Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Nissan
> Cefiro/Maxima/I30/I35 |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
car dies and starts right back up
Does a red (not burgandy) 02-03 maxima exist?
Need some advice.. Maxima newbie..
V6 Max Water Pump
Headlight Haze
whirling noise from pass side of engine
2004 maxima rattles on acceleration
Throttle Position Sensor/Throttle Body
Accelerator sticking in reverse on 2006 Maxima
Low whining when going in reverse... transmission?
nissan 89 maxima
04 Nissan Maxima coil packs
thermostat issue
Lower Radiator Support problem - RUSTING
Need to remove backseat side back rests on 2004 I35
95-99 Maxima Battery Cables
Climate Control Lighting
1996 I30t Wont Start..... Help
'96 Infiniti I30 will not start!
Panel illumination Nissan Maxima
Windows & Locks
2004 Maxima Bucking
'01 Max cruise control problem...
Serv. Eng. "mystery"
FS 1995 Nussan Maxima owners manual
rear strut mount issues on 2001 infiniti i30
05 maxima brake problem
need ignition coil and tune up advice
My GLE Maxima needs serious work :(
Help!!!
Strut & Shock Mounts
Help with Suspension for 2000 I30
Fuel Filter Replacement in a 2001 Maxima
Strut problem
Nissan Cefiro - Idling/driving rpm problem
P0455 and P1448 Codes, please help.
Front Wheel is coming off
Electronic engine mounts
95 maxima code p0443
95 maxima , passanger window don't go up
86 nissan maxima idling issue - please help
Couple of Problems
More info
noise /vibration 30/40 mph
Help w/ 2000 Maxima...
99infiniti i30
HELP Car overheating
Service Manual for Nissan Maxima 2000 GLE
Stumble when accelerating
I have no idea
fuse boxes
door pannel removel
Mechanic screwed my car and now unable to fix
Cefiro '89 Air Flow Meter Wiring
2K Maxima Engine Light On but no code found
Engine Whinning
Battery and Brake Light On, Replaced Alternator Last Saturday? (Nissan Maxima 97 GLE)
2000 Maxima Reverse Wire Location
87 Maxima lack of power
Had battery charged now won't crank!
Gas Smell in Cabin
radio when on makes a strange sound
engine makes screaching noise at startup and stalls
95 maxima timing chain
Need a new rim for 2001 20th anniversary max
1992 Maxima automatic transmission problem
Electrical problems.
93 Maxima, not starting
Replacing rusty rocker panels?
Rattling Noise When Accelarating Maxima
Air Bag light Blinking
Lights Dim
1995 Nissan Maxima V6 Runs/Dies
2004 Nissan Maxima Fog light fuse
2001 Maxima rear brake rotor removal
95 maxima car alarm randomly goes off
95 max fuel pump relay location
95 max battery getting drained
97 maxima front noise
1999 I30 Chugging and stalling
96 Maxima - Keyless door lock- Windows go down?
96 Maxima, Hard Starting WHY??????
What makes a maxima a maxima
1998 maxima front and rear speakers
97 maxima radio plays sound but no light
advice on 2000 maxima...
1989 Cefiro
windows go down no key no command..
LoLOMGWTFBBQS!
Service Engine Soon light came on
Brake and +- light on infiniti 01 i30 (91k miles)
Balljoints
2000 Infiniti I30 front end noise
CV Boot
Looking for '97 Maxima interior parts.
1996 Maxima runs rough and stalls
How good are ceramic brakes?
96-00* Max Questionable?
96 GLE/Front-end collison/Remote entry not working
INFINITI or Maxima rear lip Spoiler for I35?
air conditioning problem
First Drive: 2009 Nissan Maxima
Acceleration whistle: '03 Maxima
1995 max cranks but won't start
Passenger side key code
my Maxima Car (middle east)
All brake lights dont work- 96 max
Your opinion about this idea please!!!!!! And any tips you would like to give me.?
Alternator Output
99 I-30 with lots of miles--Please Help
No Engine Light
impossible to remove cd player
Whining Sound
max probs
Changing brakes soon, what kind would you recommend?
Should I do this with my 98 Maxima?
95 maxima DTC 0407, hard to start, kicks back
Metal noise when bump (sometimes)
out of control window
Change oil and brake
Transmission Filter
Is this true?
