Our Community is 662,000 Strong. Join Us.
View Full Version : Trooper | SLX | Bighorn | Wizard
Pages : [1] 2 3 4 5 6
  1. Differential oil seal
  2. 98 trooper 3.5 Knock while reving comes and goes
  3. Hooked up battery backwards. I have nothing.
  4. Front hub ring that holds the bearings is stuck on 1995 Trooper
  5. 2000 trooper cruise control issue
  6. Opel Monterey 3.1 TD (Isuzu Trooper)
  7. 1990 Isuzu Trooper with headers
  8. 88 trooper wont start flooding
  9. 99 Trooper Head gasket
  10. 1999 trooper engine code P0303 Misfire
  11. 2001 trooper spark plugs
  12. Whic engine oil for my Isuzu.
  13. 91 trooper
  14. 93 trooper tie rods
  15. 1995 Trooper
  16. Quick Question. Does a 86 grill fit and 88
  17. New isuzu trooper owner
  18. Cat-back system for 02 Trooper
  19. Water pump question
  20. Illusive PCV
  21. 93 trooper shaking at certain speeds
  22. trooper wont start
  23. 1994 3.2L DOHC Timing
  24. 88 Trooper engine/wire fire
  25. 2000 Trooper noise 35-45 ... shuddering??
  26. Better engine in 95 Trooper?
  27. Transmision kits for izusu 2001
  28. towing a 1988 Trooper
  29. from a new member HADIT
  30. Just bought a 93 trooper LS
  31. wont hold a charge
  32. Squealing noise and TOD check light on.
  33. 88 trooper oil pan removel
  34. Grease for Timing Belt Tensioner
  35. What newest Trooper model
  36. Transmission issues
  37. TOD Code 28
  38. trooper shudder jumping
  39. 99' izuzu trooper
  40. here is the sequence to set your remote key fob 1998-2000 trooper
  41. trooper 1993 3,2 Dohc , automatic transmission change
  42. shifting
  43. (not-simon) cowl removal
  44. code p1480
  45. Good Riddance!
  46. Ck Tranny Light After Fluid Change
  47. trooper 3.2DOHC misfire
  48. trooper 3.2DOHC misfire
  49. How to change gasket on cross pipe at rear of engine
  50. Odd whistling or squealing noise at idle and engine lite on.
  51. 1988 isuzu trooper won't start
  52. Need a 4 cyl Motor.
  53. 4X4 not working
  54. 98 Isuzu Trooper 3.5L Loosing Coolant
  55. Trooper parts
  56. Isuzu Trooper weird Problem
  57. 86 Trooper 4ZD1 Fuel Pump Damper
  58. should i buy this trooper
  59. 95 Trooper spark plug wires coming off plug (NEED HELP)
  60. 1986 Trooper Accelerator Pump Piston Leaks
  61. 1986 trooper 2 water pump replacement
  62. Isuzu Trooper TOD check light
  63. 1999 trooper cranks but no start
  64. 1992 Trooper Rear Axle Bearing Retainer
  65. 2000 Troooper CEL codes
  66. '91 Trooper, is there an eng. larger than the 2.8L V6 original that will interchange.
  67. Trooper to Vehicross engine swap
  68. 1989 Trooper Engine smog and swap
  69. 96 Trooper Power window problems
  70. 92 ABS pump keeps running when off? Ideas?
  71. 97 Trooper Brake Issue
  72. indicator lights
  73. 1998 Trooper Idle Problem(Please help please)
  74. 2000 Trooper 3.5 v6 Check Trans Blinking
  75. Sounds like marbles in the engine?
  76. 88 trooper dummy lights come on and off ??
