View Full Version : Rodeo/Passport
- Cat Question
- Spare Tire, How do I remove?
- Rodeo/Passport history?
- 2000 Passport Auto Transmission problems
- what to do...
- Hitch Install - weekend project gone awry
- Ramdm mtpl cylinder misfire, HELP!!!!!
- Maintenance Questions
- How to tighten rear glass???
- New to Passport, have some questions
- battery question
- Tranny Trouble (again!)
- 1996 isuzu CPU Problem?
- need help with 93 Rodeo Izusu Regulators for Windows V6 3.2
- 1999 rodeo 2.2 code p-1627
- Help! My cat ate a golfball!
- 94 isuzu rodeo crankshaft pulley removakl /install /torques...????
- Need running trouble shooting help with my 99 Rodeo
- Isuzu Rodeo Glow Gauges Dim / Broken ?
- Help - am I being taken for a ride?
- Where do I get an oil pump?
- Help Finding Intake Air Temperature Sensor
- Replaced Starter and Look What Happened!!
- Intake manifold torque settings.
- Cam Position Sensor error code
- 1998 Rodeo Fuel Pump Help
- 2001 Rodeo 3.2 "Bucking" on acceleration
- Black clutch fluid, hard to shift
- LOOKING TO BUY: Rodeo Soft-Top
- Speedometer question
- Rodeo driving lights replacement
- 98 Rodeo will not idle??
- 01' Rodeo transmission question
- CEL code P0342
- 99 Rodeo Coolant Coming Out Under #6 Coil Pack
- questions on 2000 rodeo
- 2000 Rodeo Bizzare Electrical Short?
- FWIW - Napa Gold 1334 oil filter's
- Got code 0157
- 1997 Passport alarm issues...HELP!!!!!
- I give up! CEL P0401 is BACK
- Selling my baby: 2002 Rodeo Sport V6/AT/2WD Softie.
- HELP (Please) 2000 isuzu rodeo, transmission
- Rims 4 Sale
- How often tranny replaced or rebuilt?
- Valve tick!!!
- How to relieve overcharged A/C
- Can a Rodeo be flat towed behind an RV?
- Goodbye Rodeo
- A/c question on a 95 passport.
- 2002 Rodeo Sport...roof removal?
- Help with 4wd and my new Tranny for 98 Rodeo
- surging rpm
- A couple questions.
- 97 rodeo 2.6L code p1406
- Please Help!
- Where are the EGR and Idle Air Controller Valves located?
- Rodeo 2001 3.2 Starts rough when cold and ofter dies
- Timimg belt Problems
- Replacing the rear main oil seal on 96 Isuzu Rodeo 3.2L
- jack storage?
- 95.5 Rodeo 3.2L cranks but wont start
- 2000 rodeo radio wires
- tranmission help
- ac compressor
- Fuel Pump gauge Flashing
- 92 3.1 rodeo no spark interm.
- Few tranny issues
- 99 Izusu - Fair Prices for Atlanta Repair?
- Rodeo SAS on 44's
- Replacing the belt idler pulley...I think
- 1995.5 windshield washer help
- 95.5 Passport Maintenance/Repair costs
- Type of Coolant?
- CV Driveaxle replacement
- High Idle on Rodeo 3.2L...tried various things
- lights on dash
- Door won't open from inside
- '01 Rodeo Hard Starts
- Transmission overfilled??
- Help With wiring..or something else?
- Help!! My Car Is Dying!
- 94 Rodeo 3.2 Headlights stopped working
- Central Locking System
- 98 Isuzu Rodeo Ticking/Rattling problem solved finally
- Timing belt--Where to buy, what do I need?
- transmission 2001 rodeo
- My Passport is running ritch..? Or is it something else? Ramblin where are ya..
- 2000 Isuzu Rodeo Spring Cleaning....Lots of stuff forsale...
- 96 Passport Low Idle
- 99 Passport Brake Pedal/Dash Lights
- cel flashing only when accellerating?
- EXACTLY which tranny fluid goes into
- Seal replacement on auto tranny
- tail light help!
- Replacing rotors and pads on 00 Rodeo... DIY job?
- Spare Tire Carrier
- Methods to Lower a 99 rodeo
- Driver's side window
- Pulling Engine and Transmission?
- 1998 Rodeo Calipers
- Help With A 96 Rodeo That Wont Charge
- Easy way to figure out the bad ABS sensor
- Turn the key and nothing
- Where to get wiper relay for intermittent prob?
- a few offroad pics of a couple isuzu's
- 1994 Isuzu Rodeo Oil Filter... whereisit?!?!?
- oil leak on 1997 isuzu rodeo
- Whining sound after replacing starter??
- Question about shocks
- whirring under the timing belt covers
- 2002 Rodeo for sale
- Think maybe after 10+ tries to start
- Exterior Maintainence
- pepboys...
- help I need to fix my truck
- Compressor clutch replacement instructions
- Scrapping noise coming from the passenger side
- How do you clean the MAF (mass airflow sensor)
- 95 Rear Doors Locked
- Bad fuel pump or bad gas
- Please Help!?!
- 2000 Rodeo rebirth
- Engine is ticking and CEL is on code 1406
- P1404
- 2001 tube steps...
