View Full Version : Off-Topic
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 [34] 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53
  1. Cold running problem
  2. Check engine light
  3. ***NEED a head for 98 GSX***
  4. how to race with an auto trans?
  5. a few general problemos with my 1g
  6. Wtf! Fuses?
  7. Installing an ECU!!!
  8. suck squish bang blow
  9. lysergic acid diethylamide LSD For you flower children
  10. 60mm TB
  11. Modding the 1st Gen GST ECU
  12. Check engine light on '96 Mitsubishi Eclipse
  13. GM MAF translator
  14. exhaust question
  15. '97 GS-T Cold Air Intake?
  16. need f5m22 specs/tolerances
  17. WTF Is Wrong With My Car?
  18. Labor prices for gauge install in CA..help
  19. Hot Cold Air Intake, Help!
  20. the 15g??
  21. Gs>gsx Swap out need help
  22. conv.top Q?
  23. Engine Lacks Power N E suggestions??
  24. What is trim??????????
  25. interfreezer
  26. looking to buy?
  27. Does any body know how to put in a belt?
  28. '96 GSX won't go into park
  29. ***engine Removal***
  30. Help please
  31. 1g radiator in a 2g
  32. Heavy duty alternator?
  33. 3rd gen into 4th gen turbo motor swap
  34. Drag AWD vs drag FWD?
  35. check engine light
  36. 420A locked
  37. How do u put the alternator belt on?
  38. Are ECU's interchangeable?
  39. Are ECU's interchangeable?
  40. o2 sensor install
  41. Eclipse
  42. 1g n/a head compared to a 1g turbo head??
  43. chalk up another for the gsx.
  44. what do you guys thnk of the NX-Ntercooler kit?
  45. Door speaker size in a 94 GS?
  46. Started her up, and she is now running rich
  47. ********Tenzo R Carbon Fiber Spoiler $260********
  48. TBS question (1g mechaninc HELP!)
  49. Ecu codes?
  50. Shipping help
  51. 1G Coil Woes
  52. stupid insurance
  53. What's making my 1g run rich?
  54. What's making my 1g run rich?
  55. intercooler off supera???
  56. Interior
  57. Coil problems
  58. Two Most Important Gauges?
  59. Dynoday in the New England area.
  60. head gasket leaking oil!!!!!!!
  61. tps..... ????? what????
  62. Stuff about F&F Eclipse
  63. How do I install Skunk2 Coilovers on a 95 Eclipse RS
  64. Talon parts = Eclipse parts
  65. 95 Talon ESi problems - NEED HELP!!
  66. EZPass question (for people in the N.E.)
  67. 1st generation cd player problem
  68. 1g transmission problem
  69. Quick questions!
  70. rear wing conversion
  71. evo 16G turbo
  72. 16g and 14b pics
  73. Talon starts but then dies a few seconds later
  74. Girlfriends!!!
  75. Battery keeps dying is it my ecm?
  76. 1g air intake
  77. intake piping
  78. molded bumpers..
  79. Would this be better than crushing BOV?
  80. steaming?
  81. 97-99 conversion
  82. Most Embarrasing Moment w/ Ride!
  83. Mechanical or Electrical
  84. The Inevitable has happened tonight...
  85. AEM v2 intake
  86. WTF are these?
  87. short throw shifters
  88. Question?
  89. G-tech pro
  90. Ecu
  91. Head Swap Question
  92. HELP! waterleak nonturbo RS
  93. Tsi Leaking
  94. Engine swappin
  95. 2g Head and block
  96. headlights
  97. stock boost
  98. 91 Talon running really rich!!
  99. hardware restoration kit
  100. newb question tried searching
  101. Hahn racecraft
  102. balance shafts
  103. Balance shafts?
  104. headlight problem?
  105. noise condenser...wondering...
  106. Underdrive Pulley?
  107. Differences between apexi N1 and GT downpipe?
  108. i painted my valve cover
  109. Racing Seats
  110. 1g head abd block on 2g
  111. exhausting
  112. resetting a sony deck? anybody?
  113. 93 intake
  114. Eclipse Vin# locations?
  115. Why does my 2G sound as if it's falling apart?
  116. 95 eclipse gsx for sale!!!!!!!!!!
  117. Damn proud of my GSX
  118. HKS Turbo timer
  119. About Flywheel
  120. whats the best INTAKE FOR 2g turbo
  121. Is Mandrel-bent Mandatory?
  122. Greddy BOV question
  123. intake plumbing
  124. Finally one showed up!
  125. Home made MBC (manual boost controller)
  126. Turbo lag
  127. Exhaust Help!!
  128. high idle?
