View Full Version : Trooper/SLX
Pages : [1] 2 3 4 5
  1. 95 Trooper spark plug wires coming off plug (NEED HELP)
  2. 1986 Trooper Accelerator Pump Piston Leaks
  3. 1986 trooper 2 water pump replacement
  4. Isuzu Trooper TOD check light
  5. 1999 trooper cranks but no start
  6. 1992 Trooper Rear Axle Bearing Retainer
  7. 2000 Troooper CEL codes
  8. '91 Trooper, is there an eng. larger than the 2.8L V6 original that will interchange.
  9. Trooper to Vehicross engine swap
  10. 1989 Trooper Engine smog and swap
  11. 96 Trooper Power window problems
  12. 92 ABS pump keeps running when off? Ideas?
  13. 97 Trooper Brake Issue
  14. indicator lights
  15. 1998 Trooper Idle Problem(Please help please)
  16. 2000 Trooper 3.5 v6 Check Trans Blinking
  17. Sounds like marbles in the engine?
  18. 88 trooper dummy lights come on and off ??
  19. 00 Trooper Failed Inspection for HO2S Problem
  20. 2000 Trooper Transmission Fluid/Filter Change
  21. Bighorn Injection Nozzle Pressure
  22. has any one tried this for 90 trooper 2.6 starting prob
  23. tropper 2.6 will not start
  24. Replacing the Oil Pan Gasket on a 2000 Trooper?
  25. 2000 Trooper 4WD Tranny Leaks
  26. Isuzu Trooper air vents blow even when off
  27. 1990 Trooper Won't Idle Until Warm
  28. Changing out freeze plugs on Trooper
  29. 95 Trooper Leaking Coolant
  30. 90 not getting fuel through injectors
  31. Replacing Stock Shocks
  32. 94 trooper leaking oil
  33. Problems after 00 transmission rebuild
  34. 1993 Trooper Check Trans Light
  35. 91 trooper
  36. Weird #3 cylinder misfire
  37. 93 Trooper Front tire locking
  38. Been There Done That. Guys I break question.
  39. '94 AT DOHC Chk Engine and Cutting out
  40. 94 Trooper turn signal issues
  41. '92-'02 Trooper Third Row Seats
  42. Does Denso Plug K16PR-P11 = PK16PR-11 ???
  43. Lights out on Climate Control Console 2000 Trooper
  44. transmission/isizu trooper limited
  45. 91 Trooper timing problems
  46. Blower Motor Going Bad -- Or is there something else going on???
  47. TOD flashing - code 31
  48. Sun Visor Needed for a 2000 Trooper
  49. Trooper driver side front seat?
  50. 1995 Isuzu Trooper
  51. Trooper 2001 transfer case fluid
  52. 88 Isuzu Trooper won't move. Help.
  53. 94 trooper check engine runs bad
  54. Intermittent CHECK ENGINE light on '92 DOHC
  55. 6VD1 advice needed for low compression (expert pls)
  56. 6VD1 advice needed for low compression (expert pls)
  57. Clutch pedal fails in cold weather
  58. 97 Trooper transmission stuck in "Power" mode
  59. 93 Isuzu with noise in right front wheel
  60. Wet Floor Board Driver Side
  61. No power
  62. Alternator output for transmission.
  63. Are there alternative trannys for 98 Trooper?
  64. Transmission flush
  65. HELP! 96 Troop 3.2 No Start
  66. Hello everyone!
  67. 2001 Trooper Heated Seat problem
  68. '94 Isuzu trooper with 158k miles
  69. How to ruin a CAT?
  70. 1999 trooper severe misfire
  71. fuel pressure
  72. Moms needs help changing alternator belt
  73. Friend drained Trans fluid instead of oil!!!
  74. 1992 Trooper - No Directional Signals
  75. starts with a little help.
  76. 1997 Trooper console question. is there enough room behind......
