View Full Version : Off-Topic
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 [39] 40 41 42 43 44 45 46 47 48 49 50 51 52 53
  1. headers,install
  2. dsmlink question
  3. 240sx vs GS-T
  4. 1992 eagle talon parts for sale
  5. Turboing My Gs
  6. Intake thread (once again)
  7. Dual Boost controller
  8. Reset my cars computer
  9. help build my car
  10. walbro 255 w/ 14b...... why am i getting fuel cut?
  11. replacing weather stripping/molding around car
  12. help
  13. early 1G headlight convo
  14. RST project
  15. '98 Eclipse Turbo FWD 4G63 Boost problems
  16. 93 engine swap or conversion
  17. Check This Out!
  18. 450cc Injectors in RS
  19. Still Need Help!!!
  20. Nology Hot Wires?
  21. ECU questions
  22. Help! PLEASE!!!
  23. 95 eprom ecu #
  24. Body Kits
  25. Bov
  26. Intake heat shield
  27. auto tranny
  28. 96 Eclipse WEIRD problem.
  29. Please god someone help me!
  30. 420a transmission
  31. Performance struts?
  32. o2 sensor voltage problem (1g AWD)
  33. Header Question
  34. Turbo Kit
  35. Wheel Crazy!
  36. With Proper Tuning, What You Guys Think This Can Do?
  37. putting '99 engine into '95
  38. Will a JDM 4G63 Engine fit into a 2G 1997 Eclipse GS NON-TURBO?
  39. What is the red block on an eclipse?
  40. Turbo XS Boost Controller ( dual stage)
  41. FMIC on 1g eclipse
  42. Curb Alarm!!!
  43. Front-End Conversion : 91 w/ 92 front end?
  44. should i buy a 98240sx or keep my gst
  45. Damn oil filter
  46. Here Are My Thought
  47. Will Jeep TB fit Venom Intake? Eclipse N/T
  48. Car stoped working.
  49. 92 Dsm
  50. 98 eclipse missfiring on # 3
  51. How do you hook up a Turbo XS Boost Controller
  52. how to adjust my new clutch set
  53. 1g intake stuff for 2gs
  54. 2 or 3 guage pillar - that is the question
  55. what to do next for mod?
  56. Horsepower Question??
  57. Pacesettler Short Shifter and Which Bushings Would You Use?
  58. ESI talon owners please read i need help within 4 hours please help!!!
  59. High idle
  60. 98 eclipse turbo valve ticking
  61. Lots of white smoke but runs fine?? any ideas?
  62. i got off, YEA!!!!!
  63. crank case evac
  64. Reverse Gauge
  65. clutch getting stuck?
  66. best 6 bolt year?
  67. Big prob, Murky Coolent, Whit Smoke
  68. About the Ruber that goes around the windows...
  69. Turbo Problem
  70. Need Help With Controlling Boost
  71. the much talked about F&F eclipse
  72. Dead car... :x
  73. 420a motor switch
  74. warped rotors
  75. Serious question... please help
  76. New Small 16g looking to buy
  77. alarm install new ?
  78. fuel pump/relay control circuit
  79. 97 non turbo fault codes.
  80. Talon to Eclipse Conversion
  81. broke my damn bov :(
  82. How much?
  83. Best take off
  84. Help with trans
  85. flamethrowers on 1st gen
  86. rebuild kit
  87. camber kits after lowering
  88. Problem with turbo...
  89. White gauge face problem <PLEASE HELP>
  90. what you think about this?
  91. Is this a good turbo,
  92. I want to get this straitened out!!
  93. 420a block engine/nitrous
  94. FS: 1995 GST *BLACK* 80k Miles! $7000.00 PICS
  95. 97 eclipse gsx vs 3000GT SL
  96. Good Sites
  97. 2g talon to 97+ ECLIPSE conversion?
  98. Boost vs. Boost/VAC
  99. 97 gsx w/16g vs. honda s2000 with intake, headers, exhaust
  100. Help with ignition
  101. turbo's are new to me....
  102. 14B Turbo on Ebay
  103. Engine swap
  104. If money was no object. Build a 250hp gs allmotor
  105. Smokin Body!
  106. conversion
  107. Engine Codes
  108. guestion about 420a internals and mods
  109. Sweet interior
  110. Cat what?
  111. Is THIS a rip-off? need DSM Help
  112. GReddy profec bII tunning question. Please help!!
  113. 95 eclipse 420a,dead as a door nail
  114. where do i find a 97-99 gsx?
  115. BellHousing
  116. Turbo Headers?
  117. Buying a 97 GSX, Need Suggestions (w00t)
  118. Black Chrome cold air intake
  119. ***FAQ*** Read this BEFORE you ask a question.
  120. do I need new struts when lowering?
