View Full Version : Rodeo/Passport
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23
  1. 95 rodeo
  2. 03 Rodeo replacement engine
  3. Whistling @ 2500 RPM
  4. help diagnosing sound
  5. Help! Surging and frequent stalling when A/C is on!
  6. Squeaking front end driving me nuts!!
  7. sluggish acceleration
  8. 1992 rodeo bad fuel pump
  9. transmission removal/transfer case 94 rodeo M/T
  10. 1995 Honda passport stuck in 4wd
  11. Re:Sounds like marbles in motor when I accelerate
  12. '96 Rodeo brake and ABS lights constant
  13. Running hot, AC cuts off
  14. finding a bad gas leak
  15. Lean on Both Banks
  16. How much Seafoam?
  17. '95 Rodeo 4cyl./5sp. random stalling
  18. 99 4WD Rodeo LSE ABS lights up driving over 70mph.
  19. 96 Rodeo, Won't Charge Properly
  20. P0442 code- purge solenoid need help
  21. 94 isuzu transfer case help
  22. Leaking valve cover ...
  23. Fixing it the Old Fashioned Way
  24. 1997 Left Rear Window Regulator
  25. Want to change Rodeo trans fluid?
  26. ABS sensor problems
  27. '93 Rodeo 4WD right front wheel noise
  28. CEL p0442 Can an exhaust leak cause this code?
  29. 2004 Rodeo burns 1qt oil in 3K miles
  30. Error code P1403 Rodeo 2002
  31. 92 Died and won't start
  32. Please help with my dumb transmission!
  33. 2001 Rodeo Reduced Power Light
  34. trans fluid-flush it or change it.
  35. suspension/handling recommendation
  36. brakes again.
  37. Stopped on Hwy and won't start
  38. new engine codes for me
  39. Starter??
  40. Air Conditioning
  41. Engine ig fuse keeps popping
  42. Speedometer-wacko
  43. 98 Rodeo Starter Issues
  44. Intake manifold
  45. 01 Rodeo fan belt replacement
  46. 1995 Passport sounds like a diesel
  47. map sensor
  48. 1996 Rodeo factory am-fm cassette
  49. Safety check before I try to add trans fluid
  50. Teeny Tiny light bulbs
  51. FOB Issues
  52. transfer case/transmission
  53. transfer case pull/install? 94 rodeo 3.2
  54. Stripped EGR bolt hole
  55. Radio problems
  56. 1999 Rodeo LS V6 spark plug/coil diagram?
  57. 92 with starter problems
  58. To buy or not to buy transmission
  59. Fuel Injector o-rings
  60. low compression on rebuilt 4ze1 motor
  61. 1999 Isuzu Rodeo - Won't Start After Long Distance Driving
  62. rodeo efi 4ze1 motor kicks but wont start
  63. 1996 Passport, battery crosswired
  64. rodeo 4ze1 efi kicks but wont start
  65. Fuel Gas Sending Unit Rodeo 1998-2002
  66. Thunking when turning
  67. P0440 continous -Solenoids good
  68. 1999 Isuzu Rodeo, bad knocking noise
  69. Parking/E-brake
  70. Will GM 6 lug wheels fit my 92 rodeo
  71. Crankshaft wont turn
  72. 94 Psprt 3.2L4x4 diesel swap, wasting my time?
  73. Audio help?
  74. 2000 Rodeo - Knocking, Rough idle, misfires, surging
  75. Fuel pump problem
  76. Rear cam plug leaks...
  77. Cracked block?
  78. 1997 Rodeo Suspension
  79. transfer case issues???
  80. Wix Oil Filter
  81. #6 coil
  82. Radio change question.
  83. running rough- fuel filter/pump/system?
  84. Looking to buy
  85. My "new" Rodeo is finally ready!
  86. Isuzu Rodeo and Honda Passport same?
  87. random misfire code
  88. decarbonize?
  89. Fan in front of radiator in 97 passport
  90. First time doing a larger job successful :)
  91. computer system
  92. Electrical connections to 94 Passport 5 speed
  93. 93 Rodeo cranks but won't idle. Help!
  94. Blower not working
  95. 95 Rodeo, 1st gear will not kick in....
  96. Hello friends of the rodeo isuzu engine is so noisy?
  97. hello my freinds i from guadalajara mex. I need your help to find the harness that co
  98. power steering fluid leak
  99. 1995.5 3.2L V6 Engine
  100. 1997 Honda Passport Timing Belt Issue
  101. Transmission Control Module
  102. 1999 rodeo..wobbing sound while driveing slow
  103. Can the 3.5 replace the 3.2 in a 2001 Rodeo sport?
  104. Can 3.2 replace the 2.2 in a 2001 Rodeo Sport?
  105. 2004 Rodeo with 3.5L DI CEL ALERT
  106. TIMING belt and tensioner
  107. 2001 4 cylinder dead after oil change/ flush
  108. new img: now high idle.
  109. ticking like its nearly out of oil
  110. CEL Help
  111. 01 Isuzu Rodeo, Clicks Once, Won't Start
  112. Engine noise
  113. CEL is flashing, HELP!
  114. Engine pull update.
  115. 01 Isuzu Rodeo 15a ECM Fuse
  116. accumulator Piston Cover.
  117. check engine light and reduced power light
  118. help needed-bizarre electrical short on 99 passport.
  119. Misfire causes?
  120. 2nd Gen Intake Manifold Gasket
  121. bleeding 2000 rodeo ABS modulator... Help!
