Igor Sushko on Facebook
Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Nissan
> Cefiro/Maxima/I30/I35 |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
maxima motor
Rims and Wheels?
300zx rotors and calipers
04 transmission in an 03
Metal Nun-chucks! Guys check this out.
2001 maxima 20th an. ed. vs. 2002 civic si, who would win?
91 Maxima Intake????
my steering wheel has the shakes
maxima for sale
Whats all this whining noise??
1993 Maxima Error code 21? HELP!
stalling
Maximas = premium fuel only?
1995 - 2000 Max engine??
1995 Maxima 4 dr for parts... (NJ) rust free
How to get to rear exhaust manf bolts on '99?
pcv valve & fuel filter
Non Maxima Owner Question 04
Ignition wires.
01 maxima se 20th an. ed. vs. 01 eclipse
Maxima cutting out
300zx
Long 2nd gear in 2k maxima?
?'s about painting my altezzas like a skyline
automatic '85 maxima gear problem
Nissan brake rotor life span?
Bank 1 & Bank 2
Dropped Maxima!! Camber Kit???
2003 High beams wrong color
fitting 3.5 Altima SE rims question
wires questions for CD player head unit
Will 97 maxima se 16inch rims fit my 96 max?
snow tires
Nissan Maxima 1996 Whining noise
all season tires
1998 Maxima SE electrical problems
Need a photoshop
Different Chassis???
possible parts car (90 maxima)
96 maxima GXE vehicle speed sensor/ SMOG check w engine light on??
HELP... Maxima RPM guage needle got stuck
Crank but no Start
Im Buying A Maxima But What Year Should I Get????
2005 maxima
would these rims fit?
Recommended Brake Pads/Rotors
Rough Idle/Hesitation/Weakness (1999 Max SE Limited 5-spd)
Sponsor
Looking for 95-99 Parts car!!
Help!
cd player install on 95 maxima
Steering Wheel Stereo Controls
having problems w/ my '91 Maxima
OIL LEAK in 96 MAX
ECU 0505 code?
Cleaning of '98 Maxima Headlight Lenses
temp gauge - '90 Maxima - help
need help cefiro RB26Dett!!
Your advice re: Weak spots: 96-97 Maximas
Rough running 1993 SE
Programming a 2002 Nissan Maxima Keyless Entry Remote
18 inch enkei rims for sale cheap
I might take ownership of late model I30.
SRS light Blinking all the time
battery light
Intermittent high beam
Old maxima (help)
2K1 I30 Bose Stereo Questions...
Who will win?
G6 or same old tricks
CEL with PO420 code
Bosch Oxygen Sensors
Reverse problem when cold
Tranny, Buy Or Rebuild... Help!
cefiro headlight bulbs and grille?
95 maxima gxe for sale
Projector headlamps for Maxima '99. Anyone saw it? Does it exist? :)
electrical problems
will these rims fit?
help fitting G35 rims on my I30
1989 max turbo????
Y-pipe and Cat.
ebcm gm#12389539 inop repair or replace?
Looking for parts for a 95 max
intake system i bought off ebay for my 95 maxima..need info
Rear brake
'96 maxima front brake squeal- help!!!
1989 Mxima Body Kit Help
1989 maxima speedometer
Service Engine Soon Light
Custom turbo kit for 95 Maxima
Wheel Question?
anyone knows where to get wheel center caps for I30?
Aftermarket radio/steering controls
Stillen Intake... worth it?
Cali Knock Sensor
92 maxima brake line leak
Changing Radio on '94, screws will not come out - HELP!
Exhaust pipe 2000 SE Max
Headers
97 Cefiro Wiring help
2002 I35 Power Seat Memory
Advice on Buying 2000 i30t
paint job
Stereo bracket removal
Infiniti to drop I35
does nissan make a tip or sport tronic transmission for maxima?
Help please!
Acceleration Problem with '98 Maxima
Rear Speaker Question 97 Maxima
Adjusting the clutch cable
Brake specs on 4th gen?
Engine Swap
Keyless Remote Programming Instructions
transmission upshift problem
WANTED - Passenger side wing indicator cap and holder for..........
considering buying a maxima
Decoding error code
98 Maxima Remote Control Problem
97 max error codes
**Infiniti I-30 Body&Parts Wanted**
98 Maxima parking brake problem
1993 Nissan Maxima (alarm need help)
Strut life
location of egr valve on a 99?