- Doing some work this weekend
- No Clutch!!!
- My next truck?
- Rodeo to Rodeo Sport seat swap??
- rear bearing replacement
- 1999 Isuzu Rodeo eating batteries
- 94 rodeo.... engine ticking noise @144,000miles
- Installing ARB Bumper on 2nd Gen Rodeo Today...Please Help!
- must be something minor....
- Momentary electric loss while appling breaks
- Rodeo Passport Fuel Sending Sensor Unit-Bad Gas Gauge
- Replacing a bad A/C Blower?
- replacing clutch in 95 rodeo 4x4/advice
- 2002 rims on a 99?
- Cracked Head and Head Gaskets
- 98 Rodeo LS V6 Automatic with Brakes Grinding
- Rodeo hard starting only when warm. Need some info...please.
- Change timing belt?
- where are the tailer light hook up??
- Throttle body - wow, nasty, cleaning as I
- Valve adjustment on 2001 V-6?
- obd2 scan tool, which one?
- intermittent rattle/grinding noise
- Auto Hubs will not lock on 2001
- changing auto tranny fluid, good idea or not?
- HighlandLake - can you repost your EGR
- Is it possible just to replace the A/C compressor clutch?
- coils on ebay:
- Piston ring replacement
- Help identify this hose ....
- How can I stop 3.2L valve cover gaskets from leaking?
- AC Condenser fan question?
- O ring and Piston rings
- Maf?? O2???? Egr??? 94 Rodeo
- Bad O rings
- Coolant hoses - There are 12 coolant
- Brake Pedal Moaning
- Bye Bye GM....Almost
- CEL turned off by iteslf
- OIL PRESSURE 94 Isuzu
- I need help with my 1999 Passport!
- A/C buzzing sporadically...Any ideas?
- 2001 Rodeo Sport-misc. questions
- 2000 rodeo leaking oil into plugs 1 and 3
- 3.2 rodeo compression
- Fog light question
- Trying to pinpoint noise
- Heater/Radiator hoses - do NOT be fooled
- to all rodeo experts out there...my 2001 rodeo is killing me
- just got 2000 LS 4X4...speaker question
- Brake and Battery Ligh Flashing
- Got my smitty's mounted
- My front rotors are warped again.
- MAF sensor - can I clean with LEAVING
- 12.75v draw on battery-can not find problem
- This site is awesome
- Did I order wrong plugs?
- Timing belt question
- Rotors - anyone else still running original
- cant figure out overheating problems
- Snow chain question
- 1995 Passport rear hatch rattle *ANNOYING*
- 4WD problem - getting desperate
- 1997 isuzu rodeo trannny hose leak
- 2000 Rodeo
- high voltage - 2000 rodeo 2.2L
- new battery question
- white exhaust smoke
- Almost new EGR valve on Ebay
- Replacing the t-belt
- high idle
- Brake Expert Needed! Vacuum Booster squeaks when I press/release the brake pedal...
- Air Conditioning Squeel
- PVC valve removal
- Rodeo Sport V-6 Engine Blows
- Intake?
- Please Help me make sense of these codes. P1404 , and P0405 - EGR Related
- 2001 Rodeo Opinions
- white smoke??!! 98/99 auto 2WD
- 99 Rodeo LS in shop with timing belt, question
- what shocks is best for rodeo?
- First time Tranny Flush at 48k?
- Environmental fan doesn't work at position #4
- 14.7
- Types of tranny fluid? Can they be mixed??
- '99 Rodeo stalling when decreasing to low speeds
- acceleration/idle issue.Help
- 97' 3.2 with 4L30E/auto. Slow/Harsh downshifts when coming to a stop
- EGR Harness VOM readings
- burned oil smell
- 4wd question
- 2000 Rodeo Hesitation on Acceleration
- Guages gone nuts - Please Help!
- Rodeo Passport Fuel Gauge Problem Fix-Sending Unit
- problem with door hinges
- Spark plugs
- 94 won't idle
- Problem with Idle 99 Rodeo
- code 0128 on isuzu rodeo 2001
- What Air Filter
- Hot Rodeo! - Help!
- 2000 Rodeo Tranny Filter Change
- Rodeo LS Heavy Duty Shocks
- 1996 Rodeo Transmission fluid/filter change.
- Simple Stereo Upgrade?
- Want to change/flush tranny fluid, but have heard of horror stories in doing so!!Help
- I want to give my car a tune-up (Spark Plugs, Spark Plug Wires) Hard to do??!?
- Advice Please; I did the EGR clean(let me know if I did right) + O2 Sensor.CEL!!!!
- 1991 Rodeo Sounds Like A Spaceship In Mid Flight
- Replacing O2 Sensors, difficulty? Price$?
- Intake Manifold Gaskets Covered?
- 96 3.2L 107K P1406 code
- flashing CEL
- How many odd-ball 4x2'ers do we have
- major repair help - sunvisor clip
- '95 passport headlights
- 1999 Rodeo 3.2 code 301
- belt squeal help
- Auto Gear shift not releasing from park
- Fuel sensor for isuzu rodeo
- Valve clearance adjustment?
- 96 rodeo starting problem
