View Full Version : Trooper/SLX
Pages : [1] 2 3 4 5
  1. should i buy this trooper
  2. 95 Trooper spark plug wires coming off plug (NEED HELP)
  3. 1986 Trooper Accelerator Pump Piston Leaks
  4. 1986 trooper 2 water pump replacement
  5. Isuzu Trooper TOD check light
  6. 1999 trooper cranks but no start
  7. 1992 Trooper Rear Axle Bearing Retainer
  8. 2000 Troooper CEL codes
  9. '91 Trooper, is there an eng. larger than the 2.8L V6 original that will interchange.
  10. Trooper to Vehicross engine swap
  11. 1989 Trooper Engine smog and swap
  12. 96 Trooper Power window problems
  13. 92 ABS pump keeps running when off? Ideas?
  14. 97 Trooper Brake Issue
  15. indicator lights
  16. 1998 Trooper Idle Problem(Please help please)
  17. 2000 Trooper 3.5 v6 Check Trans Blinking
  18. Sounds like marbles in the engine?
  19. 88 trooper dummy lights come on and off ??
  20. 00 Trooper Failed Inspection for HO2S Problem
  21. 2000 Trooper Transmission Fluid/Filter Change
  22. Bighorn Injection Nozzle Pressure
  23. has any one tried this for 90 trooper 2.6 starting prob
  24. tropper 2.6 will not start
  25. Replacing the Oil Pan Gasket on a 2000 Trooper?
  26. 2000 Trooper 4WD Tranny Leaks
  27. Isuzu Trooper air vents blow even when off
  28. 1990 Trooper Won't Idle Until Warm
  29. Changing out freeze plugs on Trooper
  30. 95 Trooper Leaking Coolant
  31. 90 not getting fuel through injectors
  32. Replacing Stock Shocks
  33. 94 trooper leaking oil
  34. Problems after 00 transmission rebuild
  35. 1993 Trooper Check Trans Light
  36. 91 trooper
  37. Weird #3 cylinder misfire
  38. 93 Trooper Front tire locking
  39. Been There Done That. Guys I break question.
  40. '94 AT DOHC Chk Engine and Cutting out
  41. 94 Trooper turn signal issues
  42. '92-'02 Trooper Third Row Seats
  43. Does Denso Plug K16PR-P11 = PK16PR-11 ???
  44. Lights out on Climate Control Console 2000 Trooper
  45. transmission/isizu trooper limited
  46. 91 Trooper timing problems
  47. Blower Motor Going Bad -- Or is there something else going on???
  48. TOD flashing - code 31
  49. Sun Visor Needed for a 2000 Trooper
  50. Trooper driver side front seat?
  51. 1995 Isuzu Trooper
  52. Trooper 2001 transfer case fluid
  53. 88 Isuzu Trooper won't move. Help.
  54. 94 trooper check engine runs bad
  55. Intermittent CHECK ENGINE light on '92 DOHC
  56. 6VD1 advice needed for low compression (expert pls)
  57. 6VD1 advice needed for low compression (expert pls)
  58. Clutch pedal fails in cold weather
  59. 97 Trooper transmission stuck in "Power" mode
  60. 93 Isuzu with noise in right front wheel
  61. Wet Floor Board Driver Side
  62. No power
  63. Alternator output for transmission.
  64. Are there alternative trannys for 98 Trooper?
  65. Transmission flush
  66. HELP! 96 Troop 3.2 No Start
  67. Hello everyone!
  68. 2001 Trooper Heated Seat problem
  69. '94 Isuzu trooper with 158k miles
  70. How to ruin a CAT?
  71. 1999 trooper severe misfire
  72. fuel pressure
  73. Moms needs help changing alternator belt
  74. Friend drained Trans fluid instead of oil!!!
  75. 1992 Trooper - No Directional Signals
  76. starts with a little help.
  77. 1997 Trooper console question. is there enough room behind......