How do you know when to check...???
96 Nissan Maxima code p0734
How to suit up '00 Maxima
2000 Nissan Maxima w/ 77K miles for $5,500 a good deal?
Brake Guide Pins - 99 Maxima
89-94 VG30E Maxima...Performance Parts?
No Eletrical power till Engine Starts
95 Maxima slow and no power
Help With Several Check Engine Codes - WEIRD!
96 Infiniti I30 Pulling
OEM Car alarm keeps going off
'98 Maxima Giving problems
Metallic Popping Noise on Sharp Turns
jumper wires get hot and spark
Fuel Light
Metal noise when turning sharply to the right
Rough idle in gear 99 maxima
2009 Maxima
97' Maxima woes...
'98 Maxima rough idle, hard starting.
99 maxima engine starts for a second or 2 then shuts off
Headlights Stolen!
Locking or non-locking differential
MAF sensor question - 2000 Maxima
Problem with windows and locks
2003 Maxima GLE parts car... many parts for sale
Bad Front Engine Mount?
Car Is Making Weird Noises
00 max service light reset
'97 Maxima Engine Cuts Off While Driving!
"program Mode" For Nissan Maxima 2004
96 maxima hyper ground kit
93 Maxima stalls whlie driving
Just bought a 4th gen vq30de... Time to fix it up...
2001 Maxima
Help! '97 Maxima
Help with 2007 Maxima!!
VQ25 runs but stops under idle
Battery draining power 94 maxima
ABS Light 01 SE
I am having trouble programming my new remote!!
Looking for owners manual for 96 Infinity i-30
Tech help needed if possible
95MAX stalls after 5 mins runs ok before and after
Did the Dealer Screw Up My Car?
Both front windows no longer working
Love for maximas....and a little help
WON'T START - left me stranded.
95 Maxima battery and alarm help
I need help please!!!!
I made a Maxima Calendar!
2000 Maxima rough idle and stalls only when cold.NO CODES?. Any ideas?
New Owner Questions
Rear Strut
92 Maxima GXE Cruise control, where to begin
Wheel bearing, or something else?
New 95 Maxima owner
Programming 2001 or 2004 Maxima Key
01 Maxima SE Electrical
I Need Some Serious Help Please!!!!
No acceleration
Should I Do It?
Lowering Springs
95 maxima check engine light
98 Cefiro OE alarm going ballistic
How long have you had your maxima?
Vibration on idle and 30mph - 40mph
I30T 98- Belt squeel wont go away & Fuse map needed
1994 Maxima - Axle?
Keys
Headlights and Tailights
Engine wont turn over
Air intake sensor location
Engine wash
Maxima Auto Trans Stuck in 1st Gear!
00 Maxima Power Window Goes Up then drops by itself.
Removing plenum off 2000 Maxima
Overdrive...?
Rattling/Grinding noise coming from front end, 97 SE 5spd
Heres my STORY
95 max - hard start - HELP
how to clear air bag codes
Removing Factory Head Unit
96 Maxima w/ code p0745
95 maxima grill
clutch prob.
2001 Maxima starter
How may miles does your maxima have
96 i30 p0500
01 Max Cat Converter Hard/Easy Replacement
2001 Radio screen keeps going off
Pending OBD II codes
maxima overheating dont kno what to do
Audio fuse keeps blowing????
Tranny issue: Not shifting after oil change
Maxima Break Squeak
dealer and ntb exact opposite opinions
I30 over heating
99 I30 stalling, HELP?
Maxima Diesels
Resetting the computer.
Wierd noise coming from my engine....
2000+ muffler on 96 I30
'00 I30 extended cranking
95 maxima no power Alt or batt?
97 max stalls
noise in 2002 j35
window inop
CEL and 2 codes
2007 Maxima se. gas tank non fillable?
Infiniti Navigation discs
97 Nissan Max curise control issue
FS:1991 maxima garage sale!!!cheap!
I30 Vacuum Hose Diagram?
90 max heat
Maxima Codes
Replaced Knock Sensor in 96 Maxima
00 Maxima, runs great, no power HELP
Noises in 03 Max!!
2001 Nissan Maxima
ABS Light
I30 Fog Light Installation
looking at a 2001 Maxima
90 maxima acting funny on start up
P0174 Code
Web
AF