  121. Stickys?
  122. Oil turbo lines
  123. What headlight system does the 95 talon tsi have?
  124. Very Hard Turbo Question
  125. Talon motor
  126. Body kits web-site
  127. T-28 Question
  128. new to mitsubishi
  129. 2g auto -> 5speed swap instructions
  130. Engine Swap?
  131. Whats next?
  132. Good combo or not?
  133. 97-99 original front bumper
  134. MSD 6 ignition install?
  135. Digital E
  136. Exhaust...HKS carbon ti or Apexi N1 or GT??
  137. crankwalk again!?
  138. Turbo upgrade for my eclipse
  139. Compression results
  140. talon dependibility
  141. Need help running wires for a neon underbody kit install
  142. Ecu +
  143. Another 1g in a 2g question
  144. DSMlink...help
  145. '95 Eagle stuff...
  146. What next?
  147. 97 Mitsu GSX vs. Stock 350z
  148. Idle help PLEASE!!!!
  149. 1g eclipse ????
  150. will eclipse side mirrors fit talon side mirrors?... i'm talking about the power ones
  151. 6bolt swap details
  152. Wide Body Question
  153. gauge needle lighting
  154. gauges suck
  155. Need to sell my 95 gst, needs work...
  156. Upgrade?
  157. 94 Eclipse Door Panel
  158. Wide Body Kit for 1st Gen ?!?!?!?!?!
  159. Help w/Fuel Filter Replacement! 1995 RS.
  160. Happy Easter
  161. woofer box for my gs
  162. EvoIII boost creep questions...
  163. need some 14g info. wastegate setting...
  164. Fang Bodykit
  165. low psi and different exhaust sound
  166. Best parts for your car!!! check them out!
  167. leaky slave cylinder
  168. 93 eclipse cyclone engine install
  169. Wierd light problem....
  170. winter driving
  171. Clutch Replacement...
  172. Think My Turbo Is Gone
  173. need an expert
  174. 91 AWD TSI questions
  175. Track results tonight.
  176. Would this work on a 2g eclipse?
  177. wrong forum
  178. 2 things wrong
  179. switching from n\a to turbo engine
  180. I have NEVER seen one of THESE before!?
  181. Track Impressions
  182. What are your opinions on the EVO3 16g?
  183. I finally did it!!!!
  184. Lock Cylinder Installation
  185. possible stupid question
  186. RULES & REGULATIONS On This Forum!!!
  187. headers
  188. lowering springs
  189. air filter to valve cover
  190. Looking for a 4g63t 6 bolt engine
  191. Safe Boost on Stock
  192. Suggestions Please!!!
  193. Needs Answers!!!!
  194. Stock turbos
  195. 420a coolant temp sender to gauge
  196. Transmission Questions
  197. 1g vs. 2G engine
  198. 98 eclipse emblem
  199. max psi on a 20g and 16g???
  200. how fast can a 20g be on FF?
  201. Exhaust for a 98 Eclipse RS
  202. intake question
  203. 97 spyder eclipst 14bgst is done FINALLY
  204. Pics Update
  205. White Smoke out the exhaust
  206. dsm experts needed on swap info
  207. Headlights won't shut ?
  208. Ducky's update: Not for the faint of heart
  209. how blue is 7500k???>>>>this blue!
  210. BCS capoff?
  211. i noticed this odd sound earlier...
  212. What's a good turbo timer?
  213. n1 evo 2 or other exhaust for my future 20g?!?!
  214. computer problem?
  215. barometric pressure sensor...pro help need!!!
  216. Update... should anyone care.
  217. what to look for
  218. Something Wrong!!!!
  219. Where Did the Oil in My GS-t GO?!?!
  220. compression ratio
  221. Need a DSM expert please
  222. Oil leak from crankcase?
  223. stock times
  224. Much diff ?
  225. Wont Go into ANY FORWARD DRIVE
  226. turbo leak?
  227. New Paint Job For My Spyder
  228. exhaust problems
  229. How good is a IHI turbo?
  230. looking to buy 1st gen eclipse
  231. Gs-T hopping
  232. Octane help
  233. T3 for sell
  234. New POS tow vehicle
  235. what year is the best to buy?
  236. Install: POSR ABS 3'' intake
  237. Electronic Boost Controller Q's
  238. Thinkin about buying a Talon
  239. NEED HELP WITH COVERING HOLES! GST/GSX Wing Swap
  240. DSM Motor specifications
  241. 02 sensors and check engine light
  242. valve cover leak solutions?
  243. 95 Eclipse F/S (do i post it here?)
  244. How much can you get?
  245. learning more
  246. Double-Clutching in GST/GSX?
  247. Eclipse GSX Engine stall
  248. rough idle,throtle lag?
  249. Looking for a turbo tranny sensor
  250. Auto GSX rpm and tranny problem...
