View Full Version : Off-Topic
- 95 Talon TSI Turbo FWD
- Good Shit
- eclipse vs wrx
- anyway?
- question: Z1 module +20hp? speed chip+20hp?
- I Need Motor Diragrams
- 2005 Eclipse
- another question: whot is a "camber kit"?
- Paint Color Codes
- Fender Flars
- Stop Crank Before It Happens
- Apex'i vs. Greddy??
- Small Block?
- 4th gen. Eclipse???
- update for 95-96 eclipse parts for sale
- 1993 talon 4g63 turbo swap
- turbo timer
- Installing Tenzo Seats
- Oil Pressure
- datalogger
- data logger
- starting new project
- '97 5-speed GS-T for sale
- 2nd gen eclipes body parts 4 sale
- Racing Opinionsssss
- Uneven Idleing & Engine Stalls
- thermostat probem?
- Probably going to buy a '91 talon TSi
- Clutch Problems?
- no fuel, no spark...need help with diagnosis
- GReddy TD05H-18G and other ???'s
- is this supercharger works?
- power chip question
- Anyone in DC
- Should I buy it?
- i need an enigine
- engine swap from coupe to GST
- I Need A 95-98 Gs-t Stock Exaust/cat-back
- can't find a transmission
- Ignition Problems
- 93 non-turbo buy or not??
- my ECM or ECU has gone bad
- Body Kits
- '95 GSX 5sp - broken cruise control
- Anyone got install tips for PIAA 1100x's?
- Body kit??
- Fuel pump
- I Need A Hood Fast, Any Help? Any One Have One???
- Gutting A Catylic Converter
- Paint color codes
- 1995 Eclipse Gs Notorious Problems
- speedometer question ????
- Talon Doesn't Run After Overheating
- Used Gsx/gst
- S15 Headlight conversion....
- Help a Girl Out?
- Looking for a MAS
- Need Passenger Door Handle ' 95 RS.
- Fiberglass Blitz Kit from Ebaymotors.com Doesn't fit!!!
- manual boost controller
- SLICK Nitrous Kit
- How can i modify My eclipse Gs
- A 1995 Eclipse gs Vs. A 1993 Acura Integra gs
- Power??????
- Re:1990 Eclipse wont start!!!!
- security light question
- Differences between RS and GS
- 6-bolt swap
- sleepers
- 93 talon
- Transmission Shifting Problems!
- Foglight 9006 bulb super white LED
- classification
- For Sale
- Keyless Entry
- Intermittant no more '90 Laser
- Need help please :(
- 1992 eclipse for sale cheap
- Website about Eclipse
- whats the diffrence between turbo and non tubo exhaust
- Clutch, feels like nothins there?
- How Much You Pay For Your Ride?
- Help
- Ebay deal check it out
- 3000 gt Air Intake
- Door Rattling
- X
- Best Exhaust System
- Would you install bushings to a short shifter?
- Specs Needed on Fast and Furious Eclipse INTERIOR
- Gst/gsx
- Higher Boost
- New, Hope im in the right place
- 95 Gsx 4 Sale
- where can i find these?
- How does overdrive actually work?
- Differential
- Eclispe stopped running after hose busted
- turbo manifolds?
- happy new year!!
- Messed up '96 Need help!
- Best Air Filter?
- FS: 90 talon tsi
- FS: 90 talon tsi
- What u be Rollin on?
- Specs Needed on FnF Eclipse
- question about rods and pistons
- New To Engines, Need Help
- So many Problems, So many headaches.
- 2001 Eclipse GT 5spd STOCK 4 Sale
- AFTERMARKET 92-94 eclipse headlights !
- any one know how to make your dash lights look like the vws
- GS to a turbo
- gs-t spyder boost guage
- 95 Eclipse GST for sale
- G2 4g63t - are they all the same?
- leather seat
- How to add a line-in connection to stock radio?
- manual trans problems
- new 99 eclips help
- 14b turbos
- Rear Driver Side Quarter Panel
- Traction for gst
- 03 Eclipse Gauges and Clock Face
- gt-s or a gtx which is better?
