View Full Version : Trooper/SLX
Pages : 1 2 3 [4] 5
  1. Stored 91 V6 Trooper, started, clutch stuck?
  2. 95 Trooper Hesitates
  3. keyless entry
  4. Location of ALDL diagnostic connector on '93 Trooper?
  5. Possible AC Problem
  6. crank pulley threads
  7. Isuzu Manual - New Upload
  8. 98 Trooper ocassionally slips
  9. '01 Trooper Stalling
  10. Need a 91 Trooper
  11. Check transmission light / speedo failure
  12. Brush guards
  13. a/c coolant charge 2001 Trooper
  14. tensioner pushrod or bearing and bracket
  15. Check Engine/Reduce Power
  16. Old Man Emu (OME)
  17. 2000 Trooper 96k conflicting codes
  18. o2 bank1/sensor1 removal?
  19. 1998 Isuzu Trooper PROBLEM.
  20. Central Locking
  21. Replacing EGR Valve
  22. On vacation need help!!! 2000 Trooper....
  23. 2000 Trooper won't start
  24. LOUD engine
  25. Odd Problem After Taking My Trooper offroad..
  26. new happy isuzu owner
  27. 17MPG HWY NORMAL? Please read about my great deal!
  28. 91 Trooper II Clutch
  29. Passenger Headlight problem please help.
  30. 2000 Trooper Front Differential Maintenance
  31. 94 trooper running rough
  32. Transmission slipping
  33. 4 WD selected by its self
  34. Does anyone's Trooper last?
  35. 2000 3.5 V6 Help
  36. Radiator Drain Petcock???
  37. Where is the Thermostat?
  38. Trooper Manual
  39. My 99 Isuzu Trooper sounds like a diesel engine
  40. 2000 Trooper 3.5L V6 Compression
  41. a/c question
  42. 86 trooper II transmission problems
  43. Anyone Using K&N Air Filters?
  44. Isuzu Rodeo Tailgate lock problem
  45. ECU code 23 and 44
  46. starting problem on 89 trooper
  47. using seafoam
  48. Cel 0405???
  49. HELP Needed With Brakes
  50. 1989 V6 died and won't start back up?!?!?
  51. 2000 Trooper - BG Engine Service??
  52. oil pressure
  53. Water dripping under dash while running a/c.
  54. Engine Ticking
  55. help trooper dash lights & tale don't work
  56. Erratic oil pressure - 94 Trooper
  57. 1988 trooper 2.6 please help
  58. 1994 Trooper 3.2/SOHC Dies
  59. 1988 trooper engine swap
  60. 98 Trooper help
  61. 1999 Trooper - Throttle Sticking
  62. 1991 Rough Idle
  63. automotive repair book for 1997 isuzu trooper
  64. intermittent problem with throttle
  65. losing power
  66. 2000 Trooper Dash Lights
  67. replacing rear disc brake pads on 2000
  68. 88 trooper missing intake
  69. Trailer Hitch Wiring on a '98
  70. stereo wiring problem
  71. synthetic tranny fluid
  72. 2000 Trooper Alternator Concerns
  73. For Sale 94 Trooper
  74. 2000 Trooper - Intermitten Blinking CEL!!!!!
  75. Cold Temp drive train noise
  76. Trying to remove rear Lap Sash Seat Belts
  77. Cleaning the EGR Tube...Gaskets Needed?
  78. 98 Izuzu Trooper Keyless entry stuff Questions
  79. Gen 2 Repair Manual?
  80. 1988 Trooper II for sale
  81. Removing Front Rotors 2000 Trooper
  82. Lamest Forum I've Ever Joined
  83. oil presure
  84. 86 Trooper windshield gasket - Rust, leaks
  85. 89 Trooper $1,000 With 2 Brunt Valves Should I Buy??
  86. Sluggish Engine
  87. Any Help Would Be Great!!!
  88. 89 trooper, no power to fuel pump
  89. Timing Belt
  90. Oil Pressure
  91. 1996 Trooper-sluggish engine crank
  92. AUSSIE jackaroo (trooper) needs help
  93. 88 trooper II Vacuum Lines
  94. intake vs. head gasket leak
  95. Thinking Of Picking Up A 95
  96. Fuel Pump Lines
  97. 94 trooper trans light
  98. 2000 Trooper Tranny
  99. 94 trooper, I can't get the relays
  100. Code P0440
  101. 1992 Izusu Trooper CHECK TRANS light
  102. 98 Chevy Venture lifter noise
  103. LSD rear axle for sale
  104. 1995 Trooper / Oil in spark plugs
  105. Better cylinder location FAQ?
  106. 2000 Trooper and spark knock
  107. F/s Trooper Motor And Trans
  108. Aftermarket parts for '02 Trooper Ltd?
  109. 87 trooper 88 transmission will it fit?
  110. 1995 Trooper - Cranks But Will Not Start
  111. 95 trooper sunroof trouble
  112. 1990 trooper No fuel code 43 please help!!!
  113. P1125 Code
  114. 97 Trooper Stalls
  115. Muffler and EGR Fixes I Made
  116. having problems with my window motor help
  117. fuel filter location
  118. check eng.light
  119. Loose handling
  120. Denso iridium spark plugs
  121. Hey Everybody Check Out This Link!
  122. '88 trooper 2.6 I-TEC 2nd fuel relay location?
