Igor Sushko on Facebook
Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Nissan
> Cefiro/Maxima/I30/I35 |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
Chips on eBay????
0509 again please hlep
Leaking Sunroof, HELP!!!!!!!!!!!!!
More cefiro help
cefiro headlamps for 96' infiniti I-30
Cefiro Help Plzzz
Cold Air Intake
Help with ECU problems
Emissions question...
reccomended wheel/rim size
gas mileage
Vibration after clutch install
Transmission Will Not Shift
Aftermarket y pipe
Computer Upgrade for Nissan Maxima?
2000 GLE Starter
*noob* AE Shift Knob
noise under the hood
My Poor Car
Rims
Help Dealership ripping friend off what can he do
CAI is it really worth it
A Mod question...
infinty or maxima
Infinity Stalls
Keyless Remote programming for 2005 Nisan MAxima
Old maxima=rwd?
4 - 19" KONIG TANTRUMS RIMS WITH TIRES
To dealership or not to dealership...
Best Muffler for a 96 Max...
2000 Maxima Stalling during idle
1993 Maxima Service Manual For Sale
FS: 1995 Turbocharged Nissan Maxima
adding RCA input jacks to stock bose system
2001 Ininiti Stereo system gets stuck
is the 2002 maxima a good buy?
2001 maxima oxygen sensor instructions?
Alternator DIY
1999 Infinity I30 Engine misses sometimes
Leather seats
Cefiro A31's body kit
unknown connector under the hood!?
My Maxima for sale on ebay
2000 Maxima SE Shift knobs/Performance upgrades ?
5 Speed tranny conv. in a 99 auto Max
new with questions
idle adjustment
2002 Maxima SE Annoyances
Need Auto Trans Expert.
95 tranny swap
Whick rims do you like better???
is $5,300 for a '95 SE with all options a good deal?
Crazy ass idea...
Mods for Maxima?
Problem with exhaust....
Nissan Maxima 2002 Fog Hid
power door locks
purge volume control valve
Heated Oxygen Sensor
HELP 86 maxima only idles
OEM Y-Pipe replaced
thumping sound when turning at low speeds...what is it?
how fast have u been in ur max
Wrecked my 96 Maxima last night--what did I break and how to fix it?
infiniti i30 side marker light
Oil Pan and Valve Cover Gaskets...
Crappy Y-pipe noise
engine noise
Transmission Issue
Alero is junk
96 Maxima Cruise problem
engine swap
O/D Overdrive light flashes on and off 16 times
99 I30 oil burner
1990 Maxima won't start
Service Engine Soon 2001 Maxima
D*mn Needles
bose system integration adapter
looking to buy maxima
flex pipe needs replacing
Okay, help me here dudes.
ODB II protocol for a 2000 Maxima
2002 Infiniti I-35 OEM BOSE 6 Disc CD Changer/Radio/Cassette
what is this?
Knock sensor was replaced...
high brake light 1999 I30
97 Max Air Sound Question???
idle adjustment
1999 maxima oil pressure guage Q's
sticky throttle/gas pedal
89-94 maxima parts
Transponder key
Where is Audio Amp Relay for Max 95?
maxima locking problem
01 maxima foglights
Traction Control Malfunc & SES light on
92 Maxima SE Auto Need help!!!
NEED 98 I30 FOG AND CORNER LIGHT ASAP Pass-side
cefiro headlights
How's I30?
I30 Rear wiring
tire problem, please help.
coil packs replaceing after 200000KM
Remove radio in Cefiro 1999?
Eec Codes
96 i30 oil leak
about to buy 91 max SE
Slow!
wtb. 96 or 97 maxima
Emergency Brake problem
any new zealand maxima/cerfiro owners out there ?
Question about Computer numbers.....
2000 maxima exhaust
95 maxima starter location?
95 Maxima Flex plate swap
How to read codes?
96 Maxima, Fog Lite Kit Installation
96 maxima timing belt replacement
Brake jam after idle for few hours(2001 I 30)
2000 Maxima dies when I put it in gear
rims
2000 Maxima engine service soon light problem
where is Throttle Position Sensor at?
