View Full Version : Trooper/SLX
Pages : 1 2 3 4 [5]
  1. '89 - Oil in coolant
  2. looking for : Weber!!! :)
  3. Clicking in engine 95 trooper
  4. 92 Trooper winter mode
  5. 97 Rodeo rear wheel wobble, losing the battle
  6. 1989 Isuzu Trooper 2.8 eng - Won't start
  7. Black smoke from exhaust
  8. Hello all, one more ignorant question.
  9. Tightening the antenna on a '98
  10. 4x4 Problem - 96 trooper
  11. Shocks
  12. '98 Trooper Keyless programming instructions . . .
  13. Just bought 2000 Trooper
  14. *cries and begs for help...*
  15. Bigger Tires
  16. WorkShop Manual
  17. Headlight problem
  18. 91 Trooper V6 serious hesitation
  19. windshield washer motor replacement
  20. How to check transmission fluid 98 trooper
  21. Need factory repair or repair manual
  22. 60K Service on 2001 Trooper
  23. O2 sensor light
  24. Blinking CEL in 2000 Trooper
  25. 1990 Trooper Headlight on warning chime
  26. 98 Trooper high idle
  27. Weird Idle, cutt off, missing problem 1990 Troopoer V6
  28. Spark Plug Removal
  29. Better Tranny Fill question
  30. 87 trooper II brake question
  31. Trooper starting hard when cold
  32. Time to Change Timing Belt 99 Trooper
  33. lsd passposrt/amigo/trooper/rodeo
  34. 2001 Trooper Transmission problem
  35. 88 Trooper won't start when hot
  36. 91 6cyl stalls
  37. body roll on my 96 trooper
  38. HELP! (Near) Dead Man Walking.
  39. 1987 Trooper II Q's
  40. Thinning Oil
  41. 89' Trooper Electrical Probs
  42. Removing door window molding
  43. 1989 T-2...fuel relay?
  44. New To Post
  45. Why automovieforums rocks
  46. 88 trooper starter short?
  47. Egr
  48. lowering a trooper
  49. When to change timing belt?
  50. P0300 Code on 2000 Trooper
  51. To Change or Not To Change? (Transmission Fluid)
  52. ignition switch r & r
  53. 95' trooper won't start
  54. 01 auto transmission fluid check/refill
  55. Cooling issue, new to troopers, please help!
  56. What are the biggest tires i can put on a stock 90?
  57. Keeping it kool
  58. things to look for in '91 Trooper
  59. '90 2.8TD Timing belt light
  60. 94 Isuzu Trooper Oil Pan
  61. Where can I get OEM Spark Plugs for 2000 Trooper?
  62. 2000 Trooper Blinking Check Engine Light
  63. Isuzu Trooper II Steering Wheel Lock?
  64. HELP!!! Oil Pump
  65. engine noise
  66. 93 Trooper/Anti-lock turning on/sponge
  67. Check Light
  68. Pouring Anti-freeze Somebody Help
  69. leaky injectors 88 trooper
  70. 92 Trooper (check tranny light)
  71. 2000 Trooper Going South
  72. Power Seat Problems! '96 Trooper
  73. What's with Trucky?
  74. 97 Trooper needs a replacement engine?
  75. Throttle Problem...
  76. 1998 Trooper Suspension Upgrades
  77. Reset Timing Belt Light
  78. Buying Trooper Advice
  79. 1992 Trooper 4WD Front Hub removal
  80. Trooper 88 Trouble.
  81. Engine Warning Light '96 Trooper
  82. 89 trooper keeps quitting
  83. 91 trooper transmission mistery...
  84. gas mileage - help!
  85. 88 isuzu trooper
  86. 1995 Trooper
  87. automatic transmissions
  88. HELP! Trans light on (back up mode?)
  89. 98 trooper transmission trouble
  90. Front Clip Parts
  91. 1989 Isuzu Trooper Belt replacement help needed
  92. Rust
  93. GOOD news??
  94. Let's make '98/'99 Isuzu Trooper Recall happen
  95. low gas mileage
  96. 98 Trooper "Check Engine"
  97. Whats wrong with my car? Help now!!!
  98. remote/power locak module/panel on door problem
  99. i need help with cooling.......
  100. 99 trooper motor shot
  101. PVC and ERG Valve Location 99 Trooper
  102. Is the 4L30E trany Self Learning?
  103. my trooper
  104. 2-3 harsh shift after rebuild in 4L30E Auto - Help!
  105. 1996 trooper fan belt help???
  106. power steering
  107. Need New Wipers. Please Help
  108. 91 trooper tranny woes... HELP!!!!!