  78. starting problems
  79. starting problems
  80. 96 Trooper overheating
  81. Looking at a 1986 5 spd Trooper II
  82. Fuel Pump Replacement on 2000 Trooper
  83. wiring problems
  84. Trooper 2002 Transmission Problems
  85. 99 Trooper TOD/SOTF-4x4 Issues
  86. strange cluster warnings after battery/alternator trauma
  87. Help: CDs stuck in 2001 Trooper
  88. 2002 Trooper noise
  89. 1984 trooper w/1.9 flooding and not starting
  90. bolts for 88 trooper flex plate
  91. 2001 Trooper bad tranny leak, then nothing
  92. 1986 trooper won't idle
  93. Wheels keep turning
  94. Rear End Troubles
  95. 1996 Trooper engine Replacement
  96. Isuzu guidlines for engine replacement
  97. No compression, help
  98. 1998 Trooper Serpentine Belt Problem
  99. 86 Trooper dash lights stay on and runs poorly
  100. 99 Trooper blown tranny seal? Please Help!!
  101. Power Steering Pressure Switch
  102. 94 Trooper S Dash Lights Came on Blower stopped
  103. Engine Replacement 99 Trooper
  104. 88 Trooper parked for 6 years
  105. Please help....Transmission issues.
  106. Power Drive won't turn off!
  107. 95 Trooper Oil Leak
  108. Will GM engine/trannys fit in 99 Trooper?
  109. 1990 trooper coolant leak INSIDE car
  110. 3rd new starter in 6 months
  111. how to change the plugs on 94 trooper?
  112. 99 Trooper Poor Mileage Highway Driving
  113. Check Engine Light - Finally Got The Codes
  114. throttle choak?
  115. 99 Trooper spark plug - Tune up
  116. towing with my 96 Trooper
  117. 2000 Trooper leaks
  118. 2000 Trooper Fuel Injectors
  119. 91 2.8 v6 trooper no fuel
  120. Wing window adjustment
  121. 99 Honda Passport, reverse only working
  122. Heater, Idiot lights and alternator failure?
  123. Timing chain
  124. 1994 Trooper rough start?
  125. 1994 Trooper cooling issues
  126. 2001 Isuzu Trooper Fuel Filter Change
  127. oil around spark plug boot???
  128. 2000 Trooper Front Disk Removal
  129. OBD Code 0440 - EVAP System Malfunction
  130. Shifter boot
  131. Flasher location
  132. 2001 Isuzu Trooper O2 Sensor and Plugs
  133. 90 Trooper 4wd not working
  134. Manual hub question
  135. need cooling part name
  136. where? and how to clean idle controller?
  137. passenger side window doesn't stay up
  138. 1987 Trooper
  139. 88 trooper not starting
  140. Carburetor Problems??
  141. Power Mode/winter Mode
  142. Totally messed up firing the order
  143. 2001 tod
  144. 98 trooper coolant leak
  145. Hours needed to replace LS/RS front axles
  146. 94 trooper automatic transmission
  147. Is the 2000-2002 Trooper a good vehicle?
  148. Just paid off the Wife's 2000 Trooper
  149. 93 3.2 V6 2dr Trooper Oil Pressure Gage
  150. driver mirror stuck
  151. 99- going off road, advice
  152. Rough Idle...Loss of Mileage 17 to 13
  153. Trooper 99 fix or sell as parts? (65000 miles)
  154. 94 Trooper - Check Trans Light
  155. 1997 Isuzu Trooper ABS Light On, Flashes Code 53
  156. Alternator advice
  157. tricky sidelights
  158. 89 trooper missing after warmup
  159. The mysterious heater blower
  160. MAS 1996 trooper
  161. 1994 trooper TCM
  162. keyless entry!!!
  163. I have a 1986 trooper II can you help me
  164. 91 Trooper LS questions
  165. 1990 Trooper 5spd 2.6 CLUTCH Change-out
  166. Ticking, Tapping, Rattling Trooper
  167. Power steering pump or something else???
  168. Will 95 rodeo 5speed fit in a 94 trooper
  169. Transmission fluid: whats too hot or too cold
  170. '95 Trooper Brake and ABS Lights
  171. Another 2001 Trooper Tranny Q
  172. remote key programming help??
