Igor Sushko on Facebook
Please
Register
or
Login
to access:
DriverSide Home
Service & Repair
Car Prices
Parts & Accessories
Reviews & Advice
My Garage
Nissan
> Cefiro/Maxima/I30/I35 |
View Full Version :
Web
AF
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
replacing the front bearings
95 Max Dash lights flicker hi / lo when hi beams on.
what projects do you have planned for your maxima ?
issues on my 02 Maxima SE..
2002 maxima seatbelt/airbag questions
Extended warranty -good idea or waste money
Wanted: 95-96 maxima fog lights....
2k1 turbo setup
Dealer or local mechanic for service(i30 2001)
Rotor is stuck
I need help removing a '96 I30 a/c evaporator
Whats the fastest quarter-mile time a Maxima has ever done??
Busted axle shaft assembly? Caused by improper towing?
1984 NISSAN MAXIMA please i need help!
Limited Slip Diff. Conversion Kit
1995 Maxima GLE. Is it posi?
Gauges Installation
what is covered in drivetrain warranty?
system too lean (check engine light)
Strange vibration noise (2001 i30)
F/S: Tein H-Tech springs, Brand new, $145
96' Infiniti I30: help installing new White gauges?
General 95 Maxima Info
98 I30 Intermittent Start Problem
1996 Maxima clutch problem
Fuel Injector Cleaner question
New turbo Maxima??
1990 Nissan DoorLock KEYPAD REPROGRAM??
96 Maxima won't start sometimes
Engines
F/S: 10000K H4 HID Kit
loud ticking/oil check valve?
Halo Headlights?!
5 Gen Maxima owners enter
Exhaust Wrap?
Infiniti i30
Maxima Videos and Much More : link inside
A/C question for 95 maxima
check engine light flashing
Performance Chip
90 Maxima idles/ runs very rough
2000 nissan maxima...automatic transmission is donezo
Maxima...Won't start sometimes....HELP!!
00 Maxima A/T Top Speed..?
thinking about buying a maxima...need your help
Project Super Sleeper
1997 nissan maxima check engine codes
Lightbulbs for my Headlights
Tire Size
Weird noise help
Oxygen Sensor for 2001 Maxima
newly replaced coil keeps going bad! Any experts out there?
Upgrading 96 maxima with 97 front end
clutch (?) help
'99 I30 Won't start...no juice - HELP!
need help to reprogram remote '97 i30
robbed last night
updating 96 maxima with 97 grille
00 Maxima-CEL code 430 and 140
About to get a '00 Maxima
Need help with an 88 Maxima please!
2001 Maxima Reset Engine Service Soon light.
95 Clutch Replacement
99 I30 Misfire at Acceleration--Exhaust Smoke Follows
2001 VQ30DE Maxima
99 I30 Transmission / Deceleration Issue
How to Install Starter in 97 Nissan Maxima
Tachometer below 1000. Will car turn off?
97 Nissan Maxima wont Start
95 maxima releases all the coolant
Oil in air intake container beyond air filter just before throttle body
where can I get a users manual for a 03 maxima se?
Injen Intake
"service engine soon" light on 2003
speedometer and odometer, HELLLPPPP!!!
Re: Announcement: Farewell Hypsi87, aka: Andy Filson. Moderator, Member and
manual transmission interchange
95 maxima throttles to 2 rpm won't go over
Just received my first vehicle, need assistance from maxima gurus please.
I hear what you're saying, but.....
91 maxima transmission dead
knock sensor help
OOPS...Ran out of gas.
Any good 350z parts to swap into 2005 Maxima??
1993 Maxima SE
Replacement lumbar lever
Lightweight Pulleys
93 maxima engine problems. please help!
2000-2003 Maxima production numbers
95-99 maxima headlights
nissan cefiro stalling no codes
92 maxima ve5, strange starting problem
P0325 and p0300 2 year battle
F/S:*NIB* Tokico Illuminas + Tein H-Techs + long travel shock mounts (95-99 Max/I30)
Start Up
Door stuck shut-front passenger
89-94 nissan maxima a/c compressor 4 sale
code po150
93 max master window control
2001 power seats
Tranmission Fluid Empty
'94 Maxima Fuel Filler leak
Turboing Maxima !
Engine turns off while driving
Updates?
2001 20th Maxima - Dashboard Blinking
2001 20th Maxima - Cig Lighter and Remote Control DON'T WORK
Buying from ebay.. Need autobody guy
parting out 94 maxima
1990 Maxima Intake
Painting dash
95' headunit
maxima i30 seat compatibility
1995 Max GLE for sale in upstate NY
Brake Upgrades
common upgrades
95 maxima starting problem
How to change rear SideMarker on I35?