- fog lights
- What two foot flame out my apexi exhaust on a stock gsT?
- getting new turbo
- My car.
- which is better hyndai tiburon gt (v6) or the mits. eclipse gt(v6)??
- lights
- idle problems
- ldeal problems
- where kind i find a Left headlight? for my eclipse
- Belt problem HELP!!!!!!!!!
- off the topic
- Idle Problem Question
- Would this Sway Bar fit my 97 RS?
- anyone with a 97-99 GST i have question
- wtf
- talon AWD TSI .VS. eclise gsx
- 14B swap with 95 eclipse gst T25
- know where i can find a 4g63T?
- what if I accidently pressed the gas instead of the brake pedal....
- battery light turns on
- DSM Cars
- Car idles differently every day...
- Wiring for A/C...
- 95 Eclipse Turbo Problems
- Apex'i turbo timer and alarm question
- OBX Catback Type H - under $200?! (need some info on it)
- a metal on metal grind near tranny
- Need Help Finding Links For Exhaust plz Help
- infinity sound system questions
- chrome headrest hoops on spyder?
- center wheel caps for alloy wheels
- Water injection
- How bad is FF really to all else???
- Boosted RS, Oil shot out NEED HELP!
- Big Post For a Newbie
- Merry Christmas everyone!!!
- gst ignition coil
- Any GTG soon??!
- Installing a cold air intake
- 420a Turbo setup
- x mas
- to bore or not to bore
- I want to buy an eclipse. But Is it beter than my old car?
- 97 Recall on ball joints?????
- Water in CAI
- some kind of lag
- Review My Choice
- Coilovers
- Talon Performance Chips
- Talon tsi alternator
- Intake Question
- Summarize Crankwalk?
- Your Opinion On This Turbo....
- Indiglo Gauges
- foglights?
- Gst VS Corvette
- horn
- How do i take out my Dashboard
- Popping?
- Leaking Oil
- "offset"
- brakes
- Coil Overs
- dumb question
- Is it Possible to Install Power Windows on an RS?
- eclipse difference
- Yep, another exhaust question
- Questions about the Eclipse
- loss of power, datalogger
- Help with Hatch Back...
- timing belt
- For sale gray 97 eclipse RS
- Fuel Smell in Oil???!!!
- CEL on 92 Laser RS Turbo- AWD
- Driver side headlight adjusting question
- Starter Question
- Choice between a Stealth and Talon
- 90 plymouth laser rs for sale In pa
- 1990 Eclipse 1.8L
- Eclipse vs. 3000GT
- Check engine light is on
- Please Help!!
- Best performance for the $
- Indy area dB and dyno test
- Engine Swap
- Engine Question
- Fill Plug
- ECU.. 130 mph max?
- spark plugs (ADVISE PLZ)
- Rebiuld Size Problems
- vacuum diagram help please!!!!!!!!!!!!!!!!!!!!!!!!!
- 12 sec. awd 4 sale
- Evo 16g Turbo Questions [once again]
- my car has a lot of issues with power
- Timing belt and tranny questions..
- question for gsxracer #2
- slipping out of 1st
- For Sale
- bolt ons
- Help for the new guy
- Wing, Bumper, head lights, hood...
- Evo 8's Turbo?
- whats the diff
- which one would u perfer?
- anyone in the north florida area?
- blow off valve
- Cheaper Replacement For An Idle Speed Control Sensor
- patch work
- Engine Noise Please Help!
- 92 eclipse GS problem help
- Invader Side Skirt Problems
- Engine Removal
- JDM Stripe
- Intake for winter
- How Much HP and Torque on this Engine Setup, and some questions
- governor on gst's?
- Hp, Tq?
- O2 Sensor problem
- need opinion on 95 eclipse gs-t
- Swap
- 95 GSX jerking at high RPMs...
- 3" Cat-Back Exhaust System for GSX
- Ideas needed for building up a 2g rs engine
- can stock clutch handle 13s?
