Isuzu
> Trooper | SLX | Bighorn | Wizard
View Full Version :
Pages :
1
2
3
4
5
6
2000 Trooper Running Too Rich
2000 Trooper, The Oil Saga Continues
High pitch whining
98 Trooper Exhaust Issues
Major Trooper Idle Problem, Help please!!
Trooper Tranny wiring troubles
99 Trooper: CEL, brakes, headlights and other assorted goodies
Auto Transmission swap with Rodeo transmission
Valve Calibration for Isuzu Trooper 1987 2.3
Egine speed sensor
TCM error code 13
Leaky Differential
89 T2 parts car: V6 is toast.
Can you help with this code??
ABS light 01 Trooper 3.5
Engine Idle at 1600rpm
93 trooper, where is fuel press regulator
Fuel Economy of Fuel Injection
Road Noise/Chatter
cleaning EGR port
does 93 trooper have MAF sensor?
isuzu trooper reduced power light
What Shocks do you Recommend (98 Trooper)
Does anyone have a good service manual for a 1998 trooper??
automatic locking problems
sluggish 3.5 after timing belt change, question???
1990 troop with hesitation stumble=no answer
1988 Trooper 4ze1 2.6L Motor Wont Start
1988 trooper 2.6L 4ZE1 sohc
I have asked everybody this can you help???
Isuzu Braking Problem
Tune up
99 Trooper workshop manual (PDF)
The best OBD2 PC scaner for Trooper.
Trooper II Transmission Control Module
Limited Slip?
Upper oil pan leak - how hard?
diesel engine swap
Red Check Engine Light 93Trooper
She dies at idle
Need Help on Suspension Parts Please
Fresh off the boat, what to do now?
96 trooper few problems/questions
I did it! Why not to use Bosch Platinum Plugs
1996 trooper purchase
91 trooper tranny problems
1991 Isuzu Trooper need tune up HELP!
Cheapest Place to Buy Old Man Emu Suspension
To Buy new Ball Joints or Reuse Origingals?
HELP Trooper 2.8 td wont start
1997 Isuzu trooper will not turn over.
'01 Trooper Front Wheel Noise
93' Trooper has too much play in steering
Oil pressure reading on gauge
No Luck with Spark Plug Boot Separation
Engine Hesitating when engine is cold
Newbie Starter Question
Couple questions about my AUTO 4 Wheel
Quick Questions
Noob Question.....Very Simple (or should be)
Transmission slips when Hot
00 Isuzu Trooper Hard Plastic Spare Tire Cover
1999 Trooper value?
1991 Isuzu trooper bad oil leak
Couple Questions on Flushing Radiator
oil pan gasket replacement 1986 Trooper
Automatic transmission swap
checking transmission fluid
Which PCV Valve for my 2001 trooper Part # ?
Check Trans/cel Both On?????????
keyless entry horn beep
97 Trooper - Mechanic says waterpump needs to be replaced and cv joints are bad
HELP - 99 Trooper- 200 Miles Per Fill Up POLAND
89 trooperII front hub replacement
1990 Trooper for sale in north AL
bucking isuzu
Transfer case trouble
Tips for the I4s
Washer pump problem
Timing belt change
1997 keyless entry ecu location?
The tick bites
manual
Proforming a 98-02 Trooper Lift
Need Fuel Injector for 2.6 1988 Trooper
93 trooper transmission problem??
What is the name of a carb. part
It has happened to me -- But Why???
Electric door locks
97 Trooper starter problems
01 Trooper Check Engine Light
89 Trooper Seat Covers and mats
Hitch, wiring harness, manual for sale
Combination switch for an 86 Trooper II...
What have I done
parting out 3.5 eng
just wondering
ALDL Location?
Bumper Bracket Kit Cost?
2k Trooper w/ sucking sound & shifting problems, now dead
Update the Wheels -- 2002 Trooper
2000 Isuzu Gas Milage
engine problems
Front End Help
Trooper W/ Mercedes Turbo Diesel
Programming Keyless Entry Problems
01 harness short kills engine
Stabilizer Bar bushings 98 Trooper
Will 86 parts fit 90 trooper?
how to take axleshaft out,, front left,, cant get out to fix 4x4
oil pan gasket replacement 2000 rodeo
88 trooper 2.6 starter staying on
97 auto trans stuck in park
Tensioner
Repair an EGR that reports Device Trouble Code P0405
stiff pedal, slipping clutch 88 2.6L
89Trooper: No compression in 2 cylinders
98/Slx/Isuzu gear problem
ABS light problem and brakes
2000 Trooper Reliability
Trooper Mechanic (Detroit Area)
I have the same problem p1125
2000 Trooper LS with rattle noise in dash board
1995 2.3L Ticking Sound
Isuzu Trooper 1998 manual please
First post -- Electrical gremlin
where to buy mass airflow sensor
1997 trooper electrical tranny issue
Intake Manifold Gasket Again?
