View Full Version : Trooper/SLX
Pages : 1 2 [3] 4 5
  1. Timing belt change
  2. 1997 keyless entry ecu location?
  3. The tick bites
  4. manual
  5. Proforming a 98-02 Trooper Lift
  6. Need Fuel Injector for 2.6 1988 Trooper
  7. 93 trooper transmission problem??
  8. What is the name of a carb. part
  9. It has happened to me -- But Why???
  10. Electric door locks
  11. 97 Trooper starter problems
  12. 01 Trooper Check Engine Light
  13. 89 Trooper Seat Covers and mats
  14. Hitch, wiring harness, manual for sale
  15. Combination switch for an 86 Trooper II...
  16. What have I done
  17. parting out 3.5 eng
  18. just wondering
  19. ALDL Location?
  20. Bumper Bracket Kit Cost?
  21. 2k Trooper w/ sucking sound & shifting problems, now dead
  22. Update the Wheels -- 2002 Trooper
  23. 2000 Isuzu Gas Milage
  24. engine problems
  25. Front End Help
  26. Trooper W/ Mercedes Turbo Diesel
  27. Programming Keyless Entry Problems
  28. 01 harness short kills engine
  29. Stabilizer Bar bushings 98 Trooper
  30. Will 86 parts fit 90 trooper?
  31. how to take axleshaft out,, front left,, cant get out to fix 4x4
  32. oil pan gasket replacement 2000 rodeo
  33. 88 trooper 2.6 starter staying on
  34. 97 auto trans stuck in park
  35. Tensioner
  36. Repair an EGR that reports Device Trouble Code P0405
  37. stiff pedal, slipping clutch 88 2.6L
  38. 89Trooper: No compression in 2 cylinders
  39. 98/Slx/Isuzu gear problem
  40. ABS light problem and brakes
  41. 2000 Trooper Reliability
  42. Trooper Mechanic (Detroit Area)
  43. I have the same problem p1125
  44. 2000 Trooper LS with rattle noise in dash board
  45. 1995 2.3L Ticking Sound
  46. Isuzu Trooper 1998 manual please
  47. First post -- Electrical gremlin
  48. where to buy mass airflow sensor
  49. 1997 trooper electrical tranny issue
  50. Intake Manifold Gasket Again?
  51. Steering wheel slack
  52. Free CD 12 Disc Magazine
  53. 1989 isuzu trooper exhaust manafold red hot!
  54. Engine swap
  55. Check Engine Light/EGR Valve Problem?
  56. 1995 Trooper Transmission Issues I think
  57. 1996 Trooper Transmission Problems
  58. 98 trooper shift on the fly problem
  59. 88 2.6L red hot cat/exhaust
  60. P0440 driving me nuts
  61. Charging Problems
  62. Erratic Idle
  63. 98 trooper transfer case popping out of high
  64. check engine light
  65. what would be the cause of toasted rod bearings?
  66. 95 trooper V6 starter bolts
  67. 97 Trooper Intermittent Coolant Leak
  68. Isuzu Oil Consumtion
  69. Trooper Power Steering Leak
  70. '86 Trooper - Broken Steering Wheel?
  71. Over heating problem 94 Trooper
  72. Oil Consumption
  73. engine swap in a 99 trooper
  74. Isuzu Oil Consumption
  75. Oil Filter/PCV Part Numbers -- 2002 Trooper
  76. '01 Trooper: $658 CV boot replacement?
  77. Audio problem
  78. 94 Trooper Passenger Window Not Working
  79. Easiest Way to Check for Bad IMG
  80. Fan belt replacement
  81. 1991 trooper with fuel pump or carbor.. issue.
  82. Better lighting?
  83. Trooper Manual
  84. 1996 Isuzu Trooper window
  85. screeching, please help
  86. Is This My EGR
  87. Engine surge (intermittent) at start
  88. Problem (EXPERTS ONLY PLEASE)
  89. Trooper Feels Like E-Brake On While Driving Also Wet Floor Mat
  90. Pitman arm needed!!
  91. 98 3.5 intermittent cut-out
  92. electics
  93. 91 trooper high beams
  94. 3.5 engine oil burning problems
  95. trans kaput at 70k
  96. Driver Side Quarter Panel Window Needed
  97. cooled down coolent leak
  98. FS: 1990 Trooper 4X4 2.8 Auto
  99. trooper 3.0 diesel workshop manuals
  100. 88 Trooper Won't Start (tried things from other posts to no avail)
  101. Tapping sound coming from.....
  102. Bad U-joint or driveshaft 86 trooper
  103. '95 Trooper - Blower not blowing - Help
  104. How to test for cracked IMG?
  105. 86 trooper hood release cable
  106. Pink oily fluid out exhaust
  107. 2000 Trooper 4WD Brake Rotor Replacement
  108. 2000 Trooper Timing Belt & Water Pump
  109. 90 2.8 Trooper Intake Manifold
  110. Blower heater won't turn on
  111. First Post - 1997 Trooper loud clicking noise
  112. Ticking Noise -- Cold/Yes & Hot/No
  113. Cylinder No. 1 does't work
  114. 90 2.8 Trooper shuddering engine
  115. 2000 Trooper
  116. I have just joined the club of people with blown engines
  117. Luggage rack 2000 trooper
  118. volt meter
  119. Should I keep my 2001 Trooper?
  120. '94 Trooper Popping Out of 4WD
  121. check eng lite, loss of power, black smoke!