  77. starting problems
  78. starting problems
  79. 96 Trooper overheating
  80. Looking at a 1986 5 spd Trooper II
  81. Fuel Pump Replacement on 2000 Trooper
  82. wiring problems
  83. Trooper 2002 Transmission Problems
  84. 99 Trooper TOD/SOTF-4x4 Issues
  85. strange cluster warnings after battery/alternator trauma
  86. Help: CDs stuck in 2001 Trooper
  87. 2002 Trooper noise
  88. 1984 trooper w/1.9 flooding and not starting
  89. bolts for 88 trooper flex plate
  90. 2001 Trooper bad tranny leak, then nothing
  91. 1986 trooper won't idle
  92. Wheels keep turning
  93. Rear End Troubles
  94. 1996 Trooper engine Replacement
  95. Isuzu guidlines for engine replacement
  96. No compression, help
  97. 1998 Trooper Serpentine Belt Problem
  98. 86 Trooper dash lights stay on and runs poorly
  99. 99 Trooper blown tranny seal? Please Help!!
  100. Power Steering Pressure Switch
  101. 94 Trooper S Dash Lights Came on Blower stopped
  102. Engine Replacement 99 Trooper
  103. 88 Trooper parked for 6 years
  104. Please help....Transmission issues.
  105. Power Drive won't turn off!
  106. 95 Trooper Oil Leak
  107. Will GM engine/trannys fit in 99 Trooper?
  108. 1990 trooper coolant leak INSIDE car
  109. 3rd new starter in 6 months
  110. how to change the plugs on 94 trooper?
  111. 99 Trooper Poor Mileage Highway Driving
  112. Check Engine Light - Finally Got The Codes
  113. throttle choak?
  114. 99 Trooper spark plug - Tune up
  115. towing with my 96 Trooper
  116. 2000 Trooper leaks
  117. 2000 Trooper Fuel Injectors
  118. 91 2.8 v6 trooper no fuel
  119. Wing window adjustment
  120. 99 Honda Passport, reverse only working
  121. Heater, Idiot lights and alternator failure?
  122. Timing chain
  123. 1994 Trooper rough start?
  124. 1994 Trooper cooling issues
  125. 2001 Isuzu Trooper Fuel Filter Change
  126. oil around spark plug boot???
  127. 2000 Trooper Front Disk Removal
  128. OBD Code 0440 - EVAP System Malfunction
  129. Shifter boot
  130. Flasher location
  131. 2001 Isuzu Trooper O2 Sensor and Plugs
  132. 90 Trooper 4wd not working
  133. Manual hub question
  134. need cooling part name
  135. where? and how to clean idle controller?
  136. passenger side window doesn't stay up
  137. 1987 Trooper
  138. 88 trooper not starting
  139. Carburetor Problems??
  140. Power Mode/winter Mode
  141. Totally messed up firing the order
  142. 2001 tod
  143. 98 trooper coolant leak
  144. Hours needed to replace LS/RS front axles
  145. 94 trooper automatic transmission
  146. Is the 2000-2002 Trooper a good vehicle?
  147. Just paid off the Wife's 2000 Trooper
  148. 93 3.2 V6 2dr Trooper Oil Pressure Gage
  149. driver mirror stuck
  150. 99- going off road, advice
  151. Rough Idle...Loss of Mileage 17 to 13
  152. Trooper 99 fix or sell as parts? (65000 miles)
  153. 94 Trooper - Check Trans Light
  154. 1997 Isuzu Trooper ABS Light On, Flashes Code 53
  155. Alternator advice
  156. tricky sidelights
  157. 89 trooper missing after warmup
  158. The mysterious heater blower
  159. MAS 1996 trooper
  160. 1994 trooper TCM
  161. keyless entry!!!
  162. I have a 1986 trooper II can you help me
  163. 91 Trooper LS questions
  164. 1990 Trooper 5spd 2.6 CLUTCH Change-out
  165. Ticking, Tapping, Rattling Trooper
  166. Power steering pump or something else???
  167. Will 95 rodeo 5speed fit in a 94 trooper
  168. Transmission fluid: whats too hot or too cold
  169. '95 Trooper Brake and ABS Lights
  170. Another 2001 Trooper Tranny Q
  171. remote key programming help??
