View Full Version : Firebird Discussions
- 92 Firebird Formula convertible doors
- 2000 Firebird headlight grinding sound.
- 69 Firebird frame replacement
- car,truck,or suv glowshift gauges
- 00 Firebird BCM Question
- 2000 Firebird windows and radio
- 89 firebird ac blower motor
- 99 bird with security problem please help
- Auto to 4 speed conversion
- Best heads for my 78 pontiac 400 motor
- 1989 firebird 2.8 mutiport fuel injection
- retro a carb to a tuneport engine
- 82 camaro clutch
- Transmission & drive shaft
- 67 Firebird - Tail lights short out
- rear glass struts.
- Attention moderators....
- 1995 firebird 3.4 just backfires?????
- I have a confession to make
- Advise on dash please
- 305 TBI to 350 TPI
- pwr door locks
- my 96 firebird....sputtering and misfire?
- Its not fair, H8TRS!
- 99 firebird security problem
- Hard Start with random battery issues
- Trouble with water pump
- Shop says I need a new throttle body
- No Torque under 2000 RPM
- Trans Am Mysterious coolant leak
- A/C system compatability?
- help replacing window motor and regulator
- How do i get the dash off?
- Need help! 455 wont stay idling
- Is it intake or head gasket
- im in big trouble with this one
- Question About a Vehicle Trade
- 3.8 Runs very rich
- 1987 firebird trans am gta wont run
- Steering Wheel Radio Controls
- Radio Help
- 2000 firebird v6 stalls out
- 94 trans am overheated?
- body work
- hard starting on 94 t/a
- What kind of Firebird do I have?
- 93 t/a power drain..just killed a brand new battery
- electrical problems
- It's time to celebrate!!
- 91 Firebird w/ 305 TBI
- 670 heads and race fuel
- wont keep running with maf hooked
- Returning to the fold...
- 94 Trans am going bump
- Original Cloths and Vinyls
- Firebird Overheating need help
- third generation camaro/firebird rust
- Cost to replace 95 power steering rack?
- 98 Firebird 3.8L coolant leak.
- 92 firebird gauge problem
- rear seat
- Tachometer only works sometimes
- 3.1L and 3.8L swap
- cant seem to find correct flywheel 68 bird
- Headers or Not?
- 91 firebird v6 please help
- Need help in hp
- 1997 ws6, Blinker problem
- 81 firebird trunk
- 84 proportioning valve
- radiator overheating
- 98 firebird head gaskets....
- 94 gauges question
- Engine swap - will trans fit???
- 95 firebird removing door panel and replacing window motor
- A plain shame...
- 94 fan problems
- 98 -3800 - Stumble under load
- Some 93 Formula Woes
- 2000 TA Cooling Fan question
- 93-97 to 98-02 Front Conversion Issue
- 2000 Trans Am
- 89 GTA Need help
- 94 Trans Am hard starting
- nose dives
- steering wheel
- 1994 Pontiac Trans Am Price Question
- charging problems
- AC Problem Help Please
- Are there any Bypass kits for the 79 trans am exhausts?
- Do I need anything special to put the LS1 engine into my 79' trans am?
- 1987 GTA fire and fuel with no bang
- 93 trans am dies when given gas red hot exhaust manifolds
- How easy are they to work on?
- 87 Pontiac Firebird speedometer isn't working
- 89 Firebird wil not run.
- 2000 trans am throttle cable plastic connector
- 93 trans am runs ruff
- starting problems
- 94 Ob1 trouble
- 95 bird no run
- 2002 Firebird Trans Am questions
- 92 firebird formula help
- 95 Firebird
- Odd Sound from Right Headlight Assembly
- Play in headlight motors with Video
- Misfire please help
- headlight VS foglight
- Headlight switch problems?
- anti slosh valve for first gen tank
- keyless entry
- 1994 trans am will not start please help me....
- 2002 Firebird Horn and alarm
- Buying 2000 Firbird 3.8....Common Problems?
