View Full Version : Cefiro/Maxima/I30/I35
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
  1. *FS 2000 Maxima SE
  2. '99 Maxima hesitates while idling
  3. Problems with alarm, digital cock, and radio
  4. 2001 Maxima, what should be done first?
  5. 91 maxima dummy brakelight fix?
  6. Check engine light
  7. 90 maxima dash cluster problem
  8. Tranny Flush on 90 Nissan Maxima?
  9. Heated, power right hand side mirror question?
  10. Wheel bearings on a 96 Maxima SE help.
  11. Manual Transission issues?
  12. '90 Maxima timing belt = catastrophic failure?
  13. TCS light come on and goes off unexpected
  14. Clockspring 99 I30
  15. 99 I30 ACS light and check engine light on
  16. Infinity i30 Transmission
  17. Need help diagnosing some problems.
  18. PARTING OUT 2005 maxima
  19. 1999 Nissan Maxima
  20. Changed Struts and Shocks On A 95 Maxima GLE?
  21. Ground Control Coilovers
  22. not shur if it is a ball joint
  23. what to do to fix air bags on the 96 se model
  24. 2000 SE Maxima 5 spd. $13,000 ... Good Deal??
  25. O2 Sensor & AC Hi-Low pressure switch
  26. Do those ebay power chips work?
  27. CD Changer
  28. How to check engine codes
  29. 97 Max error codes 1005 and 0304
  30. 93 Max SE Tranny Problems!! Help Please!!
  31. Have to replace the tranny....
  32. 90 maxima prob
  33. Nissan 97 Maxima Starting Trouble
  34. 1992 Maxima will not start!
  35. 1/8 or 3/32 Coolant temp sensor
  36. Knock and O2 sensor with a twist? HELP PLEASE!
  37. 89 Maxima Stalled going 65mph
  38. how do you fix air intake sensor (p0110)..I30
  39. 95 maxima air condition operation
  40. older transmission...
  41. Tint
  42. Infinite I30 moonroof
  43. Do i need new struts/shocks or both???
  44. The rear feels like it moves while im driving
  45. I got a new Maxima well new to me
  46. Engine coolant temp sensor...
  47. 1995 Maxima won't start
  48. Euro Tail Light Questions
  49. 1996 nissan maxima
  50. True gains from exhaust
  51. Park Neutral Switch Black Wire...
  52. '91 Maxima master pwr windows
  53. OO Transmission troubles
  54. One of the lugs broke off....
  55. I need my cd!
  56. Ticking noise after incident..
  57. What is a knock sensor?
  58. I found somthing you guys can use...
  59. We lost a good Maxima out there....
  60. Do BOSE sysstem have a security code?
  61. 96 SE tranny problem.
  62. 95 Nissan Maxima(Nissan Newbie)
  63. 1997 maxima bumper
  64. solenoide valves order....
  65. little tank....
  66. dandy: airbag and evap removal photos
  67. 88 Maxima GXE Starting Problem
  68. Can Air Filters Handle a Lot of Water?
  69. Want to install CD player on a 95 Maxima...
  70. Tein "S Tech" Springs?
  71. Second Generation Maxima(1987)
  72. Rebuild or Replace?
  73. 2004 I35 Transmission is Slipping into neutral
  74. VTC Click
  75. Someone help me!
  76. A Crying Shame
  77. Nissan OEM parts
  78. 96 Nissan Maxima
  79. Code P0189 (o2 Sensor) 01 Maxima Se
  80. Budget b-pipes
  81. Got Codes for repair..know what??????
  82. 00 maxima headlight conversion?
  83. switching from analog to digital question
  84. How do I disable my factory sec. alarm?
  85. altima 3.5 se vs maxima se
  86. NEED A31 Headlights
  87. 70,000 Mile Service
  88. tranny problems. HELP!!!!!!!!
  89. Anyone do a 96 SE Foglite install lately?
  90. Got a Question!! Stereo
  91. Choke Problems??? 97 maxima
  92. I'm BACK!!!!
  93. engine swap question
  94. 96 SE with At. trans sticks in park?
  95. axle or transmission problem?
  96. 91 maxima will not run
  97. 96 Max SE front turn signals don't "blink"?
  98. Opinion Needed
  99. Will 90 300ZX rims fit 96 Maxima SE?
  100. Turbo Kit?
  101. 93 maxima no cylinder compession
  102. Computer Change....
  103. Misfire Cylinder 2 Code P0302
  104. Advanced Timing
  105. 89-91 Maxima Injector for sale.
  106. Cost to replace fuel injectors
  107. charcoal canister
  108. 2002 Fuel octane
  109. megan exhaust
  110. Friday The 13th
  111. Hesitation on maxima
  112. starting problem
  113. Battery Changing Procedures...?...
  114. Stereo Bose Question...
  115. Intermittent odometer
  116. Please helpme!!!!!
  117. Knock Sensor or O2 Sensor
  118. 4th gen maxi questions
  119. infinity i 30 turbo
  120. '98 maxima help!!
  121. 2000 Maxima. help.
  122. Speedometer/fuel gauge dash light out...
  123. Need help with I30 wiring...
  124. Parts needed... for a 1993 Maxima GXE
  125. Help Changed My injectors now my Car Won't Start
  126. 17" rims or car parts?