When driving on the highway or not a perfect road is the outside sound easily heard?
2001 Maxima. Service Engine Soon Light is ON.
For Sale: 2001 Maxima
1996 maxima does not start on first turn of key
Check Engine Soon
Engine Knock
92 maxima missin?
Exploded bulb-now what?
Engine Swap
Engine Light ON??
95-96 Red/Clear Tails on eBay
CG-Lock from Tunervision - Worth it ?
corner lights
Need help w/ fuse diagram
Air bag
WTB:// A31 Cefiro Grille
audio system needed
FS: 98 max 95k buffalo area
Angel Eyes
Maxima '89
Opinions On 2k -2k1 Max
Dash Lights Out After Removed Factory Radio.............does Anyone Know How To Fix?
steering fluid leaking
98 maxima tire / tranny shake?
92 maxima need info!
O2 sensors, Knock sensor, EGRC Solenoid Valve
Since I know nothing about cars.....
Knock Sensor and ECT Sensor
My Maxima
2004 Maxima Headlight Aim Adjustment
Brake and Engine light on
Bose problem
1993 Air Bag Warning Light
Windsheild molding
first time at the track
5 spd Maxima vs. 5 spd Prelude.
Passenger door mirror
A 2000 Front On A 96
ECU Codes
gotta question
maxima of middle east
Just got my 99(slightly modded)
a31 cefiro grille?
Help with ecu code please
99 Blower motor resistor
Pics of 03 Max
99 Max blower motor resistor
MPG on 03 Max
Be aware!!
+20hp Power Mod Chip Nissan Maxima????
ECU Code 05 05
94 nissan maxima blower
upgrading tires - wider profile
Knock Sensor
2001 Maxima rear door will not open from inside or outside
help with tranny problems..
first time mod, 95 maxima, help wanted
Keyless Entry Help Wanted!
Where is the Front Left O2 sensor located?
adding power seats 92
Need Help...
cefiro headlight bulbs?
Parting out a 96 maxima plus some goodies
2004 Maxima Elite ?'s...
cleared headlights
2000 Nissan Maxima - Difficult Acceleration
Inside CV boots for 96 Infiniti I-30
Rear brake pads installation
Sluggish 96 GLE
Tints
ECU code help please
02 maxima vs 02 audi a4
PIAA fogs
Anyone know how to stop a squealing pully?
ecu code 0509
93 Maxima ignition will click relays, but not turn engine.
HELP tranny problems
95 SE cold start problem fixed
whiney hum (ho hum)
hi everyone
Cefiro Maxima puzzle
91 SE - stalling, no power - RESOLVED!
2003 3.5 engine swap into 98 3.0L max
Wood dash trim with charcoal plush interior?
what's happening to my '88: starts, noise, stalls
2004 maxima stalls on occasion at startup
dash trim for 2003 max
little help
Wtb:oem Rims For 2002 Gle
2 Problems
tire size
2003 Bergundy Maxima SE
2004 maxima tranny
18's or 19's on maixma opinion
FS: 1995 Ruby Pearl Maxima
engine light
Where is the PCV Valve for 00'
need help
Tuning up my 2001
91 maxima bad engine noise
Carbon fiber hood on 5th Gen
urgent! question about ignition coil !!!
2002 Maxima gas door
Instrument panel and radio display
91 Door Buttons
help
think about a 95 max
PIAA Xtreme Foglights
3 problems
Y-pipe
2003 Maxima rims
what piston brake up grade can i put on a 95 max?
what is this?
3 diff noises.
Parting out 1989 Maxima.
Any real improvements?
Xeon Bulbs
door lock problem
Maxima Discontinued 2004
ECU ERROR code: 0104 (Vehicle Speed Sensor)
Engine Ground Wire kit worth it?
FOR SALE: (MAX/I30) BUDGET Y-pipe, STILLEN RASB, REESE TRAILER HITCH
Rim Fitting Info
QUESTION?!?! Whats the Best Suspension out there For a 97 Max?
Web
AF