  109. clubs
  110. Troubleshoot?
  111. A/C not working
  112. 89 trooper
  113. Changing Calipers
  114. 91 Trooper Parts
  115. 1991 Trooper Diesel
  116. Surges at Idle....
  117. 91' door panel removal
  118. 2001 Check engine reset
  119. Check transmission, check engine
  120. Spark Plugs & Check Engine
  121. A/C fan problems
  122. 88 trooper wiring problems
  123. Code P0300 "limp-Mode" Why?
  124. ignition switch stuck...86 trooper
  125. 90 trooper rebuild engine or swap?
  126. '96 Trooper won't start
  127. Transmission Or Spark Plugs
  128. just finished my project... SAS
  129. ticking noise on 96 trooper
  130. Custom Gauges
  131. Strange Engine Noise
  132. 91 starting issue
  133. Where's the Data Link Connector?
  134. Isuzu tranny
  135. Check out my '94 Troop
  136. Rebuilding '86
  137. Flasher/Signal Problem...
  138. 98 Starter removal
  139. 1989 Trooper Timing Issue
  140. 15k maintenance.
  141. 1995 Engine Swap..
  142. P1441 error code help?!
  143. SAS Button
  144. New Member needs HELP( 88 Trooper 2 )
  145. Clutch replacement '86
  146. Considering 1999 Trooper LS
  147. I need a tranny
  148. 1994 Trooper LS For Sale in Ohio
  149. FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
  150. replacement engine for 91 trooper
  151. Need wiring diagram 1996 Trooper
  152. Need new transmission????
  153. Blowing transmission fluid
  154. 88 Trooper starting problems
  155. Trooper pumping oil
  156. Larger Tires?
  157. 89 trooper transmission problems
  158. (3) Car Seats in a '98 Trooper???
  159. 1989 Trooper V6 - Idle adjustment?
  160. 88 Trooper II FOR SALE in Ohio
  161. 87 troooper engine rebuild--suggestions wanted
  162. hard to start when warm
  163. Front Rotor removal trouble...
  164. tropper running on 3 cylinders
  165. 89 Trooper II transmission problem
  166. transmission fluid
  167. 92 Trooper LS 3.2 Starter replacement?
  168. '96 3.2 Flywheel/Flexplate Problems
  169. '86 Trooper has no power
  170. HELP! No heat!!
  171. Check Engine, Check transmission
  172. Keyless entry remote question/programming
  173. '95 "Power" button
  174. overdrive
  175. 97 voltage irregularity
  176. 2001 Trooper, Spark Plug woes
  177. Please help!!! long crank 93 trooper
  178. 2001 Trooper, blown engine at 45,000 miles
  179. Dreaded Check Engine Light...and warranty
  180. radio wiring diagram
  181. Popping out of 4h
  182. Isuzu 12-bolt Brake Problem - All please read
  183. Severe gas milage decrease
  184. transfercase for sale
  185. Trooper For Sale!!!
  186. My Trooper
  187. My Trooper
  188. Engine compression 1988 Trooper
  189. Engine Troubles - Oil Pump?
  190. Score!!!
  191. trooper help?
  192. Need help removing drive axle ASAP!!!!!!
  193. is the 3.2 an interferance motor?
  194. g200z
  195. 91 trooper engine replacement
  196. engine stalls when cold
  197. I need help dropping the differential
  198. '94 Isuzu Trooper-oxygen sensor, reset (clear) warning light & computer?
  199. '86 Trooper2 engine confusion
  200. 01 Trooper, blown engine 70k miles
  201. Wrecked 2000 Trooper parting out
  202. Stalling problem
  203. parts supplier for 1995 trooper
  204. 86 transmission
  205. 99 trooper engine replacement
  206. 92 Trooper troubles!
  207. 88 Trooper trouble! please help
  208. selling aftermarket
  209. 89 Trooper CHEAP
  210. 1995 Isuzu Trooper for Parts.
  211. Aftermarket Fog Lights
  212. Moving seat frames back in an '02 Trooper
  213. 1993 Tooper leaking Power Steering Fluid
  214. 95 Trooper - tighten alternator belt
  215. transfer case fluid
  216. Location of computer
  217. Battery hooked up backwards
  218. 95 Trooper AC And Blower On All Time
  219. 3.2 trooper 95
  220. Urgent, help please
  221. 95' Trooper won't start all the time
  222. Please Help
  223. Wanted 95 or newer wrecked Trooper
  224. Selecting 4 wheel Drive
  225. 1986 trooper wont start
  226. 1986 Trooper running rough
  227. 98 isuzu trooper buring oil excessively
  228. winding noise
  229. Tod
  230. '89 isuzu trooper ll won't start...:frown:
  231. 96 iszuz trooper
  232. trroper broken alloy
  233. Trooper II: Gas mileage?
  234. Lots of Websites
  235. Help Me!
  236. No One??
  237. number one baby
  238. Off-Road Accessories
  239. 2003 Trooper Replacement
  240. 1992 Trooper
  241. SLX?
  242. Parts