  127. Help with a code 420 on 2000 GLE
  128. 95 Maxima 1000$ Or Best Offer Hurry
  129. help changing engine.
  130. Bizarre Heat Issue
  131. VQ35DE differences
  132. Ignition Fuse Problem
  133. octane booster for Maxima
  134. 99 maxima oil dipstick
  135. Please Help...
  136. 02/03 Climate control
  137. Maximized Smile :) & Merry Christmas yall ppl
  138. Need info on ancient car
  139. 2001 vs. 2002 Bose
  140. 96 Infiniti I30 knock sensor
  141. replace stock radio & keep Bose speakers
  142. problems with 97 fog light rewire
  143. **Wanted** 95 Air Bag Control Module
  144. f/s 93 Maxima
  145. 96 I30 oil pump replacement
  146. 01 Anniversary Edition maximas
  147. Shocks
  148. nissan pick-up light dimmer
  149. power steering noise
  150. 4th Gen: Maxima Map of Owners: Add yours today !
  151. 93 maxima fog light question
  152. Newbie with a few problems, 93 maxima
  153. 1995 Nissan Maxima GXE one spark plug wire no spark
  154. Back seat Passenger side door wont unlock from inside
  155. I30 bogs down at 2000 RPM
  156. BMW Headlights
  157. Did 3rd gens come with keyless entry?
  158. desiree
  159. 3 Problems with 89 Max...
  160. Check Engine Codes
  161. Underdrive Pulley
  162. Love My Maxima
  163. HELP! 14.1 miles per gallon
  164. [Help] Cold Start OK, change gear and engine dies
  165. 84 Maxima Will Not Start Fom The Ignition
  166. If I change module does code change?
  167. Rear speakers rebuild
  168. Wanted: 95-96 Maxima fog lights
  169. Replacing tranny... questions
  170. Bunch of electrical not working...related?
  171. infinity i30 drains battery???
  172. springs, struts, shocks questions
  173. 1999 Nissan Cefiro 2.5 S-Touring (Neo DI)
  174. Help Me!
  175. Clock Removal for 2000 I30?
  176. winter cold start problem
  177. Engine light code
  178. Oxygen Sensor
  179. Transmission Problem On 2001 Maxima??
  180. Tint Suggestion
  181. head lights wont go straight
  182. remove gauge cluster?
  183. 1987 Maxima - motor mounts????? HELP PLEASE
  184. '96 I30 oil light flickering on\off
  185. rough idle/irratic Check engine light
  186. new i30 98
  187. won't go
  188. Transmission Fluid
  189. Replacing CV Joints 93 SE
  190. Got My Warpspeed Y-Pipe Installed...
  191. A31 Cefiro Service Manual???
  192. Maxima door stuck shut
  193. Vq35de??
  194. '97 maxima--rubbing noise
  195. Maxima 1995-1997 Sunroof Assembly Service Bulitin
  196. 95 maxima GLE, how to program new remote
  197. Anyone have a crank pulley for sale?
  198. spark plugs
  199. Upgrade Ideas for 1990 Maxima SE
  200. 92' Maxima Heater Core Installation
  201. No Transponder Key with New Engine Swap?!?
  202. sputtering 240sx
  203. maxima muffler
  204. High RMP al low speed after driving for >1 hr
  205. 90 maxima signals
  206. Premium Fuel?
  207. 95 maxima wont start when warm
  208. Max needs a drop...
  209. 97 Maxima Does not Start
  210. brights stay on when turn signal engaged
  211. 00 SE replaced MAF, coils, sparks
  212. 1997 Nissan Maxima starting Trouble
  213. 89 auto trans rebuild... How to make it better?
  214. Help! Quick!
  215. Cold Air Intake?
  216. 96 maxima headers
  217. should i race??
  218. Electrical?
  219. ECU Upgrades
  220. VI question
  221. Next performance upgrade
  222. just bought 95 maxima, oil dipstick wont come out, please help
  223. Foglight bulb #?
  224. Help knocking noise when accelerating
  225. BOMZ Racing Blue Cold Air Intake Kit for Sale
  226. Ebay Mods
  227. Check Engine Code
  228. Why is warning light on, after putting new starter on Maxima?
  229. Problems with the anti theft of a Nissan Maxima 92
  230. Cold Start
  231. whinning noise from engine when driving at low mph
  232. when rear defrost is pushed by bose fm signal gets staticy
  233. '95 Maxima-Stalls-No code
  234. Warm Air Intake?
  235. Ignition Coils
  236. covered under warranty or need to pay
  237. Here's one for Nahkapohjola...
  238. 90 maxima maf ?
  239. Anyone Got a Clue About my Srating Problem?
  240. just bought a 95 max need help with the radio
  241. 1997 Maxima Idle Question
  242. Antenna Fuse Removal
  243. car hesitating during acceleration
  244. '90 Max transmission upshifts @ 5000-5500 rpm (almost redline)
  245. 95 Maxima won't start
  246. power windows and locks not working
  247. Maxima's, 1996 to 2001, Any chronic problems?
  248. upgrading "Big 3" 2001 maxima
  249. Clicking noise in tranny.. PLEASE HELP!!
  250. replacing the front bearings