  122. oxygen sensor...
  123. Thermost valve, Isuzu troper 2.6
  124. Isuzu 12 Disc CD changer and In dash CD/cassette
  125. CHECK ENGINE LIGHT (again)
  126. Interior lighting problems....
  127. problems with starting
  128. Loking Place Engine Repair
  129. setting engine idle and timing question
  130. 88 Trooper engine swap
  131. 86 Trooper 4x4 comes out of gear after
  132. complete loss of power on acceleration
  133. 1999 Isuzu Trooper 4WD
  134. High Pitched Noise
  135. 89 trooper vsv pressure regulator queston
  136. Transmission stuck in park
  137. 4x4 1989 Isuzu Trooper!!!
  138. repair or sell?
  139. Oversized Cylinders, undersized rings
  140. Fuel Injectors Need Cleaned?
  141. Stall / Surging idle, no CEL on though
  142. 1994 trooper for sale
  143. trooper manual
  144. EGR under 2nd owner warranty?
  145. 95/96trooper 3.1 td blower not working
  146. TOD causes odd noise. Any advice?
  147. TOD 4WD not working
  148. Where to find a carburetor?
  149. Looking Some Parts
  150. Best place to get a catalytic converter?
  151. "89 Trooper head bolts?
  152. Trans.light blink fix
  153. Trooper Hesitation
  154. isuzu trooper 2000 won't start
  155. Knock sensor
  156. 11mm-1.25 Flanged Nut for 2000 Trooper
  157. Diesel for 94 Trooper
  158. mudflaps on a 94 isuzu trooper
  159. please help trooper stalls
  160. Spark plug quesion
  161. EGR Valve
  162. CEL, O2, CIL, Brakle lights on after......
  163. bottom out
  164. Still shudders...now funny noises
  165. drained transmission (they thought it was oil plug!)
  166. 1989 O2 sensor info...
  167. 95 Trooper, intermittant CEL & tranny troubles related?
  168. 2000 Trooper Exhaust Manifold Studs
  169. 01 trooper trans. problems
  170. How do I replace front turn signal bulb for a 2000 Trooper?
  171. 88 Trooper transmission/hydraulicproblem?
  172. 87 Trooper - Clutch Problem (I think)
  173. I am buying a Issuzu Trooper '93 From a friend of mine?
  174. 88Trooper Blower/relay
  175. Isuzu manual
  176. Transfer Case/FRT Difff and Noise 98TRP
  177. transfer case fluid
  178. 1986 Isuzu trooper for sale
  179. 98 Trooper wont start
  180. '88 trooper thermostat question
  181. 2000 Trooper Check Engine Light
  182. 1990 Trooper Missing and Knock on Accel
  183. belts
  184. +98 trooper install write up:
  185. Need original Trooper fog lamps and dash switch
  186. Fuel Millage
  187. Wheel Bearings
  188. Hydralic Hose
  189. Expensive tick fix down the road... ?
  190. Clunk in rear Diff....
  191. 2000 Trooper Oil Usage and Piston Rings
  192. my 93 3.2L w/233,000 says its overheating???
  193. Keyless entry
  194. tranny woes
  195. 86 trooper manual transmission fluid....
  196. Clutch problem on 95 Trooper
  197. 86 trooper tranny removal
  198. Wheels for 1989 trooper-
  199. 91 trooper skipping
  200. fs whole or will part
  201. Bogs down under load!
  202. 1989 trooper repair manual download
  203. 1996 3.2v V6 Sounds Like A Deisel!
  204. 89 trooper heater - no heat
  205. Poison Mist? Ack?
  206. 2.8 head conversion
  207. 2002 Trooper 75k miles, code retrieval
  208. Tranny Service -- Now it shudders in O/D
  209. bagged isuzu pickup?
  210. 98 Trooper rear window FM Atenna connection with after market stereo
  211. 1991 Trooper reverse gear problem
  212. front axle removal
  213. Radio/Antenna Question?
  214. Front of 03 is lower than rear
  215. P1406 from '96 Trooper
  216. 2000 Isuzu Trooper Engine Replacement
  217. 2000 Isuzu
  218. '96 EGR valve
  219. Laboring engine
  220. 2000 Trooper muffler
  221. 89 Trooper head repair
  222. TOD light is out/running funny
  223. 91 Trooper question - general
  224. Paint question
  225. EGR Valve for 1993 Trooper?
  226. 96 fuel pressure regulator
  227. Engine
  228. 2001 Trooper MPG ?
  229. Engine check light and Reduce Power
  230. Looking into the Trooper and I have some Qs
  231. 1991 Trooper Manual
  232. 97 trooper power steering fan belt help
  233. 93 Trooper starting problem
  234. 1991 Trooper II 4wd 5spd
  235. How I Found a Substitute for 1998 Trooper Muffler
  236. License Plate Bolts?!
  237. How much to replace gaskets?
  238. 1991 Trooper accessories
  239. 1991 Trooper reverse gear problem
  240. Butane/Gasoline 1991 Trooper
  241. !995 Trooper Aftermarket Speakers
  242. wiring diagrams
  243. recall 93 trooper 3.2 sohc
  244. 91 trooper
  245. Green Air Filters?!
  246. 16 yr olds 94 trooper
  247. more power for my 99 Trooper
  248. 2001 Trooper dies going down road
  249. 2001 Trooper Transmission
  250. Where can I find 97 trooper repair manual?
