View Full Version : Trooper/SLX
Pages : 1 [2] 3 4 5
  1. Alternator Gone
  2. GAUGES 1990 Trooper Fuel/ Water Temp Gauges don't work?
  3. 87 Trooper II AC Clutch will not engage
  4. '91 Trooper 4x4, change to diesel?
  5. transmission problems already?
  6. 88 trooper, fuel problems
  7. 1998 Trooper Help - serpentine belt
  8. crank sensor location on 92 Trooper
  9. Oil soaked alternator
  10. Start
  11. 98 Isuzu trooper transmission rough
  12. 1987 Trooper II No fan and no turn signals
  13. 93 Trooper Transmission Failure
  14. Used engine source
  15. Turn signals 2000 Trooper
  16. couple issues
  17. 2002 Trooper
  18. 1996 Rear Binding On Take Off
  19. 1988 isuzu 2.6L 4cyl & Transmission parts F/S
  20. Thinking of Trading it in...
  21. Replace starter without removing exhaust
  22. Intake Manifold Gasket 2000 Trooper
  23. irradic throtle position and idling
  24. spotting radiator problems
  25. where is the switch
  26. Squealing engine still
  27. Transmission or yet another sensor?
  28. 88 Trooper will not start
  29. Let's try again!
  30. 89 trooper new front boots
  31. Starter
  32. Anyone ever solve the misfire on a 3.2 95 trooper?
  33. dragging brakes
  34. 2001 Isuzu Trooper Trans Filter Change
  35. 2 Issues, hopefully connected
  36. 94 Trooper Oil Pump Change
  37. Top Dead Center For 94 Trooper
  38. Audio Question
  39. 2000 trooper limited not staying in 1st gear
  40. sqeeking 4x4 93 trooper automatic
  41. Squealing engine
  42. Trooper Voltage
  43. 2001 Trooper Shift on the fly problem
  44. 94 Trooper headlights
  45. Just bought a '94 trooper...help!
  46. Towing Question
  47. 93 trooper weird tranny slipping problem
  48. no fuel
  49. 93 Trooper White Smoke
  50. HELP 92 trooper won't start just bought 2day
  51. Wheels ????
  52. Compatability question
  53. Problem!!!!
  54. 90 rear differential--compatable rear ends?
  55. 88 Trooper transmission swap
  56. Automatic FWD & REV on 2nd, 3rd, or 4th
  57. 2001 trooper drinks
  58. 2002 Trooper dash clock / temp display need one! Help!
  59. 2000 Trooper Tranny
  60. 1995 isuzu trooper locker
  61. 01 Trooper stalls
  62. Rebuilt engine installed truck wont start
  63. Burning rubber smell from 91 V6 trooper (5spd)
  64. 2001 Trooper flutter problem
  65. 91 Trooper Heater
  66. 2000 Trooper Rebuild Help - Can't Find Parts!!!
  67. 2002 Trooper reliability? I don't believe
  68. 1991 trooper start/idle problem
  69. How to make an auto transmission last longer?
  70. 92 Wandering
  71. What is this clutch part? Pressure problems
  72. 94 Trooper AC dryer pressure switch?
  73. 2001 Trooper starting problem
  74. 93 trooper transmission slipping help
  75. RPM Drop after warmup, but no shift
  76. I smell gas in the cab of my 98 trooper
  77. 1999 Trooper with bad engine-need information
  78. Need help
  79. new to trooper need answers
  80. How to remove the lower instrument panel??
  81. egr tube cracked
  82. 96 trooper should i buy?
  83. 94 izuzu trooper
  84. abs sensor
  85. 5 Speed Transmission help
  86. Timing belt change, need advice
  87. 93 Clutch line pressure loss?
  88. Trooper 98, alarm suspect - disable engine
  89. 1988 Isuzu trooper engine swap
  90. Isuzu Trooper 2.8TD Wiring Problem
  91. TOD Check Light issue
  92. 2000 Trooper CD Player
  93. cheap trooper
  94. WOW how do you get to intake cooling hoses.
  95. Using too much oil? Easy fix!
  96. Pulling a trailer 3.2L DOHC automatic 1500lb
  97. +98 OEM alt for sale:
  98. 94 3.2L How to adjust timing belt tension?
  99. NEED HELP w/ft Brake rotor 99 trooper
  100. I am desperate
  101. Clanging noise only in neutral 94 3.2L v6???
  102. 1998-2002 Trooper Fog Lamp Install w/ factory wiring
  103. in need of a service manual for my 92 trooper
  104. Erratic Idle when starting 98 Trooper
  105. oil light flickers on morning commute
  106. 98 trooper running board
  107. 1993 trooper air idle valve 3.2 motor
  108. Tires for 2000 Isuzu Trooper 4WD
  109. '91 - Power or Winter modes not working
  110. Pitman seal question
  111. Locating ALDL/OBD connector for checking CEL codes '91
  112. For sale: 99 isuzu trooper longblock v6
  113. 2000 Isuzu Trooper hesitating when less
  114. 95 trooper- keyless remote programming HELP!
