View Full Version : Cefiro/Maxima/I30/I35
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
  1. Please Help!
  2. Ring gear access plate
  3. Front brake make noise
  4. I Need Some Headlights
  5. Knock Sensor
  6. EGR & oxygen sensor trouble codes related?
  7. 95 maxima firing order
  8. 97 max rad. support
  9. 95 maxima misfire code p0306.
  10. 96 maxima 3.0 engine will not start at all!! Help!
  11. 96 Maxima code PO130 again
  12. Power steering woes
  13. Ford Alternator in a 92 maxima
  14. 2000 Maxima not starting after starter install
  15. '93 maxima Sunroof questions
  16. 2000 Max SE - Rear Brake Caliper stuck
  17. Maxima Battery goes dead.
  18. i30 1996 - Review
  19. Fog Light and Bumper
  20. Injectors
  21. What does my car actually weigh?
  22. Clearence issues, any ideas?
  23. 2006 impala
  24. Should i attempt doing the axles on a 95 maxima my self???
  25. Throttle shuts off
  26. 1985 Max Speedometer is Erratic or Not Working!!
  27. 97 nissan maxima problem
  28. Repair Manaual for 2001 I30
  29. 2001 Maxima Leather Seats cracked
  30. Opinions on 2006 (new) Maxima 3.5 SE Price Quote
  31. injen replacement filter
  32. 96 I30 cabin filter
  33. 95 Maxima won't start screws up POS count
  34. Has this been done yet?
  35. Keyfob unlocking & windows
  36. Changing the Airbag Module in a 99 Maxima
  37. Struts and Springs 99 Maxima
  38. 93 maxima gxe drives sluggish after warms up
  39. 2K Maxima stalls when warm
  40. Maxima 99 misfires
  41. brake upgrade
  42. '95 Max warm start up miss?
  43. 1996 i30
  44. Which aftermarket parts throw up codes?
  45. type of gas
  46. Maxima No start No crank
  47. 1998 maxima good car ???
  48. Parting Out 1992 Maxima-Most parts available
  49. stalls on reverse
  50. just got a 96 and needs front end work
  51. just got a 96 and needs front end work
  52. Help with ideas for mods to a 00 maxima gle
  53. Which year are these Maxima rims?
  54. Question about stock Bose system in.....
  55. air intake
  56. BOse radio issues
  57. oem parts
  58. 92 Maxima High emissions at low speed
  59. thundering noise when pressing accelerator
  60. Problem with fans on '90 Maxima
  61. 97 nissan maxima se no start after accident
  62. Need Help with Inifiniti I30 (1996) knock sensor
  63. 96 maxima won't start - intermittently ??
  64. Rich fuel mixture
  65. Window Problems
  66. Anyone seen these on a car?
  67. Nissan Wire Replacement
  68. 5 1/2 Gen Maxima
  69. 98 Maxima GLE P0325 & P0400 fault codes
  70. 95 Maxima Sensor and suspension problems.
  71. oxygen sensor + knock sensor change on Infinit I30
  72. 1990 Maxima dash removal
  73. valve gaskets after accident
  74. Car shaking at speeds above 70 MPH
  75. I30 Performance Upgrades?
  76. I30 Dash Seperating above radio
  77. error code P0500(Vehicle Speed Sensor) - 1996 Nissan Maxima
  78. 98 Max - power steering leak
  79. heres a stumper for you gearheads
  80. 95 Maxima Keyless Entry issue
  81. Sticky power windows
  82. 2001 I30 Dash warnings lights up & car dies on freeway!
  83. keyless entry
  84. Fourth Gen VQ35
  85. hard starting 94 maxima
  86. 92 Maxima Tranny issue
  87. new car, tech q's
  88. knock sensor on 1996 nissan maxima gle
  89. Question about clutch system, 97 SE
  90. steering wheel button lights?
  91. 2000 maxima keyless problems!!!
  92. 2000 Infinity I30-T Oxygen Sensor replacement
  93. 94 maxima pwr seats problem???
  94. Infinity I30 fuel filter replacement?
  95. Low fuel light not working 1998 Maxima
  96. 91 Maxima engine wont start
  97. 300ZX Rims on a Maxima?
  98. 1995 max code P0400
  99. 1995 max EGR Valve Replacement
  100. Rocks and Grills Dont Mix
  101. Used Injen Cold Air Intake ok to use?
  102. Looking to buy a Airbag Mod.
  103. I NEED a Rear bumper
  104. Thinking of buying an 89 - 94 Maxima - Opinions?
  105. Maxima Dies
  106. P0430 Catalytic Efficiency Below Threshold Bank 2
  107. P0430 Catalytic Efficiency Below Threshold Bank 2
  108. Engine Dropping Off
  109. problem on my 98 i30
  110. Shaking Wheels
  111. DIY clutch replacement
  112. buy 91 max???
  113. Maxima Service Manual
  114. Nismo meeting in Goldsboro, NC!!!
  115. Just got 98 i30 w/ 41k miles
  116. 91 Maxima Starting Problems
  117. Custommaxima.com projectors Vs. Ebay
  118. 1999 Maxima SE vs Sentra Spec-V..??
