View Full Version : Rodeo | Passport | MU
- No dash lights, DANGER!!
- Reprogram 1998 Isuzu Rodeo remote- can't get it to add new remote!
- Isuzu Insider:
- 94 rodeo mode display
- need a head for my 98 rodeo 3.2 dohc v-6 any recommendations
- Tired of taking the damage
- Should I buy a 2004 Rodeo?
- 1990 Aussie rodeo 4ZE1 Stalling
- diff bolts needed torquing
- Ok, for those that live in the cold...
- Throttle Body on 99' 3.2L V6 Rodeo
- Gizmo - "Tad" from the
- exhaust leak
- stuck in park
- PLz help look for a 89 rodeo upgrade in braks!!!!
- Had alternater belt too tight !!!
- abs problem with 1999 rodeo ls
- '96 Rodeo
- Gabriel Ultra shocks, any feedback
- 1998 Isuzu Harmonic balancer
- overheat - sort of
- Short in wiring headaches!!
- 98 Rodeo - CEL P0171
- how do u find an exhaust leak?
- 98 3.2 misfire on cylinders 3&5 coolant in spark plug tube
- Door Ajar warning
- 99 Rodeo Automatic won't go into 4WD
- In the middle of installing Calmini 3" Lift
- 2003 Rodeo Runing rough
- Sylvania Silverstar Ultra Headlights
- VSS - Vehicle Speed Sensor
- 93 rodeo - alternator keeps packing it in
- 265/75 R16 on stock wheels?
- Best thing a Rodeo Owner can do is!
- Anyone have a gas tank/fuel pump for a '96 -'97??
- Whistle or somthing when engine reeves?
- Well, had to say good-bye to an old....
- Fix somthing, break somthing else...
- Factory driving lights are they worth it??
- 1997 3.2 with low acceleration
- ck trans light and cruise engage light
- Clock Light on 2000 Rodeo
- Starting problems, fuel related
- Dtc 1870
- Reap wiper motor - 1999 Passport
- 94 Passport 3.2 bad injectors
- piston condition
- Isuzu Rodeo 1999 - DTC 0336 Crankshaft Position Sensor
- Capacity of Power steering fluid?
- 1998 Isuzu Rodeo AC troubleshooting
- 1998 Rodeo Thermostat replacement
- first real issue with the engine...
- Passport Check engine & check trans
- totalled!!!!!!!
- Rebuilt Cylinder Head v. Machine Current
- CEL came on but goes off when I don't give it any gas
- Seafoam, synthetic oil, etc.
- 97 Rodeo, 4x4
- How the #@%*&!!!
- 4L30E Bang Shifting into 3rd
- No juice to starter on 93
- fuel filter
- FL offroad content
- 2000 Rodeo, 3.2 idle air control/CEL/tranny
- 95 Passport...runs rough...coolant leak...head gasket?
- Changing timing belt
- 99 Rodeo trouble codes - MAF or VAF High input/Low input
- 1994 Isuzu Rodeo 3.2 v6 will not start
- Shell Rotella facts
- Best trouble code reader for 1999 Rodeo?
- 2000 Passport stalls
- Seeking hitch for 2004 Rodeo (3.5L)
- Just is NOT my year - sorry for the rant....
- Power window switch problems
- 99 Rodeo ABS
- Rodeo fuel gauge gas problem issue sending unit needed
- ABS Light Activates at odds Times..
- 1999 Rodeo ?
- Cleaned Trans mode/sensor now bent linkage?
- help me help you
- Question about shocks/mounts
- '93 Rodeo 4WD front drive axle
- is th e3.2 an interference engine
- Gage Cluster for 94-97 Rodeo
- Need some Dashboard help - Remove Speedometer Assembly
- Car died
- Volunteer
- ABS Light
- 97 Rodeo 3.6 4x4
- 94 rodeo, back seat floor saturated when it rains
- thermostat housing
- Moon and Gamble Gulch trail run pics
- Check Engine Light...Bad Computer?
- Serpentine belt tensioner removal 99 3.2L
- Alldata Service
- front and rear bumpers
- valve adjustment 99 Passport
- Help with rear ABS Sensor!
- Rodeo related... trust me.
- Curious, if you don't mind me asking - -
- Who has the best dealer prices...
- HELP!! High Pressure Hose on Power Steering
- ABS codes
- Where is the starter?
- Emblems and or Badging
- Range sensor or other issue?
- oil found on plug galley...
- Going to 265/75/16 should I also do the shocks?
- 3.5 L transmission
- Re:1993 Rodeo Transmission Check Light Fashing
- Crankshaft pulley removal methods?
- coil spacers
- Colorado trail run Sept 24th
- Just got a lift kit, good deal?
- spedometer light replacement?
- Tar Leaking from Door Panels
- HELP!..Idle issue with high ppitch whistle
- checking low gas light
- aftermarket parts for rodeo..
- need help, no dash lights
- Isuzu Diesel won't Start
- check engine light after replacing starter?
- Rear differential service
- leaking coolant, where is it coming from ?