  172. 2.8 L fuel economy?
  173. 99 Trooper TOD Green Rear Wheels Flash then CHECK but 4wd Works Fine
  174. Mysterious battery drain on 98 Trooper...
  175. 1994 Trooper Issues
  176. 1998 3.5L engine swap for a 2000 Trooper?
  177. Flex plate to torque convetor bolts will not stay tight.
  178. Rear engine oil seal how to replace?
  179. Rear water cooling hoses. When to change?
  180. What type automatic transmission seal to use
  181. 99 Trooper p0121
  182. Blower only works on 2 speeds
  183. sparkplug and distributor question
  184. No Pressure in hyrdraulic clutch line
  185. Fuel Sending Unit
  186. 1996 Isuzu Trooper Hesitates & Stumbles
  187. 1991 Trooper
  188. wiring diagram 99 trooper
  189. Acura 1997 SLX 147,000 miles plus
  190. Changed Alternator charging light stays on
  191. Bought an '88 Trooper yesterday...question
  192. 90s Izusu trooper Fuel pump question
  193. 2000 Isuzu Trooper codes P1290,P1125,P1295.How to shut off Check engine light
  194. Power steering pump parts
  195. trooper 96 noise P/S pump
  196. 90 Trooper 2.6L A/T over drive Problems
  197. new OME shocks and springs - really nice.
  198. trooper trouble: rear wiper relays
  199. 94 trooper manually over ride transmission computer
  200. 2002 Trooper engine clicking
  201. Scanner Adapter conector for dignosis engine
  202. Isuzu trooper 95 3.2L dignosis engine conector
  203. Trooper 94-changed alternator now have no lights and power
  204. 1990 Trooper clutch hydraulic system
  205. 2001 Trooper gas/diesel engine swap
  206. Bushwaker fender flares
  207. anyone ever change speed sensor on TOD?
  208. How to bump up the HP in my 2.8L?
  209. Emergency brake lite.
  210. Alarm won't turn off
  211. Brake Squeal
  212. Trooper BLACK SMOKE/ACCERATION
  213. 1999 trooper stalling
  214. 96 trooper hesitates and chokes up while accelerating, aweful burning smell
  215. 1998 Trooper 3.5 V6 Accelerating @ gear problems
  216. Looking to buy motor...
  217. 2001 Isuzu Trooper Limited.... ABS Light
  218. Replacing Voltage Regulator in 93 Trooper
  219. 94 3.2 sohc changing valve cover gasket
  220. P1404 after the EGR and tube have been cleaned
  221. 98 Trooper uneven front tire wear, vibration above 30 mph.
  222. TOD and Front Drive Shaft
  223. 1990 2.6L Trooper overdrive problems
  224. Effects of Timing Belt Failure 2000 Trooper
  225. 1990 2.6L Trooper Fast Idle Problems
  226. 99 trooper tranny question
  227. 1990 Trooper has no spark
  228. Want more power and torque
  229. 94 trooper trany swap. How much time?
  230. 2000 Trooper and 10% Ethanol Gasoline??
  231. I just bought a 87' isuzu trooper II for $1800
  232. 92 Isuzu Trooper engine probs
  233. why is it leaking?
  234. 94 trooper "O2, fuel, brake, & charging" lights stay on
  235. 2001 Isuzu Trooper Transmission NIGHTMARE "Thread 2"
  236. 2001 Isuzu Trooper Transmission NIGHTMARE
  237. Are all engines the same?
  238. Alternator questions
  239. Override automatic transmission computer?
  240. 1994 Trooper wiring
  241. 88 Trooper Engine Knocking
  242. 88 Trooper For Sale
  243. 97 Trooper dash battery and 4WD lights don't illuminate before 'start'
  244. 1994 Trooper randoming flooding
  245. Isuzu Trooper Owner Manual
  246. Oz Photo Guide to 3.2V6 SOHC Timing Belt/Water Pump Replacement
  247. Roof Rack and Brush Guard Recommendation
  248. value of Trooper
  249. 01 Trooper with 1340 code and a P0502.
  250. Alternator Gone