  129. Front Dash For 93 Eclispe
  130. rs gs
  131. Catalytic Converter
  132. burning oil
  133. Daily Drivers
  134. Bov
  135. bov without an intercooler?
  136. Quick Question
  137. No Turbo 4G63?
  138. RS rear brake
  139. Af/x Ecu
  140. How Can I Install A Head Unit Into A 90 Eclipse Gs?
  141. Car was STOLEN... seeking any and all available help
  142. 1990 Air Bags??
  143. Body Kit FR Bumper
  144. Exhaust manifold to pipe leaking
  145. My New Pistons!!!!
  146. HELP!...Oil Pump?
  147. I dunno what model this is...
  148. new shocks and springs
  149. headlamp buckets
  150. Doors 90-94
  151. Do it ur-self cold air intake
  152. Tools for modding
  153. Eprom???
  154. bov question
  155. pwr windows???
  156. Turbo Sound
  157. wastegate/mbc/whatever
  158. How to remove window switches (1999GT)
  159. know the poblem, but need to fix it.
  160. sunroof wont shut...
  161. Talon Vs. Stealth
  162. Fuel regulator/FMU RS-T (95 AT)
  163. turbo on GS
  164. read below
  165. I want to buy a 95-99 Eclipse!!! ANY FOR SALE?
  166. I got 700-800 to spend, what mods should I get.
  167. Brake booster line?
  168. profec b vs avc-r
  169. dash insert
  170. Restarting The Computer?
  171. Need help with my RS
  172. 95 eclipse prob..HELP!!
  173. Dash lights and SRS problem
  174. dont know what to do
  175. Catalytic converter
  176. Can you help me build a 1G Turbo Oil Feed Line?
  177. Can you help me build a 1G Turbo Oil Feed Line?
  178. Cat-back...Apex N-1 or Greddy Evo?
  179. Rear differential
  180. Automatic or Standard
  181. eclipse parts
  182. exhaust
  183. 95 or 98?
  184. head and intake manifold
  185. would these work?
  186. Check out my car!!!
  187. Racer X Motorsports & Sport Compact Pro
  188. gsx or gst or 3000gt vr4?
  189. Newbie in need of help
  190. 95 or higher
  191. Help with 95 RS automatic transmission
  192. Eclipse Vs Celica
  193. Safc-ii
  194. Je Pistons, Eagle Rods, Arp Studs
  195. Eclipse good?
  196. Stupid People !
  197. need help to make maximum power
  198. WTB- black eclipse front bumper 97-
  199. 98' Breeze vs 97' Eclipse GS
  200. Manual Boost controller
  201. Machine shops?
  202. Throttle body where to buy?
  203. just baught a gst what should i do?
  204. which TurBo to get?
  205. Fwd to Awd help please
  206. 360 on the freeway!
  207. need a rim and foglights
  208. Conversion Kit
  209. Can you help me stop my oil leak?
  210. Can you help me stop my oil leak?
  211. non turbo and turbo EPROM ecu guys enter in...
  212. for sale 2 w6v2's and 1501bd amp
  213. afc wiring
  214. Evo On The Track!!
  215. Non-turbo eclipse or talon Esi cold air intake install
  216. Here a pic of my ride. I don't know how to use [IMG] though
  217. Power Mirror Installation
  218. Some Suspension and rim help please.
  219. Cam Belt
  220. tradin teh honda for a dsm
  221. want a 95-99 gsx
  222. Choices on Boost controllers... Apexi Super AVC-R or Greddy Profec-B
  223. Cyclone Intake Manifold on Ebay!
  224. check out this site.
  225. throttle body upgrade
  226. 2g problem
  227. problem with UICP and 1gbov
  228. Mitsubishi Eclipse GSX vs BMW 740IL
  229. 91 talon awd tsi
  230. idling rough
  231. Dealer pisses me off
  232. 1G engine in 2G body
  233. 2GNT vs. '93 NSX (kinda long)
  234. Suspension Tech Help
  235. Need an aftermarket exhaust manifold.
  236. Check This Eclipse Out!!!!
  237. Fast or Slow.. I dont know!
  238. opening the space for the FMIC
  239. 1995 Tsi
  240. white smoke please help
  241. the super Profec B spec-II tuning guide!
  242. Rocker Arm Came Off
  243. My Kill List Is Growing
  244. Turbonetics T3/T4 Turbo Kit
  245. My New Car!!
  246. 91 talon awd tsi
  247. My Stock Gsx vs Modded V6 6speed Tiburon
  248. Spark plugs?? Running rough??!!!
  249. Finally hit the track!!
  250. Advice On Head Removal
