View Full Version : Cefiro/Maxima/I30/I35
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
  1. Maxima.org
  2. GLE/GXE & SE suspension question
  3. OIL CHANGE QUESTION 1997 Max 3.0
  4. Groaning Sound from Rear pads 97 Maxima
  5. First weird thing ever happened
  6. anyone have a plastic tray for the dash lying around?
  7. steering rack leaks - what are my options?
  8. steering shaking b/w 60-80mph
  9. Problem codes HELP
  10. bad paint on 2000 se
  11. How do I test Fuel Injectors?
  12. are these shifters any good? why so cheap?
  13. Spark plugs
  14. 2002 Max w/Bose 6 disc question
  15. f/s intake, mafs, altezzas, and iat sensor
  16. Electrical problem, HELP!
  17. Left the gas cap off...
  18. Parting out a 94 Maxima
  19. replacement of struts
  20. no start 95 max
  21. new keys
  22. 1993 Maxima Fuse Problem
  23. LED side mirror turn signals
  24. maxima shirt
  25. WARPSPEED Y-PIPE (95-99) Maxima
  26. Looking at a used max..
  27. Clear Side Markers....
  28. 2000 I30T speedometer head
  29. 00 Max Bose Rear Speaker
  30. Opinion....
  31. Quick Question B4 I go back to my Mechanic
  32. Replacing Rear Struts Easy?
  33. how to change out Oxygen adn Knock sensors for 96 I30
  34. Should i buy??
  35. Should i buy??
  36. more reliable? altima or maxima (95-99)
  37. Blew my F***ing MAFS again
  38. Bose rear speakers '95
  39. 87 Intercooled, Turbo for sale.......
  40. Weird problem
  41. where do you mount the air temp sensor
  42. difference between a 98 Nissan Maxima GLE and SE
  43. 2003 maxima problem!
  44. latest pick
  45. Which intake? Which Y-pipe?
  46. will 10.5's fit
  47. I don't usually post this stuff
  48. Found keyless code, need help using it.
  49. Check Engine Light From Trunk?
  50. 1996 corolla, camry or maxima?
  51. front strut bar
  52. Possible starter problem
  53. Need Rims 4 Bolt 15 To 17 Inch 205/215 45/55
  54. 97 Maxima at dragway Video
  55. Starting Problems Max98gle-one More Time
  56. stumped...whatsup with my brakes
  57. Opinions on Xexon Theft??
  58. Nissan Maxima MAF Help!!!!!!!IMMEDIATE RESPONSE PLEASE!!!
  59. R32 Headlight Mod
  60. simple air cond. question
  61. 96 maxima egr temp sensor
  62. better but not quite right!!!!!
  63. does FTSB work well?
  64. parts that fit 93 max
  65. My car went dead and I need your help..
  66. For Sale: Brand New!! Injen Cold Air Intake Still In Box
  67. 89 maxima engine swap
  68. speedometer is failing
  69. 1993 maxima emission problem?
  70. P1105, Wath is this?
  71. tranny on '94 slipping
  72. HELP Maxima just quit!!!!
  73. 04' max 350z parts
  74. Error code 31. Replace ECM???
  75. Knock Sensor and C.E.L.
  76. HVAC Controls
  77. Airflow Direction
  78. Weird noise from front right wheel.
  79. Suddenly running on 5?
  80. synchros
  81. quick question
  82. favorite tire care stuff
  83. small maintenance= big difference
  84. 1985 keyless entry problems, HELP
  85. Murdered a jdm b16 powered CRX.
  86. F/S or Trade: 18' 2004 maxima wheels w/less than 700 miles on them.
  87. modded maxima
  88. bodykits for 94 maxima
  89. need new clutch
  90. Maxima 93 (White) for parts
  91. stereo installation
  92. clutch fluid
  93. OEM LED SPOILER REPLACEMENT need help!!!!
  94. maxima questions
  95. Aftermarket alarm on 5th Gen Maxima
  96. 2004 Nissan Maxima SE engine knocking sound
  97. Engine Knocking
  98. Cattman.com problems..
  99. 1996 I30 Hesitation, only from a stand still
  100. *NEW* Genuine Nissan Maxima Foglight Kit F/S!!
  101. maybe buyin max....
  102. Chip Guards (Like Mud Flaps)
  103. Opinions on FUEL CLEANER "Dura-Lube"
  104. Maximum Fog Light Wattage H3???
  105. 2000 Maxima engine noise + stalls @ low RPM
  106. I30 shifting
  107. CLuster for 95-97 SE
  108. 2003 Maxima color choice ?
  109. 1998 Nissan Maxima - Spark Plug Location
  110. 96 Maxima Fuel Tank Capacity
  111. 6speed max???
  112. Shimmey?
  113. help loss of power 95 max se
  114. 1985 Nissan Maxima, alarm system
  115. P0430 DTC Code - 2000 Maxima SE
  116. CUSTOMIZED MAXIMA GAUGES...really custom!!!
  117. Where do you get your stuff?
  118. can i install my own timing belt -- 92 maxima
  119. Terminology?
  120. need help with me car
  121. weak steering response
  122. what tires should i buy?