  115. Revo's and Poly Bushings - WOW!
  116. 88 trooper cold stalls
  117. Starter Shims
  118. Help. having transmission problems
  119. 01 trooper code p0440
  120. TOD Check Light
  121. 01 4x4 TROOPER A/C COMPRESSOR
  122. Engine stumbles after 1 of hot running
  123. Where is EGR on 93 LS
  124. Dead
  125. Transmission Indicator Displays Wrong
  126. After Market Add On's
  127. Red Dawg and Blue Mule
  128. Puzzling check engine light
  129. Replacing Gear Oil -- Synthetic Questions??
  130. 2002 Trooper -- Back Door Rattle
  131. wire diagram 89 trooper t.c.u. HELP
  132. 89 Trooper Tranny Problem Send Help>>>>>>>>>>>>>>>>>
  133. what fits
  134. 1996 Isuzu Trooper for sale
  135. Tranmisson Problems
  136. Window will not go up
  137. Engine for 95 Trooper - $500
  138. Changing rear rotors/pads 00 Trooper 3.5
  139. Air Conditioner causes transmition to slip
  140. 02 Trooper high idle in gear
  141. Key stuck in ignition
  142. 1993 Trooper Winch Bumper?
  143. Service and Maintenance on 99 trooper
  144. Service and Maintenance on 99 trooper
  145. 1997 trooper charging problem
  146. carburetor base plate
  147. RPMs Jumping.
  148. malfunctioning oil pressure guage
  149. Plastic Wheel for Window Regulator
  150. new to isuzus
  151. Vacum leak near EGR, wont start
  152. 97 Rodeo starter removal?
  153. Rebuild or not...???
  154. 98-02 Sealed Transmission- can a dipstick be added?
  155. 93 trooper transmission slipping
  156. 2000 Trooper 3.5 - Programming FOB *AGAIN!*
  157. passenger side brake light not working
  158. 95 trooper 3.2l Auto stutters off and on
  159. Too much oil
  160. 1998 Trooper keyless entry ecu location?
  161. location of oil drain plug for 2000 Isuzu Trooper?
  162. 2000 Trooper 3.5 v6 Tranny Shuddering
  163. somethings rubbing
  164. 98 slx tranny gone @ 90K
  165. Check trans warning light
  166. catalytic converter
  167. Radio, speakers and amps
  168. TOD "Check" warning light
  169. 1996 Problems, Please Help.
  170. 2000 Trooper Spark Plug Question
  171. K&N Air Filters??
  172. 2000 Trooper Running Too Rich
  173. 2000 Trooper, The Oil Saga Continues
  174. High pitch whining
  175. 98 Trooper Exhaust Issues
  176. Major Trooper Idle Problem, Help please!!
  177. Trooper Tranny wiring troubles
  178. 99 Trooper: CEL, brakes, headlights and other assorted goodies
  179. Auto Transmission swap with Rodeo transmission
  180. Valve Calibration for Isuzu Trooper 1987 2.3
  181. Egine speed sensor
  182. TCM error code 13
  183. Leaky Differential
  184. 89 T2 parts car: V6 is toast.
  185. Can you help with this code??
  186. ABS light 01 Trooper 3.5
  187. Engine Idle at 1600rpm
  188. 93 trooper, where is fuel press regulator
  189. Fuel Economy of Fuel Injection
  190. Road Noise/Chatter
  191. cleaning EGR port
  192. does 93 trooper have MAF sensor?
  193. isuzu trooper reduced power light
  194. What Shocks do you Recommend (98 Trooper)
  195. Does anyone have a good service manual for a 1998 trooper??
  196. automatic locking problems
  197. sluggish 3.5 after timing belt change, question???
  198. 1990 troop with hesitation stumble=no answer
  199. 1988 Trooper 4ze1 2.6L Motor Wont Start
  200. 1988 trooper 2.6L 4ZE1 sohc
  201. I have asked everybody this can you help???
  202. Isuzu Braking Problem
  203. Tune up
  204. 99 Trooper workshop manual (PDF)
  205. The best OBD2 PC scaner for Trooper.
  206. Trooper II Transmission Control Module
  207. Limited Slip?
  208. Upper oil pan leak - how hard?
  209. diesel engine swap
  210. Red Check Engine Light 93Trooper
  211. She dies at idle
  212. Need Help on Suspension Parts Please
  213. Fresh off the boat, what to do now?
  214. 96 trooper few problems/questions
  215. I did it! Why not to use Bosch Platinum Plugs
  216. 1996 trooper purchase
  217. 91 trooper tranny problems
  218. 1991 Isuzu Trooper need tune up HELP!
  219. Cheapest Place to Buy Old Man Emu Suspension
  220. To Buy new Ball Joints or Reuse Origingals?
  221. HELP Trooper 2.8 td wont start
  222. 1997 Isuzu trooper will not turn over.
  223. '01 Trooper Front Wheel Noise
  224. 93' Trooper has too much play in steering
  225. Oil pressure reading on gauge
  226. No Luck with Spark Plug Boot Separation
  227. Engine Hesitating when engine is cold
  228. Newbie Starter Question
  229. Couple questions about my AUTO 4 Wheel
  230. Quick Questions
  231. Noob Question.....Very Simple (or should be)
  232. Transmission slips when Hot
  233. 00 Isuzu Trooper Hard Plastic Spare Tire Cover
  234. 1999 Trooper value?
  235. 1991 Isuzu trooper bad oil leak
  236. Couple Questions on Flushing Radiator
  237. oil pan gasket replacement 1986 Trooper
  238. Automatic transmission swap
  239. checking transmission fluid
  240. Which PCV Valve for my 2001 trooper Part # ?
  241. Check Trans/cel Both On?????????
  242. keyless entry horn beep
  243. 97 Trooper - Mechanic says waterpump needs to be replaced and cv joints are bad
  244. HELP - 99 Trooper- 200 Miles Per Fill Up POLAND
  245. 89 trooperII front hub replacement
  246. 1990 Trooper for sale in north AL
  247. bucking isuzu
  248. Transfer case trouble
  249. Tips for the I4s
  250. Washer pump problem
