View Full Version : Off-Topic
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53
  1. buying an eclipse
  2. My happy 30th birthday
  3. Just installed S pipe. Now a problem occurs.
  4. Heater doesn't work... IT'S FREEZING!!
  5. 97 Eclipse Spyder top leaking when it rains
  6. Need New Struts...
  7. 95 no start
  8. Still knocking!! WHAT CAN IT BE!!??!!
  9. po134 code..
  10. quick bodykit question...
  11. looking for a 95-96 cas
  12. What Flywheel to buy?
  13. more clutch problems help!
  14. Engines
  15. Brakes swap from an RS to a GS
  16. cat-back useless without downpipe?
  17. re: turbo to non-turbo
  18. Exedy Vs. ACT clutch
  19. FS: 99 Eclipse RS
  20. Head Question
  21. 6a12?????
  22. Akward Acceleration Experience
  23. My first solo flight!
  24. 4G63 Question
  25. repaint my back bumper or not ?
  26. major leaking problem help fast!!
  27. Body Kits
  28. bov!!!!!!
  29. What is the #s on a M/t 95-96
  30. front bumper repair?
  31. Garrett T61 Turbo
  32. Header glowing red
  33. 1g bov vs greddy type s bov
  34. bov
  35. FS modded Eclipse GST
  36. Should my weather stripping look like this? *Pics*
  37. Rims
  38. all black 2gs, lets see what rims your workin with
  39. Big T28
  40. Blow Off Valve!!!!!!!!!
  41. act 2600 6 puck streetable?
  42. Help with Racing report?!
  43. 1g motor into a 2g car
  44. Motor Mount Installed, now new problem
  45. suggestions on getting the crank pully off
  46. full soop job
  47. New POS daily driver
  48. Parts for a 92' Talon
  49. What Now?
  50. Wiring or ECU problem
  51. Ontario Street Races (Saturday Night)
  52. various mods.
  53. Main bearing?
  54. Catalytic Converter on Ebay??
  55. New brakes
  56. Air, Fuel, & Spark - Still Doesn't Run??
  57. mmmmmm...wheres my CAS??
  58. power steering pump and alternator need change ??
  59. Evo VIII steering wheel to 96 eclipse?
  60. TMO Datalogger cable diagram?
  61. Poll:
  62. extra coolant lines?
  63. launching
  64. 2000 posts suckas!!!
  65. FS AWD Rolling Chassie with Extras
  66. Car making New sound
  67. What turbo and what do i need
  68. boost leak probs??
  69. Strange Problem.
  70. double clutching
  71. oil pressure gauage
  72. My electrical problems...
  73. big16g shaft spin????
  74. Uber excited about my GSX!
  75. Funny/Sad story, Read It!
  76. 2nd o2 sensor
  77. 6/7bolt
  78. SRS Light On
  79. Will a bad TPS couse misfire?
  80. cash or 1g gsx
  81. How much is it to rebuild a head?
  82. 1g datalogger
  83. engine not firing...hmmmmm??
  84. How to remove valve springs. Please Help.
  85. Where I can buy a belt tensioner?
  86. freaking battery
  87. Convertible hard top...any custom shops out there?
  88. Ooooh myyyy god!
  89. FOR SALE! ~ ~ ~ 85 Very Clean
  90. normal oil psi?
  91. throtte cable out of whack
  92. huge oil level problem need help now
  93. How Do I Take The Water Pump Off!!! Help!!!!
  94. CEL on again. Please read
  95. Turbo going bad, need help.
  96. Muahha awsome race question
  97. clutch problems yall
  98. supercharger problems
  99. Venom 400 Control Module
  100. mpg
  101. Now what do I do with it????
  102. Radiator question: Is this normal?
  103. 1gb to 1ga conversion
  104. Some problems solved
  105. FMIC 1g For Sale
  106. I was driving around in Riverside CA and guess what I saw....
  107. Is this something i should consider?
  108. Engine Mount Inserts... Again
  109. Kevin:palm 505 Usb To Serial?
  110. T25 Boost?
  111. best exhaust manifold for my set up
  112. Valve Seals?
  113. Out: Tail, Reverse, Instrument Lights - Short?
  114. cheap strut bars.
  115. throttle cable
  116. How much boost should I be able to push? A few other questions too
  117. downpipe question
  118. Anyone From NC?
  119. New Mobile 1 oil !!
  120. oil pressure question
  121. Looking for some body/engine parts
  122. When is it needed ???
  123. gonna get killed for asking this........
