Mitsubishi
Eclipse/Talon/Laser
> Off-Topic
View Full Version :
Off-Topic
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
nitrous
Turbo last?
power door locks lock me in!
How do you port and polish somthing?
Turbo Kit. dose it suck
Apexi Power Intake or the FIPK?
Can the Temp sensor interlock ignition ??
Computer compatability 1990 Eclipse
Quick question on wiring under hood...
No Spark at the Coil Pack/no spark to the plug wires
NOS on RS? rofl
Maken A Gs Into A Gst
Removing Crank sprocket on 420a
testing Idle air controller
how do u test the fuel pressure regulator
new clutch
Electric Supercharger?
Need help removing panel
Needing to replace an engine in my 95 GSX
Boost guage connection.
Newby Sayen Whats up
Engine help
replacement engine or engine swap
Nitrous Express
What kind of wheels and tires should I buy?
Temp out side where you live
help car is broke
headlights
Help!!!!???
Catalytic Converter
Turbo question?
Somebody please help me out w/ my new BOV that I just broke...have a few ?'s
Factory Stereo Issue
Apexi N1 exhaust question
Falling Temp?
Tranny help quick!!!!!
cold starts
Good Deal or not?? Hurry please
Should I go w/ a A Piller Pod or a Gauge cluster pod?
homemade intake system
chrome valve covers
what is the difference between a gs and a rs?
how much does a 2nd gen gsx go for?
what is the best generation dsm to tune?
high performance exhaust that isnt loud and anoying?
GSX racer
profec b
Injen vs Dejon Tool
14b
flywheel
A few more questions(sorry)
Audio amplifier fuse keep burning out
650 HP Eclipse?
Ultra-Lite vs C2...
Can a 97 1.8L Mirage Header fight 94 1.8L Eclipse?
badass AND girly?
Anyone from Calgary?
96 Eclipse RS Block
timing belt procedure
what kind of O2 housing?
coil overs. dropped. now what rims???
Core Firing Sequence???
92 talon vs 96 probe gt
JDM vs DOMESTIC 4g63t
eclipse GSX Air Suspension?
light weight flywheel
Eclipse
Suggestions;Struts and Springs
POLL: What are the Best Rims for DSM ?
rhd eclipse
whatdoes this symbol mean ???
exhaust smokes
1990 Eclipse no spark & cannot retrieve codes
Eclipse Leather seats... real leather? (+ will this fit my RS?)
Car Bra, Good Idea?
Eclipse
Hks Ssqv
Should I get another gauge or just order a boost gauge?
*intercooler*
96 talon: battery/ light problems
need turbo
Cold Air intake on 94 ?????
AT not shifting
Better Light Output with stock Headlights or Projector Halo?
Argh car wont start (-28C)
guages
StreetGlow in Canada
DSM GS-T Vs. Supra
Is my 1g GSX haunted?
420a- 6g72dett swap
general maintenance help???
mbc help
Easy questions
ilde surging, need help!!!!!
Problems Starting
car back fires
headlights always come on
lowerin' springs
92 talon cold starts
Hood reversal
Top speeds
ignition question
Walking Crank
Problems starting w/grinding noise...
Oil Gauge...
K&N FIPK vs. ExtremePSI Intake Kit
Vapor barrier sealant
skyline ?!?!?!?!
Clutch Problem
Engine & Tranny Swap on my 96 Eclipse
? on getting rid of power hoping when launchine
I need little help
over heating
help with installing led washer lights to fog lights
Beltronics Accelerometers
Rice On My School
A Major problem with my 91 eclipse
1st gen bov questions...
fuel pump
speedometer/odometer problem
Few Questions regarding tuning !!!
Big, big problem. HEEELP PLS
Light Weight Smaller Overdrive Pulley Decreases HP?!?
2g turbo pistons cheap
Help
talon has bad problems help
GST/X vs. Integra GSR vs. RSX-S
Eclipse or 3000gt
timing belt on talon turbo
defi gauges?
gsx over gs-t
Mitsubishi Eclipse 96 Rear 6"x9" Speaker Brackets
I Fing Give Up!
Anyone from or near St. Louis
(hate 2 do this) FOR SALE
Need help with a Profec B II
weird rubbing sound...
18 or 19inch rims on my 95 Eclipse?
95 RS RIMS Question
Boost Leak or what?
engine swap i want to know if i can do it
What spark plugs should i use?
bov's
new car...?
queston for 95GSXracer
wastegate and BOV
Car audio: factory deck removal
too off spark plug wire cover to find oil
Short shifter....
Engine Primer
eclipse gsx vs. srt-4
Got some stuff:D
strut bars
indiglow guages
? about upgrading upper and lower intercooler pipes
Lost to a turboed talon....i think?
Intercooler question...
electronic questions...???
Burning Smell
how to install roof scoop?
Wondering if these Phat 18" Rims Fit and if Worth it
How To Clean a Air Filter Properly?
Newbie BOV question
Suspension thoughts
gsx reliability?
FM radio band gone...
convert
Store in Los Angeles area?
Engine Flow Chart (and compressor maps)
Cruise control problems
what do you think my 1/4 would be?
no start after engine wash
1996 talon for sale
Need Help inner lights messed up
which is the better drivetrain?
Does anyone know what wheels these are???
Starting problems...
Stage 3 chip
A few tips on performance please
TurboXS help
Tuning when adding power upgrades?
98 eclipse gst 6 speed conversion!
another question about the crankshaft pully
JDM/DSM Eclipse/Talon TURBO motors needed
FS: 4G63T and Blitz polyurethane full kit 95-99
Need new Motor, Help! (dsm newb)
2G 4G64 & 3G 4G64
Corner Lamp
Web Sites Please
Syncro Rings
91 Eclipse
98 ESI quesitons
any reprogrammed ecus out there that i can buy?
BOV questions....
6 Bolt Engine Conversion Questions
anyone got an rs*r catback?
belt noise
crank pulley question(need answer fast)
info in vfaq section
RS engine swap
Where to get Used 1g BOV
Help Me
2g Parts in a 6 bolt Engine
R-1 Racing Wheels
18 by 9.5? do they fit? what rims do u guys suggest
Disconnecting the clutch start switch
93 Talon Some Probs
Need help Converting Automatic Into Manual
replacing my 4g63 engine
will this engine work
14b // TD05 turbo Mixup
Put MBC in and it doesnt do anything
car vibrates bad!!! PLZ HELP
1st generation tranny in 2nd generation
mitsu vr-4 galant vs. viper video
Update:
DSM site list
Hotwireing a transmission in 1g?
Need Your Help! Would these rear seats fit my Eclipse?
replace the rest of exhaust too??
Electronic Boost Controller
exgaust manifold question
this forum
ssup
Where to get a new Engine?
what do you think about the New Eclipse
91 talon trans ecu
Door Sensors?
CV Joints? NEED HELP???
Will 97-99 rear bumper cover fit on 95-96?
Oil squirters???
is it hard to install camber or ingalls kit?
Buying an gsx
ECM wiring harness
Need Suggestions/help
HID Thread
converting an automatic to a manual
Eclipse problems
dose any one live in utah have a radiator
Exhaust for ma GST
Brakes: Cross Drilled or Slotted
is this a good deal?
engine swap or transmission
Dual exhaust on a 95 GS "1 on each side" HOW DO I DO IT?!
need a new engine
need a new engine
Turbo years?
Magazine...
Jan.03 Issue#046 Import Tuner, Pics of Gunmetal Eclipse???
