View Full Version : Cefiro/Maxima/I30/I35
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
  1. VQ30DE Compression Check
  2. 92 Max with Engine Stalling at StopNGo Traffic
  3. Low Fuel light
  4. Lights for Bose
  5. ecu upgrade
  6. Reset my ECU???
  7. Help on checking ecu fault code on 2kse
  8. Stock Clarion Amplifire inputs/outputs
  9. Manual Tranny for '86
  10. Auto to 5-speed
  11. Worth it to install 6x9 spkrs on a 4th gen?
  12. Rear sway bar
  13. does over drive burn more gas
  14. How hard it is to install headers on 5th gen?
  15. some intake questions
  16. drive axle installation problem
  17. Performance parts?
  18. 1994 maxima automatic down shifting probelm
  19. newer rims on an old car
  20. 2000 Maxima hesitation under acceleration
  21. 1993 gxe, put in D won't run, trasmision problem?
  22. Pics of my car with rims...
  23. these any good?
  24. New '96 GLE, a few questions
  25. stupid question
  26. Gas Mileage 2000-2001 I30?
  27. what is the recomed tire pressure for 17" aftermarket rims?
  28. Garage Door Opener!!
  29. Newb needs help !
  30. 1/4 mile 0-60 times
  31. Window/Lock Switch Lighting
  32. Tire Shopping: 99 GLE
  33. check out the deal
  34. cold air intake and CD player
  35. F5 Hurricane Resistor Sensor Modification
  36. 1992 Maxima fuel return hose
  37. 87 maxima reverse lights not working
  38. steering vibration over 110km/h
  39. BOSE question, 03 Maxima
  40. will these rims fit my 2k1.....
  41. Need Help! Will 19x9s fit a 5th gen front?
  42. Couple of exhaust questions.
  43. 92 max burning oil.
  44. 93 maxima got her period
  45. polished mevi on ebay...
  46. 03 Berhundy Maxima
  47. good rear component speakers
  48. what exhaust do u have
  49. 97 Max idle problem in neutral
  50. Clutch fluid leak question
  51. 95-99 max vs 99 hoda civic SI
  52. This Is What I Need
  53. Intake Temperature sensor. Where is it ??
  54. 1996 Infinity I30: booming noise on highway
  55. i need help quick
  56. pace setter exhaust......good? bad?
  57. 95 maxima gxe for sale
  58. Dash and rear lights not working, HELP
  59. New rimmies
  60. what the hell is the flex plate
  61. AC Odor
  62. anti-freeze leaking from the back
  63. Rattling trunk
  64. Electrical Problem
  65. 1998 Wierd things happening
  66. 93 maxima blower switch
  67. Idle Problems
  68. My right headlight never turns off
  69. RVM rims
  70. Is Premium gas really needed?
  71. evaporater cannister/fuel tank
  72. I Need A Hood For A 2001 Nissan Maxima Gle
  73. Window down feature
  74. Can't get flywheel off, please help!!
  75. Help Where is connector for back O2 sensor
  76. MOdifying the IAT sensor with a Capicitor
  77. does anyone live in dallas
  78. Help the Chariot Spank old domestic at RANKMY RIDE !
  79. Elusive Part
  80. Suspension and Rim info
  81. Doh
  82. all my Sh** is labeled in japanense!!!
  83. FS: '97 Stock Springs and Shocks
  84. need tran. for 98 se
  85. 92 maxima alarm won't go off
  86. Which cat-back exhaust?!?! Please Help
  87. which maxima should I buy?
  88. 96 Max, can I install the BOSE system???
  89. remote car starter
  90. Fan resistor question
  91. does anybody have one??
  92. Cattman Headers
  93. 2001 i30t transmission shifts very hard
  94. Sensors
  95. Will KYB dust covers work on GR2's?
  96. Help? I give you my maxima and 1,000 bucks! ... kinda
  97. how does this work???
  98. what axles?
  99. Maxima's new passive alarm will decrease your insurance
  100. 2003 Maxima vs. 1997 Grand Prix.
  101. you know jersey123 is an idiot when...
  102. 03 Nissan Insurance; Acura CL insurance
  103. how fast have you been
  104. 96 Max, where should I get it repainted?
  105. EVAP canister purge volume control valve
  106. GAB intake mod info needed
  107. KYB GR2 better than stock for 95SE ?
  108. Maintaince Info Needed!!
  109. nOOBY Question
  110. Fog Light
  111. Exhaust info
  112. 03 Maxima VS. 03 Acura CL
  113. codes again!!!!! after fixing everything
  114. 94 Max Audio problem
  115. 0701 multiple cycliner misfire, anyone has that?
  116. FS: 96 Maxima SE 5-spd
  117. For Sale, My rims!
  118. 1997 Maxima has slight drift to the right
  119. Need transmission for 93 Maxima GXE
  120. What year rotors will work????
  121. Almost Stalls
  122. MAF sensor and codes
  123. 18x8 Volks on Pearl White Max
  124. Been away awhile
  125. 97 Maxima 3.0 with 80K QUESTION
  126. dash sensor
  127. Defrost vents?
  128. 02-03 help needed
  129. Brake & Battery Lights
  130. For Sale: 95 Maxima GXE
  131. Parting out 89 Maxima
  132. losing Power...Electrical
  133. interior courtsey lights
  134. XM radio for 2004 Maxima (aftermarket)
  135. 93 Gxe V6 Dohc Hesitates And Cuts Off
  136. 02-03 parking light replacement?