  173. 2.8 L fuel economy?
  174. 99 Trooper TOD Green Rear Wheels Flash then CHECK but 4wd Works Fine
  175. Mysterious battery drain on 98 Trooper...
  176. 1994 Trooper Issues
  177. 1998 3.5L engine swap for a 2000 Trooper?
  178. Flex plate to torque convetor bolts will not stay tight.
  179. Rear engine oil seal how to replace?
  180. Rear water cooling hoses. When to change?
  181. What type automatic transmission seal to use
  182. 99 Trooper p0121
  183. Blower only works on 2 speeds
  184. sparkplug and distributor question
  185. No Pressure in hyrdraulic clutch line
  186. Fuel Sending Unit
  187. 1996 Isuzu Trooper Hesitates & Stumbles
  188. 1991 Trooper
  189. wiring diagram 99 trooper
  190. Acura 1997 SLX 147,000 miles plus
  191. Changed Alternator charging light stays on
  192. Bought an '88 Trooper yesterday...question
  193. 90s Izusu trooper Fuel pump question
  194. 2000 Isuzu Trooper codes P1290,P1125,P1295.How to shut off Check engine light
  195. Power steering pump parts
  196. trooper 96 noise P/S pump
  197. 90 Trooper 2.6L A/T over drive Problems
  198. new OME shocks and springs - really nice.
  199. trooper trouble: rear wiper relays
  200. 94 trooper manually over ride transmission computer
  201. 2002 Trooper engine clicking
  202. Scanner Adapter conector for dignosis engine
  203. Isuzu trooper 95 3.2L dignosis engine conector
  204. Trooper 94-changed alternator now have no lights and power
  205. 1990 Trooper clutch hydraulic system
  206. 2001 Trooper gas/diesel engine swap
  207. Bushwaker fender flares
  208. anyone ever change speed sensor on TOD?
  209. How to bump up the HP in my 2.8L?
  210. Emergency brake lite.
  211. Alarm won't turn off
  212. Brake Squeal
  213. Trooper BLACK SMOKE/ACCERATION
  214. 1999 trooper stalling
  215. 96 trooper hesitates and chokes up while accelerating, aweful burning smell
  216. 1998 Trooper 3.5 V6 Accelerating @ gear problems
  217. Looking to buy motor...
  218. 2001 Isuzu Trooper Limited.... ABS Light
  219. Replacing Voltage Regulator in 93 Trooper
  220. 94 3.2 sohc changing valve cover gasket
  221. P1404 after the EGR and tube have been cleaned
  222. 98 Trooper uneven front tire wear, vibration above 30 mph.
  223. TOD and Front Drive Shaft
  224. 1990 2.6L Trooper overdrive problems
  225. Effects of Timing Belt Failure 2000 Trooper
  226. 1990 2.6L Trooper Fast Idle Problems
  227. 99 trooper tranny question
  228. 1990 Trooper has no spark
  229. Want more power and torque
  230. 94 trooper trany swap. How much time?
  231. 2000 Trooper and 10% Ethanol Gasoline??
  232. I just bought a 87' isuzu trooper II for $1800
  233. 92 Isuzu Trooper engine probs
  234. why is it leaking?
  235. 94 trooper "O2, fuel, brake, & charging" lights stay on
  236. 2001 Isuzu Trooper Transmission NIGHTMARE "Thread 2"
  237. 2001 Isuzu Trooper Transmission NIGHTMARE
  238. Are all engines the same?
  239. Alternator questions
  240. Override automatic transmission computer?
  241. 1994 Trooper wiring
  242. 88 Trooper Engine Knocking
  243. 88 Trooper For Sale
  244. 97 Trooper dash battery and 4WD lights don't illuminate before 'start'
  245. 1994 Trooper randoming flooding
  246. Isuzu Trooper Owner Manual
  247. Oz Photo Guide to 3.2V6 SOHC Timing Belt/Water Pump Replacement
  248. Roof Rack and Brush Guard Recommendation
  249. value of Trooper
  250. 01 Trooper with 1340 code and a P0502.