  77. 00 Trooper Failed Inspection for HO2S Problem
  78. 2000 Trooper Transmission Fluid/Filter Change
  79. Bighorn Injection Nozzle Pressure
  80. has any one tried this for 90 trooper 2.6 starting prob
  81. tropper 2.6 will not start
  82. Replacing the Oil Pan Gasket on a 2000 Trooper?
  83. 2000 Trooper 4WD Tranny Leaks
  84. Isuzu Trooper air vents blow even when off
  85. 1990 Trooper Won't Idle Until Warm
  86. Changing out freeze plugs on Trooper
  87. 95 Trooper Leaking Coolant
  88. 90 not getting fuel through injectors
  89. Replacing Stock Shocks
  90. 94 trooper leaking oil
  91. Problems after 00 transmission rebuild
  92. 1993 Trooper Check Trans Light
  93. 91 trooper
  94. Weird #3 cylinder misfire
  95. 93 Trooper Front tire locking
  96. Been There Done That. Guys I break question.
  97. '94 AT DOHC Chk Engine and Cutting out
  98. 94 Trooper turn signal issues
  99. '92-'02 Trooper Third Row Seats
  100. Does Denso Plug K16PR-P11 = PK16PR-11 ???
  101. Lights out on Climate Control Console 2000 Trooper
  102. transmission/isizu trooper limited
  103. 91 Trooper timing problems
  104. Blower Motor Going Bad -- Or is there something else going on???
  105. TOD flashing - code 31
  106. Sun Visor Needed for a 2000 Trooper
  107. Trooper driver side front seat?
  108. 1995 Isuzu Trooper
  109. Trooper 2001 transfer case fluid
  110. 88 Isuzu Trooper won't move. Help.
  111. 94 trooper check engine runs bad
  112. Intermittent CHECK ENGINE light on '92 DOHC
  113. 6VD1 advice needed for low compression (expert pls)
  114. 6VD1 advice needed for low compression (expert pls)
  115. Clutch pedal fails in cold weather
  116. 97 Trooper transmission stuck in "Power" mode
  117. 93 Isuzu with noise in right front wheel
  118. Wet Floor Board Driver Side
  119. No power
  120. Alternator output for transmission.
  121. Are there alternative trannys for 98 Trooper?
  122. Transmission flush
  123. HELP! 96 Troop 3.2 No Start
  124. Hello everyone!
  125. 2001 Trooper Heated Seat problem
  126. '94 Isuzu trooper with 158k miles
  127. How to ruin a CAT?
  128. 1999 trooper severe misfire
  129. fuel pressure
  130. Moms needs help changing alternator belt
  131. Friend drained Trans fluid instead of oil!!!
  132. 1992 Trooper - No Directional Signals
  133. starts with a little help.
  134. 1997 Trooper console question. is there enough room behind......
  135. starting problems
  136. starting problems
  137. 96 Trooper overheating
  138. Looking at a 1986 5 spd Trooper II
  139. Fuel Pump Replacement on 2000 Trooper
  140. wiring problems
  141. Trooper 2002 Transmission Problems
  142. 99 Trooper TOD/SOTF-4x4 Issues
  143. strange cluster warnings after battery/alternator trauma
  144. Help: CDs stuck in 2001 Trooper
  145. 2002 Trooper noise
  146. 1984 trooper w/1.9 flooding and not starting
  147. bolts for 88 trooper flex plate
  148. 2001 Trooper bad tranny leak, then nothing
  149. 1986 trooper won't idle
  150. Wheels keep turning
  151. Rear End Troubles
  152. 1996 Trooper engine Replacement
  153. Isuzu guidlines for engine replacement
  154. No compression, help
  155. 1998 Trooper Serpentine Belt Problem
  156. 86 Trooper dash lights stay on and runs poorly
  157. 99 Trooper blown tranny seal? Please Help!!
  158. Power Steering Pressure Switch
  159. 94 Trooper S Dash Lights Came on Blower stopped
  160. Engine Replacement 99 Trooper
  161. 88 Trooper parked for 6 years
  162. Please help....Transmission issues.
  163. Power Drive won't turn off!
  164. 95 Trooper Oil Leak
  165. Will GM engine/trannys fit in 99 Trooper?
  166. 1990 trooper coolant leak INSIDE car
  167. 3rd new starter in 6 months
  168. how to change the plugs on 94 trooper?