- 69 Fire-Bird
- 1981 turbo trans am vacuum diagram
- Buying a Trans Am
- Firebird Option codes
- front turn signals
- 2000 trans am,scraping from front of engine
- 79 TA -Fuel pressure goes to 0, engine stops
- 1996 Firebird High school project
- 87 firebird wont draw power
- 94 formula
- '91 firebird won't start
- Cable Broken
- head work/ please help
- 305 tpi> 93 LT1
- cai or fwi ideas for 91 tpi
- help with heads
- ls1 swap for my 67 firebird
- t-top conversion
- PLEASE HELP cat converter
- F.A.S.T. Class '74 T/A
- firebird dash clock
- firebird console
- 1997 Friebird Code interpetation
- gorillachipz F-40 need help/instructions
- 67 F-bird info
- starting problem 1988 firebird
- this a good deal?
- need parts fast
- headlight adjustment problem
- problem with 98 pontiac firebird exhuast
- Good buy? '94 Trans Am LT1
- 79 TA 403 w/ bog going up hill
- 95 trans lt 1
- 1981 Esprit question
- ok i got a question
- intake gasket leaks at exhaust on a 69 350
- Bought....
- smokey or paint code 80
- Transmission problem
- New Owner/ New to Firebirds
- clutch plate (las vegas,nv)
- ecm swap?
- A/C compressor
- 32 mpg
- Intro and a question
- 1977 Transam T/A 6.6 (Bandit model)
- T-Tops???
- TBB Experiment
- does anyone know the price of...
- Antenna went out on my 2000 WS6 Trans Am, need to replace
- 1997 Firebird Trans Am Question
- Question..
- 1998 Firebird Question
- New to board, have a few questions
- 87 firebird no inside lights? HELP!
- Red Light behind gear selector?
- Wanna know about a 79 espirit
- 67 firebird question
- where is the computer in the 92firebird
- Free Set Of Headers
- 98 trans am with tps and traction problems, please help
- new here and need help
- Can you put a 77 front end on a 76?
- Front license plate mounting question, 1994 Formula
- Optimal Cruising RPM
- hear air being sucked into fuel tank???
- How can I program my remote keyless entry?
- Price range for 3rd gen. Bird
- Info on '71 Formula 455
- considering purchasing a firebird
- Looking for good source of parts for 1994 Pontiac Firebird (6 cyl)
- 1987 Trans Am GTA
- Decals
- should i trade?
- do i need smog?
- HID's installed in the TA
- Dayum
- Does this seem like a good price for a WS6?
- '67 Firebird Restoration
- new member
- father vs son
- New Knight Rider TV show!!!
- Intake manifold for 2000 Trans Am
- 1978 firebird formula??
- Trans Am Spare Tire
- 1999 v6 Firebird
- price of car
- 94-97 gen formula or t/a
- 1967 Firebird
- Trans Am Questions
- Oil leaks SUCK
- What trans is it?
- Check out my 77 Bird with 455
- 77 transam motor?
- 84 firebird
- 1994 Trans Am, is it worth it??
- 68 Firebird
- reviving my 83 firebird
- Trading a 2005 GTO for a mint 68' 350 Firebird
- hi everone
- New Here!
- 86 firebird
- New to firebird
- 9.2 @ 80 mph in the 1/8
- looking at buying a 91 bird need help
- fresh firebird newb
- Year One Burt Renyolds Ta. LIke It ?
- Concerning Restoration
- Hi from Puerto Rico
- Hey people...
- 3rd part auto hauler...ever heard of of BAS ( best auto shippers)
- extremely quick 89 firebird 2.8l
- Anyone have any parts for sale? HELP
- so what do you say?
- After Market Tail Lights
- Whats your choice 3rd generation
- '99 f-body firebird
- Has anyone done ....?
- Power Antenna Question
- Unkown Wire
- Window Stabilizers for 95 firebird
- 88 iroc and 88 t/z bumper
- power locks
- power antenna
- I'm done.
- fuel and heater lines
- fire-bird night rider? could it be true?
- 396SS vs. 400HO
- Just bought a 93 Trans Am, Can somebody check the vin for me?
- `95 firebird
- Interchangable parts for 94 firebird
- 1981 Pontiac Firebird
- let myself introduce...ummm...myself
- Sold the Trans Am
- firebird by 2010!!!!
- Speed limiter in T/A 98
Automotive Network, Inc., Copyright ©2012