HELP - P1320 Code
93 nissan maxima fan for ac/heater
A31 Cefiro's body kit
2001 Maxima Front Bumper Cover
squealing sound 2001 max
00 maxima turns off by it self
02 I35 Manual
How to remove alternator?
how to attach?
power steering pump
Programming door locks, not keyless
Getting Rid 18" Nissan wheels
'03 I35 not responsive..
99 Max power antenna removal
I Just Can't Freakin' Believe It...
transmission code p0740
93 Maxima-Won't start
speedometer bouncing on '03 I35
2003 i35 air condition
02-04 maxima reviews
US Maxima = JDM Cefiro?
Interchangeable o2 Sensors
Why does my overdrive light flash when my car starts?
Brake pad help
Lower Control Arm Pin Problem
96 maxima won't start
ABS, Slip and TCS light on constantly.
2001 Maxima - P0420 Code
New member from Norway:)
Suspension Shudders
95 GLE Bose driver question
Rear O2 sensor - P0158
For Sale!!! A Nice Package!!! Shocks/struts/coilovers!!!!
96' Maxima vs 01' Intrepid ES
95 max slow to start
'92 Maxima SE Smelled gas this morning
suspension tuning for my A31 cefiro
Manual transmission diagram
Ignition Coil - What Brand? 99 Max
Service Manuals - phatg20.net
How to make throttle cable tighter?
96' I30 fog light removal
Altezza lights for 1990 Maxima SE
I have some probs...90 maxima
'90 maxima muffler
nissan cefiro noise when turning
Interchangeble Rims?
Mother Fu**ing MAFS
1995 GLE Sound System Swap
Springs???
Greddy SP2 Catback
01 maxima stalled this weekend??
GROUP DEAL on Top Speed Pro-1 Y-pipe: $100
seatbelt indicator
HELP ME!!! Auto Climate Control Install
1 of my HID light went out
Looking por Maxima parting out.
Cylinder Diagram???
Bose volume control problem
Alternator help!! 96 SE maxima
19" Rims throw off SPEEDO????
95 Max Auto trans not downshifting during rolling stop.
FOR SALE!!! GROUND CONTROL ADJUSTABLE COILOVERS & TOKIKO SHOCKS AND STRUTS
Looked for code
Problem with rim offset?
Keypad what does what?
VE to VG swap...straightforward swap?
What to expect
Need 92 SE AT Guru! O/D prob among others
Rear spoiler
Anything to know about a 99 I30?
2000 maxima rear brake calipers
owner manual
owner manual
Where Can I get this Bumper
Bought a '90 Maxima for $200.00
Updated Cardomain Page, Check it Out.
Maxima 2002 GRILL LIGHTS
Lowering Springs for 1979 Datsun 810 (Maxima)
tire size help... please anyone.
17" OEM Nissan 350Z Wheels and Tires ??
HID Xenon Headlights Bulbs
Idle Air Control Value Question
My 95 Maxima will not start, help!!!!!!!!!!!!
Need engine for '90 Maxima
'02 Maxima Repeated Battery Failure
Seat Heater Wiring
96 Maxima vs. 89 Camaro 350 IROC-Z
Check Engine light code 0705
Greddy SP2 Catback
Tune up on my car
programming keyless entry pad
car does not stay on ? help
2001 Infiniti I30t (Strange sound) pls help
Mileage and gas tank question
1992 Maxima SE minor upgrades
we are selling the nextel i930 for $130usd
Riding until the wheel fall off
1992 Maxima SE Temp gauge
1990 Max SE Didn't Pass Emissions!
Repair Manual
2001 max angel eyes fog lights install??
Need help with battery drain
Wow.
Factory Sparkplugs, Wires etc
1991 maxima engine problem
1991 Maxima with transmission problems
1992 Maxima battery discharging
Struts / shocks to buy
PLEASE HELP!! Odometer Fraud or Clerical Error?
Gas lid won't shut- puzzled
NEED ADVICE!! should i sell or KEEP?? 1995 Nissan MAXIMA
tranny upgrade
Help With Reprogramming The Keypad
best mods
Engine/Transmission Marry
turbo for 2000+ maxima
Speedometer light not working
99 I30 service engine light problem
2kMax running lean - please help
95 Maxima clutch problem???
1995 Maxima Passenger Door Panel Speaker
Ctback Exhaust
Heating near my feet during driving
LSD equiped Max questions?
1996 I30t with 170k Poor low idle, stall when starting
Taillights? ? ?
1996 Maxima Starter removal problem
vg30dett
Uncontrolled Sudden Acceleration In I30!
Larger alternator needed
Web
AF