- 02 Rodeo No A/c
- 98 Rodeo - Fuel Gauge
- Check Tranny light
- Gizmo42 - have you been up Rollins
- 1994 Honda Passport - Clueless
- 94 Passport 3.2 running rough
- 4k mile trip in 93 Rodeo 5 speed 2.6L
- Is there a classified section ??
- Luv the Honey Comb passport rims !!
- Getting to rear brakes
- 2000 rodeo 3500 rpms at 75 mph..what do i need to do
- blower switch melted
- R - U - A - Moonroof / Sunroof Buff?
- starting
- CEL Code #1171
- 2000 Honda passport Spare Tire Cover
- Rodeo sputters on start/take off
- towing 4000lb with 98' Rodeo
- Blower switch wiring diagram?
- West Magnolia/Kingston Peak/Yankee Hill trails loop
- Loose Alternater belt -- on 95 Rodeo
- Replacing rear brake pads
- Morons Strike Again (Oil Change)
- Automatic Trans not shifting.
- P0401/EGR CEL code seems effected by
- Purchase it or pass?
- how to check the trans oil level
- overheating
- Think my starter going. Need Help.
- Driver side wiper wont turn
- 98 Rodeo 4x4 not engaging
- [Off topic] Jeep wheel thread
- St. Charles Isuzu:
- Starter
- What Weight Gear oil?
- how angry am I?
- 2000 ls rodeo 93000 miles goes crazy when i get to 20mph
- 94 Rodeo Tranny/Brake problem ??
- new catalytic converter - now more problems.
- Oil Pressure High
- why do aftermarket alternators not work?
- Let's give moment of peace for the Great
- stupid clutch
- Big Cypress Preserve, FL
- Where is the iac valve for 97 Rodeo?
- Few issues with '94 Rodeo 3.2. Probably unrelated.
- 93 rodeo stalling and no turn signals
- Is alternator needed for starting?
- Front turn signal lamp "socket"
- P1125 TPS signal intermittant
- Replaced shocks - a few questions
- Gizmo: How do you like the Daytons?
- rear wheel bearings
- 1998 Isuzu Rodeo Exhausht
- '98 Rodeo low fuel pressure
- Finally got tranny rebuilt
- what could have happened?
- 1997 Turns but doesn't start
- 98-02 Rodeo-Ever had the Timing Belt break?
- Where is coolant drain plug?
- torque converter cover missing bolt
- Several warning lights (transmission dificulty)
- Steering Boot
- P0300
- 1993 Rodeo Transmission Check Light Fashing
- 1994 Passport engine miss
- Heater-inlet Hose
- 98 Rodeo - Lug Nut key/locks
- '99 LSE Won't Start
- 94 passport heater core
- combo of dash warning lights.....diagnosis?
- Please Identify this part
- Cross reference. Bracket needed
- Tire/Rim question
- Idle air control valve
- A/C expansion valve location on 99 rodeo v6
- 1998 Rodeo Isuzu Window and Cruise won't work
- engine swap
- 2000 Rodeo Door Popping
- Strange Transmission issues- 99 rodeo
- Small Gas Tank Issue
- Window washer question
- Where do you folks get parts?
- 94 rodeo engine problems
- 95 rodeo 3.2L 4WD 5 speed gas mileage?
- 1993 V63.2 4WD wheel bearing
- Fan Clutch - how many of you have had
- Timing belt, plugs & hoses
- 96 Rodeo Gas Pedal Sticking Pictures!
- Yankee Hill / Loch Lomond trails run pics
- 2001 Rodeo brake light problem
- Repairs Cost: Front Brakes, T-Belt, water pump etc
- Air Conditioning Myth !?!?!?
- '99 Passport trans filter change
- Found an engine for a '97
- Extended warranty
- 1998 Isuzu Rodeo 4X4 problem
- 01' Rodeo p300 code/Randm mtpl cylndr msfire, HELP!!!!
- Low Mileage 96 Rodeo on Ebay:
- What Is Better?
- off-topic help
- 94 Rodeo ATF coolant lines
- 94 Rodeo is gutless til "Check Engine" light comes on
- rodeo shocks..
- Cross country road trip chcklist; have I
- 1998 Isuzu Rodeo AC not engaging
- Surferfletch - can you advise me
- Rodeo Gas Pedal Sticking and Brake Fluid Light on HELP!!
- Rodeo problem.
- '95 Rodeo... no Instrument Lights
- Starter?
- Rodeo Alt OEM New on Ebay:
- dirty egr stealership$$
- proud of my battery
- 2000 Isuzu Rodeo - Electrical
- thermostat
- Heavy duty radiator replacement?? ......
- '98 Rodeo A/C Compressor Won't Engage
- 1998 Isuzu Rodeo Rear Axle
- Back to smaller tires - anyone interested ...
- 97 Passport- Not getting enough charge
- Alternator Again!!?!?
- Problems never end
- '94 Rodeo overheating issues
- Parts/ classifieds
Automotive Network, Inc., Copyright ©2013
