Our Community is 705,000 Strong. Join Us.
View Full Version : Trooper | SLX | Bighorn | Wizard
Pages : 1 2 3 [4] 5 6
  1. 2000 Trooper Oil Usage and Piston Rings
  2. my 93 3.2L w/233,000 says its overheating???
  3. Keyless entry
  4. tranny woes
  5. 86 trooper manual transmission fluid....
  6. Clutch problem on 95 Trooper
  7. 86 trooper tranny removal
  8. Wheels for 1989 trooper-
  9. 91 trooper skipping
  10. fs whole or will part
  11. Bogs down under load!
  12. 1989 trooper repair manual download
  13. 1996 3.2v V6 Sounds Like A Deisel!
  14. 89 trooper heater - no heat
  15. Poison Mist? Ack?
  16. 2.8 head conversion
  17. 2002 Trooper 75k miles, code retrieval
  18. Tranny Service -- Now it shudders in O/D
  19. bagged isuzu pickup?
  20. 98 Trooper rear window FM Atenna connection with after market stereo
  21. 1991 Trooper reverse gear problem
  22. front axle removal
  23. Radio/Antenna Question?
  24. Front of 03 is lower than rear
  25. P1406 from '96 Trooper
  26. 2000 Isuzu Trooper Engine Replacement
  27. 2000 Isuzu
  28. '96 EGR valve
  29. Laboring engine
  30. 2000 Trooper muffler
  31. 89 Trooper head repair
  32. TOD light is out/running funny
  33. 91 Trooper question - general
  34. Paint question
  35. EGR Valve for 1993 Trooper?
  36. 96 fuel pressure regulator
  37. Engine
  38. 2001 Trooper MPG ?
  39. Engine check light and Reduce Power
  40. Looking into the Trooper and I have some Qs
  41. 1991 Trooper Manual
  42. 97 trooper power steering fan belt help
  43. 93 Trooper starting problem
  44. 1991 Trooper II 4wd 5spd
  45. How I Found a Substitute for 1998 Trooper Muffler
  46. License Plate Bolts?!
  47. How much to replace gaskets?
  48. 1991 Trooper accessories
  49. 1991 Trooper reverse gear problem
  50. Butane/Gasoline 1991 Trooper
  51. !995 Trooper Aftermarket Speakers
  52. wiring diagrams
  53. recall 93 trooper 3.2 sohc
  54. 91 trooper
  55. Green Air Filters?!
  56. 16 yr olds 94 trooper
  57. more power for my 99 Trooper
  58. 2001 Trooper dies going down road
  59. 2001 Trooper Transmission
  60. Where can I find 97 trooper repair manual?
  61. How to disable airbags '98 Trooper
  62. 2000 Trooper Surges / Stumbles
  63. 89 Trooper II w/blown head gasket
  64. Stored 91 V6 Trooper, started, clutch stuck?
  65. 95 Trooper Hesitates
  66. keyless entry
  67. Location of ALDL diagnostic connector on '93 Trooper?
  68. Possible AC Problem
  69. crank pulley threads
  70. Isuzu Manual - New Upload
  71. 98 Trooper ocassionally slips
  72. '01 Trooper Stalling
  73. Need a 91 Trooper
  74. Check transmission light / speedo failure
  75. Brush guards
  76. a/c coolant charge 2001 Trooper
  77. tensioner pushrod or bearing and bracket
  78. Check Engine/Reduce Power
  79. Old Man Emu (OME)
  80. 2000 Trooper 96k conflicting codes
  81. o2 bank1/sensor1 removal?
  82. 1998 Isuzu Trooper PROBLEM.
  83. Central Locking
  84. Replacing EGR Valve
  85. On vacation need help!!! 2000 Trooper....
  86. 2000 Trooper won't start
  87. LOUD engine
  88. Odd Problem After Taking My Trooper offroad..
  89. new happy isuzu owner
  90. 17MPG HWY NORMAL? Please read about my great deal!
  91. 91 Trooper II Clutch
  92. Passenger Headlight problem please help.
  93. 2000 Trooper Front Differential Maintenance
  94. 94 trooper running rough
  95. Transmission slipping
  96. 4 WD selected by its self
  97. Does anyone's Trooper last?
  98. 2000 3.5 V6 Help
  99. Radiator Drain Petcock???
  100. Where is the Thermostat?
  101. Trooper Manual
  102. My 99 Isuzu Trooper sounds like a diesel engine
  103. 2000 Trooper 3.5L V6 Compression
  104. a/c question
  105. 86 trooper II transmission problems
  106. Anyone Using K&N Air Filters?
  107. Isuzu Rodeo Tailgate lock problem
  108. ECU code 23 and 44
  109. starting problem on 89 trooper
  110. using seafoam
  111. Cel 0405???
  112. HELP Needed With Brakes
  113. 1989 V6 died and won't start back up?!?!?
  114. 2000 Trooper - BG Engine Service??
  115. oil pressure
  116. Water dripping under dash while running a/c.
  117. Engine Ticking
  118. help trooper dash lights & tale don't work
  119. Erratic oil pressure - 94 Trooper
  120. 1988 trooper 2.6 please help
  121. 1994 Trooper 3.2/SOHC Dies
  122. 1988 trooper engine swap
  123. 98 Trooper help
  124. 1999 Trooper - Throttle Sticking
  125. 1991 Rough Idle
  126. automotive repair book for 1997 isuzu trooper
  127. intermittent problem with throttle
  128. losing power
  129. 2000 Trooper Dash Lights
  130. replacing rear disc brake pads on 2000
  131. 88 trooper missing intake
  132. Trailer Hitch Wiring on a '98
  133. stereo wiring problem
  134. synthetic tranny fluid
  135. 2000 Trooper Alternator Concerns
  136. For Sale 94 Trooper
  137. 2000 Trooper - Intermitten Blinking CEL!!!!!