  124. Getting S pipe and intake pipe.. any warnings?
  125. Should I use synthetic oil?
  126. thinking to buy these
  127. Anyone From Virginia??
  128. Another Won Ebay Idem:
  129. fuel presure regulator
  130. Help RST!!...
  131. 95 eclipse transmission oil
  132. Injector Question
  133. Ignition Problems I Think
  134. Squealing Belts!!!
  135. gsx good in the snow?
  136. PW onto a RS..???
  137. sellin my car...
  138. Test Autometer accuracy?
  139. South-Eastern DSM Meet...
  140. esi convertion to tsi
  141. Arceo brand rims???
  142. Should I buy 1g bov & RRE uicp from dsmtrader?
  143. o2 sensor question
  144. Insurance On Eclipse???
  145. speedometer not working wheres the fuse at?
  146. speedchip?
  147. Gimme some help right quick!!!!!!!!
  148. Ignition Problems
  149. high rev after carb cleaner
  150. Talon Electrical Problems. . .Please Help!
  151. Turbo Model Information
  152. When does CEL come on again?
  153. oh no spam
  154. o2 *housing location*
  155. No Spark to my spark plug.... =(
  156. 95 Talon Staring Problems
  157. genral estimate
  158. Alternator brace
  159. FS: 98 GS-T Eclipse
  160. On the way home
  161. left signal blink problem ?
  162. New Eclipse
  163. Turbo
  164. 91 Eclipse Tail lights
  165. Transmission Swap
  166. good idea or not??
  167. mls mitsu headgasket part number
  168. Rota's, Kumho's, where?
  169. GM maf
  170. Something interesting about top speed in my car
  171. Oil Pressure Sender Install
  172. Import Motion
  173. coolant temperature switch
  174. 2nd gen motor in 1st gen car swap.
  175. My new meaning to VFAQ
  176. odd smoke?
  177. Convertable top problems
  178. Wheel and tire questions
  179. 02 Housing And Tial Done: Pic!
  180. EARLY or LATE fuel kit?
  181. turboxs 2 stage boost controller
  182. Confirmation of what my turbo is WITH PIC
  183. 97 body parts on a 96
  184. Cyclone intake Manifold
  185. '95 RS Headgasket Leaks
  186. How Do I Know What Turbo I Have
  187. used ARP head studs
  188. Motor Inserts
  189. boost question again....
  190. price on a gasket kit good?
  191. Rough Ride ALL THE TIME Give me a Hand
  192. Good ad for Lancer VI
  193. Does anyone have a 14b laying around?
  194. o2 sensor location
  195. conversion kit?
  196. talon esi
  197. Difference between the GS and RS (stock and modifications)?
  198. Boost and AF Gauge question
  199. 17's w/ drifter bodykit on a 91?
  200. cant see any coolant
  201. Hawaii DSM?
  202. I need an oil pan!
  203. Looking for Eclipse
  204. Clutch Blood
  205. 1G turbo in a 2G eclipse
  206. electronic boost controller need gauge?
  207. CHECK THIS OUT!!! FREE iPODS!!! EASY!!!
  208. Weak Clutch Pedal
  209. Idle/Starting Problems STILL.....getting pissed.
  210. is this a good deal?
  211. Where to find a bigger alternator?
  212. maf/intake?
  213. Ground Control with which shocks?
  214. GReddy Type-RS BOV review :)
  215. A 2gturbo or a 2g then turbo?
  216. dual gauge pod complete pillar?
  217. body kit owners, please read
  218. -Body Kit Owners- READ
  219. 95 GS Engine rebuild with HRC stage 2 turbo?
  220. Buying GSX. What to ask mechanic to check for?
  221. Oil Pressure Gauge Issue
  222. new problem
  223. dejon intake...?
  224. 4g63 engine swap
  225. trying to identify dsm turbo.
  226. talon vs. probe
  227. Buying my new turbo in 2 weeks!! I need help on deciding!!!
  228. IPT electro-matic manual contoller
  229. 2g gst cutting out or missing in all ranges and gears
  230. 2g awds have bumpstops?
  231. low idle all of a sudden...help
  232. is anyone from jersey here
  233. 95 Eclipse gst question
  234. need help installing mechanical oil pressure gauge
  235. 97 Talon BOdy KIT
  236. Question about my car...
  237. Idle bounces around, can't hold straight idle
  238. Where to find a black center tail light strip?
  239. Automatic transmission: failing to drive
  240. 4G63 motor work who to trust...
  241. Punishment Racing 02
  242. Driver Side Door handle
  243. Chop Top?
  244. Boosting a 420A
  245. WAnted to buy...97-99 eclipse GSX AWD turbo
  246. block crack in below freezing temp?
  247. Dead Batterie
  248. stopped and no start
  249. Electronic boost controllers? which one
  250. Like the noise but dont want to vent?!?! Alternative to venting