  123. Difference's btwn. 4th generation models (GXE, GLE, SE)
  124. Can I replace my own brake pads?
  125. FS: Orange Corners, Indiglo Gauges, TireFlys, & Bulbs
  126. Y-Pipe?
  127. new guy
  128. Where's all the 3rd gens???
  129. 01 Maxima Keyless Entry
  130. Y pipe or exhaust?
  131. Help with Maxima Exhaust
  132. Service Engine Light
  133. Question about damage to engine?
  134. Burnt Clutch
  135. 04 Max steering wheel jiggles at speed
  136. why does maxima.org suck...
  137. 95/96 factory fogs
  138. Axle Bolt
  139. Hook up a 96 Maxima, $????
  140. HELP!!! hardwire V1 to a 99 Maxima!
  141. yah weird question
  142. 95 maxima help, important
  143. Need a big favor!!
  144. Cat back exhaust for sale
  145. question about dash removal on a 96 Maxima
  146. DANGIT! Transmission P.O.S. PLEASE HELP!
  147. Mods/Adjustments to a 93 se...please help
  148. y pipes and exhaust
  149. 95 Max - Engine Shudder, Exh Sputter, & Stall Symptom while idling @ stop
  150. droppng the clutch
  151. Whistling
  152. 97 Maxima Keyless Entry Help
  153. Couple of maxima questions
  154. 2 things check engine light/bumping in steering
  155. Why???
  156. maxima years and horsepower rating
  157. slammer kit aka air bags
  158. 1996 I30 Odometer problem
  159. maxima ?'s water temp/knock loc.
  160. Hey Guys and Girls;
  161. 1990 Nissan 300ZX & 1987 Chevy Celebirty
  162. 2004 Maxima Knocking Noise (not engine)
  163. DR mod...
  164. Aftermarket Fenders
  165. 2002 Maxima engine knock
  166. Exterior mods for a 4th Gen.
  167. lost power
  168. 97 Maxima vs. 2003 Accord V6
  169. oil problems after i peel out STARTING TO PISS ME OFF
  170. 92 SE throttle position sensor resistance range
  171. Mods on '04s look very nice
  172. 95 Maxima questions ( steering related)
  173. 440,446 trouble code 97 max !HELP!!!
  174. Help! Need CarFax Report ASAP
  175. Wiper arm removal
  176. HELP !.. Engine power surges, stalls when at low RPM's, not constant but annoying
  177. Update, Recall & Service Engine light
  178. GReddy Catback Systems/Exhaust setups!!
  179. stock 95 GXE vs. stock IS 300
  180. Mevi
  181. Exterior....95-96/97-99
  182. having trouble starting my max
  183. Selling a Datsun 280Z. See pics.
  184. My 95 is trying to die on take off
  185. Adapting I35 stock stereo unit to I30
  186. moods for 2004 maxima
  187. 84 max, no oil pressure at idle
  188. 180 climate control on A31
  189. anyone change the 2004 max headlights
  190. Front Clunking Noise - Strut Mount?
  191. Maximadriver.com
  192. Seatbelt cable out of track? How would you fix it?
  193. Homelink and X10
  194. 1996 Maxima brake pad question. CAN I Combine pads?
  195. 0303 or P0150 code, O2 sensor
  196. Easy Install for 95-96 G3 Altezza Tail?
  197. 03 Maxima
  198. Need To Buy New 1996 Maxima Keyless Remote
  199. must sell brand new stillen side skirts !!!!! 3rd gen maxima
  200. Bose Headunit Blackouts
  201. New owner of 2004SL
  202. Cleanout headlight?
  203. Which brake pads should I use?
  204. Isuzu Rodeo 2000 - How do you reset the cars computer?
  205. car is hesitant to start
  206. For Sale 17" Nissan wheels and tires
  207. Do you have experience with replacing Camber Bolts?
  208. My passenger side Headlight won't turn off? HELP
  209. Body kits!
  210. Help!!! Odometer question on my 96 Max
  211. 99 Max Front Bumper Cover
  212. Sould I buy a I30 or a es 300
  213. My mounting troubles with my 1996 Maxima
  214. 96 Maxima Altezza's
  215. A Strange thing happened to me today...
  216. Tornado Fuelsaver
  217. 1987 Maxima Sunroof leaks... OEM parts?
  218. A31 Cefiro For Sale.
  219. I30 & Maxima 5 sp. the same?
  220. Runs rough after starting a warm motor.
  221. 96 Maxima antenna mast replacement
  222. Service Engine Light came on today
  223. 96 maxima start no run
  224. When should we be scared?
  225. rubbing/dragging noise coming from wheel
  226. 1996 BOSE cd player shows - err
  227. cabin air filter
  228. Need Help-20th edition SE skirts
  229. Where is everyone from ?
  230. 91 maxima seatbelts
  231. Maxima Racing Forum is Up: Join the Crew
  232. Help with 1990 ECCS Diagnostic
  233. my 95 maxima is fucked, how much will all this cost
  234. my 04 maxima vs. s2000
  235. How to program an OEM remote
  236. Life-time brake pads!!
  237. Where to buy a muffler?
  238. Looking to buy
  239. Key Problems with 1990 Maxima
  240. Drumming Noise in 1996 Maxima?!
  241. Which exhaust?
  242. Auto Shift Knob ??
  243. Bigger rims, Bigger Acceleration???
  244. Computer / exhaust
  245. PLEASE buy my exhaust 4th gen Greddy SP2
  246. Maxima vs. SE-R Spec V
  247. 2000 Maxima Belt Replacement
  248. short throw shifter
  249. Need help getting alternator out of '91 maxima
  250. Greddy Exhaust Question
