss plan
- Isuzu Rodeo 95 Window Regulator Cable Rewiring Question
- new guy with a used 98 rodeo Ls 4x4
- Please help me rich fuel mixture.
- 1999 rodeo transmission probs
- 94 Rodeo TOO MUCH FUEL (rodeo02 and others!)
- warranty..yes? no? maybe...
- P1391 and P1392 CEL
- Water Pump/Timing Belt?
- Stalling...CEL
- 95 Rodeo 3.2 Realigning timing marks
- Super Charged Axiom video:
- PCV question
- Abs!!!!!!!!!!!!!!!!!!!!
- wiper linkage: help
- Brand New 2004?
- Front turn signal on 95 Rodeo
- Where are timing marks on 95 rodeo 3.2l??
- Probably gonna lose the Rodeo......
- Cargo Panel
- Alternator does not charge
- rear caliper overhaul kit
- a rose, is a rose, is a rose...
- i want a new alternator
- loss of engine power uphill
- oh come on!...CEL again..
- Rodeo 99 LS 4x4 for sale
- For Sale 1994 Isuzu Rodeo
- 01 Rodeo Front Wheels Buckle under tight turns
- 95 rodeo 3.2l help
- 2001 Rodeo starting problems - linked to Alarm?
- Fixing Rust
- will it fit??
- Leaky transmission
- 94 4x4 rear axle
- Opinions on a 00 Rodeo grill modification
- Spark Plug Oil
- egr
- sticky rear caliper pin causing squeal?
- For you oil fanatics....
- Almost lost the Rodeo last night....