  138. Cold Temp drive train noise
  139. Trying to remove rear Lap Sash Seat Belts
  140. Cleaning the EGR Tube...Gaskets Needed?
  141. 98 Izuzu Trooper Keyless entry stuff Questions
  142. Gen 2 Repair Manual?
  143. 1988 Trooper II for sale
  144. Removing Front Rotors 2000 Trooper
  145. Lamest Forum I've Ever Joined
  146. oil presure
  147. 86 Trooper windshield gasket - Rust, leaks
  148. 89 Trooper $1,000 With 2 Brunt Valves Should I Buy??
  149. Sluggish Engine
  150. Any Help Would Be Great!!!
  151. 89 trooper, no power to fuel pump
  152. Timing Belt
  153. Oil Pressure
  154. 1996 Trooper-sluggish engine crank
  155. AUSSIE jackaroo (trooper) needs help
  156. 88 trooper II Vacuum Lines
  157. intake vs. head gasket leak
  158. Thinking Of Picking Up A 95
  159. Fuel Pump Lines
  160. 94 trooper trans light
  161. 2000 Trooper Tranny
  162. 94 trooper, I can't get the relays
  163. Code P0440
  164. 1992 Izusu Trooper CHECK TRANS light
  165. 98 Chevy Venture lifter noise
  166. LSD rear axle for sale
  167. 1995 Trooper / Oil in spark plugs
  168. Better cylinder location FAQ?
  169. 2000 Trooper and spark knock
  170. F/s Trooper Motor And Trans
  171. Aftermarket parts for '02 Trooper Ltd?
  172. 87 trooper 88 transmission will it fit?
  173. 1995 Trooper - Cranks But Will Not Start
  174. 95 trooper sunroof trouble
  175. 1990 trooper No fuel code 43 please help!!!
  176. P1125 Code
  177. 97 Trooper Stalls
  178. Muffler and EGR Fixes I Made
  179. having problems with my window motor help
  180. fuel filter location
  181. check eng.light
  182. Loose handling
  183. Denso iridium spark plugs
  184. Hey Everybody Check Out This Link!
  185. '88 trooper 2.6 I-TEC 2nd fuel relay location?
  186. Where To Buy '89 Engine New
  187. rough idle on 94 trooper
  188. spare tire holder
  189. How many miles do you have your Isuzu?
  190. 1989 Isuzu Trooper II engine surge at idle?
  191. trooper alarm goes off by itself
  192. 99 trooper - wheel problem
  193. got spark, got fuel, won't start, stumped?
  194. Excellent article on oil by someone in the know
  195. 2000 trooper egr valve info needed....
  196. Getting to the plugs
  197. Identification
  198. 94 trooper brake/dash lights
  199. '95 Trooper 4 cyl. clutch adjustment
  200. 3.5L DOHC reliable? Want your opinion
  201. Electrical problem when brakes are applied a
  202. 1989 Trooper II Engine Surge Problem...
  203. 91 trooper v6 sohc
  204. 2000 Trooper engine problems
  205. Calling all 94/95/96 owners
  206. pulling dash on 89 trooper, also A/C
  207. 99 troop: Where is transfer case?
  208. '89 Trooper II leaking heater core
  209. Exhaust is really rich
  210. 1990 getting no spark
  211. EGR Cleaning -> EGR insuff. flow engine code?
  212. What is a G-Sensor?
  213. gas light
  214. Sluggish Engine
  215. 99 Trooper maint questions - 100K
  216. manual transmission help
  217. Running boards from '96 compatable w/ '97?
  218. 87 Trooper Backfiring
  219. 1992 Trooper Radio Interference
  220. Torque spec 99 intake manifold
  221. HELP..Parts Needed
  222. 89 trooper won't start help!!
  223. How can I get TOD codes?
  224. #4 misfireing
  225. FAQ's for +98 Isuzu's:
  226. Welcome to the Forum: Read This FIRST!!
  227. Clutch problems 89 TrooperII
  228. Does anyone know where the vacuum lines to the 4x4 actuator originate?
  229. Cylinder Location 99 3.5l
  230. Schematic for vacuum switching valve
  231. 88 Trooper 2.6 Won't Start
  232. 89 trooper won't fire
  233. 1989 trooper won't start
  234. Adjusting clutch on '96 Trooper
  235. wheel speed sensors on 2001 trooper
  236. DIY Tranny
  237. isuzu tod transmission
  238. Engine light on after o2 sensor replacement
  239. 4ZE1 Problem... HELP!
  240. 2000 Trooper need help with a few Qs !....
  241. '91 trooper cranks, won't start
  242. Need parts for 88 isuzu trooper???
  243. heater blower motor????
  244. heater core leaking 93' 3.2
  245. Have You Replaced Your Own Tranny and Clutch
  246. need and egr
  247. Mpg
  248. 1993 Trooper Transmission grinding in 2WD
  249. Oil Usage Problem- 94 Isuzu Trooper
  250. Clutch Replacement