  137. Master cylinder questions
  138. BOSE Problem
  139. skyline
  140. 2002 Maxima CD PLayer Problem
  141. New car... maybe??? Help? yes? please?
  142. o2 sensor change sound?
  143. tired of weak lights!!!!!
  144. Cost of CAI
  145. 00-03 Rear Sway Bar Suggestions
  146. 96 Max, How do i fix my spoiler LED's?
  147. New Ride
  148. Service in Question
  149. Where To Buy Replacement Fog Lamp??
  150. overheating
  151. 02 max 6spd short throw shifter
  152. Maxima.org ?????????
  153. 95-96 97-99 tail light difference
  154. For Sale Brand New Exedy Clutch $220 Shipped
  155. Maxima stock hp figures for 97-99 SE & GXE???
  156. 96 Max, Why does it keep hydroplainning?
  157. Clear Taillights - Home Depot
  158. P1320 warning light code on. Anyone know what this means?
  159. Where to buy parts...
  160. burn outs
  161. which rotors??????
  162. Conversion FWD to RWD
  163. auto transsmission
  164. Transmission Fluid Change
  165. 2003 Maxima tail lights
  166. Trouble finding this material...
  167. DIY transmission fluid change?
  168. ABS Dash Light
  169. 00 maxima timing chain
  170. Waterpump
  171. Need help with brake replacement please!
  172. 95 Max (4th Gen) - Fuel Cleaner Suggestions
  173. power braking/brake torque
  174. 2000 maxima stall on rev
  175. Short Throw Shifter???
  176. Need Help with Frankenar Install
  177. Toyota Scion TC
  178. Fuel Injector Problem
  179. Rear driver side wheel rolling tight....smoke/burning smell coming from the wheel
  180. Emergency In Md Need Brakes Now
  181. linking the dimmer switch to the clock
  182. PSA: "service engine soon" light - check it yourself
  183. blown valve
  184. Axle replacement. Anything difficult about this?
  185. Best Fuel Injector Cleaner?
  186. 00' needs diet.
  187. Beware Ebay bulbs!
  188. Anyone with 18"s on 00-02
  189. bleeding clutch
  190. good alignmentshops in Central NJ?
  191. Cali Spec Questions
  192. going to lose my car
  193. Air Flow/Exhaust censor causing this?
  194. Bose Radio Illumination
  195. Anyone else paranoid?
  196. shift kit or vb upgrade
  197. Clutch problem!
  198. smoked a preppy strap in his jetta
  199. Nissan Maxima SE For Sale
  200. anywhere online where i can get exhaust diagram for 89-94 GXE ?
  201. Knocking from front of the Maxima
  202. Advancing the timing
  203. Shift boot/E-brake boot purchase...where to buy?
  204. Components of stock '96 Bose system?
  205. Engine light with new cone filter
  206. 3rd time a charm???
  207. new ride
  208. Question about doing a I30 LSD tranny swap
  209. 1987 Maxima VIN # ??
  210. 2003 Maxima Insurance
  211. AE Pedal Installation
  212. factoy foglights...
  213. Windshield Problem
  214. Strobe Kits
  215. Sup newbies???
  216. turn signals
  217. K&N Air Filter...Worth it?
  218. anyone with y-pipe as only exhaust mod?
  219. Polish headlight & windshield?
  220. 02 MAX Rear end alignment
  221. Which Cold Air Intake?
  222. Caliper Replacement
  223. Parking Light Fuse
  224. ECU error code 0704
  225. Car Domain Sites?
  226. Bodykits...Have any of u ever?
  227. Bodykits...Have any of u ever?
  228. Bodykits...Have any of u ever?
  229. Sub Ruins Rear Tires?
  230. 97 Maxima lights dim, radio turns off
  231. PICS - Floyd Bennett Field
  232. 1996 Maxima SE Bose Stereo System Problems
  233. 4th Gen Maxima Auto Climate Control
  234. Brake pad replace questions
  235. PLEASE help :-)
  236. *NEW* Genuine Nissan Maxima Floormats !!
  237. Bought a '96 SE, now I'm leaking oil a day later...
  238. 1995 maxima
  239. What happened to www.maximaforum.com??
  240. Door handle codes unlock and lock doors
  241. Anyone know how to reattach a spoiler?
  242. "Whirring noise in 1st gear"
  243. Shifter squeek or chirp
  244. synthetic motor oils For Turbo & SuperCharged maxima
  245. forum
  246. Frankencar...Deadbeats???
  247. stalling prob. w/ 3rd gen maxima
  248. Hum and Vibration from right front of 99 Maxima SE
  249. Size of axle hub nut (97 SE)????
  250. difficult to explain