  123. Where To Buy '89 Engine New
  124. rough idle on 94 trooper
  125. spare tire holder
  126. How many miles do you have your Isuzu?
  127. 1989 Isuzu Trooper II engine surge at idle?
  128. trooper alarm goes off by itself
  129. 99 trooper - wheel problem
  130. got spark, got fuel, won't start, stumped?
  131. Excellent article on oil by someone in the know
  132. 2000 trooper egr valve info needed....
  133. Getting to the plugs
  134. Identification
  135. 94 trooper brake/dash lights
  136. '95 Trooper 4 cyl. clutch adjustment
  137. 3.5L DOHC reliable? Want your opinion
  138. Electrical problem when brakes are applied a
  139. 1989 Trooper II Engine Surge Problem...
  140. 91 trooper v6 sohc
  141. 2000 Trooper engine problems
  142. Calling all 94/95/96 owners
  143. pulling dash on 89 trooper, also A/C
  144. 99 troop: Where is transfer case?
  145. '89 Trooper II leaking heater core
  146. Exhaust is really rich
  147. 1990 getting no spark
  148. EGR Cleaning -> EGR insuff. flow engine code?
  149. What is a G-Sensor?
  150. gas light
  151. Sluggish Engine
  152. 99 Trooper maint questions - 100K
  153. manual transmission help
  154. Running boards from '96 compatable w/ '97?
  155. 87 Trooper Backfiring
  156. 1992 Trooper Radio Interference
  157. Torque spec 99 intake manifold
  158. HELP..Parts Needed
  159. 89 trooper won't start help!!
  160. How can I get TOD codes?
  161. #4 misfireing
  162. FAQ's for +98 Isuzu's:
  163. Welcome to the Forum: Read This FIRST!!
  164. Clutch problems 89 TrooperII
  165. Does anyone know where the vacuum lines to the 4x4 actuator originate?
  166. Cylinder Location 99 3.5l
  167. Schematic for vacuum switching valve
  168. 88 Trooper 2.6 Won't Start
  169. 89 trooper won't fire
  170. 1989 trooper won't start
  171. Adjusting clutch on '96 Trooper
  172. wheel speed sensors on 2001 trooper
  173. DIY Tranny
  174. isuzu tod transmission
  175. Engine light on after o2 sensor replacement
  176. 4ZE1 Problem... HELP!
  177. 2000 Trooper need help with a few Qs !....
  178. '91 trooper cranks, won't start
  179. Need parts for 88 isuzu trooper???
  180. heater blower motor????
  181. heater core leaking 93' 3.2
  182. Have You Replaced Your Own Tranny and Clutch
  183. need and egr
  184. Mpg
  185. 1993 Trooper Transmission grinding in 2WD
  186. Oil Usage Problem- 94 Isuzu Trooper
  187. Clutch Replacement
  188. '95 Trooper Lifters Knocking, Knocking at my door.
  189. 91 Trooper lacks power
  190. CEL Still on
  191. Source for used parts
  192. Answer's about my 1990 Trooper
  193. 91 Trooper possible new tranny and other minor stuff
  194. 1990 4 cylinder timing problem, need help.
  195. 2000 Trooper leaking coolant
  196. Repair Guide???
  197. electronic rust protectors
  198. Need help: codes p0171 and p0174
  199. 3.2 trooper
  200. body roll??? last question.......
  201. Huge help!
  202. headlights turn on by themselves
  203. '90 Trooper Temp Guage position
  204. PO446 code
  205. 2000 Trooper ( the jeep is another long story )
  206. Please Help........!
  207. oops got to rebuild my rear axle.....
  208. Thanks Alot For No Responses
  209. Emergency-brake light
  210. Loud Ticking throughout entire rpm range - 97 3.2L
  211. 92-97 No armrest? where to find one?
  212. 97 - Check Engine Light! Lean on Bank 2, O2 Sensor?
  213. '96 Trooper Window Regulator
  214. Transmission Problem
  215. Montero vs Trooper vs Explorer-buying used
  216. 1989 Trooper Transmission
  217. 89 trooper, fan works but no heat
  218. LOUD ticking 3.2 quiets at 2200RPM
  219. 86 trooper tranny help
  220. Changing out the differential fluid?
  221. No Dash lights, HELP!!!
  222. Engine removal 1999 Trooper
  223. '88 Trooper for sale/parts in FL (Check it out!)
  224. place your vote!
  225. large THUNK when stoping
  226. 92 trooper elec fan.
  227. 96' Trooper Dilemma
  228. Radio/ Int. Light Outage
  229. Low idle, stall, electrical surge
  230. power mods 1994 3.2 V6 trooper
  231. 1991 trooper starting problem
  232. After-market Headlamps
  233. 98 Trooper overheating after intake manifold gasket and Plenum gasket
  234. 91 Trooper Rim question
  235. 2.8-3.4 swap
  236. engine size
  237. 95 Trooper Rear Axle
  238. Repair Manual for a 2001?!
  239. '95 Trooper Light Guards
  240. 1990 isuzu trooper
  241. Strange problem with 87 Trooper
  242. 89 Trooper 180,000 O2 Light
  243. 97 Isuzu Trooper Transmission
  244. I now have two seperate clicks coming form engine, one is really loud.. Please help!
  245. NEED REVIEWS 1993 trooper!!
  246. 87 trooper tire reccomendations?
  247. Just bought a 2001 Trooper LS 2wd, what to mod?
  248. Need Engine
  249. 88 Trooper would lose power, now won't start
  250. 93 trooper trany light blinking