Steering wheel slack
Free CD 12 Disc Magazine
1989 isuzu trooper exhaust manafold red hot!
Engine swap
Check Engine Light/EGR Valve Problem?
1995 Trooper Transmission Issues I think
1996 Trooper Transmission Problems
98 trooper shift on the fly problem
88 2.6L red hot cat/exhaust
P0440 driving me nuts
Charging Problems
Erratic Idle
98 trooper transfer case popping out of high
check engine light
what would be the cause of toasted rod bearings?
95 trooper V6 starter bolts
97 Trooper Intermittent Coolant Leak
Isuzu Oil Consumtion
Trooper Power Steering Leak
'86 Trooper - Broken Steering Wheel?
Over heating problem 94 Trooper
Oil Consumption
engine swap in a 99 trooper
Isuzu Oil Consumption
Oil Filter/PCV Part Numbers -- 2002 Trooper
'01 Trooper: $658 CV boot replacement?
Audio problem
94 Trooper Passenger Window Not Working
Easiest Way to Check for Bad IMG
Fan belt replacement
1991 trooper with fuel pump or carbor.. issue.
Better lighting?
Trooper Manual
1996 Isuzu Trooper window
screeching, please help
Is This My EGR
Engine surge (intermittent) at start
Problem (EXPERTS ONLY PLEASE)
Trooper Feels Like E-Brake On While Driving Also Wet Floor Mat
Pitman arm needed!!
98 3.5 intermittent cut-out
electics
91 trooper high beams
3.5 engine oil burning problems
trans kaput at 70k
Driver Side Quarter Panel Window Needed
cooled down coolent leak
FS: 1990 Trooper 4X4 2.8 Auto
trooper 3.0 diesel workshop manuals
88 Trooper Won't Start (tried things from other posts to no avail)
Tapping sound coming from.....
Bad U-joint or driveshaft 86 trooper
'95 Trooper - Blower not blowing - Help
How to test for cracked IMG?
86 trooper hood release cable
Pink oily fluid out exhaust
2000 Trooper 4WD Brake Rotor Replacement
2000 Trooper Timing Belt & Water Pump
90 2.8 Trooper Intake Manifold
Blower heater won't turn on
First Post - 1997 Trooper loud clicking noise
Ticking Noise -- Cold/Yes & Hot/No
Cylinder No. 1 does't work
90 2.8 Trooper shuddering engine
2000 Trooper
I have just joined the club of people with blown engines
Luggage rack 2000 trooper
volt meter
Should I keep my 2001 Trooper?
'94 Trooper Popping Out of 4WD
check eng lite, loss of power, black smoke!
oxygen sensor...
Thermost valve, Isuzu troper 2.6
Isuzu 12 Disc CD changer and In dash CD/cassette
CHECK ENGINE LIGHT (again)
Interior lighting problems....
problems with starting
Loking Place Engine Repair
setting engine idle and timing question
88 Trooper engine swap
86 Trooper 4x4 comes out of gear after
complete loss of power on acceleration
1999 Isuzu Trooper 4WD
High Pitched Noise
89 trooper vsv pressure regulator queston
Transmission stuck in park
4x4 1989 Isuzu Trooper!!!
repair or sell?
Oversized Cylinders, undersized rings
Fuel Injectors Need Cleaned?
Stall / Surging idle, no CEL on though
1994 trooper for sale
trooper manual
EGR under 2nd owner warranty?
95/96trooper 3.1 td blower not working
TOD causes odd noise. Any advice?
TOD 4WD not working
Where to find a carburetor?
Looking Some Parts
Best place to get a catalytic converter?
"89 Trooper head bolts?
Trans.light blink fix
Trooper Hesitation
isuzu trooper 2000 won't start
Knock sensor
11mm-1.25 Flanged Nut for 2000 Trooper
Diesel for 94 Trooper
mudflaps on a 94 isuzu trooper
please help trooper stalls
Spark plug quesion
EGR Valve
CEL, O2, CIL, Brakle lights on after......
bottom out
Still shudders...now funny noises
drained transmission (they thought it was oil plug!)
1989 O2 sensor info...
95 Trooper, intermittant CEL & tranny troubles related?
2000 Trooper Exhaust Manifold Studs
01 trooper trans. problems
How do I replace front turn signal bulb for a 2000 Trooper?
88 Trooper transmission/hydraulicproblem?