  169. 99 Trooper Poor Mileage Highway Driving
  170. Check Engine Light - Finally Got The Codes
  171. throttle choak?
  172. 99 Trooper spark plug - Tune up
  173. towing with my 96 Trooper
  174. 2000 Trooper leaks
  175. 2000 Trooper Fuel Injectors
  176. 91 2.8 v6 trooper no fuel
  177. Wing window adjustment
  178. 99 Honda Passport, reverse only working
  179. Heater, Idiot lights and alternator failure?
  180. Timing chain
  181. 1994 Trooper rough start?
  182. 1994 Trooper cooling issues
  183. 2001 Isuzu Trooper Fuel Filter Change
  184. oil around spark plug boot???
  185. 2000 Trooper Front Disk Removal
  186. OBD Code 0440 - EVAP System Malfunction
  187. Shifter boot
  188. Flasher location
  189. 2001 Isuzu Trooper O2 Sensor and Plugs
  190. 90 Trooper 4wd not working
  191. Manual hub question
  192. need cooling part name
  193. where? and how to clean idle controller?
  194. passenger side window doesn't stay up
  195. 1987 Trooper
  196. 88 trooper not starting
  197. Carburetor Problems??
  198. Power Mode/winter Mode
  199. Totally messed up firing the order
  200. 2001 tod
  201. 98 trooper coolant leak
  202. Hours needed to replace LS/RS front axles
  203. 94 trooper automatic transmission
  204. Is the 2000-2002 Trooper a good vehicle?
  205. Just paid off the Wife's 2000 Trooper
  206. 93 3.2 V6 2dr Trooper Oil Pressure Gage
  207. driver mirror stuck
  208. 99- going off road, advice
  209. Rough Idle...Loss of Mileage 17 to 13
  210. Trooper 99 fix or sell as parts? (65000 miles)
  211. 94 Trooper - Check Trans Light
  212. 1997 Isuzu Trooper ABS Light On, Flashes Code 53
  213. Alternator advice
  214. tricky sidelights
  215. 89 trooper missing after warmup
  216. The mysterious heater blower
  217. MAS 1996 trooper
  218. 1994 trooper TCM
  219. keyless entry!!!
  220. I have a 1986 trooper II can you help me
  221. 91 Trooper LS questions
  222. 1990 Trooper 5spd 2.6 CLUTCH Change-out
  223. Ticking, Tapping, Rattling Trooper
  224. Power steering pump or something else???
  225. Will 95 rodeo 5speed fit in a 94 trooper
  226. Transmission fluid: whats too hot or too cold
  227. '95 Trooper Brake and ABS Lights
  228. Another 2001 Trooper Tranny Q
  229. remote key programming help??
  230. 2.8 L fuel economy?
  231. 99 Trooper TOD Green Rear Wheels Flash then CHECK but 4wd Works Fine
  232. Mysterious battery drain on 98 Trooper...
  233. 1994 Trooper Issues
  234. 1998 3.5L engine swap for a 2000 Trooper?
  235. Flex plate to torque convetor bolts will not stay tight.
  236. Rear engine oil seal how to replace?
  237. Rear water cooling hoses. When to change?
  238. What type automatic transmission seal to use
  239. 99 Trooper p0121
  240. Blower only works on 2 speeds
  241. sparkplug and distributor question
  242. No Pressure in hyrdraulic clutch line
  243. Fuel Sending Unit
  244. 1996 Isuzu Trooper Hesitates & Stumbles
  245. 1991 Trooper
  246. wiring diagram 99 trooper
  247. Acura 1997 SLX 147,000 miles plus
  248. Changed Alternator charging light stays on
  249. Bought an '88 Trooper yesterday...question
  250. 90s Izusu trooper Fuel pump question