  119. Upper Strut mount I35 02
  120. infiniti I30 seats
  121. Aftermarket Stereo
  122. it been a good while now
  123. Should I buy it?
  124. trying to get started on 99se
  125. Idle air control valve, bad idle
  126. '97 Maxima Questions
  127. Should you turn of your AC/Heat when shutting down or before starting your vehicle
  128. 2001 downstream oxygen sensor
  129. 00 problem with tranny?
  130. Loosing oil?
  131. To extend or not to extend ?
  132. 91 MAXIMA shift problems
  133. Does the back seat in the I30 fold down?
  134. Replacing Hood Struts on 96 Maxima
  135. ECM bad on 5th gens?
  136. Turbocharge or not?
  137. 94 maxima weird idle
  138. Sticky speedometer needle
  139. A?C Blower Problem
  140. Governors on 5.5 gen
  141. Bose stereo
  142. 99 Maxima Engine Missing?
  143. advance timming?
  144. 04 maxima vs. 03 bmw 330ci
  145. 02 maxima,intake air sensor
  146. front struts
  147. Noise in right rear wheel 1995 Maxima
  148. 94 maxima runs rough and has no power???
  149. 94 maxima runs rough and has no power???
  150. 96 maxima dies when coming to a stop
  151. The Deal with Ebay exhausts?
  152. 01' Maxima Exhaust/Intake Suggestions?
  153. 93 Maxima power door locks
  154. alignment
  155. Maxima as a Used Car
  156. Check out my slammed 95 Max.
  157. Engine stalling question/help
  158. I hope someone can hellp. 95 Maxima. Starting issue
  159. 92 maxima heat
  160. Need Left Fender & Bumber Cover for '97 Maxima
  161. 02 nissan maxima no turn signal help please
  162. is any infiniti based off of the maxima
  163. maxima trans diff help
  164. Maxima power antenna
  165. Headlight Cover removal
  166. Good Deal or Not?
  167. How many Maxima Owners are out there?
  168. 95 maxima
  169. front strut question
  170. front strut question
  171. 97 Max Front Right Boot...
  172. 1994 Maxima
  173. 94 maxima axle removal help
  174. Hard starting
  175. Loss of Power?
  176. Braking jiggle. Warped Rotors?
  177. FS: 2000 Infiniti I30 (Luxury)
  178. 2002-2003 Maxima headlights vulnerable to theft?
  179. 2003 I35 bass question
  180. stereo install (bose)
  181. Have CEL and Car stalling. PLZ HELP
  182. 2000 Radiator Fans - Both Bad?
  183. 5th gen tranny problems?
  184. '01 Maxima 66K miles. Should I buy?
  185. 96 Max, O2 sensor, Bank 2 sensor 1, which is it?
  186. 1997 maxima
  187. 1995 Max, engine dies irregularly but always
  188. Engine wont run.
  189. 99 nissan maxima thermostat
  190. For Sale! Parting Out 97 Maxima SE 5 sp
  191. Advice on DDE's
  192. need help
  193. Maxima 1998 blinking airbag light
  194. Bose Deck Question
  195. 96 Maxima failed Emissions - OBD II "Not Ready"
  196. An order to Performance - 4th Gen
  197. Interior Light Bulb Question
  198. performance upgrades
  199. clutch replacement 2004 maxima se
  200. distributor woes
  201. 98 I30 airbag light flashing
  202. intermittent misfire
  203. programing a key fob that has auto start
  204. A great site for MAXIMA HOW-TOs and FREE UNLIMITED Picture Gallery!
  205. i30 bose stero with aftermarket deck will it work
  206. 95 max question on struts/shocks????
  207. 92 Alternator brackets
  208. 95 maxima se engine died on me 4 times!!!
  209. trying to remove the trim arround the display for the radio
  210. 84 Maxima, dies when hot out
  211. 92 maxima speedo works sometimes
  212. Start/Stop problem...help?
  213. maxima 2000 : Engine starting on cold start
  214. Engine Life of Nissan Maxima 1999
  215. 2000 Maxima 5 spd for sale $6500 Arkansas
  216. 1992 Maxima Transmission issue
  217. Infiniti I35 02
  218. 1998 Maxima Problem
  219. timing chain question for a friend
  220. NEED HELP! Antenna Installation ~
  221. 1995 maxima Air Bag Problem
  222. FS: 1994 Maxima - Highly Modified
  223. new 92 maxima alternator
  224. 95 maxima AC compressor clutch wont engage
  225. O2 Sensor
  226. FS: Technosquare Upgraded ECU: 96 manual ecu, cheston mod
  227. 2001 I30 Rear Brake Fluid Leak
  228. 00 nissan maxima
  229. Chugging/Stalling/Hard starting
  230. 00 maxima
  231. Maxima surge issues
  232. what coul happen?
  233. 95 trans issues help
  234. 1995 Maxima, gas in exhaust system
  235. Where are my spark plugs on my 02 I35
  236. catback suggestions for 95 maxima requested
  237. 1995 Maxima number 5 cylinder not firing
  238. 89 Maxima Starting problem
  239. High rpm >4500 and car not going above 45
  240. Intermittent problems...
  241. Buying a Maxima
  242. I-30 Motherboard
  243. 1997 I30T Starters
  244. new alternator $
  245. 2003 top speed
  246. Transmission Headache
  247. Warranty
  248. Transmission shift lever STUCK!
  249. Headers....2000
  250. 04 maxima rotors