  122. Code P1171
  123. WHOA. not what bucking snorting backfire
  124. Negative / Positive Speaker Wire , 01 Rodeo
  125. Rear Diff Maintenance
  126. Thanks from a lurker!
  127. Running out of ideas, 95 Rodeo
  128. what is the tank size?
  129. Axel/CV Boot
  130. '97 w/ headlights but no parking lights??
  131. 95.5 air bag
  132. 99 rodeo rear wheel lugs
  133. '99 2.2L p0301/idle help
  134. Engine Rev in Park
  135. 95.5 rodeo pcv valve / grommet 3.2
  136. Camber kit
  137. loose steering wheel.
  138. Time for a new exhaust...
  139. Engine swap possible w/ GM 4.3 V6
  140. Rodeo body lift
  141. 96 Rodeo Losing Power
  142. manually open sunroof--2003 Isuzu Rodeo
  143. where can I find a 98 rodeo relay diagram?
  144. I almost sold my Rodeo, continued....
  145. i need this A.S.A.P
  146. point me in the right direction
  147. Replacing IMG
  148. 98 3.2 4x4 engine stalls
  149. Alignment Issue
  150. another problem
  151. *UPDATE on "EGR P0401 that won't go away"
  152. 98 rodeo wiring problem
  153. Can I do these myself?
  154. 1994 passenger side door
  155. Transmission Question.
  156. After warm up
  157. Alternator
  158. 1997 Rodeo idling problem update
  159. 97 Rodeo Issues
  160. 1997 rodeo sensor problem
  161. Knocking noise at speed
  162. H e l p
  163. High output alternator?
  164. passport coolant o-ring size
  165. Rawl fuse
  166. Key stuck in ignition...again!?!
  167. '99 Passport not firing on passenger cyl bank
  168. roof rack cross bars how to install
  169. rear noise
  170. 1994 Rodeo Thermostat Housing
  171. 95' no cold start
  172. 1993 Rodeo Overheating
  173. 4X4 Light Blinking
  174. 94 passport no 3rd gear shift in 4 wheel drive?
  175. 1995 Isuzu Rodeo, Trans Problem
  176. 99 rodeo 4wd, replaced starter still no luck.
  177. exhaust question
  178. Electronic Throttle Control
  179. 2002 rodeo-tail light fuse shorts out
  180. P0172
  181. Hard Starting Blues?
  182. Hood latch problem
  183. 99 Rodeo 3.2 hunts, stalls Code P0101-0102
  184. 1998 Rodeo Started Problems
  185. abs brake light indicator - failure?
  186. axle issue
  187. 01 passport need door handle
  188. 98 Passport - 4WD Not Disengaging Consistently
  189. 98 Passport - 4WD Not Disengaging Consistently
  190. Fuel Pump Seal issue
  191. rodeo engine suddenly turns-off while driving?
  192. Rear Wiper Will Not Stop!
  193. Interior Temperatur Control Cable
  194. Drivetrain Light on
  195. '95 Rodeo 3.2L Tune-Up Questions
  196. New Owner maintenance questions
  197. side view mirror on rodeo
  198. P0116 ECT Circuit Range/Performance CEL Help
  199. Flipping upper ball joints on a lifted Passport
  200. 2000 Troubles starting
  201. 2000 Troubles starting. . .but it always starts eventually.
  202. Oil Pump replacement
  203. Rear End Shake/vibration
  204. Opinions on dipstick heaters please
  205. Replacing leaf spring bushings and engine ticking...
  206. 1997 Transmission slip in 1st gear
  207. 98 Rodeo Catyl. exhaust flange to header
  208. 1996 Rodeo interferance engine ?? yes or no
  209. Blinking 4x4 light
  210. EGR P0401 That will not go away
  211. Please Help 4cyl Rodeo.
  212. EVAP Canister Vent Solenoid
  213. Removing Transmission Pan Bolt 99 Passport
  214. '00 3.2L 6VD1 Valve Adjustment
  215. 94 Passport 3.2L starting problem
  216. 94 Passport 3.2L starting problem
  217. Coolant Crossover o-rings?
  218. 99 Isuzu 3.2 - upgrading to larger oil filter?
  219. '99 Rodeo - won't start after accident
  220. I almost sold my Rodeo
  221. EVAP Canister Vent Solenoid
  222. Shocks to replace ISC ones.....
  223. 04 rodeo workshop manual
  224. crankshaft position sensor on 99 isuzu rodeo
  225. gas gauge not working? same for 94 rodeo?
  226. 2000 Passport Rear Wiper not working
  227. New brakes and Front Bearings $1000????
  228. Wipers come on with turn signal
  229. new timing belt wearing very fast.
  230. Worn timing belt
  231. Free Cupholder for '90-'96 Rodeo!
  232. New Isuzu owner.....
  233. another oil guzzler
  234. My smoking 01 rodeo..
  235. Key won't release from ignition
  236. 98 Rodeo 3.2 4x4 code p405 help!!
  237. Really stupid problem.
  238. Harmonic balancer
  239. 97 Rodeo accelerator cable
  240. 97 Passport Timing Belt Replacement
  241. What are you buying your Zu for Xmas?
  242. 95 Rodeo Repair Manual
  243. 2001 Rodeo 6cyl - Timing Belt or chain??
  244. Anyone DIY remote start?
  245. 2004 3.5 Rodeo Will Not Start
  246. 04 Rodeo 4wd Problem
  247. still having problems with my 3.2
  248. 96 Rodeo 3.2 no power and sputtering until TPS is > 60%
  249. 98 Rodeo 3.2 4x4
  250. Red Dust? All Over Pulleys