2000 Rpm
96 Maxima Cut BCM Harness
Auxiliary Fan Motor Problem - Not Sure
Flowmaster...
acceleration problem please help
i smell gas
FS: Yakima Roof Rack System for '04 Maxima
ECU upgrades
cruise control
Brand new tires 4 sale
start
light bulb change
2001 Infinity I30 O2 Sensor Bad already?
Computer problems....
Fuel Guage
Car chugging
1994 Maxima wiring....
2002 SE 6 spd Problems
99 Maxima Service Engine Soon
Maxima's..Future Car..How Are They..
Headers for '95 maxima?
problem starting max
just did 60k tune-up, what a difference!
Check list for 94 Maxima
will 2005 maxima rims fit my 98?
g timer 2
Maxima 92 Ti Electical Problem
93 maxima interior lights bling for 2 minutes on startup
how does one program a car remote
Degree timing change?
1997 Maxima SE- slow to start
idkle air control
Question About Swapping Factory Radios
97 I30 Won't start just hear buzz and pops
Need new trunk
Best CAI Filter
1996 Infiniti I30 won't start
98' almost stalls in cold weather
engine swap
F/S NEW(never installed) MEVI with cover and install kit.
Exhaust Recommendations
?'s about 00-04 max's
help! is my shaking 2000 maxima dying?
95-96 vs 97-99 grille
my new 2004 maxima SL.
1990 Max mods
tires
1993 Maxima GL Axle Boot
Side markers and fogs don't work!
Does Tire Size make a Difference? ? ?
nissan cefiro
G-Tech Pro
Bose stereo cuts off
replacing spark plugs
ECU Question
Newbie here! 90 Max won't start!!!! Help! Anyone!
in-cabin microfilter 2001 i30
new code
Cylinder problem, and ground wire.
Power Antenna -98 Maxima Wiring Troubles
Idle Burp - 99 Max
Lifters - possible to only replace 2 or 3?
1994 Nissan Maxima GXE - Will not go into P
Oil leak
fuse diagram for 1995 maxima
carbon fiber hoods
heater problems
Dead Forum
CA31 Cefiro again
Winter car.
Engine Light
99 Maxima Fuel Economy
Lowering on 20's
Any good Mechanics(NISSAN) that anyone can recommend in Los Angeles
95-96 vs 97-99 Body Question
WTB 95-99 SE 5-Speed Atlanta
91 Max Speedometer/Odometer
-93 J30 Maxima dash lights R&R
Fuel Pump Relay
20" rims for an i30/maxima/etc for sale cheap
Engine Ticking noise - Lifters? need help!
2004 Maxima strange noise from dash??
Tires
"Sensor" Warning Light '87
1995 Maxima SE VS. 1994 Toyota Camry
Parting 86 Nissan Maxima
Braking Problem
2005 Maxima vibrating problems
headlight removal
94 Nissan Maxima Tranny problems.....
2000 A33 Maxima Transmission problem
1999 Infiniti I30 keyless entry
Engine Swap
Rusty rotors, what to do?
04 max y pipe
hyundau
(98 max auto) VS (98 Accord V6 Auto coupe)
1992 Maxima J30/VG30E not starting when warm
engine oil
stalling in reverse
Sellin my rims
Help with purchase:99-01 Maxima
Want to Trade my 98 Eclipse for 5spd Maxima!
please help
headlights
Loss of power!? 93 automatic se
Keyless entry remote question
Hesistation caused by fuel injectors?
VTC Gear
air bag light on
Wanted: 95-98 Max Standard Cd player unit
interiors for sale
Newbie Looking For Maxima Resources
Oil on alternator
Engine (transmission?) Mounts
97 Maxima 3.0 auto trans Question
Potions for a new deck
Reliability of VQ30
Wanting to trade 95-99 Maxima rims
2000 Maxima front rotor removal
problems
maxima vs. legend coupe
door lock problem
Compression Ratio
Looking for a '99 Maxima
Web
AF
